View Full Version : Acura Integra
- b18c1 swap into Integra LS, a few problems
- does anybody know how to take a lock off a door
- ZC and D16A1...same block??
- Just installed exedy organic clutch....now wont shift when car is running....i
- NEED HELP FAST!!! fuse / blinker question!!!
- JDM Gauge Cluster question
- trans question...
- Cam Seal part number
- Fidanza Cam Gears
- Timing Belt Maintenance
- dc2 seats with DA
- Have a quick question?????????????
- rough idle.....
- Look at my best friend's superchargered JDM Integra SiR DC2
- 15psi radiator cap good enough?
- A/C belt install
- fOG LIGHT QUESTION?
- Boost gauge Install need help!!
- Help my sick 90 'tegra! please! might swap to GSR need advice! NEED MECHANIC!
- how do I know how much the car is lowered on GC coilovers
- any one need 1991 RS pasts
- advice to beef up my engine
- SMOG test question??
- what does ths check engine code mean?
- proper position for intake
- Too much oil?
- b-series intake manifolds
- jdm yellow fogs
- Got me a DA
- Blue B-Series DOHC VTEC Valve Cover?
- can someone provide a 98 and up Turn signal connection diagram
- Help Gsr Owners? Proper O2 placement obd1 gsr ?
- Changing rear engine mount on gsr... Something I should know before prceed?
- Help me fix this!!!!!!!!!!!!!!!!!
- Driving coast to coast
- Steering Column and SRS Reel.
- What is this part called?
- 1991 Integra Starter?!
- integra plug wires??
- need bumper asap!
- itr muffler
- South Carolina Cookout/Grand Opening
- pic request
- cel#6, help
- Charcoal filter on 90 integra
- Rebuild parts for a b18b1 b18b motor
- LS Vtec
- 94-97 halo lights?
- Battery charging question
- Stock muffler w/custom piping?
- 1/4 in my gsr
- Quick Air Condition Question?
- fixing a car door after a break in
- gsr cams or crower stage 1???
- Autocross-worthy Suspension Set-up
- LS tranny- switch the final drive to aftermarket 4.9
- Whats my integra worth?
- anyone have HUGE DB8 pic thread bookmarked (searched)
- Energy Suspension Motor Mounts
- wanna know how much is needed for a five lug conversion for a 2nd gen teg???
- How much sould I sell for?
- Auto/Mannual swap need help????????????????????????
- b18c swap
- Anyone with DIY for installing Horn?
- JDM front
- ways to keep car and engine fresh
- oil leak
- SomeOne Help Me Find Out What Cams I Have
- The name of this specific mount...
- anyone running slicks on their DC...what size?
- new here new teg
- solid rear tranny/engine mount, any suggestions, looks like a B****
- What Color To Paint The DB8
- 1992 DA questions. Help.
- i need more power
- gear ratios for GSR and testing if speedometer is off
- HELP!!-----DIPPING/LOW IDLE----did search...
- tranny acts up when going uphill....
- Howling and droning noise at about 40mph HELP!!!
- exhaust manifold ?
- b18a-b18b vavle cover ?
- TEIN Springs and Toyo Tires - Needed for Integra
- Average Water Temps
- Inspection
- good spark plugs?
- dc squad
- hid kits
- Koni yellows
- Integra Upper control arm.
- What is this leak?
- Power Antenna
- timming belt replacement part numbers
- Overheating problem..... i cant figure out
- ITR cam install and Cant feel a loss or a gain? Weird Type R cams??? Tried search
- Mixing Clutch Disc and pressure plate combos? can you?
- Wiring map sensor from 92LS IM to Type R thottle body map sensor
- I have a DA COOLANT TEMP SWITCH PROBLEM???
- any difference between the 94-97, 98+ headlights?
- GSR Oil Cooler O-ring
- APEXi type r exhaust/muffler on an rs?
- Automatic Transmission Question
- Automatic Shifting Early
- boosted DA pics
- Slanted license plate on 3rd gen Integra?
- CEL Code 43 Fuel Supply System 90 Integra?
- would a b16 cable transmission work on my 94 b18c motor?
- ecu code 22?
- Oil pan leak?
- is there a way to tell the diffrence between high and low impedence injectors?
- GSR ecu in SI
- quick GSR question....
- auto gsr cams vs maual gsr cams difference?
- Will a 2dr. Da Hood fit a 4dr. Teg?
- my first da
- built ls head
- what is the name of this part?
- Anyone know about the Stage 2 Exedy??
- Anyone running 17x7.5 ssr comps?
- anyone ever do a ITR susp. Swap on 92 Teg? Need help.
- LS Fuel Pressure Regulator work on a GSR
- exhaust on a 90 DA
- Compression test problem (coil???)
- MY 95 GSR STOLEN!!!, what car now???
- Wiper delete
- skunk2 intake man. questions on gsr
- door help
- b16 tranny slight grinding problem. help!
- UNI Cone Filters
- gsr or redtop
- window problem-gsr
- rotot paint?
- A/C Recharge Question/Dilemma
- Will I feel a difference between PR4 vs the P74/P75??
- shopping for lowering springs/struts
- ITR clutch fit a 91 b18a??
- Looking for a Clean Kit for my 99 Ls
- @ philly races last night...and see teg with same 02' Si Hatchback wheels...coincidence i think not
- Black 94-01 integra interior
- please help my car wont start..
- sunroof relay
- Safe to run more boost?
- p28 or p75 for ls motor
- roll cage??
- 94-97 front bumper or 98+
- wat 2 get
- Radio code for 1998 Acura Integra
- stock rotor weights?
- Clutch problem
- what full coil system for under $1k?
- Post pictures of your teg...as a wallpaper?
- how to remove back seats
- Blown clutch, or tranny? read inside
- B16A ECU question
- ABS fault code 1 3 (high pressure leakage)
- Creaking from left side of dash / A-pillar?
- 2G LS turbo, 2G gsr na, or 3G LS ...which product to start?
- spark plug problem .. need help
- How to tell difference between ls/gsr tranny
- kyb AGX only adjustable on front ?
- Hks Hi Power Install
- Hollowing out cat
- got a CeL, need some advise...
- 90-91 Tail Lights or 92-93 lightz?
- Is it safe to take the heatshield around cat convtr.?? Rattling like krazy!!!!!!!!!!!!!!*Ls or GSR*
- I need a diagram or something of how to install gauges yeah i know im stupid for this
- About LS vtec and H22 I NEED YOUR opinion plz...
- need a diagram of making a wire harness
- Swapping out an old steering wheel for a NEW one??? How hard is it?
- S2000 filter fit a GSR motor...?
- si headers on teg?
- Hasport bolts - OEM bolts too short
- Travelin cross country in Jrsc'd GSR, BAD??
- 92 da electrical question
- just purchased a teg!
- simple question??????
- need ecu
- OBD1 injectors into OBD2 motor?
- Skunk2 IM concern
- ITR Wheel Question
- plz help..... can't spot leakage
- Question about Integra type R valve srings..Upgrade from GSR?
- quick sea-foam question???
- b&m fuel pressure gauge install
- turbo
- Air Conditioning not working
- neuspeed race springs, which shocks?
- vibration during acceleration
- what chip is best
- Idle surge and MSD SCI+ box ignition problems....
- What have I got myself into...
- rubbing noise or something like it?
- Climate Control
- Just tried my new Comptech Tiebar/ITR sway bar swap!!!
- ok i have the engine in ,now whats up?
- FUCKING THIEVES STRIKE AGAIN!!!
- clutch install went bad on gsr
- Back up battery for aftermarket alarm system
- got in a wreck...maybe need a new radiator and front beam?
- Type-R or GSR Muffler - Differences
- Engine Code P1336 Please Help!!!!!!!
- !!!!!!!Difference between Non-directional and directional tires??????
- Need some info on a camber kit.
- Eclipse/Talon Fuel Injectors on an Integra
- Track day Camera Mount...ideas?
- HELP! AEM INTAKE RUBBING ON ABS LINE!!!
- Needing Help...
- mugen thermostat
- Pro Street/ACT Flywheel Quality Comparison
- HOW TO: install pulley
- what damage will a piece of rubber glove do to my new motor...?
- Problems shifting from 4th to 5th... then a KAA-CHUKKK on freeway....
- 4x114.3
- eaton supercharger
- 92 Acura Integra 1.8L 113k ABS/E-Brake Light Oddities
- LS Webs Pics
- to flatblack or not to flatblack??? poll time kids.
- LS owners, Need your help quick, regarding OEM radiator.
- I Wanna See u Reppin da 4DRs
- Hello! Im new to HT Too!
- Koyo radiator? what's the difference?
- ** need safc "before start-up" intructions quick! **
- Altenator advice please help!
- anyone has a pic of the V I S JDM dc2 carbon fiber lip
- Very Loud Clicking from my DA
- map sensor maybe
- engine question...
- A leak, Can this be fixed? or replaced?
- New to ht
- B18B1 question? (confused)
- when clutch springs fail
- my hood randomly pops
- icu
- Wher is my radiator fan relay?? 1994 integra ls
- What kind of struts should i get
- gsr motor oil....
- sunroof help
- vibration when braking anywhere above 65mph
- anybody hook up their power folding mirrors to the alarm?
- lighting a DA
- Isky cams,anyone ever used these??
- tranny serial number for gsr???how to check???
- What head should I put on my stock 00 GSR block?
- 2nd gen integra JDM vin tags
- valve tapping..
- quiet performance mufflers, apex ws??
- Catalytic Converter
- plug n play Starter Kill Switch
- b17 question
- gsr 1/4 mile time?
- Speaker problem?!?
