View Full Version : Acura Integra
- Can it be fixed? got rear ended yesterday.
- Question about DC header
- From Ls to Gsr coolant piping help!
- Is my tuning correct?
- my acura 95 wont start
- DC4_Dad’s 1997 Integra Build Thread
- Coolant Temp sender mating plug
- Click when hand cranking
- Aftermarket torque mount bracket?
- Transmission/clutch loud noises
- jdm engines
- NEED HELP B18C ROD BEARINGS
- Check engine light appears and disappeares?
- Wire gauges for battery terminals
- 91 integra overheating!
- B18C1 misfire cyl 1... I’m lost
- Need a little guidance for NA build.
- Aftermarket engine mount recommendations
- Heat is super hot and car starts to over heat only when heat is on
- JDM B18C piston rings and bearings
- Steering wheel shaking at high speeds, rattling sound from wheel.
- Back in the game 1997 GSR
- 1990 Acura Integra Ls Automatic Swapped engine to Honda repairs:
- Integra idle problem
- ECU Compatibility
- Power Steering Mount, only need the upper?
- Open deck coolant flow question
- Oil in coolant but car sounds and runs fine
- Gasoline in oil please help
- No start
- 95 acura Integra wont START HELP!!
- Engine is broken - what next?
- What headlights are these?
- White smoke
- Will 15" Kosei K1 wheels clear the Type R brake conversion?
- 01 TypeR ECU help needed
- Messed up coilover preload.
- Replacing front bumper?
- 91 INTEGRA GS SERVICE CONNECTOR HELP!!!
- DB2 Integra Bogs down in low RPMs and dies. Won't start.
- Transmission Synchro order question
- Map sensor issues
- 95 Integra RS rebuilt b18 cold start idle issue
- Acessing the front motor mount?
- Exhaust help?
- UKDM Type-R taillights on a 94 LS
- Anyone know What Lsd this is?
- Battery tray bolts
- 1995 CW GS-R Integra 5MT
- JDM Parts to Buy
- Do all non-vtec b-series heads use the same valve cover gasket?
- Adjusting ignition timing...
- YS1 Differential Bearing Part Numbers
- ISO: 1990-1993 integra sedan parts
- b18b turbo bucks when gave gas under load
- Integra wont start
- 1990 Integra De-Rice Build
- Troubleshooting: B18c1 GS-R No turnover- starter wire issue?
- Car won't start
- Integra battery dies after car gets turned off
- Idle bogging? Let off gas bogging?
- B20B(VTEC or NONE VTEC) vs B16A
- 95 Acura Integra ls, battery light is on. HELP
- '95 & '00 Integras: Interchangeable Parts?
- Rattle in low rpm <1000rpm
- Intega, NO SPARK
- Ignition Nightmare
- Starting From Scratch.
- '92 Acura Integra charging issues
- Taillight separation
- Car dies
- Best coilovers for 2000 integra gsr.
- TPS Calibration Issues, Rotation Maxed out
- ECU pin trigger ?'s and Valve Cover Baffling...
- hellp
- 1990 Integra b18 crank but no start
- Reverse lights issue
- Motor mount bolts
- OEM Honda steering wheels that fit DA
- AP1 or K20 swap in integra(2000) ls???
- Car won't start
- 96 Integra Ls
- Ignition timing question
- 98 GSR track car - sway bars - Type R or ASR
- backfiring jumping idle
- Seat codes
- What does it take to add Keyless to 2001GSR
- Recently stolen, won't start 01 gsr
- Integra Failed Smog due to Rpm
- New home, new axles
- Gsr will shut off at idle until car reaches operating temp
- DB8 GSR Engine Throttle problems - HELP!
- b18c1 axles
- Wiring Radio Issues - 97 Integra GS 2 door
- Gas tank out of shape
- Green key light
- 01 Integra Ls Coolant Issues
- Auto TCM differences between years
- Harness problem
- water lines messed up?
- Car failing after warms up
- Premature Wheel Bearing Failure
- Dead GSR, No Start, Code 0
- 99 teggy Transmission Problem
- 94 Integra LS
- Distributor Cap
- jdm front turn signal help
- First Time Buyer - Does this GS-R look ok to you all or does something seem off?
- not sure what is going on with my turbo teg
- HELP: Weird Noise Rebuilt Motor
- 94 integra cranks but wont start.
- 2000 Integra ls, problem with fuel pressure or pump
- Car will only crank . Only starts when I hold down gas pedal before trying to start
- 1995 Integra ls b18b1
- 1992 floor mat fitment hatch vs. sedan
- 98 integra gsr issues....
- What to do about door locks?
- Underhood insulator cover for Dc
- Exhaust Tip Sizing
- Prop valve integra 94 replace abs
- Valve Issues with P8R head.
- 1991 Acura Integra LS—ecu replacement help
- FIXED!!!
- 94 Integra engine miss
- Rear Windshield Replacement Q?
- 1991 Acura Integra Ls problems with ecu fuse.
- P72 OBD2B Immobilizer issues!!
- 1994 Integra LS bumper light issue
- Integra 95 Power Window Unit
- 93 Integra Idle Surge -- Very Strange
- VTEC Problem - not electrical - eep
- I have a stock gsr!! I want high hp whats best things to buy at a low budget..?
- Cat Suggestions
- HELP!!! B20V Power Problem
- Want to J Swap my 95 GSR
- 3rd GEN INTEGRA NOOB BUILD!
- Stripped cam cap bolt in head b18c1
- LS Coolant Bleed port thread / pitch
- Check engine light not working
- Temperature Sensor Not Working
- Intermediate shaft
- Widebody on a Integra GS-R 2-door
- Exhaust Suggestions
- heavy ice/snow cover for integra
- outer valve cover nut rant! 8(
- exhaust shield?
- will auto motor mounts work on my gsr chassi?
- In need of some guidance! Plz help
- 2000 Integra GS-R Ignitor (ICM) Removal???
- about b16 tranny
- 95 Acura Integra LS B18B1 with a 98 engine Half Shaft issues
- I NEED NEW OEM CAM CAP BOLTS PLEASE HELP!!!
- cl1 seat in dc2
- 1994 Integra smoking
- Stock head height for a B18C1
- Check engine code
- these lines in my Integra are leaking...what lines are they?
- red light
- 1997 Integra won't start
- 97 Gsr won't start help
- [97 integra] cleaned throttle body, now engine stalling out
- Integra Problems DIY Help
- Wheels don't fit!
- anyone have any experience hardwiring dashcam to fuse box under the hood?
- Nothing special, just a picture of my 96 RS by the water
- Problem with VTEC engine..!!
- I just got a new crankshaft
- Basic Transmission build and install questions!!¡!
- Stage 4 too much?
- Mechanical issues
- PGMFI Wiring and Code 9 (D16A1/89 Teg)
- need help with brakes
- removing dash
- CA Emissions Sticker for 96 Integra HELP!!!!
- Brake lights went out... Help...
- 93 integra NEED HELP CHOOSING FULL COILOVER SUSPENSION
- Best Clutch for Daily Driving/Street needs?
- Acura integra rattling noise
- B16a2 PCV query
- screws
- Cuts off at 2k rpms
- Broken heater outlet nipple
- B18C1 Burning Oil
- My '89 Teg: What to do?
- 1992 Integra Sat for a while
- Is my GSR head still good?
- 93 Integra Fuel pump Won't turn on with new pgm-fi relay
- 2000 Integra GS-R Won’t Start
- P0505, P1359, and P1457 codes! Help!
- misfire
- Is it worth it?
- Burning oil when engine braking 1990 DA (stock)
- Clutch or transmission slipping?
- Ls B18b into GSR
- 1998+ Rear Bumper black Inserts
- 96 Integra coupe wiring puzzle
- MY. 94 Acura Integra has no heat
- 1994 Integra GSR Build
- 1997 acura integra GS Crank No start
- Quick question, b18b or b18c non-vtec
- DA7 engine swap
- Tach help
- D16 integra help help help
- Integra GS-R interior dash blinks twice with oil sign
- Tach help
- Axle seal question
- piston replacement
- carstallled after gas up has not started since
- Integra vs Sti Handling
- Headers and exhaust
- 1990 Integra b20b HELP!!
- 94 Integra Interior AC/Heat fan
- 1992 Integra no start
- Results from my b18b1 valve lash adjustment
- Keyless Entry DIY Issue - '00 Honda Integra
- Crower 403 b18b
- Driver’s blinker and hazard don’t work
- ECU help
- motor mount comfortability
- 1990 DB1 - Dies when giving gas or put into gear
- Brake Line / Fuel Compatibility Issue:
- Running Issue...
- new clutch won't engage
- Finally got my Integra! '95 GS-R 392whp
- Fuel rail question
- 97 Integra GSR engine wiring question
- Driver side axle nightmare
- Need help with some technical questions
- Crank but doesn't start
- D4 blinking and cel on
- 997 Acura Integra LS Auto w/ 143000 miles for $2900 good or bad?
- Timing belt woes- one plate to rule them all
- 1991 Acura integra- **No crank**
- idle issues
- 2001 Integra GSR fuel cut off
- Got the shakes 00 Teg LS
- Rear Trailing Arm Bushings for Daily Driving?
- which one is the correct ECU ?
- can i incorporate honda lane watch into my integra?
- 90 Integra heater rad/heater hoses
- B18C integra gsr wired noise
- evap system / vent line replacement options
- Integra DB6 saloon
- Bad fuel pump on my 94 gsr?
- 1998 integra starts and idles rough
- URGENT Help P1456 code Gas smell with new lines ish
- B20 integra cabin heating & engine cooling issues
- Integra fuel/brake lines replacement
- Integra LS
