View Full Version : Acura Integra
- Vtec messed up?
- 91 GS auto tranny.....
- exhaust pipe diameter?
- b18a stroke length
- Dam another exhaust ticket? Help
- gonna swap my 00 teg piping with a friends 94 teg piping, just wana know if it will all bolt up
- where to buy itr throttle body rotor?
- please post: bronze VOLK SE37K 17" on DC2
- CEL CODE 45, too lean/too rich - FIXED!!!
- S*@TY LOWERING KIT
- How many miles can it last?
- Y21 LSD vs Y80/S80 LSD
- I don't know jack about lowing my car, can you help?
- Need help with repainting my car
- crashed gsr for sale $4000
- Header Gasket Question
- Quick exhaust clarification question.. please answer!
- Window molding
- Jun2/ITR combo
- What flywheel weight to go with??
- Free CARFAX report
- acura dealership
- member check
- fitment of skunk2 front tower bar
- Changing Final Drive ??s
- 98-01 integra type r front lip
- Need help with Skunk 2 manifold installation....
- spark plugs/ header???????
- Offset of GSR wheels?
- what do I to loose the belts to take the power steering and alternator belts off? GEN3
- Rear hatch lock mechanism
- Eibach Sportline with????????
- help!! tranny or clutch
- vibrating dash
- HELP!: I think my cv boots are torn. How do i replace?
- should i try getting a low milage 95 teg LS or GSR or get a 98-99 teg LS or GS instead???
- clutch/flywheel/tranny finally its broken in!
- Eibach Pro-Kit on my Integra - BLISS!!
- critque my time slip
- Location of the IAC(idle air control) sensor...
- Brake Tech question!!
- $ for break master cylinder
- what could be wrong with my break
- obd1 or obd2
- Integra stock airbox question!!
- non JDM DC 4-1
- Whoa! It's been a while... help me with good quality exhaust feedback!
- What Gaskets do I need?
- BAY AREA dyno day meet. Interested?
- ENDYN Headwork?
- what's up w/ everyone's long signatures?
- Any links on how to install a header on a GSR!
- B18c1 help (lagging)
- Attn:AllMotorMaddness Pls relpy
- need a little help.....so i start my car and this noise...
- i need help installing a tach in my integra, can anyone help me out here>?
- how do i install this monster tach in my 94 rs??
- VIN check please
- Need help, starter problems!!!
- Can someone please check this Integra VIN for me?
- fuel pressure on gsr
- Clunk noise update
- AEM cold air question
- Finally, my car's new track shoes, feet, and laces are here!!!
- 95 GSR 4d - Front Passenger Window Won't Roll Down?
- Holley throttle body
- help - anyone have kelly's blue book or similar
- Tech drosp to Zero when I press the gas pedal
- Teg is making a humming/moaning sound...
- MSD
- Funky Starts
- Map Sensor
- RSX Steering Wheel
- cams for ls?
- any good shop to do head work?
- Azenis worth the wait?
- gains from new cams and cam gears
- Any fellow Integra owners have a pocket rocket as a 2nd toy?
- need some launching tips please...
- Drag slick question... LONG...
- Cam won't move.
- I have a question about shocks?
- Broken temp gauge
- Race Day
- Poppin noise from exhaust
- custom interior
- Would 99' OBD2 ECU works on OBD2B (00+) teg without harness?
- shifter
- Bay Area shop recommend for timing belt(south bay)?
- suspension question....
- Heavy duty oil pump?
- Replacement Air Filter Brands
- for those who might remove the driver's seat: READ THIS!
- No Vtec?
- itr bottom end and valvetrain
- question
- SoCal Dyno Day Schedule
- Seatbelt Question
- what are symptoms of needing to replace belts
- Im talking to the dealer for a 2000 integra LS......opinions please...
- Fighting with myself
- NA, Forced Induction (Turbo, Supercharger), New Motor....What to Choose????
- ITR HEADER - IS THE POWER WORTH IT??
- Question about tuning with Hondata
- Amsoil 0w30 synthetic
- Transmission, clutch?
- B17A build up: CTR cams and Eagle rods...
- Pennzoil Synthetic...anyone hear any bad things?
- ITR header for a LS
- removing my ABS
- testpipe size on 94 GS-R
- Skunk2 cam gears install help
- Stereo security code
- Exhaust: Stainless or Ceremic Coated? Pro's and Con's?
- SQUEAKING NOISE
- clutch/flywheel tranny first impressions
- 453.7hp Daily diven teg
- How much would a b18a be worth?
- How to tell if they're ITR valve springs+retainers
- a "tac" sound when I'm releasing the clutch in first gear... any ideas???
- 14 sec in my LS
- odb2 what????
- Need Tires Soon....
- ECU difference ???
- Third Pipe, CatBack, I'm confused, need help!!!!!!!!!
- Flywheel weights? Already did a search.
- Check engine light
- Ls Vs. gsr (differences)
- Need help BAD!!!!! cel(s)
- oil drain plug ?
- Water in my exhaust?
- JDM STOCK BUMPER WITH TYPE R LIP??
- Ok...turbo for me...finally decided but need help !!!
- GSR STB
- Gsr's with TODA B's
- Test Pipe, worth buying?
- Erratic Idle
- Engine Mods without taking away reliability
- Can i use ITR Intake Valve springs for Exhaust valve springs?
- type r pistons on b18b?
- Head Gasket?
- ADR DTM 16s weight?
- question...i need help....
- anyone herd? 5zigen border II cat back
- $311.00 Shift Stabilizer!!!!!!!!!
- whats a average 60ft. time for a GSRwith only a AEM intake???
- valve adjustment for 94gsr
- 97 GSR ticks alot and sounds real rough when cold
- discoloring on headers
- My headwork is finished!
- whats the best way to chnage brake fluid?
- distributor cap and rotor replacement
- Steering wheel is shaking? Help me here....
- AEM Big brake parts
- getting skunk2 cams
- Does a brand new cat-back exhaust need to be brokin in?
- itr head w/b18c1 block
- Anyone ever seen this before?
- Yikes, tried to fix maintenance light, and got a CHECK light.
- please help! i need a back bumper
- ITR HEADER - FIT OR NOT FIT???
- GSR tranny and LS redline
- good SCC article
- how to remove resonator box on 94 rs??
- Any one have an Iceman cold air intake on an rs/ls????
- I/H/E is Done, What comes next?
- gas tank location?
- injectors
- dropping off my car for surgery
- OEM FOG LIGHTS?
- Will this work
- Expert install service for lsd...Bay Area
- Ground Controls: Should I keep them???
- Little Talledega Track days March 9th and 10th...Sign Up Now!
- Cam Gears, V-AFC, ITR Cams
- 1/4 mile times?
- 4-2-1 OR 4-1 ON A LS
- Tokiko Blues Vs. KYB AGX, comparasion.....
- ANYONE LOCATED IN EVERETT, WASHINGTON ?????
- motor sucking in dirt and water?
- Anyone running Pirelli P7000s?
- short shifter install - HELP!!
- What type of plugs and heat range should I run with my setup (see below)
- Big RIMS
- stock GSR header and LS same or different?
- question?
- exhaust
- NO dashlights, got new battery. HELP!
- Will engine clear...
- Many parts f/s
- Help me decide Kumho Ecsta Supra 712 or Falken Ziex ZE502 ?
- Where can I get a silencer for a 5zigen fireball catback?
- Anyone done a custom install for the Apex-i V-AFC?
- Problem Pulling Engine..
- If I have 205-50-15's up front, and 195-55's in the back, will it look wierd?
- toda clutch
- Anyone want a Skunk2 intake manifold for a GSR head??
- **My Dyno Sheets........Over 220 WHP, Over 205 FT-LB TQ**
- alignment question
- "Water Mist" carbon cleaning method
- tranny removal? why so difficult?
- for pitty's sake!!!!
- Anyone here running Neuspeed Sort Springs w/ stock struts?
- weird question, does this exist? power outlet like wall socket for car?
- LS turning into a GS-R monster but Need help!
- What comes after I/H/E?
- Widest wheels/tires on a G3 Integra?
- difference between dc 4-1 and dc 4-1 jdm...really...
- 2.75in vs. 3.00in CAI on GSR
- What camber kit to use gor Gen 3 Teg?
- taking out breather valve
- H&R Springs @ $149. Anyone find a place cheaper?
- should i repaint the whole car?
- What's the difference between Honda coolant vs aftermarket ?
- Are these Coilovers good?
- how hard is it to remove PS rack to Civic rack?
- Zex DOHC VTEC cams, opinions, comments?
- electric supercharger
- Easy exhaust Q----Help me out please
- How do you take the hood gasket off?
- BSQ or other DIY intake, Power Gains???
- Whats needed for b16 in 90 teg?
- CEL Code 10, IAT
- Please i need to get the car started
- Skunk2 Intake manifold
- Pictures of GRENADED B17A block, rod, and windage tray
- Wheels?
- anyone know who rents cherrypickers?
- Why did my post get locked? White Integra
- COOLANT question
- Let me know what you think about my car....
- Integra Short shifter Install - Need help once again guys!!
- Pros/Cons: Eibach Spo vs Pro
- Replacing other belts on Integra gsr.
- just dyno tuned my ITS GSR
- Fastest GSR on street tires
- Looking for a little more power.
- Anyone with Throttle Bodys?
- '95 Del Sol VTEC header on a '95 GSR
- Does anybody in or near the Chicago area have H&R coilovers?
- fitting jdm 4-1 headers in a DA?......
- Tornado? Has anyone tried it cause that damn infomercial about sold me.
- Mods for GSR'S
- Supercharger question
- Axxis Ultimate for the 1994+ Integra GS-R
- i finally got my gsr!
- Might switch to turbo (from Toda "B" setup)
- update on my shocks
- DENSO Iridium plugs. Are they worth it?
- Just got the AEM CAI installed!! Thanks, HT..
