View Full Version : Acura Integra
- spraying header
- help with skunk 2 manifold
- where to learn how to pull engine?
- OEM ITR is bad, read up inside
- upper strut bar install
- Skunk2 Intake Manifold
- Please help
- WHy Am I Smoking OUt The Exhaust??
- Can someone explain the numbers ont the blocks to me, which ones which?
- Please HELP! I have two ?'s about leather seats
- 99 si mid pipe to 97 gsr
- How can I get P/S back?
- Some pics of my bars...
- plexi glass rear window
- Which wire does the tach hook up too?
- PLEASE HELP!! Clutch issues
- hood latch cable question
- Question : will the JDM inner fender liner fit usdm ?
- Techs out there need help car won't start seems too much gas.... HELP!!!
- Quaiffe in my 96 gsr
- lowering
- Help!!! i switched my p72 to a mugen chipped p28 now my p72 is acting up?
- Str throttle body or itr throttle body for a b18c1 which one?
- My GSR
- This might help some people out CODES
- B20 in 94 Teg GSR?
- To "T" the stock oil pressure sensor or leave it off ?
- lookin for pa boys close to gettysburg. need help
- NEED A TURBO
- GSR SYNCROS??
- Breaking down VIN's
- Need Help taking off DC2 integra door window
- boosted ls vs. all motor gsr
- Engine Spec Question?
- LS header and cat on GSR 94-01 HELP!
- wheel options?
- decision time for the g2..
- clevite bearings HELP
- SRS unite Module, what year is it?
- will DC seats fit DA seat brackets??
- were are integras manufactured in america?
- whats the 0-60 on all integras stock ?
- check out the pics of my integra let me know what you think
- 90-93 DA exhaust catback, who makes one?
- Please post pics of your Exhaust!
- Rota GT3s
- 87 integra- question- cams and Suspension
- COLOR CHOICE???????????????????
- Holes in Rear Bumper
- springs from a 98 civic interchangble with my 92 DA?
- turn signals
- Replaceing Trailing arm and bushing
- question honda engine code
- What lowering springs?
- lighting wires
- K20 swap questions... searched..
- Double Syncros??
- what to make taillight gaskets out of?
- 94 gsr with 150K miles
- ls in a 93 hatch swap-now I have a jumping idle what should I check
- NEED ASAP! torque spes for 96' b18b1 main and rods
- b18C1/C5 build ??
- 94+ strut bar on a 90gs?
- My Dyno Sheet 182 whp LS with n2o
- Timing light flash question
- does a light weight flywheel make faster times?
- need help reading & identify keys in Helms manual page 11-15
- about clear corners
- JDM B18C swap HELP please
- synchromesh "friction modifier"
- Bumper question?
- 94-97 corner lights same as 98-01??
- b16a1 direct bolt in?
- Just got done dropping my tranny out.
- anybody know the the part number to this
- HELP! Buying an Integra (vibration)
- Upper radiator hose similar to blitz
- replace valve seals???
- Just put in B16 pistons in ls block help something went wrong!!!!!!!!
- $6000 and some Questions
- Black Integra carpet?
- Suspension for a low, yet comfortable ride...h&r ultra low or modded agx's
- HID DA help
- will a 4 wire primary 02 fit
- mod question
- xhaustOk.... this has been pickin at my mind
- 95 Integra LS vs. 95 Mazda MX-6
- Anyone hydrolocked with a short ram?
- will a purge solenoid from a 95 LS fit a 96 LS?
- OEM GSR strut bar on a G2
- ecu pin out where?
- pr3 ecu in gsr?
- Question about Jdm DC2 conversion
- 92-93 integra front bumper?
- bogging between 3k and 4k
- wireing question?
- Can rear camber just "go out" for no reason?
- obd0-obd1 conversion in my 90 integra...
- turbo kit for 90ls?
- DA shakes when i accelerate
- ITR Tranny swap question
- Rotora Slotted Rotors?
- HID's in DA 1pc headlights
- Do you know your DOHC VTEC?
- HELP WITH RADIATOR
- Prostreetonline/Neednetwork :thumbsdown:
- Installing new waterpump on LS...Questions
- Integra clutch/flywheel Q's Help
- 93 DA Car Won't Start
- auto tranny and ecu ???, yes...i searched first
- CKP sensor please help!
- GSR with LS bottom end
- Fuel pump relay??
- Southside Jacksonville..Whip Out Ya Whips
- Engine Swap
- Is it possible to switch.......
- Some LS-Vtec Questions...
- very high cold idle
- axle vibration
- USDM Integra GSR MOTOR FOR SALE
- help! jdm dc2 hid wiring help!?
- What Should I Do To My Integra?
- How Do I Remove My Butterflies??
- How to lubricate a/c fan been sitting for 1 yr.
- stock gsr exhaust piping size?
- part number question
- I fucking hate thieves!!!
- Side Marker Harness
- sparco harness
- What i need for RHD
- Strut Bar Question?
- ORIGINAL ENGINE???? How do I find this out?
- carfax help plz.....
- CF front-bumper....
- Problems
- Lowering G3
- Looking for a fuel rail
- gs-r head
- Fujitsubo RM01A
- A pic of my hydorlocked bent rod and some new parts...
- Auto to Manual progess on my car, wiring question
- H.I.D. LTB
- Slotted Brake Pads, who makes 'em?
- HELP!!!
- Ingalls + Omni cambers at the same time?
- greddy gauge install for water temp.
- Officially frustrated with my gauges!
- 94 Acura Integra LS
- engine build question
- Carbon Fiber ITR Replica Lip 94-97
- Integra is leaking!
- lookin for oppinion
- where is the integra turn signal relay?
- whats this sensor on this B17?
- The saga continues, tracking down my final leaks
- Transmission shifts hard when moving, but not at stand still.
- My buddy has an VAFC2 question..
- sup guys hey u think this are real wicked
- lexus seats into integra LS
- turbo timer and alarm?
- 94 integra 4 door
- Integra Rebuild
- Alpine HU time correction HELP
- Gen 2 integra camber kit
- a poor man's carbing 3pt strut bar
- what brand is a good bearing brand?
- will synthetic oil leak threw my engine?
- Greddy profec E01
- Blaster Coil bracket?
- carfax please JH4DB8590XS000112
- Vacuum Lines
- Sway Bars, Which one have u tired?!!?
- what would this be.............engine jerking
- Problem with my car please help
- p28 question
- itr aftermarket exhuast question
- having trouble removing...
- i need help putting my car back together!
- My friend needs help with his car, he's about to junk a brand new car!!!!!
- Axxis Ultimates on Brembo blanks
- GSR cluster on LS
- Gas door lever STUCK!!!!
- Apexi dunk piping size?
- 1/4 with I/E/H, whats your time
- do bigger injectors make a differ???
- Valve Adjustment
- LS Transmissions
- convnetional or synthetic???? helpppppppppppppppppppp
- Civic bumpstops same as Integra?
- my new clutch smells...
- cylinder honing
- camber kit hitting inner fenderwall
- How to break 14's with a 97 GS
- icm, (ignitor) voltage
- HELP_b18c swap now car won't start
- Thinking of getting a new project car
- Quick question...
- cousins turbo teg check it out...
- Frame Straightening body shop NYC?
- is sleeving the block bad for your pistons?
- pre-obd B18a1 Crx vs. modified Obd-1 92' Integra?
- Help, Did i buy an Oem gsr pressure plate??
- Problem with stock cd player - 98 DC2
- SRI made my gsr slower??
- thequick question regarding Rs-R exhaust, need quick answer!
- ECU... tapping off wires, will it screw up the ECU?
- **STOLEN Black 92 integra GS Rosemead **
- Haynes Acura customizing
- Help! will a 1995 Valve assembly fit a 96 integra?
- 99 seat bracket bolts same as civic yes?
- Acura parts, or dealers... i need a clutch kit.
- EP3 DC5 10.2 rear disc brake upgrade for 94-01 Integras
- www.luminicsbulbs
- Putting together my motor questions
- WANTED: anyone selling a 94 or 95 integra shell/chassis?
- H3 Bulbs???
- 96 GSR blox intake manifold error code
- Leaving the Integra World... for now.
- Apexi piping?
- pic request.. DA integra with painted blades.....
- Power steering lines??? HELP!!!
- Front sunroof drain tubes, where do they exit?
- pistons question?
- Maintenance required light
- All About Headers
- question about intake
- a test pipe or the cat?...
- Honda Engines R/S ratios.
- Got a swap question..... researched and don't find too much
- 96 Integra LS seeking LS/Vtec swap
- B18c1 w/p73 Pistons
- cutout
- help on installation of cams and valve springs
- Gaskets for b20 ?
- brake pads efficiency
- need help fixing abs light codes
- itr gsr sway bar hardware
- CAI+ Gas Station+ rain+ Standing Puddles= Almost Ownd myself.
- Choice on coilovers
- Vin CheckUp Please
- Antenna switch...what do you all think?
- ITR Tranny Gear Swap - anyone??
- Found A Cheap Teg Shell in my area, need some info...
- ITR Tranny ?'s
- reflash or ecu chip
- OEM GSR Spoiler - Broken Bolts - Installable?
- Problems with battery power
- JUST did compression test....Can I boost on these number, or should I rebuild ?
- Squeaking Sound when i turn the Wheels
- opinion on exhaust..
