View Full Version : Acura Integra
- Strange Idle problems.
- Lumpy idle when hot no CEL
- What's it worth" for the integra section ???
- jdm gsr oil pump question
- Buddy Club Coilover set-up question?
- integra starting help
- JDP Front Lip
- How do these valves look ?
- need help please.
- schrader valve stuck in spark plug well ! need help.
- B20 or LS/VTEC
- cd player delete plate help
- tires rubbing in the back
- Weird hunting idle. No answers searched everywhere
- 2000 gsr sedan keep or sell?
- Blown gasket? (video inside)
- MPG, RPM's, gearing and throttle load.
- supertech valvetrain issue
- DC4 Sounds Bad Man and Loses Magic Green Liquid
- Gasket/seals replacement // what brand or type
- 95 ls integra starting problem
- DA9 seat rail problems
- b20v help!!!
- Jdm gsr intake manifold
- obd1 p72 code 41 bad o2 cel still on!
- Jdm gsr wiring with usdm p72
- Cold start trouble- dc2
- Integra stalled and wont start
- Frying ECU's
- Car's running richer.
- Running rich?
- DA and DC Bushings
- 1991 DA - a cut wire, know where it goes?
- Gsr transmission problem. Tranny gurus please help. Hard to shift.
- how would a car feel with a bad map sensor?
- Another confused da9 owner
- My poor man build
- LSVTEC assistance
- Car Temp lights on/off
- stock 94 teg radio help.
- ign coil compatablilty(dizzy)
- Driver side engine mount loose GS-R.
- welding stock tranny bracket back on(been cut off for kswap)
- Got an A/C question
- need help with my acura integra PLEASE!!!!!!!!!!!!!!
- built gsr problems
- how to turn off check engine light
- Acura Integra RS - Shortage?
- Type R cluster in LS causing high idle
- Replaced fuel pump then distributor and starts but as soon as I take off it dies
- DC trunk holes
- Piston rings going/gone. 94 gsr
- Steering Wheel Help
- 00 GSR Black dash reflections?
- Jdm gsr helppppp!!!
- Pictures of red integra with
- speedo jumping on gsr
- My RS came without A/C, someone help?
- Wierd Over Heating Problem HELP!
- bare vtec head yes or no?
- 1996 DC4 coupe fuse box/turn signal harness removal help
- What is it?
- NEED HELP!! Acura brown top zc
- NEED HELP!!
- I need a junkyard in the dfw dallas tx area any suggestions?
- 1995 GSR Overheating while sitting at idle
- GSR Starter Issues (Early Engagement)
- Need help!!!! Crossmember question! In desperate need! Help!
- Idle help!
- Need help with swap
- P72ecu makes my car die after 2 seconds...need help
- Brakes for boosted gsr
- CEL Bulb?
- Jdm gsr problems please help!!
- CEL code 41
- how do i get the air out of my radiator?
- clutch/gear problems
- Rebuild or scrap?
- just got a 250km engine what should I do with it?
- B20b converted to obd1 sluggish in 1,2 gear
- 92 auto integra s3 tcm code 13 fix? no cel.
- acura integra antenna
- Tps readings question
- Replace Cigarette tray and lighter
- Acura itr badges fit jdm dc2?
- b18c1 gsr catch can question
- H2B help
- GSR Overheating
- WTF is this??
- Integra 92 GS project
- JDM B20 Swap in 2001 Integra... What ECU?
- ABS light on
- Not Getting Coolant
- Car won't start after compression test
- Rough start after stall
- Fuel pump primes but doesn't build pressure pls help !
- Possible leak?
- No/waek spark after dizzy removal(new cap+rotor) no start
- Exhaust Manifold Torque Sequence
- Emission fail
- Oil & gas
- 90 Interga Ls Cam Rocker Moves at Valve Adjusting Nut!!!! Video Inside
- 1994 integra cranking but no start
- 01 gsr so so so sluggish until vetc
- stagg 4 shocks/struts????
- temperature Problem
- no low end power
- Intake Manifold setup
- I'm 16 and this is my Gsr Integra
- 99 acura integra w/lsvtec idel problems?
- Time to change the timing belt?
- Overheating issue
- rpm jumping
- Ignition and fuel injector Help
- Sensor I.D.
- Do you like? What needs to be done to it?
- Dc5r brake swap help
- 90 integra, im having trans problems
- 90 integra problems need advice asap!
- Please Help Identify this VALVE (pics inside)
- Please help me, need car for school
- Fuel leak from hardline ? (pic)
- Temp Gauge Not Reading Correct
- Integra Mugen gen 1 replica question
- JDM Front - Turn Signal Bulbs
- Identify mysterious plugs
- quick question about running an extra ground wire or two
- 90-93 oem integra seat belts in 94-01 integra?
- Integra Ls Manual Trans Question
- short shifter
- WAKING UP THE FORBIDDEN "92 GSR"
- obd1 b18b with obd2 valve cover question about smog
- 1996 Acura GSR
- 1992 Acura Integra GSR
- LS/Vtec Header Problem
- Running extememly rich all of a sudden under very light throttle
- Transmission question 92 gsr
- 1990 Acura integra DA with b20 Idling really hight
- need help with aftermarket intake for carb smog
- 92 DA electrical issue
- New oil pan gasket leaking
- Where can i get oem parts?
- Throttle body stuck? Gas pedal only goes down half way
- b17a1 what fuel upgrades?!
- B18C1 GS-R could this be my cat???
- 92 db2 brake issue
- b20z starts, idles at 5k
- 95 Gsr starting funky
- o2 problems
- Brake question
- b18c1 rod knock ?
- weird battery light problem
- 92 DA cooling system problems
- Distributor rotor part number
- rack and pinion 01 gsr help
- 94-92 engine wiring harness help
- b17a1 valve clearance
- B18C 96 Spec MPG
- 15x8 best offset
- GS-R sputters/bogs NO V-tec MisFires
- Weird Starter Problem. STORY inside...
- Buy a Ebay starter or no?
- Speakers not working
- b18b1 transmission problems.. did i blow my tranny???
- what kind of header is this?
- Ground wire (g201) location ? ELD issue
- Fuel filter banjo + service bolt
- Main cap question (oh not, not another one of these)
- DA9 brake caliper piston
- quick wiring/electrical question. pics inside
- 92 integra gsr- HELP ASAP
- Power door lock issues
- 99 Ls Overheating At Idle Random.
- Where To Start?
- fuel pump primes but when cranking no gas? wtf
- Auto throttle body and the iacv on a 5 speed?
- Getting code 20&22 after swapping back n fourth ECU's
- coolant issues 98 teg ls auto
- replaced rack but moved steering wheel
- Antenna Delete
- Tail lights...
- 96 GSR Headers
- 00 integra p1399 only
- Bad IACV?
- Cel code 61 After replacing primary o2
- Major oil burning in VTEC GSR
- 98 GSR HELP!!
- Ac system question?
- Burning through oil quickly?
- Other parts necessary for 94-99 GSR Header Install using PLM Toda Rep?
- Engine temp question.
- acura integra code p0441
- Throttle getting stuck
- 92 integra gsr help!!
- Still running rich after tune?
- Strange Injector #1 issue need electrical experts !
- 90 Integra water leaking on the passenger carpet.
- ecu ?
- Strange Rattling Noise?
- Misfire on idle only... need some ideas please!
- Blackworks Control Arms ..
- 2000 GSR 7200 rpm rev limit...
- B17a1 tranny swapped
- h22a7 euro r into 2001 integra gsr wiring issues?
- PR3 Ecu Wiring issues (b16a)
- DA9 different fuel injector replacement ?
- 93 RS intermittently runs on 3 cylinders
- brake ducts on mugen lip
- toyo proxes R1R
- full suspension?
- 96 Teg GSR OverHeating
- No start, No crank, starter tested back good?
- ls vtec power steering question
- Unfinished Swap :( Help Anyone??
- 98 Integra, B18b1 Engine. Car wont start!!
- ECU for B16A obd2?
- 94 ls misfire no cel
- b18 shift linkage bushings
- Idle weird when coming to a stop, now hard start :(
- 2000 LS hood won't close
- lighting need advice
- full aluminum radiator
- overheating problem
- 1990 acura integra shift solenoids ???
- HELP ! GSR motor problems
- 1994 integra water temp sensor
- GSR won't even crank ! worked fine 2 minutes ago WTF.
- Car no longer thinks it's in park (auto to manual swap), and now shows code #15
- b20b4 91 teg obd0 a few ecu codes and possible timing issue!
- ODD CLUSTER ISSUES ***NEED HELP***
- Fuel question
- ITR Recaro seat won't fold forward anymore.
- Idle control valve & Throttle body coolent problems
- B20B motor in 00 integra (LS) ECU
- Carbon Hood Suggestions?
- Need help Identifying a block that's in my crx
- Integra 205 45 16 16x8 pic request
- 96 GSR
- Integra Frame Rail Replacement
- 95 Integra not starting
- B18C1 Coolant hose size / length specs
- Cooling system question(s).
- What to look at when buying an integra ?! (Potential future integra owner)
- DevinG916's DC4 Integra Build // OEM parts etc
- cant get da to start please help
- GSR Sputters/hesitates when in VTEC.
- Engine temp spiked when in vtec today.
- 1990 Acura Integra LS Headgasket/Timing belt kit
