View Full Version : Acura Integra
- 97 Integra Main Relay Problem..
- car hesitating codes 7-8-12,reset ecu no code
- window motor problem.
- HELP...swap done, leaking oil from rear block, missin cap plug catch?
- Worth it to convert to obd-1?
- RHD A/C line for 96 Intgera ?
- GSR ecu on ls engine!!??
- Quick Question regarding brakes
- phearable ecu?
- GSR Harness wiring swap?
- test pipe options with jdm itr header
- squeak help!
- LS with jdm type R swap&harness ?'s
- replacment quarter panels?
- b16a2 head and GSR Block install question
- 95 ls hydro tranny ?
- DC header question
- Bogging down and dieing
- Wheres the link to the B18B Engine Rebuild manual??
- WOT Engine troubles...
- installing 01 prelude cluster into a DC
- Help Removing Fuel Feed Hose
- fuel rail
- DC2 Airbox into DA9?
- timing mark jumping around
- fuel pump does not turn on
- Tranny issue after rebuild
- Will a DC radiator fan work on DA?
- Need stock crankshaft, Crower, scat, Eagle, OEM?
- Complete b18a1/b1 for sale 67000 miles
- GSR tranny (anywhere i can order one?)
- quick computer question (fast input needed)
- What is a PM5 ecu off of?
- DB1 Sideskirts
- Vtec issue
- Fuel Line Issue
- Relays on passenger frame rail??
- ek with gsr motor what plugs?
- obd0-obd1 check engine light test???
- Good? Bad? Anyone ever use this company?
- HELP with my ls/vtec
- dude!! help me... i was freak out
- mounts
- tranny or axles gone bad??
- the wire by the brakes
- Speedo stopped working
- minor performace parts??
- Cars Runs better WB02 help
- LS/Vtec Last Questions
- gsr compression test results ideas?
- Crazy idle. revs to 4k at start then dances all around
- which header? any help or opinions?
- converting a carb to vtec(which wiring loom)
- Auto trans help!!!
- Should I change my tire size?
- manual to auto help(i searched)
- shaky steering wheel at lower speeds
- can i fix it? or sand it?
- Car not starting
- power loss while in 4th gear?
- Asr sway bar bolts.
- New With a Few Questions
- passager door lock and wont open. need help bad
- 98 Integra Maintenance question?
- Can i use a DA underdash harness to convert a 91 auto wagon to 5 speed
- my little DA coupe
- Where do I purchase a rebuild kit for a B18B??
- type r 4-2-1 header bracket?
- 90-91 vs 92-93 DA9
- Integra starting issue, dying issue
- 95 teg gear box area squeek!!
- popping
- 94 teggy ls sedan!!
- RPM Problems
- DIY tranny swap, help
- obd2 ls auto p1382 CKF ( NOT A NOOB HERE)
- My b18b1 stalls wen i floor it?!?! help needed
- Integra seems to be losing power... Help please...
- Engine Removal
- May be buying an integra any one have tips?
- what clutch do i buy?
- Few Problems... Assist Inside :D
- Dead pedal just flat out BROKE OFF!
- Boost ?
- Lug nuts coming off?!!
- Stock temp gauge bad?
- Car harder to drive with A/C on?
- A/C bracket compatability
- what are the 2 sensors on the b18b head
- my rotor button wont come off!
- name of bushing in rear right tire?
- electric power steering
- Not popping vtec?? Possible symptons?
- b18c into a 94 civic
- 87 integra ls project newbie needs tips
- mobil1 15k mile oil
- need ideals to relocate my cruise control
- ABS
- RPM stopped working one day "HELP"
- Gauge lights blowing fuse
- Identify these cams...Pics inside
- 96 integra ls missfiring
- 2000 LS weak 2nd gear output/ bad MPG
- car not heating up to normal temp.
- I need a Radiator Fan for my DA. Can I use other Honda fans?
- Overheating at high speeds...
- Squeaking and stalling!! Need help
- ARP Rod bolts torque
- 1990 LS Build Thread. Opinons wanted/needed
- Full Bolt Ons - Need a tune?
- Question about integra sedan
- how to pull codes from JDM ecu?
- b20b into a dc question
- ac not aworking
- 1991 teg bogging in higher gears and low rps
- 1st gen DA fuel tank? where do I get one?
- Gsr Question on using nitrous
- Oil flowing to head slowly? Need Help
- My radiator reservoir is empty
- diy front lips for a da9 integra
- Speed Daddy parts?
- Are integra Alternators model specific.
- LS Vtec bogging , hesitation , stall engine problem
- no compression?
- 1993 integra dohc should i buy this?
- integra paint job
- 1990 integra how to read DTC flashcodes????????
- 1996 Integra GS-R Air conditioning input/help
- JDM Integra gunmetal housing headlights
- overheating problems
- 95 obd1 integra computer question (from theft)
- Where to buy OEM Acura parts?
- AC whining noise?
- Technical Question - New Car
- Intro - Technical Question
- p75 hondata s300 vtec not engaging
- My First Import - Bought Yesterday
- twm performance short shifter
- back in the game.
- 93 teg converted to hydro
- Lsvtec Sluggish Stalls
- DC Front Wheel Hubs Q *SEARCHED*
- So i decided to get a B20....
- 91 db1 project
- Misfire?
- when it's cold it runs bad
- 2000 gsr/ex swapped block FINISHED!
- 95 integra proble,with fuel
- coolant problem/leak
- P75 s300 in a GSR?
- code on ecu
- Repainting my Acura Integra
- etd racing on 93 interga
- question about intake manifolds for my db1
- Stereo Problem
- swap options..... LSV, GSR, or H2B
- Tan Interior to Black Help~!
- need help....
- Need help with my ls ... going ls vtec
- CEL 6, 9,and 22
- OEM oil cooler & aftermarket oil filter block
- 1991 4door rear bumper on hatch?
- A couple questions about swapping an F20C into an Integra LS
- Coupler size for OEM GSR throttle body
- help abs delete 94 integra
- OBD CODE P1362.......
- Need help with speed sensor?
- 95 ls teggy losing power?
- B18C1 oil problem!
- obd2 to obd1 wire harness
- Hard To Find Problem..... PLEASE HELP!!!
- GSR engine noise troubleshooting knocking
- E Honda's Official Build Thread
- B18C4 in my 1990 DA9
- s2000 antenna??
- 91 Integra No Spark????
- A/C with Bisimoto Exhaust Manifold
- clutch cover..
- Question on stock springs
- 94-95 GSR Idle Control Valve Question..
- Already Searched: Tranny mounting bolt
- my clutch make a wierd noise
- Difference in tail lights?
- quick release steering wheel with a lock.
- Please Help..
- subframe tire shredding and rubbing wheel wells to the bare metal
- i thought my motor was done with...
- whell fitament ?
- Frame is cutting into tire help!
- car problems please help
- 97 integra running sluggish
- 95 integra transmission question / help
- GSR, misfires and no power after VTEC
- 91 RS keeps popping fuses
- what is the OEM name to this piece inside the 94-01 hatch?
- b16a head on b18c block
- Group buys for wheels?
- Car won't start sometimes, high idle
- pushbutton v-tec
- what kinda turbo manifold ,and turbo to go with
- 97 gsr w/out moldings
- Need help with major loss of power!
- B18 Pricing Question
- problem wit distributor?
- 94 GSR swapped into 93 DA9 ??
- HELP newbe Vacume/valve?
- what is the best intake manifold for my set-up
- Can somebody plz help me with this TCU code?
- My wire tuck "attempt"
- 1998 acura ingetra GS 140000miles good buy?
- Best header for a GSR?
- check-engine light not working???
- obd1 gsr 02 sensor help...
- Where To Buy... JDM Integra Hood...
- DB8 B20B/B16A or DC2 Stock?
- the new LCAs are they direct bolt-on
- What's wrong with my car?
- wtf coolant in oil pan
- weird noise
- GSR cutting off when clutch pressed in
- Integra Brake Booster Queation
- viper 5002 un-installation.
- Alignment issues! Please help. Toe can't be adjusted any more..
- 1994 Acura Integra Ls alarm location
- rebuilt dc4 starts then dies?!?! help needed!
- DA integra is their a diffrence??
- DA 92 GSR Tranny help!!!!
- ls-vtec engine questions
- Newbie DA Build Thread (Suzy 2.0)
- Type-R Swap questions
- Proper way to reset ECU...???
- No start 91 Integra
- oil burning up, using 10w40 synthetic
- engine help cel 22
- 94 Acura Integra AC Problem
- Anyone ever disassemble their steering rack?
- Turba DA stalls when I attach brake booster vacuum line!
- Car cutting out when pushing in the clutch
- Wierd CEL and quick CAI question, 90 DA
- Tuning a GSR with the V-AFC, ratio question
- Annyone Painted they're WS2 Canister?
- obd0 or obd0???
- 95 integra Poorman itr.. PROBLEMS!
- Condenser Fan and temp gauge help needed.
- Automatic Teggy, transmission prob yes or no?
- steering rack question
- Lose of power....
- gsr enging problems and cel 22
- Strange Idle/drivability issue.. Replaced parts, still didnt help..
