View Full Version : Acura Integra
- gsr alternator on b16
- custom color carpet pictures
- 91 integra GS gauge cluster removal NEED HELP
- h.i.d high beams.....
- built gsr questions
- CAR IS TOO LOW? HELP
- Yonaka Exhaust
- engine problems and i need to go racing on wednesday
- 92 acura integra foglights
- Noob Question, What is..
- Driver's Low Beam Not Working, Help!
- DC2- Finding the perfect offset?
- boosting gsr
- gsr head?
- ICU
- need some advice for my set up
- 01 GSR Teg with LS VTEC swap running hot HELP!
- My turbo teg LS , 5 lug , opinions please
- P75 ECU???'s
- Identify these wires.
- Question on 02 sensor, CEL throwing code 1. New sensor, same code after reset
- changing muffler
- AM I GOING CRAZY? (im hearing strange noises in my "head")
- Aluminum Radiator from civic????
- rear bumper reinforcement
- DA code 14 wont go away
- 94-97 bottom piece bumper clips. need help
- b17 rebuild problems
- ground kit question
- CEL/MIL codes 41 + 65
- Wtb: Jdm Ef9 SIR Front end
- Any difference with LS, GS, GSR test pipes?
- will b18a1 external components for head, fit on b18c1
- Uh oh.......Installed some GlowGauges on my Cousinz car but Now the Speedo dont work?
- Integra Clutch play
- abs turns on at 3mph
- will this clutch fit my ls
- injector plugs
- OPINIONS PLEASE!! Power
- 98 integra gsr cel code p0108 problem help
- where to get OEM grill on 98-01 bumper?
- My current DD setup, imput wanted.
- JDM ITR HUB BEARING
- how can i fit a hid itr in my jdn conversion 95 gsr..
- ABS Sensor Part Number
- good tuning shop in southern new york area????
- help on used block
- IAT problems with my 97 ls.
- Turbo Gizzer in need of help...
- Question about parts?
- White Smoke after Oil Change ?
- old skool DA exhaust
- NEED HELP.. AC/HEATER FAN problems.. PLEASE HELP
- STARTER RELAY LOCATION IN A DA?
- accord exhaust on integra??
- how to change ps feed line
- B18B completely rebuilt - head gasket leaking
- fuel gauge
- Any advantages to F2B over H2B?
- Help with B18c in 91 teg
- 95 gsr fuel relay cutting out????
- What's a SSBP '98 GSR worth?
- Engine and Transmission swap
- Trade Rota's for Work's?
- ***** PLEASE READ AND VOTE: Why do you visit the Integra Forum? ***** Poll closes on June 1, 2008
- time for new cams. Need help
- DA front end swap.
- deleting power steering system help
- Electrical Problems: Please Help
- coolant bleeding issue on 94 integra, w/ a 98 b18b..........
- Two front Strut bars?
- ITR spoiler on a Gen 2 teg?
- whine from engine bay durring cruise
- Ticking noise when i turn my Wheel
- 1995 DC1 idle sticks while driving
- Where to buy Affordable Motor mounts.
- car bogs
- HOT WEATHER! DRIVER's WINDOW WON'T ROLL DOWN! Can't breath!
- Anyone have this setup...
- HOW TO REMOVE THE CLIMATE CONTROL
- Smoke comming out
- help with Knock sensor. yes i searched
- spring rates
- blox intake manifold with stock throttle body
- Somethings wrong with my car!!!
- b20Z2 questions
- opinions on camshafts for b18a....???
- p.s. return line leak
- best h.i.d kit for 94 int. ??
- Newbie dictionary please?
- Help! ABS wanky.
- Cylinder Position sensor
- Adjusting timing through my dizzy???
- best of both worlds
- Sportmax rims and DA integra (90-93)
- Mishimoto Civic Radiator
- B16A Transmission Seal
- wire routing for dash
- >Please Help Test/Smog test Tune up
- 1996 integra ls problem Motor mount or tranny?
- Modified steering wheel (personal neogrinta) anyone got the horn to work?
- Just got a fix it ticket
- DC Squad
- ls vtec chips
- questions regarding GSRs
- Where does this go?
- ES: Trailing Arm Bushings
- vtec cutting in and out!
- any suggestions???
- DA Engine Sound
- ITR intake
- Water Leaking Through Door Help.
- yo!...new to HT...thinking of B20 swap?
- to much vacuum ?
- turbo gsr has no spark
- the quickest way to remove the 5th gear from a 90 cable s1?
- New to integra
- new set-up,bigger problems
- ls/vtec oil leak
- humming sound
- Thief warning: Orlando / Winter Park area
- Need Rods
- i'm new, sup
- DA Integra: Starting up and then turning off after being on for a while prior (overheat?)
- I'm new help me out here
- Working link to Michael Delaney's intake article?
- need advice regarding replacement of the front sway bar links
- power draining
- a few days after installing my fuel cutoff
- what tranny do i have
- car sputters. loss of power..
- OBD1 P75 ECU ????'s
- progress on the integra so far.
- problem with VTEC
- Where to find stock engine specifications for GSR Engine...
- aftermarket DA metal radiator (no longer available?)
- help! guage cluster wont light up, cant see it at night !
- integra 1990
- loud noise when turning
- zoom clutch
- Stolen Acura Integra SAN DIEGO, CA
- gsr motor with cable b16 trans
- Are b18a motors good at handling turbo?
- DA Hatch
- Need Help. knocking noise inside engine
- Burnout light..........
- New to this board """PICS"""
- Integra Cutting out and bogging/ only revs to 3500 and cuts out when gas is hit hard???
- GSR turbo in Civic
- upgrade ecu
- slit in slave cylinder cover
- integra crash....lame
- abs questions
- reverse gear jamming
- does 14in steelies clear 98 gsr?
- This is the strangest clutch i've ever felt... having problems!
- problem solving
- GSR TRANSMISSION MOUNT QUESTIONS...
- Adjust headlights?
- blox throttle body on a skunk 2 manifold...
- Header options which is best (need more input)
- so i broke my oil pressure sensor.
- 98 ls cam seal
- ls transmission
- So my car just sputtered and died..
- Gas tank lid won't close.
- car makes weird sound at 3000 rpms
- My clutch is very very soft!
- where do i find the water tempeture sending unit
- have a check engine light on need help asap
- NEED HELP: I dont know which header to get?
- da gauge lights,heat control,and rear deafroster
- install motor from bottom
- interchangeable dizzy?
- I have a 93 LS auto sugestions
- H.I.D problem
- need answer
- HID oem FOGS...good or bad?
- Help my Turbo GSR build.
- Worldsport 2
- I need a clutch replacement write up
- buddy club exhaust spec 2
- Is this the right turbo?
- All motor build..What next?
- dc2 tuning question
- ISO ls or b20z2 Block and or b16/gsr tranny in MIAMI
- 1 peice headlight wiring???
- 1995 integra rs idle problems
- cam question?
- WORST PROBLEM AT THE WORST TIME!!!!!
- What year did they make non-abs GSRs?
- Want to rebuild GSR to run like stock
- 92 integra suspension setup help
- 2000 ls vs. 1999 gsr?
- non op. motor sugestions
- 95 integra running rich!!!! help!
- cant figure it out
- trouble shooting sk2 cams...Help!!!
- IAB Question/ Temp Solution
- so i woke up this morning
- toda spec B's for gsr
- transmission fluid?
- GSR IM/TB to ls
- gsr camshaft?
- ek camberkit on a dc2?
- Base timing connector same as CEL connect?
- rhd dc2 with dc5 dash.............
- Which car should I choose?
- Problem
- Hydraulic vs. cable tranny
- gsr motor with ls tranny ????
- IS THIS POSSIBLE
- i just
- psi for gsr fat fives
- Blacking Out Headlights
- Invidia Test Pipe
- engine Missfire all cylinders code and cfk code.
- DIY for Rear Transmission Mount
- how to wire oem fog lights to work anytime with oem switch?
- 90-91 Teggy's What Clutches are you running
- da mudflaps fit on db1?
- Type-R build cam swap?
- obd0 b16 engine into obd1 car how please
- will DC upper control arms fit on a DA with coilovers?
- Where do i find an auto b8c1 SirG motor swap?
- GSR Integra running terrible
- 9k on a da cluster?
- has anyone painted there head of there engine?
- PR3 ECU ON INTEGRA
- Oh craps, just went over a puddle!
- 86' Teg has no pressure in clutch
- gsr vs type-r?????????
- Is there any diffrence in a 94-01 automatic transmission?
- Oil change time?
- auto to manual swap estimate?
- Pics needed: 94-01 Integra with Eibach Prokit springs, and Rota J-mags.
- simple tuning
- entra plug on wiring harness???????????????
- Measuring gas mileage
- rear window motor question
- Cluth or tranny bad???
- JDM?? gsr harness???
- is it my tranny or tranny mount?
- Full Distributor needed ASAP!
- anybody know a shop where i can get my auto transmission fixed for my 90 integra?so cal
- IS THIS RIGHT? (trans. question)
- Gauge Cluster Swap.... now problems
- GSR seized after hitting a puddle, What now?
- clutch master cylinder
- Strange Problem..
