View Full Version : Acura Integra
- What is the use for this!?
- Is this a stupid idea?
- Purchasing a used block, Need input.
- can the autolock be taken off??
- 94 gsr
- legit???
- What kind of lightbulbs??
- I have a question about changing out motors for my 1990 Acura Integra RS
- After jacking up car for oil change, fromt end now bounces when driving, why?
- my project 2000 dc2, milano red jdm front in progress
- rs/ls/gs 2nd gen
- help!! valve spring right side up/ up side down?!!?
- HEADERS!!
- Head Gasket Question
- check engine light
- 94 b18b timing belt/cam gear question?
- losing power at 7krpm
- B18 swap: Idle really low and "sucking" noise from the TB?
- Too low...
- integra thread patern
- 94 integra b20 question
- Anyone running Koni SPSS3 race struts on their DA's?
- b17 tranny question????
- New England Nopi Nationals pics
- k20a3 for 900
- turbo vs supercharger..
- can any one post a pic of their H.I.D's "dc2" (with brand name and price)
- clutch switch
- will b16a cable tranny manage b20vtec?
- removing power steering on 96 gsr. need help.
- brake fluid change
- The Ultimate Street Racing Documentary
- waxing carbon fiber....fogged up my hood!
- Caliper Repair Kit
- Radiator Pressure Problem/Headache
- May buy this integra...awesome deal..I think.
- 93 da one peice headlights
- Gsr Redlining?!
- Body differences between a USDM Teg and French ITR?
- help need to find ALTC pinout
- Rear Upper Control Arm Bolt (Rear Camber Kit)
- B18B OBD-2 ENGINE IN OBD-1 INTEGRA
- 92 acura integra gsr overheating at IDLE with A/C on
- where to order 4x100 ITR wheels ?
- Does a muffler tip have any functional purpose?
- Auto-down on passenger side
- perfromance cat advice needed
- b18c1 vs b18c5
- Worst luck possible....
- da tranny question
- b16 or gsr tranny?
- b18a1 stock:need basic boost
- What color should i paint my wheels
- what is the engine code for the USDM GSR?
- coolant leak
- 94 integra install cd player help plz
- Gsr...I wanna be able to get that high end power...?
- tranny question
- 909 DC2>Parts wanted....
- b16A Vs. b18B in a 93 LS integra
- electrical help please
- Tire wear problem in my 93 integra
- ITR Four Lug Help....
- I have searched and still cant find exactly what im looking for...Best setup for stock gsr?...
- Types of Lip Kits
- engine names...
- anybody heard of wheels called infernos?
- spark plug wires???
- New member from Maryland
- GSR Starting problem
- Bumper question
- SPAL door popper problem, wont pop solenoid...
- Timing belt tensioner question
- Think its worth that much?
- 95 Gsr poor acceleration and power
- car boggs out while driving...
- cluster swap
- Custom 4040 Prop valve setup.... Tell Me If U Likes ! ! ! K20 in progress
- hrm integra 1995 rs, should I?
- what kind of lca's are these
- How to replace transmission housing?
- OEM DC2 GSR alternator belt. made by mitsubishi???
- increase compression on lsv....
- 70mm BILLET THROTTLE BODY???
- 18" Polish Magnaflow XL SS Oval muffler?
- Opinions on wheel size for DC. 15's or 16's??
- JDM OBD2 B18C TYPE R into an OBD1 LS Chasis
- 1993 Integra Idle problem
- guage cluster swap legal?
- DC Radiator into DA
- integra white face gauge?
- Cams, Springs, Retainers, Cam gears....
- How do you verify rear seal leak? I'm stumped....
- obd0 to obd1
- Hey! Whats up guys I'm new Welcome me to HT!
- 98 4dr C-Pillar Bar.
- Motor not always starting/fading out on start up.
- No fuel injectors, spark plugs, or fuel pump
- just back from the shop
- help need info on auto tranny changeing oil please help
- painting front bumper! help....
- Need help finding some gaskets.......
- OBD-0 B16 into 89 Integra
- Future turbo....Valve springs and retainters
- CTR Pistons into LS Motor Question!
- help me with my check engine problems....................
- I was bored and i did a little Photoshop to my hopptie!
- NEED REAL HELP
- 1993 Acura Integra gs Core Support question?
- cluster/climate control/tailight went out
- crazy idea...
- valve adjustment spec?
- Factory Alarm Remote Replacment?
- fitting in
- driver side speakers dont work???
- DC Sports Short Ram Intake
- eibach ground coilover leaks
- Help, How to fill ABS reservior
- Koni Sport wit skunk2 springs or tein basic
- How to install strut bars and tie bars on Teg?
- ABS Light "2-1 Parking Brake"
- rear main seal plus other questions?
- CEL code 67 and ABS code 17
- HELP ME WITH THE RADIO....HERES THE #'S OF MA RADIO
- Need input
- Tried everything but cant figure it out
- b20z swap in 94 ls?
- new to this...please help me ....thanks for ur time
- 94 integra ls valve lash specs
- broken thermostat?
- new to these fourums and question
- DC2/I have a couple of problems here>>>
- BC spec 2 ON a 4door
- jdm foglight help
- Need Help with Gsr Ecu!!
- Fluid/Coolant Question
- black smoke when in vtec
- Brake Master Cylinder help
- SPAL door poppers install...help
- B18c SC ECU??
- Megan Drift Spec exhausts
- ls motor in gsr shell?
- TOP END!!
- IAT 70 celsius (too high??)
- How do you, prevent your car from being stolen?
- ac thermostat question / compressor not engaging
- Need suggestions on what to add to my new gsr
- quick question gsr swap driver mount
- White Integra GSR JDM front-end conversion
- shock help
- does anyone have the rota auto x?
- Teg lurching
- carbon fiber trunk lid for db1?
- itr jdm tranny question...
- blowing smoke
- b16 Teg, Some problems...
- rebuilding block
- 91 integra problem *update*
- Wats the name of this hose???
- Crank Pulley Tool NEEDED PLEASE HELP!!!
- How to remove a heater control panel?
- Repaint or time for some CF?
- Where is this oil comig from?
- picked her up yesterday
- Coolent Leaking *pics*
- throttle cable...
- difference between comptech intake for 94-99 and 00-01 gsr
- question, installed front lower tie bar and crossmember bar
- I need help with paint color
- oil in spark plug holes.. searched but still have ?
- msd plug wires
- b18a cam timing?
- Need New O2 Sensor?
- ITR headers on a DA9
- Do I have to resurface my flywheel when I replace my clutch???
- Fuel pump hot wire?
- DA front emblem question
- high flow cat
- Helms manual
- I am idling really hi ...good/bad?
- the crank
- engine bay wire harness diagram?
- recaro seat
- Some wierd noises from my 95 ls teggie..
- T3 Air Research turbo...Good Deal?
- ????? About using OEM glass in CarbonFiber Hatch for DC2
- NGK ZFR5FGP Plugs in 94 LS?
- Climate control removal
- Hid question with TSX retrofit
- paint color on my rota boosts on my integra
- H22A and DC2/DC4 Chassis Q?s Newbs just read, Dont post. Intelligent Posts Only!!!
- which one would be better?
- Im new here ,cylinder 1 not working
- custom cabin filter
- DIY shock install
- how do i remove my fuel pump
- DEL SOL SEATS IN A DA9
- Rear Swaybar install problem.
- ecu pins
- starter problems?????????????????????
- 2nd gear crunch noise
- can anyone show me an o2 oxygen sensor chart or diagram?
- pr4 mugen chip install?
- Which Spark Plugs to Use for 95 GSR
- Stripped Spark Plug threads for Cylinder #4
- jdm headlight wire harness & side skirt bolts wanted
- Rebuilding block or buy a new one?
- Acura Integra
- help! FITV question
- 96 GSR 2nd gear problem.
- No spark, no what?
- tach goes all over
- New bumper from the dealer
- running rich
- Debadging - most effective ways?
- Signs of fuel pump needing replacement
- Installed new s-techs but need help.
- clutch pedel....
- ac problem noise
- p30 auto to a manual?/(RP18?)
- LS wont start but will crank
- New Here
- itr tb gasket question
- Are there any Meets near LA, CA?
- how to clean IAB soleniod filter
- new exhaust!!
- Where to get NEW jdm honda parts?
- ecu and motor question
- loss of hp in high rpm on b20b with LS tranni (has issues)
- Head Choices
- Help guys...Car wont start
- Might leave my 666 Integra...
- what size socket to use for spark plug removal
- Check engine light
- split timing belt car won't start need some help!!!
- RS*R Sport Spring, Any Good?
- Steering stiffener
- --need help--
- axles.... please help ...
- GROUND PROBLEM
- P/S Question!
- piston not working DA!!! HELP!!!
- might have spun a bearing
- roof cut for sunroof
- need quick answer
- Sterring Bushing
- Type-R Civic B16b Pistons In GS-R
- my shift knob sucks, did i do it wrong?
- Two quick questions for dc2 owners
- DC Sports Header & Catback, Random Tech Hi-flow Cat = LOUD
