View Full Version : Acura Integra
- Redlined car, now it won't start ! Possible bent valve?
- Wanted... LS Knowledge NA or TURBO
- DOES ANYONE KNOW WHICH EXHUAST IS GOOD WITH PERFORMANCE AND QUIET???????????????????
- need help car wont go pass 7200
- Spark plug cover!!
- will either of these rims fit!?!
- hit the rev limiter a few times, now car idling low
- how much PS fluid?
- Hasport Press Release - Replacement mounts for 90-93 Integra
- garrett t3/t04 TD06 turbo any good for 94 integra gsr?
- 01 GSR ABS Question
- Just got my 95 gsr!:) First Integra
- where can i order yakima rack for my 4 door integra???
- those who have skunk2 inatke manifolds on there LS b18b what kind of gains did you get??
- 95 gsr...What should I do....I already searched and didnt find anything useful, any info is apprecia
- Integra Stages - What does each stage consist of on car?
- B18B1 w/vtec Head Vs. B18C1 Vs. K20A2- Boosting Low/High Compression - Need All Opinions
- air conditioner a/c recharge. .... NOT WORKING :(
- Suspension decisions...need opinions
- upper and lower hose cold overheating?????
- How do you take off rear hatch? 91' teg
- Thieves @ a hip-hop show??? Who knew?
- itr cams question??????
- Radiator and A/C fan dont work
- Turbo delima.....?
- JDM Lips
- will 94 head light internals fit in 98 head lights?
- 96 Integra clutch pedal rattle.
- b20 head with b18 block???
- cel code #22?
- ys1 trans
- Defi gauge wiring
- can remote starting stick shift mess up clutch? read for more details...
- My 1996 B16 GSR
- pacesetter headers
- Swapable parts - models and years
- gsr master cylinder question...differences between years
- help with a brake problem (tricky)
- Replacing INTAKE MANI's on a GSR??
- daily driven gsr
- 94 GSR hit by tree! :(
- ABS Light On
- Blown Struts?
- Integra hatch spoiler
- anyone knows how to take the center consol off
- HELP! How to install sunroof in dc2 !?!
- 93 DA vtec build on stock motor or swap question
- Metal shavings on spark plugs !?!
- 4 door GSR Hood question...
- H&R 1.8in lowering springs on DA
- compression question???
- HAHA turbonator is a joke!!!!
- I AM NEW TO TEG FAMILY
- entering the Honda world
- HELP!!!!!!!!!! JDM TEG STOLEN AT CSCS AUG 11th :(
- The best headers for a gsr?
- what rims resemble jdm itr 5 lug?
- JDM DA Headlight light output
- full tune up and still misfiring...please read
- valve cover difference?
- Cant seem to shake code 10...IAT
- how to tell skunk2 cams from other..
- Hi, Im new, Welcome me to HT
- The best place to buy and swap motor, in L.A
- DA JDM B20 IM NEW TO HONDA TECH
- which cams do i have?!?!?!? Pr3
- Failed Smog in CA. NOx was too high along with HC's
- STARTING PROBLEMS
- project question
- problem with b18C1 motor
- 97 GSR transmission whirring noise 1st, 3rd, 5th gears
- Major Problems with my 90 LS auto, help me out!
- Throttle Lag - Low RPM Acceleration - Help?
- driver side axle again!
- blox LCA's
- Not the average no start issue
- UCA Ingalls camber kit with balljoint problems
- ground control sleeves, which are front whcih are rear??a
- HOW TO SET TPS (THROTTLE POSITION SENSOR)
- 91 da value
- starting issues
- Check engine light and oil light not working.... HELP ME aaaahhhhhhhh!!!!!!
- Pics of my teg after the rebuild ;)
- I dont know where the other end of this hose goes can U help me pics inside
- what do you
- gsr vs. type R
- differences in brake boosters and cylinders
- need help with cluster
- 94rs made into a beautiful type r....MUST C 2 BELIEVE!!!!!!!
- 94 and 98 fender the same?
- acceleration vibration...intermediate shaft?
- b18c1 rebuild help
- rattling
- whats the difference?? itr tailights and usdm tailights..
- Front wiper removal
- Weird electical problem
- Which integra rims are the lightest?
- b20 piston help
- bad ecu?
- for those with ecu knowledge "mugen spec" ecu responsible for bad mpg?
- Fake catwhat will
- 94 champ white teg finished complete with the rear bumper on!!
- air conditioning belt issue
- Exhausts
- Alternator belt squeals!
- I read and looked up ebay turbos
- Neutral Safety switch location on a DA
- Springs for Integra????
- Stereo Power Cord Broke
- smoke out of exaust
- my DA needs help?
- oil in cylinder 4
- How do i know...???
- Need help diagnosing my DA
- Help: Dizzy question for B18b1 Integra
- 92 integra gsr converter to b16 jdm.. fuel trouble.smog trouble
- Stupid noob question I'm sure
- ANYONE KNOW WHERE TO ORIGINAL HONDA REAR WINDOW VISORS FOR DA6 OR DB8
- 95 integra struts & 95 accord struts?!
- 1990 Power steering pump fit on a 1993 integra ?
- NEED HELP! Need new exhaust on 96 Integra.
- Opinions needed on exhaust too
- 90 Da TeggY w/ Mods For TraDe
- acura Emblem
- b17 throttle body question
- Need help identifying an OEM part!
- HELP!!!! VERY HIGH IDLE WHEN CAR IS COLD!
- oil light on! plz help!
- 2.5" Cat on a 2.25" Invidia Exhaust...????
- timing belt kit.
- DC Sports 1 piece ceramic header install question
- need help with a motor ?
- benefits with running skunk2 manifold and 70mm t/b on my ls integ??
- WHo would Win 96 GSR teg Or 97 vtec Prelude
- problem removing head
- D16A1 what modifications are possible and recommended
- Supra
- tranny seal help
- Awesome integra video with Michael J Fox
- FS 97 GSR
- Flipped my gsr.....
- Opinions wanted: what are a set of gsr blades worth
- '95 Integra LS troubles.
- Jdm integra guage cluster????
- What transmission.
- any one know what relay this is?
- deciding on front lip for jdm bumper (DC2)
- Catalytic Converter
- NOOBIE HERE
- vtec help!!! ECT help!!
- Question about ITR center caps.
- A spring on wheel stud???
- No Spark...Need Help (DC2)
- can i use the injectors without flooding my motor?
- Help! What FPR setting for LS Block, CRV Head Non turbo and turbo?
- WTB ASAP blown gsr/itr transmission
- JDM Foglight harness question..
- Exhausts!!!!
- 1994 acura integra: hydraulic to cable conversion help.
- rpms keeps on jumping....don't know what to do....please help!!!
- Civic radiator in Integra need help!!!
- Blox camshafts tuner Series B idle quality
- What's dripping from under my hood?
- confused bout my cluster?????
- need help identifying a transmission
- HOW TO REPLACE THE HEATER CORE
- can you rewire a obd0 dizzy to obd1??
- AC compressor belt question?? will B18b belt work on a d15b7??
- upgraded valvetrain and higher rpms
- Where to buy rubber moldings?
- Bumper Foglights on 90-91 DA
- CEL turns on after 30 mins of driving. Turns off after restart.
- ticking from engine?
- Anyone have a DYI for energy suspension?
- 1992 Integra won't start in the rain.
- Water in hatch
- need help! B18b in 95' gsr
- tranny seal???
- Weird break problem
- Lowering a 92 DA
- 90 LS car wont start?????
- valve cover question?
- buddy club vs. gt3's
- IDENTIFYthis plz
- car not starting after tune up
- WS2 Exhaust running very hot
- break problem?:-/
- Can you fill transmission with fluid trough vss hole?
- filling transmission with fluid through vss hole??
- got a check engine light what does this code mean
- Engine mount question
- Spoon steering wheel, no horn??? HELP!!!
- need help taking out my antenna with motor?
- EDM DA???
- Crank/Conrod Question, Will B18C Rods fit the LS Crank?
- Clutch engages and disengages VERY low....
- HELP! JDM HEADLIGHT QUESTION
- ctr intake and itr exhaust cam...95 gsr
- Oil Leak
- problem with a 90-93 integra
- B16 Teg, Look Here, Smoking
- turboing a b16a in a da
- ls/vtec help
- PIC REQUEST: DC Cluster into DA (searched but they are all red x's)
- problems when accelerating
- 1994 CHAMP WHITE TEG WITH ALL THE PARTS ON!! FINISHED
- 99 GSR Help
- JDM VS USDM Throttle Body
- stolen Integra
- 98 gsr
- CCW Classics on DC's??? Pics Welcomed
- black halo's?
- engine swap
- 92 integra shock
- No ignition reference pulse code 21, how do I fix?
- heater/ac blower still not working!!
- 97 DC2 b20 swap- PROBLEM!
- selling my teg :(
- need oem parts
- How to install one piece headlights??
- koyo radiator
- injector cleaning
- Help!!!Broke something on valve cover and dont know if its bad or not...
- Need your car for TV show "The Shield" pays $$$$
- Integra Broke Down
- will 14" steelies fit 94 gsr
- is there any benefit
- D16 94 integra
- Tach freaking out
- in need of a dc2 shell
- 98 integra sedan with unbalanced wheels, brakes or wheel bearings?
- Help me pass emissions please
- whcih one is best... n/a, s/c, or turbo?
- Whistling sound when accelerating.... vacuum leak???
- 90 integra
- 1992 gs suspension mods question
- tranny dilemma
- what is actually needed for a 98 integra front oem conversion from a 94 one?
- B18a1 with throttle body
- 91 integra EBRAKE problems
- front end cnvrsn on 91' teg
- Need help with idle problem.
- any pictures of integra with s2000 antenna??
- where to get cheap itr lip?
- Gas Mileage ?
- ITR/GSR Differences?
- erl 5 main girdle
- engine help
- Will this fit??????????????????????????
