View Full Version : Acura Integra
- timing belt cover off, LEGAL or NOT?
- will a '92-93 B17 GSR Intake Manifold fit a b18c GSR motor?
- GSR Vtec Plaque
- CTR cams in GSR? What power gains?
- how to install a injector resistor from a 92 integ on to a 93 integ
- Which would you go with?
- Changing Transmission fluid
- question about VAFC
- Wheel pictures
- main parts 4 t-bo charged Integ
- STR Cam Seal... where to get
- Wilwood brakes
- Is it possible for your car to go back to stock with parts on???
- Aerospeed floor bars - Any good?
- cheap vafc
- Does anyone know a good wheel/rim repair shop in Houston??
- need help with my nitrous
- X-mas Silverstars for my sister's GS-R...
- what parts i need when i get a b18c5 into a 92 2dr teg ls?
- Question about OBD2 to OBD1
- o2 sensor wire color?
- GSR's and aftermarket headers, etc
- Need Tranny For B18B Swap
- My dilemma and the search for sanity
- 00-01 GSR header on an LS?
- Mounts...Engine or Transmission? .....:::: Integra ::::.....
- got my LS head last night
- itr shocks and springs, but without the tops? would it fit onto my ls?
- Gsr T-Body Swap Question
- Spoon throttle Body
- high idle when starting the car cold
- Has anyone had service done on their Koni's? at how many miles?
- skunk2 intake manifold on b18a
- civic koni yellows on integra?
- MaH b0i's Ls/Vt3k is GONE!
- How do you guys estimate time??
- 96 LS MT vs 93 Prelude Si AT
- almost finished with motor and guess what i had to go and do.......
- Integra center console
- Who wants to hear me hit vtec? Host my vid please?
- A test for VTEC!!!
- neuspeed springs and koni yellow
- 94-01 DC4 w/ TE-37's
- Some stock Integra LS times and such
- brake fluid
- dyno in N NJ
- New NGK SparkPLugs go bad? now my engine grumbles... why me why?
- ITR, LS and GSR gear ratios?? which are shorter in order????FAST!!!!
- Spark Plug Wire HELP
- lightest 15" rim for cheap
- Type R valve springs and retainers into LS head
- Replacing Oil Filter w/out going under
- rota
- what other Honda springs can I use on 1990 Integra?
- Removing carpet on G2 Teg - Need Help!
- Will a 89 crx si driverside axle fit a 90 civic hatch base model?
- Predicament
- anyone wants to donate their leftover bottle of transparent amber paint?
- help, one of my lugs is bent and the other is stripped....
- how much $$$ is big turbo build on average?
- will g3 shocks and coilovers fit a g2?? i searched!
- will 1997 CRV exhaust manifold work in a 1994 Integra?
- will 1990 tranny syncro's work in a hydro tranny?
- E-brake HELP!
- Flood Damage to Engine...Please Help!
- which drop in filter do u guys recommend?
- car smog in socal...?
- Dyno results/ maniflod vacum line to 4 butterfly valves
- Will 195/65/15 fit OK .. '98 GSR
- g2 integra, more than one teal/greenish color?
- anyone know the port size to the skunk IM?
- Can someone please check a VIN for me?
- anybody know where to get...
- custom manual steering rack from england
- Question about cats, 02 sensors, and check engine light
- skunk2 manifold? weight? difference to the gsr mani?
- ne from ohio?
- Tranny Compatibility
- gsrb18c obd1 harness work for 97 & up obd2 motors
- 84mm Bore on a b18c bottem end
- why noone ever put CRV tranny into Integra?
- how to make tranny stronger
- Sparco Sprint or Speed for an Integra?
- Problems with windshield defroster
- Need verification: ITR tranny only needs Honda MTF?
- gs-r midpipe length
- Clutch Net blowning trannies
- b16 intake on a GSR with skunk2 mainfold
- Question: How to replace your fuel filter on a G3 teg
- Hankook W400 tires
- Weight of Stock Integra RS?
- 89 CRX rims on Integra
- what else should i do "while im in there"
- 6 puck clutch disc
- skunk ti-retainers
- rebuilt motor idle problem?
- would you?
- check engine light
- does 96 gsr head fit 2001 type r bottom end block?
- quarter mile times...
- Anyone have mint GSR Blade set for sale?
- Anyone have those new tokico coil-overs?
- neon radiator
- JRSC movies
- Rattle coming from the heater/blower motor behind the glovebox
- Check engine light....
- Coupe & Sedan = Same Doors?
- best compression for all motor gsr?
- chassis codes
- 92 gs-r worth fixing? check out the pix...
- RSX seats
- I need to know what is the best LSD for me to buy for my 99 GSR with a b16 trans???
- Where to get alarm w/ a pager?!?!
- Dual nitrous setup?
- New Lightweight wheel offering. Pics Inside---->
- Tires
- Electrical Problen on my GSR Please Help!
- FOR SALE: 98 GSR!! *i can't post in classifieds, it won't let me...*
- Wheels for sale
- How does this sound like a 3 year modification plan?
- Magnetic Oil PLug Gasket
- 32-40 Wheel Offset on 90 integra? Anyone help?
- Maybe I can get help here...(Mods, please delete if deemed insuitable for "Integra Fourm"
- Downshifting
- B18C rebuild
- took my block apart today
- will my tires Rub?
- GS-R OWNERS????????
- RedLine but No Speed!!!!!!
- Header Suggestions?
- mobil 1 15w50 users help????
- anyone know places that will smog with swap in LA,CA area.. please pm if you know
- aem shortram question
- oem fog lights.
- clutch/tranny gurus, please check in
- best place to find intake filters?
- Which shocks?
- one more time,heater probs.
- thinking of swappign a h22a into a integra rs good idea?
- DRAG turbo kit differences
- Hondata ECU compatibility ?'s
- JUN Lightweight or Ultra Lightwieght Flywheel
- Got a new integra, any ideas on what to do first?
- my gsR just hit 90k guys how long before timing belt will go?
- wtb--acura integra headlights
- itr rear sway bar on DA hybird suspension?
- abs problem..
- Need to know the total weight of B16A engine?.
- LS turbo install, wont start
- check out this turbo setup its crazy
- drop zone coilovers???
- racing harness's
- Windshield wiper suggestions?
- gsr ecu?
- Center Console
- got my short block in today
- JDM CF hood? which one?
- 2 part DIY question, don't want to pay a dealer to fix it.
- Buying some winter wheels/tires
- Teg B18c Swap
- Does anyone know where I might find a stock ADRIATIC BLUE GSR SEDAN?
- bmw hid kit fitted into integra
- LS intake manifold on GSR head
- Thanks for the advice
- If my motor hydrolocks, will I know it?
- F@ck Thieves
- Help me decide on my next move
- ECU and battery question..
- GSR intake manifild modifications
- Integra radio??
- Flywheel question...
- Bulb Question...
- ITR Lip for Integras $200
- Tire Pressure for Oversteer/Neutral
- will jdm recaros type r ft and jdm rear seats fit in a 92 intergra 2dr???
- Icebox Dyno?
- OBD 1 Conversion for my GS_R
- Another ITR Sway Bar thread
- interior question?
- anyone running crower 403 LS (B18A/B) NON VTEC 62403
- anybody have videos of their cars or races or any kind of videos to post...... post them here.....
- Upgraded swaybar and bushings on GSR...
- Mounting Type R Lip
- Could someone please check the following VIN for me?
- Anyone know a good,expensive body shop in Western North Carolina, northern SC?
- where can i rent a cherrypicker?
- vtec at 5600 is it to late for gsr on stock cams?
- neuspeed coil overs vs tein ss coil overs
- stripped strut bar bolt, how do i take it out?
- "WTB:" Does anyone have a K&N air filter for stock airbox?
- JRSC users..w/ Nitrous
- bent my rim
- What looks awkward in this picture?
- Group Buy...
- Rate my Integra
- eare there any shops in CA that carry MA AUDIO?
- Question for Hardcore JDM heads...
- Integra LS Compared to Prelude SI
- Need info on ECU's
- San Diego I Need Your Help ....
- 190 WHP
- my blade wheel has curb marks..need help.
- GSR v-tec/tranny question
- Reving to idle back to reving?
- dyno of my gsr 154.9hp/114.9 tq with aem cai, tanabe rm
- Newbie?
- 10W-40 oil OK in GSR?
- For people who did seat swaps, What's wrong with these pictures? 94-96 seats/panels different from
- Airbag Block Tray On Ebay
- projector lamps on a g2
- Review: stock gs-r manifold
- New with integra
- problem with my abs
- how to: wire a jdm type r gauge cluster in a gsr or type r
- Compression Test Results - What do you think?
- got that 94 GSR... :)
- rearview mirror problem
- AEM cam gears HELP
- Value of Complete LS engine
- what should I do w/ my front end? (it got scraped up)
- anybody got a dyno comparision on the Greddy Header for Gs-R, or do you know if i can strap on a 2.5
- need serious help with ignition (all please look)
- where to put vafc?
- easy ? about camber. please answer
- What bolt on's can you put on a LS to stay or beat a GSR??
- Steering wheel removal - How To?
- stock gsr 1/4 mile times
- Stock spioler plugs?
- SpOon Mirrors
- Clutch reservoir dry, do I need to bleed?
- AGX fitment question...
- Any supercharged integras out therE?
- 94 teg Engine Problem...Need help fast!
- piston slap
- 90integ.. suspension question (interchangable suspensions?)
- Anyone have to do this before?..HELP!!
- Great Header Test?
- Injectors?
- AT to MT conversion for 95 teg RS
- Painting OEM side molding...
- What to do...
- Ideal Cams ??
- How hard is it to fit an Optima battery in a '94+ Teg?
- greddy
- 1993 Integra LS Problem..Please Help..
- DYNO'd my car!!! I need your feedback...
- DYNO'd my Car!!!!! I need your feedback.
- Few questions about air con, refilling, weight etc.
