View Full Version : Acura Integra
- Whats the difference between Redline MT-90 and 75W90 gear oil?
- gsr manifold secondary. picture inside
- The Apexi NOIR?
- is this a good combo?????
- Squeel when I launch...
- Clutch slipping?
- What type of fluid to use in my 94 GS-R manual tranny????
- Car wont start.
- Can/will Z3 seats fit?
- 94-97front ends
- 2dr moonroof motor on 4dr?
- will a da LS header fit a dc2 LS?
- where to get INNOVATIVE BILLET MOTOR MOUNTS?
- 1987 acura integra...what turbo manifold?
- Will it work if i do this fron non vtec to vtec ?
- Need opinions
- which tranny is this
- E-brake handle.. the silver part, how do u make it fresh again if its chipped?
- gsr wiring help
- will dc sport header for DA fit a DC?
- New bumper on the DA
- bumper lenses dont work
- Wheel Bearing ?????
- 99 radio/cd deck into 95?
- replacing rear pads ono 95 integra LS
- How to identify a motor swap (NOT a n00b thread!)
- springs or coilovers
- ITR or Aftermarket Valveterain? -- for boost...
- trying to decide, Skunk2 coilover sleeves or Pro-Kit springs?
- JDM catalytic converter?
- Replace t-belt and water pump w/engine in or out?
- anybody knows if a 92-95civic fork will fit on a 90-93 integra?
- What is this sensor?
- dont laugh
- Suspension Techniques
- installing exhaust...need help
- ctr crank pulley question
- Online stores that sell studs
- Battery Relocation.......
- Best clutch
- gsr blades anyone selling?
- Where do I find the rest of the bumper?
- what o2 sensor??
- Front lower arm bolt length
- radiator mounting
- what headgasket?
- DC4 exhaust setup
- Check Engine light
- Evap plumbing?
- *searched* civic ex wiring harness to a B18C????
- im going to post it here(clutch)
- Rebuild GSR Transmission???
- suspension question
- S2000 antenna installation?
- gsr engine noise(vid)
- 94-97 Rubber Seal Install on VIS Hood???
- Putting a moonroof on a non-moonroof integra??
- Timing Belt
- bolting rotor to hub
- type r head or b16
- just wondering, switching manifolds on ls head
- trying to convert ls to vtec
- cams?
- Any Poorman's Type R's Out there??
- 92 integra KOITO bumper fog lamps.....searched
- 90-93 ls driver side mount same as 94+?? block mounting stud??
- front sway bar removal
- Fuel cut off problem
- cable to hydro conversion on DA??????
- ls-vtec question
- tranny recomendations?
- nitrous help asap
- HID already out??
- Bragging..... Eat it out bitches.
- HELP CAR WONT START AFTER HEAD SWAP PLEASE!!!!!!!!!!
- obd1 computer
- how do i connect this to headlight ?
- YS1 DA tranny?
- obd2 to obd1
- ls/vtec conversion kits
- Do these rims look alike?
- Just another honda radio code help thread
- 90 integra b20 swap
- Will a OBD0 b16a dizzy work on a OBD0 b18a?
- JP body kit
- DIY: Quick Release C-Pillar Bar
- What is a retrofit?
- wiring for the radio harness
- no vtec = more torque?
- HID Retrofit Weird Question. Which Bulbs?
- where can you buy oem gsr piston rings???
- Back seat hole on 3rd gen sedan
- Are there upgrades available to make an auto hold up to a turbo? What will stock hold?
- Questions about my LS
- Replacing Sideview Mirror Glass
- Where to buy a EVO 2 Flange Gasket
- Espelir JGT500 vs. DC Sports Exhaust Systems
- will the type R Ring Gear fit on the LS?
- Please look at picture and help!!
- slappin heads
- Daily driven.ITB or IM?
- Clubs can get free show space
- Is there anyway to make my CF like new again??....or is it done for....
- help on window
- Does my teg have vtec?
- Shock Dilemma - bumpy city streets
- Need help with people who have OEM DC2 car covers
- H.I.D. guys, one of lights is out, where do I start looking?
- When did you change your timing belt?
- Tuning in New England for acura integra (crome, hondata)
- Does anyone know whats the problem is ?
- LS motor shut down need help finding the problem
- Changing oil to soon........
- 94 usdm GSR shell with JDM GSR swaped in....different wiring...problems
- Ebay item legit?
- Anyone remember the thread to roll back your OD? (not for illegal purposes)
- Whats the difference btw these two NGK Iridium Spark Plugs??
- Low beam headlight bulbs 9005 or 9006???
- Another car won't start thread. Stock '97 GSR Have fuel/no spark/replaced coil
- where do these lines go on my b18b1?
- exhaust pics..
- Street bike exhaust???
- do the rockers on an ls b18b motor have to be in a specific cylinder?
- Newbie with a bit of a problem
- Evo Magazine (UK) names Integra Type R "greatest front-drive car ever"
- header for a 93
- Rev probelm
- JUN 421 race headers on a 90 Ls
- mud guard question
- OBD2b to OBD1 conversion on 2000 gsr...IAB...not working....
- skunk2
- gsr engine rebuilt, it run then when stall, it wont start again...
- gsr cat
- b16 vs gsr head on ls buttom end
- painted engine bay
- this guy is crazy
- stock airbox question
- what headers will fit
- searches everywhere please help heater problems!!!!!!
- just picked it up for $1400
- Engine specs and codes
- turbo ????
- Light weight fly wheel anyone??
- help head swap no start
- clicking sound in 98 integra
- painted the LS mesh gold
- installing exhaust? hard? easy?
- LS distibutor doesnt work after being on a b16 head
- Suggestions on what to look for when buying a car
- Spun bearing
- dc2 power folding mirrors ??????s
- quick question?
- gsr driveshaft splines question will any other hondas fit?
- will this fit
- the new guy
- Question Skunk2 intake manifold in a 97 gsr
- Will 14" honda steelies fit a DC2 GSR?
- crome
- a quick question about map sensor
- FINALY GOT MY DA
- VTEC is nuts!
- replacing cracked foglight
- 0bd0,1,2 ls motors?
- help
- need help asap!!!
- b18b1 turbo
- 94 GSR slight grind going into 3rd gear above 4,000 rpm.....HELP!!!!!!!!!!!
- My car 1998 ITR
- Prelude brakes on a 3rd gen Teg
- Have some motor choices here...
- VIN on the Engine Block
- B20VTEC+HEADERS+FULL PIPING=???
- 23mm sway bar
- voltage stabilizer
- High mileage value rebuild? lol
- Fuel problems, need help
- 90-93 cable trans mount same as 94+ hydraulic mount??
- how many belts does my b18 non vtech has??
- GSR bolt kit?
- HELP! check engine light not working or unable to check cel codes..?
- My da
- Alarm...
- Windshield replacment question
- Upper control arm install on DC2, any suggestions?
- Fuel pressure setting?
- JDM front end conversion??
- DA 1.5 in drop
- Need help on my b18c1 head ??? What is better???Skunk2 or Omnipower???
- C pillar bar [quick release]?
- Does Amperage determine starting power?
- I NEED HELP PEOPLE!!! B16 SWAP INTO A 94 INTEGRA
- My radio antenna
- Finished auto to manual - Now for problem solving...
- brakes
- crank pulley question
- skunk 2 intake question
- IS THIS A GOOD BUY? I NEED HELP BAD PPL
- turbo dip stick?
- F&@*#&$^ WHEEL BEARINGS!!! where to buy, how to fix?
- Rain=car died???
- Broken Power Door Locks!?!?
- Night shot of my 4-dr
- Brake Light Problem
- newbie to b-series. q's
- The rain is coming!!!!!!!!!!
- rsr exhaust???fitment question DC2
- looking for more horsepower...92 integra gs-r
- Question About 90 Integra Engine!
- anyone with boosted LS... need opinions!
- turbo my 91 LS
- Anyone have a T3 super 60 turbo on their GSR and in the Chicagoland area?
- convert 94 to 98 front bumper ?
- why are these cheap
- difference between 2dr 4 dr front bumper 94-97 teg?
- stock(factory), car quest axles
- 90 LS Automatic Tranny problem ?
- inspection??
- need help
- quick question
- DOES REPLACING YOUR ANTENNA WITH A SHARK ATTACK ANTENNA SAVE WEIGHT?
- b16a motor build
- bad piston rings?
- DIY shaving side mouldings - WRITE UP
- typer with gsr edelbrock header and gsr comptech exhaust. which cat?
- rs prop vavle
- Help on getting going...
- gsr belt
- Whistle sound when shifting...
- yellow high beams for 97 teg......where????
- gas
- why the F do my vavle stem keep blowing?
- b18b vrs b18a tranny parts different?
- how do you reroute the hood latch cable ?
- Got spark and fuel- won't start
- 94-97 Fogs on a 98 LS
- NEED HELP PULLING MOTOR....
- STOLEN INTEGRA PLEASE HELP!
- JDM Visor cleaning
- A 96 integra antenna into a da?
- What does a Vafc do?
- Code 91, what the hell is malfuctioning?
- What brand cat for direct bolt on?
- skunk2 coilover adjustment SEARCHED
- type r cams
- gsr swap in a da integra
- Need a wiring genius for a basically stock DA
- Interior Lights & TailLights Aren't Working
- Over-revved and don't know what to expect..
- cel 70 automatic transaxle
- HELP what bolts to use
