View Full Version : Acura Integra
- window off track
- type R motor on a Ls tranny
- 95 gsr ~I am on a monthly budget and this will be my first build~
- GSR Heating problem!!Help!
- help please gsr wont rev pass 4500
- downpipe question
- need help installing recaros
- k20 into a da?
- Track ?
- stuck valve cover nut!!!
- Quick Suspension Question
- Blinkers act differently.
- quick question
- PERFORMANCE QUESTIONS
- Sticking a Turbo in my Acura
- Bleeding brakes on a GSR?!
- Looking to BUY DISTRIBUTOR
- Could it be a spun bearing or something else?
- ?$b17$?
- OFFICIAL 90-93 Integra bouncing tach,rear defrost, ICU, wipers, electrical problems Thread
- Which radiator for 97 GSR
- Rear Seat Carpet Attachment Caps
- B18C Type R into LS Chassis, SWAPPING MOTORS AGAIN!
- GS-R heat shield with JDM Type-R 4-1 header?
- KEEP GOING THROUGH MAP SENSORS!!!!!!!!!! ARGH@@#@$#%#
- Quick compression test question.....
- Acura Integra - ITR & RS.LS.GSR - Side Molding - Body Work or Stock?
- air/fuel question
- p61
- help with Timing please watch video!
- 96 integra lx engine shut off
- Gutting the insides!!!
- HELP!!! code 43
- I need to know the size of this screw...
- Rebuild questions
- ITR Sway, Subframe Brace?
- 94 DB8 build...any suggestions
- hood
- SEARCH FAILED !!! air conditioning.... please help...
- Check engine light after oil change
- Oil Filter question
- Boost question
- identify this please (pic)
- can there be a 6th gear in an integra?
- ls vtec build
- maa shitt..
- Pricing on a B18a
- swapping b20b into da
- axle same? for gs/ls/gsr?
- Problem with Distributor Cap/Spark Plug Wires
- how much would a build cost?
- Coolant Leak
- Motor Noises
- Lets get some pics of clean A$$ DA's
- Brake Light problem...
- weird motor sound please help!
- Cable tranny, throw out bearing spring
- black smoke not the usual
- pics of my gs not an r
- Help please Size of O2 sensor in cat 1997 LS *ASAP* Please
- sidemarkers
- Valve Cover
- Type R LCAs
- obd2 gsr into obd1 ls
- <<<<<<<wtb!!!97 rs door wires with master plug...asap!! los angeles area..>&
- VAFC SETTINGS. posted.
- Goodbye Acura, Hello Honda
- what is better an ls vtec or gsr???
- hks turbo timer not working
- ITR SUSPENSION SWAP TO A DA CHASIS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- VAFC2 questions! HELP!
- what is the purpose of a bigger throttle body?
- alignment on 92 DA
- Anyone have a JDM front with yellow HIDs
- What color for DA
- obd2a to obd1 conversion harness
- Replacing cam shafts
- doing a swap and i have an engine mount question
- Cigarette lighter / Ash Tray Light Bulb?
- Help check engine 10
- QUICK STUPID QUESTION
- misfiring out of nowhere..
- 94 LS 4DR DO i NEED ANY MENDREL BEND PIPING?
- How do you adjust a fuel pressure regulator?
- Need help
- The biggest OEM Honda brake upgrade ever - Custom mounted Acura RL calipers
- clicking noise when changing throttle position
- please post pics of blue integra gsr engine bays
- Skunk2 Springs on DA
- need help wit my da!!!
- knock sensor for vtec
- tow hooks
- WIll a rack-n-pinion from a dc2 bolt up on an eg hatch????lmk asap
- Red light ticket (not tech related, i know)
- is this bad
- injector wires
- Top Dead Center meet in SC,
- 92 Integra condensor fan?
- 70mm throttle body gasket
- b20 vtec or ls vtec?
- Can someone list all the parts of my suspension update?
- Question about gsr intake manifold
- What is forged internals?
- dc2 rear foglamp question
- Convert to OBD1? or Swap oil pumps!?!?
- i want to turbo my integra ls
- beeping noise from the dash, not the stereo... what is it?
- Intake
- so i finally snapped a couple of pics of my gsr
- RHD guys. Just about to start my conversion.
- engine starting problems!
- gsr engine wiring harness diagrams?
- low idle
- 1990 Integra gas pedal question?
- BAD, BAD, BAD gas mileage. Perfect E-test?!?!?!
- Best CF HOOD for Turbo DC2
- What Centercaps Fit on Fat Fives?
- corner lights
- No oil on dip stick!
- motor oil for tranny ???
- Quick Should i but it question
- ~ My 98 gsr build.. looking for suggestions and opinions! ~
- speed sensor
- anyone knows how to install optional kit for 4dr integra?
- need help wont stay running problem PLZ HELP N LOOK N BUMP
- LIps on DA??? accord?
- ls skunk 2 manifold on b16 head
- Buddy Club Spec 2 on ls?
- gsr seats
- 1991 DA9 Brakelights won't turn off.
- Take out gsr's with no problem
- skunk2 sleeves and tokico blues
- Fuel pressure question
- How much can I sell my 2001 Integra LS with a salvage title?
- quick body part question
- 94 teg a/c where is the high or hot side?
- need help with alarm quick reply plz
- what cams to run with the b20
- How exactly does tuning work???
- Which set of tire should I get??
- Should I get my car tuned???
- GSR engine harness on LS Engine???
- Tuning??????????????????????????
- Eibach Race Springs
- is 900$ a good deal for a 95 b18b1 obd1 complete swap?
- best suspension setup (dropped daily driver)
- help with 2000 gsr
- axle DIY link anybody?
- head stud question
- b20b pistons.....ur input
- b16 . help!! i got problems
- b16 . help!!
- DC SPORTS 4-1 DENT HEADERS HOW BAD IS IT?
- Car wont hold idle after running it hard
- 91 teg wayy off time
- Mufflers!!
- power steering issues
- a/c compressor
- I get more break dust in the rear ???
- tach issue on a 98 integra
- integra whistling???
- GSR PCV Valve Relocation?
- Beef up the Automatic? Please help
- maint. required 10 flashes
- Another n00b....
- whats makes the acura integra so special!!!
- 90-91 integra axle question
- Tranny differences. OBD1 OBD2
- help me with my 95hatch/gsr.....knock sensor
- Full Tune Up
- Carbon fiber Hatch Question...... help needed
- Code #9 CYP - Cylinder sensor???
- How far could I push my turbo?
- Front bumper Support Q
- Rc 310cc Injestors in stock gsr
- Removing shifter cable on AT... help!
- change suspension myself?
- Car starts but dies out after engine is warm
- Brake breakdown...?
- Best clutch flywheel combo
- fourth cylinder not firing
- Should i buy 1yr used TEIN w/ coilover?
- Need advice
- Double check my rebuild parts list
- Where can i find the brightest light bulb?
- Quick vtec question
- Quick question
- Vtec engaging early compared to normal
- New Tires
- light bulb help
- transmission question
- Torque specs for 90-93 Integra help.
- ls turbo route
- b20 swap in progress
- Knock Sensor Question about Gsr in Ls
- B18B1+C1 Head Vs. B18C1 - 11:1 Compresson Turbo Setup - Need ALL Opinions
- Water Pump...HELPPPPP!!!!!
- 200hp+?
- Help with headlights
- PINGING HELP! GSR, B16A HEAD!
- need help on code 23/knock sensor
- 2000 Acura Integra GS/GS-R
- valve cover screw broke!!!!
- need help
- WHEELS!!!!!!!
- how can i tell if i have a bad ignitor or a bad icm
- will a vtec motor run on a nonvtec ecu?
- tire size opinion
- Oil light flash.
- B18b1 Vs B18b2
- steering wheel help
- EF pedal set into DA
- how long welded hairline crack on flange last?
- i need a PR3 ecu
- im new to H-T here are some pics of my DA
- Gears
- torque specs
- installed shift lite now dash lights and rear running lights dont work
- Civic radiator on a DC Integra
- I have yet to bounce off the rev limiter, is it there?
- car misfires... NEED HELP!
- I Need A New VTEC Head. Which One Should i buy?
- Integra gsr 00 brake light problem!!!!!!!! Pls help
- ABS Elimination Questions on 95 GSR
- Big Brake kit
- car wont start, cranks but wont turn over
- charcoal canister question for BAR
- integra front bumpers
- chipped ecu
- Do you think these are real?
- how should you break into new kyb gas shock.
- 94 Integra Driver Side Window Help
- HELP with this FIX IT ticket
- Bringing over a shell from Japan
- jdm obd2 ecu questions
- Is it worth putting money into this...
- cable clutch
- B18 GS swap to B16 Vtech Head
- NEED HELP IN MOUNT JOY!!
- valve lash for LS/Vtec with GSR cams
- Driveline
- 0db0 cnnverted to 0db1 prob wiht codes 1 and 4 crank angle
- I got a code 15 in my DA
- procharger for gsr
- hood conversion
- ATTN: JDM Front Guru's....Front grill clips?
- Taking a 2,000 mile trip, wondering about a tune-up before I go.
- CAMS for B18b2 DC4
- new car
