View Full Version : Acura Integra
- wtb:comptech icebox
- Engine Rattles..
- 98 Integra GSi Power Ouput Australia spec?
- which cams is better for GSR, USDM ITR or skunk 2 stage 1?
- New here.
- time slips for my teg what ya think?
- jus bought teg2
- how much does ur teg weigh?.........
- Need HID help, PLEASE!
- Removing the back seat as pertains to performance...
- Which vacuum line, when leaking, causes a loopy idle?
- Is 16lbs too much weight for a rim?
- ecu question
- Need some input on starting my motor, pics included...
- Help: Smog test
- 2.0 Liter gsr Dyno video
- best place to buy tein springs?
- B-Series Motors
- Went to the Track: SH*TTY TIMES!!!!
- Wiring harness on 92 gsr? Engine and Interior all in one??
- Throwout bearing NEED HELP ASAP
- stock GSR fuel pressure?
- what kinda honda rim is this?
- I need an edumacation on integras
- hydrolocked interga
- Rear Engine Cover Rubbing the Camshaft Sprockets. Acceptable?
- o2 sensor
- integra gsr
- How do you reset the maintence required light? (searched)
- finally got the koni yellows sp3's installed on the 00 gsr 4 dr
- my teggy got into a accident...
- New 99 ls teg...2 questions
- help, possible cef, kinda lonq, tech question though
- exhaust...just the muffler?
- Running w/o primary O2 on 99 GSR - smoke?
- Pics of my parts I installed. Fun and Longf day
- Couple new things on the teg
- Damn timing belt..
- Help!: How to Take Header Off
- Comptech Sway/Tie bar problem ~> Understeers again!!!!
- Where can i get a clutch in SoCal
- getting itr pistons on eagle rods?
- COLD AIR INTAKES
- how much?
- How lite can a DA be?
- jerk in engine, droping rpm's!! PLEASE HELP
- Tokico Illumina Coilovers BROKEN POPPED THROUGH HELP!
- 90 LS ECU?
- d1what would i need....
- how do you remove shock from the rear 2000 integra
- Gen2 idle air control valve cross reference
- Need part number or this part.
- b18b wiring harness help
- changin springs I NEED HELP!!!
- 90/ 93 hoods are they the same???
- RPM
- WTT: Rota Group N's w/tires for Circuit 8's w/tires in bronze
- Advice on mounting Azect SideSkirts
- ITB's on a daily driver?
- test drove 01 GSR...
- pep boys or oem head gasket
- TDC sensor
- engine coolant temp sensor.. could it cause major problems?
- Will a JDM cluster from a second gen Integra plug right into my USDM wiring harness?
- Radiator Over Flow Question
- MTF Question.
- AEM ram intake pics on 94-00 non vtec teggs
- Axel popping out from half shaft
- best swaybar for 95rs?
- prelude motor swap
- 60,000 mile maintence looking for suggestions
- Got some time slips tonight.
- Vtecb20coupe and Seth Scott known as Turbocivic5@hotmail.com..hard to deal with..
- turbo timers
- Brake Lines
- lsvtec lifespan
- Door Wiring Diagram
- Broken sensor..... what is it?
- race
- Thermal exhaust vs sp2 or ws2
- Where to refill manual tranny fluid??
- 93 ls motor and trans into a 97?
- Convertible Integra ?
- 98+ rear bumper bolt onto 94-97 integra?
- symptoms of leaking brake booster?
- To GSR Owners: Which one is a GSR shiftknob?
- PRIMER OVER PAINT
- clicking noise when brakes are applied...help
- Tranny problems
- change engine coolent and thermostat!
- I want pics of your TEGS!!!
- H&R Cup Kit?
- How do you adjust your parking brake?
- Caliper Bolt Question
- Daytime running lights_disconnect
- GSR use 87 oct?
- Broke the teg :( HELP!
- how shoud the spring perch on koni yellows on the rear be facing??
- What the hell is wronge with my car?
- B16 OIL PUMP
- Enkei RSF-2
- Carbon Fiber Air Intake
- Turbocharged GSR Tegs....With AC???
- half-shaft question: 90-93 the same as 94-2000?
- Rattle in first gear
- HELP! sir-g fog light install??
- new fuel upgrade
- Speed Sensor (code 17)
- V-Tec???
- Help, speedometer is going crazy!
- Comptech site address.
- OEM Side Skirts: 94-97 vs 98-01
- what shops in orange county california or socal installs superchargers ?
- Whats the max width on 16x7 wheels
- Percentage of members who've encountered theiving activity....
- new Rotors?
- Any integras from fresno??
- compression
- HELLA FUNNY! Check out what some guy is selling on eBay for a grand!
- I need a part number..
- lots of cool type R and JDM parts! Southern CA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- 14s on my teg?
- dizzy help PLEASE!!!???
- NEED HELP asap!!!!!
- May 04 import tuner 4 door power
- Help Quick!!!
- B-18C1 Build
- Hello! I am new to the Integra forum and have a couple Q's.
- Integra Type-R Expo 3 DVD
- B18B1 valve cover where
- custco cage?
- please help me save my 98+ headlight. big problem.
- Side Moulding Removable-Searched
- Tornado fuel saver
- i want to buy:
- Is this the correct Helms shop manual for my 91 Integra?
- AEM kit and 16"s
- TB on a b20z setup.
- anyone have experience with Rev Hard Turbo's?
- Custom sub job
- pic request- GSR w/ VALVE cover oFF
- my impression of the abs integra front lip spoiler
- hello everyone
- exhaust question
- Does anybody know the piping diameter of the comptech intake?
- Moonroof problem
- okay now i reset my ECU... still got prblmz...
- Automatic GSR
- 98-01 GSR: Stock Shifter
- Squeek When turning Steering wheel
- Ef headlights/hood on DA.
- magnaflow exhaust ??
- benefits of type of gas?
- Valves louder after adjstment?
- door panel
- parts are lose.
- putting a 98 type r lip on a 94
- What order to upgrade performance?
- ? Block with Gsr head
- Question about JDM Conversion
- quick PASADENA CALIFORNIA!
- Exhaust tip repair?
- squealing noise...need help
- valve cover bolt stuck... need some advise.
- need some tips
- b18c5 swap
- Little LS project.
- Intake and Exhaust
- RADIO WIRING SCHEMATICS
- Any have this one seize on them?
- got the koni yellows installed on the front side of my 2000 integ,how do you adjust and how bout the
- Need parts advice from anyone who has installed the OEM front lip.
- NEED PARTS?????
- skunk coilover question
- Dreaded headlight condensation......... possible fix?
- Trying to find the same material on the dash... (Vinyl Part)
- Eibach front strut tower bar
- HELP ME FIND MY 92 CX HATCH IN RICHMOND
- Do you think this will work? (insurance related)
- DB8 (integra sedan) hit up this forum
- Yet ANOTHER Integra TYPE R Stolen!!!!! Northern California People HELP!!!
- integra/crx tranny question
- window!
- Can anybody tell me if any company makes a rear transmission mount for da integra
- how to make sure engine is good, out of the car
- 97+ ITR header on 94 RS?
- Anyone have an owners manual for 3rd gen?
- When removing your muffler...
- Does 95 LS block fit 98 GSR transmission?
- help i am throwing cel code 23
- Painting headlights
- Do I need a dyno???
- asdf
- Vouch Thread For 99ls
- Dunlop SP Sport 5000 Asymmetrical - Goodyear Eagle GT-HR
- integra dash harness...
- black shit coming out of exhaust
- are all bseries fuel rails interchangeable?
- 94+ integra shifter work on 93 gsr?
- how much should stock p72 ecu sell for?
- Dumb question prolly
- daily driver exhaust question
- RSX steering wheel -------> 94 integra?
- spring rates
- Struts for 93 GS with abs
- drop question
- Purchasing a 95 gsr
- Where to find a good deal on a DC sports exhaust?
- cams for gsr
- How to clean off residue???
- crower cams
- Would you be interested in this?
- legal JDM swaps?
- Help on installing a Tranny.
- Exhaust
- What is the difference between a 2nd generation Teg Ls or Gs?
- putting type R cams into a GSR
- Can aNyone help me??
- all motor
- stock gsr fuel pressure?
- Installing pistons...a question
- Auto gsr ecu pinouts
- Someone tell me the Diff between the GS and LS model of the integra?
- removing the 'acura' badge from the back... integra specific.
- turbo oil?
- alternator wiring
- G2 Integra seat Question
- Difference between GSR, RS and LS front seats.
- 90-93 jdm headlights
- Spring compressor Nedded??
- did i install the S2 manifold wrong, look at pic
- Rear license plate bracket???
- DC suspension on my DA
- Adjust clutch pedal
- 3rd gear
- getting all new brake stuff
- ARP rod bolt help for a 92 LS... experts only please.
- SO they all almost here!!!
- Has anyone ever put Legend Calipers in a teg?
- Still trial user ???
- RSX seats in a 96 Integra?
- ITR CAI Questions
- skunk2 manifold??
- Sunroof
- All motor LS
- hatch doesnt work
- squeeky noise coming from inside head?
- Corner lamp problems on JDM front end
- Hazards wont work
- 98-01 integra bra fitments with itr lip
