View Full Version : Acura Integra
- burning oil help
- lookin for ls b18 builds. show me what ya got
- help with Integra
- Custom Headliner DIY?
- b20 non v-tec head on gsr block.
- Bound/Broken Axle Symptoms?
- OBD0-OBD1 Conversion
- fog light wiring help
- AP2 Seats into DC?
- 1999 GSR Sedan Build.....Very Mild..........
- jdm front end wiring
- max lift with gsr pistons on ls rods
- Weird overheating issues with GSR
- Installed NEW brake master cylinder and still having issues
- 91 teg fan turns on after i shut off the car!!!!
- Redundant, but DA Integra Insurance question
- Would this suspension and lower control arms fit my DA? PICS INSIDE
- low boost questions
- tail lights you guys have this before
- Hard to shift?! Help!
- engine harness burning wtf??
- 95 Integra ABS issue
- OBD2 GSR IAB wiring
- Does JRSC for B16 fit to B18B1 integra LS?
- 90 da integra pops up oil lights and goes away help?
- Raderwerks stp-1 s
- Brembo Rotors or PWJDM Rotors
- Wiring harness plugs
- Part numbers for front suspension install - bolts
- i got reffed
- CRV steering wheel in an Integra?
- 0bd0 Dizzy???
- Do all 94-01 Integra front seats have the same rails?
- burning oil in vtec
- which turbo kit to get?
- engine torque damper questions
- "hard and fast" vs. manufacturer recomended break-in
- picture of 6x9 rear speakers in a G3 integra
- 91 ls non-vtec b18a1. wut would be best to upgrade next.
- Can shift gears at a stop with out pressing the clutch & car does not move.
- 1992 DB2 Integra GS-R Motor Swap (HELP!)
- Car Overheating while at idle?
- Steering squeak?
- Electrical Problem - Blowing cabin fuse
- back in the game
- Code 20 (Electrical Load Detector)
- A lot of Engine Movement??
- wiring help??
- Leaking in my Floor panel
- Car locks up when backing up in reverse and I push the brakes
- Best rear camber kit?
- Should I trade my teg?
- Fuel problem?
- watch your cars if you live in white center
- egr valve on 92 b18a1????
- what is this sideskirt and where can i buy it?
- Horrible Clutch Shudder
- Integra GSR Repair... few questions
- 94 GSR ECU
- Story of my first Integra... 2001 LS Coupe
- Old DC4 (formerly "New DC2")
- distributor cap
- B18 Swap cranks doesn't turn over
- Axis OG OldSkool
- Clean DA Integras! Post em up!
- Car running like crap and no code
- Exhaust combos?
- had a photoshoot today
- High Idle
- Start Up Problem!?!?!?!?!
- trouble with vacuum hoses on 91 ls teg
- Looking at 93 Integra, whats it worth?
- 93 GSR Swap bogging down at WOT. Need HElp!!!!
- Bad valves seals or guides?
- Burning Oil/Smoke from exhaust
- stock exhaust bolts
- 1994 integra LS Sedan wont start after sitting for 1 month
- 1999 Automatic Transmission fit in a 2000?
- Intake Supercharger Kit???
- Do I need alignment after installing new tie rods
- Cranks, but doesn't start up.
- 98 Integra with a ls-vtec swap, oil pressure sensor is not hooked up?
- help!!!!!!!!!!!! DA bogging
- 94 GSR stalls at 5,000rpm speedometer drops to 0mph
- Rough idle problem, need ideas
- 96 Integra Built Thread!
- I didn't read the rules that say no bench racing threads
- 95 GSR oil leak, help identify
- Air Vents
- Help on puting in rocker arms on ls
- Washer motors gone bad??
- Where can I get a 92 gsr Vibrant axle back exhaust for a low price & free shipping?
- fresh 95 integra build / wtb cali dc2 parts
- oil leak diagnosis help
- Wat do I need to make My B20 Vtec ? and around how much will it coast me ?
- need info
- to loud
- GSR/No Oil.. new pump
- how do u install a tie rod?
- 1991 DA integra rpms
- so i just installed a short shifter..
- clutch pedal (cable)
- 1994 intertgra and no electrical power inside
- Flywheel Hits JDM b18c block.
- Integra kickin my BUTT!
- Trans/clutch issues
- just finished clutch job and clutch makes a squaking noise
- 94 GSR, low RPM no power
- Clueless on where this plug goes! (PICS)
- need help clutch pedal goes all the wy to the floor after clutch job
- DC JDM SS 4-1 header (2.5'') ,JDM itr B-pipe, EZ tuning universal muffler (2.5)
- Air vents not switching, stuck
- Need Help!!!
- DA 3pc drag frontend
- Could it be a Cat problem or injectors??? or something else??
- what gaskets to rin on a b18
- clicking noise when trying to start
- 1998 Integra Gs-R Headlight Bulb Out Sensor?
- Underhood Fuse box - screwed in wires?
- da roll cage
- Question about 93 Integra
- need help asap to figure this problem out please!!!!!!
- rear bumper sags...
- Oil light don't come on at start up???
- Please Help!
- if i put the jdm b20b from hmo. in my 96gsr integra can i keep ac?
- MSD Distributor cap and rotor ?
- brake headache after rear trailing arm replacement
- Cam jumped out of time *Any idea's*Pic's inside*
- Q: About Integra door panels
- 1991 Check Engine Light?
- What is Needed To Reach 165+Hp
- Clutch Pedal Mystery
- Check engine light
- door locks randomly wont work
- h22a stuff on b20?
- Will ls acl .25 rod bearings work in gsr?
- High pitched noise coming from 97 gsr?
- b18b cranks but wont start?
- No Fire
- b18b1 help
- how hard is it to replace a headgasket
- question about 1991 Integra GS-R value
- What would your DA look like if it was...
- gsr scored walls
- 4 black relay like boxes, wtf are they
- b18ls question
- b20 in an integra
- crv 5 lug on integra
- Code 14 IACV Colors Needed
- gsr tranny wont go into reverse
- 1996 GS-R sounds like it's pinging
- how to change driver side axle 96 Integra
- Installing H22 new pistons help this newbie
- Need to pick your......(@)
- Fuel pump on with engine off?
- Question about Clutch master adjustment 94 LS
- exhaust fitment
- question about swaping my 94 gsr motor into 99 shell
- 95 Integra GSR now has a B16 from 00 Civic SI
- My da update thread
- any advice before installing my clutch and tranny
- quick question about skunk 2 manifold
- best piston/rod combo for b18b
- B18C1 GSR question regarding cams
- DA9 Suspension suggestions
- Integra Ls Motor Idle Problem
- Integra rebuild parts list
- Alternator Removal on 1995 GS-R B18C1???
- teg vaccum and fuel line
- Integra water temp gauge goes down when acclerate
- 1998 Integra LSV-T (looking for feedback)
- VTEC Malfunction... HELP
- Its been too long.
- Big teg problem please help!
- Manifold studs
- have a 91 integra ls and need more power!!!!
- I suspect I have a bent rear trailing arm. help?
- 1995 acura integra rs, with b18c1 auto swap. performance parts ?
- DC2 Headgasket Job: Questions
- Engine Hesitation
- Fix a ticket gets transferred to new owner?
- Has anyone bought from JDM Importers?
- Integra insurance rates
- 91 integra starting problems
- arp headstud question
- Alternator kills engine.
- Integra shocks that were on a Civic without washers won't fit Integra anymore
- need help picking cam shafts!!!!
- Tranny rpms
- where is tcu/tcm? 2000 teg
- Just picked up a 92 DA Teggy OBD1
- .57 trim vs. .60 trim
- trying to figure out about my integra!!!!!
- B18A problem!! help!!!
- My 95 Tegger Project
- Check engine light question
- my dc2 integra is idling high
- Race Bearings
- Vtec engagement questions
- B18a engine
- 1996 GS-R 230,000 miles re-build questions
- help me please, car pulling bad
- power steering feed hose all the same?
- Water leaking
- A little help, please.
- Wire harness question
- quick exhaust question
- B18C1's gearbox type, is it S80 or S4C or what?
- clutch from a obd1 b16a fit a 90 cable ls transmission?
- 91 b18a engine
- Need help with Integra wiring.
- Question about swapping Teggy susupension
- sell my volks te37 and get ccw classic or just keep the volks
- mugen header 2.5" collector. which gasket?
- Cam caps
- aftermarket alarm, doors wont unlock.
- GSR oil consumption
- losing oil
- are integra and civic brake boosters compatible?
- Will a momo Steering wheel hub from a 94 Integra fit a 90 Integra?
- my ls build
- FS: 5.5 qt moroso aluminum oil pan w/ pick up and taps
- interior rattles
- B18C overheating. not the typical problem i dont think.
- Car cranks but won't start. Spilled antifreeze...
- ABS Axles on a 90 Integra Non-Abs
- Ebay Intake Manifold for B18 1.8? w/Link
- b18a1 bubbling
- Post up your DC's and DB's. Need help choosing one.
- Skunk2 exhaust in my 1995 acura RS
- brakes hot?
- JDM B20b Test Only!!!
- ground wires weak signal??
- coolant and fan problem?
- mysterious smoker
- Code 17 GSR
- Rough Idle help?
- TEG HELP
- 1993 Integra Rs Check Engine Light help
- Rough idle, sometimes stalls?
- want to buy a integra..... your advice
- Paint Job:Super Sonic Blue Pearl to Electron Blue Pearl
- Rear Motor Mount?
- DC Clutch / Tranny question
- 95 integra b18b1: brake issue required
- engine noise
- coupe and sedan difference in seat brackets?
- dashboard light dont work
- E-brake light comes on with brake pedal is pushed...
