View Full Version : Acura Integra
- alignment after spring and shock install
- Informative sites?
- Dyno charts of skunk cams vs. crower?
- B18B Auto in 95 LX Auto
- How penalized would i get if i was to end my lease 6 months before and jump into a new Teg???
- loose fuel filter?
- where to get stock emblems at a cheaper price than the Acura dealership?
- i had to change my front left caliper, whats the easiest way to bleed that thing the right way?
- Oil pressure low in my GSR
- How do you fix small rock chips in your windshield?
- Rolled my Integra onto it's side tonight
- H&R OE Springs w/stock struts
- Flywheel?
- which ecu do i have
- do i need to balance these?
- to greddy or not to greddy
- Good deal ITR cams?
- stock gsr exhaust
- Is it possible to remove the 2 bolts from the 3rd brake light?
- KYB AGX vs KONI YELLOWS
- comptech icebox Q
- Motor swap is it easy?
- Is the P28 or P30 ECU w/ skunk 2 program OBD I or OBD II ?
- best price for dc sports?
- anyone down for a meet at fudruckers in pasadena ca
- state referee
- type r cam specs
- Anyone with blown KYB's?
- oem headgasket
- how much???
- jdm type r conversion
- ES muffler
- What's the biggest Trend?
- Any More Improvements to my Suspension Setup?
- OBD-II and headers...
- Buying 94 Integra LS - any maintenance gotchas?
- need 94 gsr upper control arms
- Where do I attach the hoist to my GSR motor?
- Q? about installing leather seats
- braking pressure problem, continues
- OT - any FFsquad members on the board?
- How long do u guys warm up your teg during winter?
- "Jet Hot" or Powdercoating.....
- Moderators Please , Please make a Suspension Forum !!!!!!
- How to identify rear and front springs (stock LS)
- can someone plz tell me what kind of cam is this?
- kinda ot but should i claim this?
- ZEX users, wheres you box mounted? Pics if you got em.
- Help wanted How do you intsall jdm lights on a 92
- Still Leaking
- Replacing rear Hub and wheel bearing assembly
- anyone do a 5 lug conversion on a non-typeR?
- numbers on LS pistons and rods
- Eibach pro-kit and sportline
- SUSPENSION
- how do you disable the antennae?
- coilovers or..............
- Lowering the integra
- Albuquerque or anybody from NM
- <><><>Please post pics of your balck rims on your integra<><><>
- Grinding gears
- smoking from steering wheel
- Where can I get a Mugen front bumper or Spoon CF Lip for JDM Front?
- S2000 KIT. Who is the man to order from?? :)
- Stock GSR rims
- is there an easier way to put on an aem cai?
- How does a thermostat help the performance of a car?
- Which Replacement Radiator?
- Question for you 2dr guys....wheres the back wiper button?
- ls teg dash vs. gsr teg dash?
- Big difference between ITR and SI intake manifold?
- Shield for the factory header?
- ls on boost
- please critique my budget all motor setup
- I need help finding a Teggy for real cheap. Please
- Update on my car....
- degree of difficulty in valve adjustment?
- How long will a water pump hold on?
- ANOTHER ICEBOX QUESTION
- New dyno in the Albany NY area
- 94 or 95 P72 (GSR ECU)
- Which Integra would YOU buy?
- Battery is smokin'
- Part # to OEM Fog Light Switch?
- No Power to the Road
- skunk2 IM(dyno charts)
- can anybody vouch for GSR2001
- b18c1 vin # how to tell if legit or not
- Project LS Dyno
- Need help with ignition wire order (As soon as possible!!)
- OT: Any good Acura shops near Pleasanton, Ca?
- This has got to STOP!!!
- Supercharged GS-R
- Cheap testpipe for Stock exhaust. where?
- how to remove carbon deposits off the tops of pistons while in the car
- CEL code 45 too lean/rich
- Gauges in dimmer/cruise control
- Quirky Electrical System
- Strange Sounds...
- full car bushing kit
- Comptech Icebox
- Pic request: Red '94-2001 Integra with Alcheeza taillights...
- Beaks Products Website -- Purchase Subframe Reinforcement Kits Online
- Rota Circuit 8's?
- What Pistons for a B20b???
- Please help, CEL, code 67
- Tokico springs
- sidemolding?
- Valve Adjustment Question?
- Attention Virginia people: Possibly no more front license plate required.
- Problems with Teggy ...
- The truth about getting shocked..cont.
- having a test pipe constructed.....suggestions
- SoCal-Dyno Day Feb 24th
- Is this connector under my dash supposed to not connect to anything?
- My timing belt is loose....
- What can i buy...
- Auto to manual conversion
- Cut a groove in my flywheel after 2K miles, normal?
- Rear trailing arm
- Cost for sleeving
- Best camber kit ?????????
- Do u need gasket for jdm itr header?
- Tokico shocks with Eibach pros? good? bad?
- CARFAX integra
- Integra GS-R pple
- cat?
- anybody with a headup display?
- where to get it done
- fixing a bent LS rod
- Wondering if my car has been lowered
- I want to rev past 8000 safely what do I need?
- do i need my cat?
- Flywheels
- B20VTEC dyno
- what am I lookin to pay...
- How long is the carsound cat to fit the GS-R and JDM 4-1?
- What valve train w/ SPoon cams?
- What parts do I need to install the skunk manifold?
- Which exhaust to get, greddy evo or sp??
- Brakes, best bang for the cheep buck?
- roll cages
- headlights
- new springs drop 1.8in. Problems? Camber plates needed
- swap for LS?
- 2nd OR 3rd gen
- anyone have pic of 16" rims without lowering your car?
- This Forum
- best thing to do to integra
- What Flywheel, with ACT 4or 6 puck
- Track Day at Little Talladega - March 9th and 10th
- please help i got scammed!
- im tired....
- Camber kit install
- rice is bad!!!
- burning smell
- gsr aem cai question
- How much is this worth??
- air ride suspension for 95 gsr
- Hydraulic brake system problem.. is it? or not? help!
- tiny shavings in oil help?
- Integra GSR 95
- Weird CEL problem....its there and then its not....but it is
- Do you guys think the B18C1 is a better candidate for FI or NA?
- does a axleback for GSR or Type R fit all 94+ integra's?
- What mod would give me the most HP gain?Mods Listed...
- Alignment cost?
- Z10 radius rods on 98 GSR question and pics
- Apex'i World Sport or N1 Exhaust for GSR sedan
- build me a perfect tranny from a gsr tranny
- how to upgrade
- new tires?
- what kind of wheels is everyone on?
- Ignitor module gone again.
- 92 USDM GSR vs 91 JDM SiR cable tranny???
- Anyone have JG 301 cams
- Posted in Tech, but maybe this will work better. Skunk2 VS. GSR manifold
- timing adjustment...
- Color code for adriatic blue pearl?
- 91 TEG GS B18 QUESTIONS engine experts needed
- Daily Driver GSR with a low budget...turbo???
- GSR vs LS
- kyb agx or tokico illumina adj. shocks?
- 1994 Milano Red Integra GS-R - 116k miles. worth looking at?
- Should I get the Blitz Technospeed Z1 wheels in 17X7 with 205/40/17 ???
- What kind of muffler should I get?
- is it possible to swap an integra type-r engine in a civic
- what is OMP's website?
- problem getting it into reverse
- is this a good price for ground control.?
- which header is the best
- Is your 2nd gear a bitch with your short shifter?
- Anyone have pics of a teg with NSX side inlet air ducts???, I saw it in a mag once!
- Post pics of s2000 Push Button Starters INstalled on tegs!!!
- Looking to buy an integra...
- confused.. what to do?
- Momo steering wheel?(did search)
- Carfax, Please!
- I need a carfax report please!
- Fastbrakes Question: ITR Rear Caliper e-brake cable
- 13" Wheel on Integra??? Slicks?
- Those with nitrous, did you use teflon sealer on your connections?
- Price of complete B18C5 motor with tranny and ecu?
- clutch
- Koni Yellows worth the extra cash? Where to get 'em?
- Looking for Black Cloth rear seats (2dr)
- stupid screws for front brake splash/dust shield ?!
- Help Cel Flashing Code 74
- car leaning to the left?
- any of you guys recomend a place online where i can get stock A emblems at a good price
- B series hydro tranny with ecu
- 91' integ, RS with a 98 GSr head, how much HP and what would the 1/4 mile times be.
- Chassis code help
- Just installed my springs!!!
- Is a B18A1 pre-obd or OBD-I ?
- GSR questions
- 95 GSR - Condensation in headlights
- Energy Suspension shift stablizer on stock shift lever? Has anyone done this?
- moderators get to keep their avatars ...no fair
- New here... Clutch question?
- exhaust for integra gsr sedan
- Finally completed the wheel studs
- cluster, tail, corner lamps, went out
- will a Turbo Kit for 3rd gen teg fit into a 2nd gen?
- hey snatch, carfax for me? :)
- NW Dyno Day at ISA (sign up sheet)
- what should i do next.....
- My fuel pump is going bad what fuel pump should i look into?Im planning on going NOS.
- Im planning on getting "Cam Gears" which to get for most gain?
- What are the best headers to get "Greddy,DC Sports,or Neuspeed"?
- Do u think these are worth it?MSD Blaster 2 Coil,MSD Distributor Cap?
- Vtec Tone's
- robot adjustable short shifter
- ITR HEADER
- valve cover swap
- Anyone selling Toda Spec B's...?
- Anyone Know Where To Get the Z-Speed Replicas of the RNR's??????
- ITR front lip spoiler
- Clutch Noise
- Shifter stabilizer bushing kit
- HUGE!!!!!!!!! Garage sale @ Landspeed Racing
- Shifting Question....
- ls integra swaybars??
- Japanese car racing videos, Options, Best Motoring, Initial Ds
- DC Sports Header
- Anyone know how to change brake fluid?
- As seen in SUPER STREET-Feb'02, Speedvision/NASA US Touring Car-'93 Integra: FOR SALE
- JDM ITR or Toda A?
- Leaking oil
- SMALL DENT DAMN!!!!!!
