View Full Version : Acura Integra
- did some research but can't find please help
- 90' teg tranny q
- 91 ls cam vs 94 up ls cams
- gsr interior peices.
- buying sparco seats out of prelude
- Power Steering Reservoir
- What to buy for my REBUILD ??????????? please help
- veeery low idle after test pipe (picture)
- just bought a 4 door ls but the windows have bad water spots how do i remove them!!??
- How much lower is a integra type r than a 98 gsr
- 96-97 spec JDM B18c (R) into 2001 GSR
- CEL #3 map sensor
- just wanted to share a story with everyone...
- question
- Blinker problem Help!
- VSS Wiring Help
- Car starts cold but not after warming up
- engine management
- very strange sound alternator belt?!..
- What to look for if this happens to you
- GSR with type r cams
- Mugen thermostat.. what diff does it make and how do i know i have it??
- Q: high pitch sound coming from my motor? what is it?
- transmission help
- help?
- check engine light
- Light on Rear Bumper.... Where do I get this?
- how did this happend?!...
- Where to get oem b17 parts?(besides dealer)
- 90 integra operating temperature?
- jdm carbon inserts on usdm integra.
- 90-93 teg guys, what are these??
- Wrap your noodle around this one
- Crank Shaft Washers?
- exhaust
- DC seems to move left and right while going 50mph+
- prelude wheels
- catch can Q
- motor mounts
- fuel pump???
- Running Rich?
- da 1 peice headlights with stock fenders.
- DC 98+ leather seats in a DA, please read
- freeway rpms
- chipped pr3...what can I get rid of??
- STUPID QUESTION NEED ANSWER!!!
- iab
- Disconnect brake pedal from Brake booster?
- Attention Technicans of HT.... HELP!!!
- Left head light not working Or a/c doesnt blow... Help
- Swapping a D series into an integra?!
- Throw Out Bearing help
- intake manifold line
- EVAP purge selenoid question
- Shifting into first (searched but no luck)
- 94+ lower rad hoses... ls vs gsr... difference?
- to the ground
- Anyone have experince with these rotors?????
- Car won't start
- Will a sunroof and all the material of a 96' 2dr teg fit a 94' 4dr teg.
- Got pulled over 2x on my way over
- CAT-BACK
- all motor or fi?
- Oil filter relocation kits?
- need help with ecu
- b18 engine mount BOLTS/bracket/mount
- dumb question
- Fog Lights?
- Questions about an itegra.
- Installed my new exhaust!
- what turbo kit can i get for my integra
- suspension question.. what is good settings for a lowered car to have a smooth ride?
- Will a 96 gsr dash harness work in a 95 integra rs?
- suggestions for poor-man's edm tails?
- '91 Teg Crank but no start with Check engine light and flashing S3 light???
- ran out of gas broken fuel pump
- never seen this integra b4....have you?
- G35 tailights
- over heating and fan dont turn on
- dyno results
- Removing Charcoal Canister/ Evap Emissions
- Check engine light: Code P1457
- SRI Installation
- BOOST!!!!
- Exhaust Rattling..? Easy fix?
- Quick question
- A/c cutoff?
- funny idle on my 96GSR
- What is this car worth????
- over priced for a gsr?
- TYPE-R SWAP? OR K20A-R?
- snowboard rack...
- Just what the hell is that sound????
- 96 GSR idle issues..
- which clutch kit to use for my mildly built gsr turbo???
- Show Car engine bay
- okay, quick ? about lowering springs on DA...
- Valve adjust.
- Damaged and repaired Integras ! Post pics! :)
- BROKE A CAM RAIL BOLT HELP!!!
- What do I need for a auto to manual swap in my Integ?
- Tach
- JDM integra fog light question...
- quick question
- quick question about oil pump
- PLEASE HELP!!!
- Water gettin trunk
- what would have more vibration
- intake harness?
- $80 For 98+ Mirrors, is it too much?
- What o2 sensor
- so i heard 94-95 integras came in "thunder grey"...is this true? well here she is.. post your thunde
- Cannot remove Oil Pan - 90 Integra LS Automatic
- Acura Genuine Vs OEM replacement parts
- new clutch problem..HELP
- VTEC crossover change in GSR help!
- Weird Starting Problems...92 DA Help!
- Need Help!
- Popular/cheap route for more power.
- Is this ITR MC/Booster or GSR?
- Power steering Question
- 94 integra power loss
- GSR crank and LS crank the same?
- Car Stalling
- Dizzy Installation on a LSVTEC(Stroked out) 12.1 comp
- XSi what the heel does it look like?
- legal issues with jdm front end?
- tach install
- OBD0 to OBD1 wire harness question
- my DA wont start in the rain
- Power loss going from stock IM to Blox?
- gsr cams and cam gears...
- b18a1 integ with mpra aka automatic transmission
- Two unidentified plugs near the bumper lights...what are they?
- California ticket/laws
- CA-san jose- 1 piece headlights illegal ?
- gsr or b20?
- fuel pump noise...
- HID RETRO FIT TSX PROJECTOR QUESTION. HELP ME
- B18C1 block / B16A head What gasket set etc
- LS Rebirth
- Whats wrong with my gsr..
- One peice headlights for my DA
- obd1 vs obd2 gsr...what are the differences??
- looking for more horsepower...92 integra gs-r
- pic request!!
- Post pics of your stock white tegs exaust!
- Is Jdm obd 1 gsr dist . The same as USDM ????
- TRanny ?
- soo umm yeah my FPR broke.
- Short Block Identification?
- Which oil for my 98 DC2?
- Not enough gas 2 last
- 93 integra died while driving
- rare ys1 tranny is this true?
- whats the differance
- thermostat question
- GSR tranny diagram?
- G/F cracked her type-R lip......
- 1989 integra
- ls a/c compressor???
- Removing the unwanted
- wtb iab pump tank and solenoid
- Post Pics of your exhaust!
- abs elimination
- i cant post in the market place fourm.
- type r cluster....?
- YAY i finally got all the parts for my new motor...!!
- bending ac lines
- little Wreck
- ground control and KYB AGX combo ?
- Integra AC compressor?
- have a question!!!
- ls motor
- Need some input on K-Sport coilovers, or coilovers in general
- CAR "DIES", DASH LIGHTS COME ON, CONTINUES TO RUN
- Thinking of buying a salvaged 00 LS coupe
- timing belt and water pump
- hard to shift?!
- Anyone have any tips on removing a crankshaft pulley?
- type-r header? type-r cat?
- GS-R Hatch Vs. Sedan?
- RHD conversion
- it rained, now my heater doesnt work
- Qucik question about B&M FPR
- Best header?
- Axel Questions
- Help! Removing shift rod
- Process of Looking up C.E.L???
- Help fidanza flywheel question
- tiny motor bracket on driver side help please!?!?!
- H-Brace
- HELP LOUD tapping after mods!
- MSD removal process??
- All of a sudden my car bounces soo much
- ONE MORE!
- MY car got broken into!!!
- standpoints on an integra?
- got a ref ticket for my JDM GSR motor
- where is the classified section?
- Skunk 2 Pro Series Vs. Edelbrock Victor X
- How much would you pay for my integra?
- Cloudy Cluster
- My tranny used to work
- Tie Rod..
- 1/4 mile
- starter
- Does anyone know where I can pick this up at?
- Clutch wont disengage, weird background story.
- Headlights
- b18b head
- Will a 95 Integra GSR stock shifter fit a 90 integra GS? (need answer quickly!)
- New 2 da honda crew
- how much did you pay for your gsr?
- firewall brake line bolts broken, replacement???
- Oily Spark Plugs
- 99 Teggy GSR-$3000 obo-SOCAL
- head bolt size?
- What happens when one Spins a Rod/bearing
- autometer tach install
- oh my god paint job?
- need pics? please
- Napa axles SUCK!! ONE DAY , driven about 10-15 MILES and Greease shoots everywhere?
- My JDM ITR steering wheel is loose.. how do i tighten it..
- omni vs. teins
- what size are these rims?
- all you k20 swappers
- 91 teg b18a1 going ino 90 gs body HELP !!
- B16 swap. Wiring 2nd o2 sensor. What wire is origanal o2?
- 95 teg and ipod integration
- Height and fitment question....
- OBD-2 to OBD-1 question
- speedometer stopped working
- we all LOVEEEE buying used cars.
- ECU + EGR problem/question, help
- DEL SOL SEATS IN A DA9 HELP!!!!!!!
- tein or h&r springs?????
- Whats up guys/girls i have few questions
- watCha noe about that my blkdc2
- watCha noe about the that my blkdc2
- Paypal Scam Possiblilty Let me Kno Thanks
- Racing Harness Predicament
- B18C1 turbo manifold for sale
- How do you clean the top of your pistons???
- B18b1 auto tranny problem
- my integra was stole last night in front of my house arlington texas
- Project DC4-R
- What Honda OEM intake manifold will fit a P72 head??
- Quick question about door molding
- VTEC
