View Full Version : Acura Integra
- Squeaky Sway Bar bushings after lowering?
- obx lsd now available for hondas
- What freon is used for 1996 LS? and 1999 GSR
- has anyone made there own short throw shifter?
- Mugen 5 ways
- Thinking about these. Give me a reason not to and wait for the Tein's.
- Most HP for under $200.00?
- b16 exhaust cam same as ctr cams??
- does anyone else have a hard time starting.....
- how hard is it to change a differential????
- Neuspeed Strut Bar
- another tein height adjust question.
- Best injector type for boost?
- How wide are the steelies on my 96 LS?
- Phantom Grip LSD?
- Tanabe Springs
- Paint match???
- A little help please from the honda guru's.
- installed 12lbs flywheel.. rpms arnt all that quick???
- Guess What I Saw
- ACT heavy pressure plate and disc
- ***SEARCHED*** Skunk2 Stage 1 or 2?
- difference between gsr header and ls header
- Integra Forum-same topic question?
- Fixed radiator leak
- How much should I sell my GSR for...
- GSR insurance.
- Intake Manifolds
- ITR LSD + GSR TANNY = WORK?
- convertion of dc2 to type r japan version
- i have a engine light the code is 43 fuel supply system what you think it is on my b20vtec lsd trann
- Does a 01 Teg LS OEM Exhaust fit a 95 Teg LS?
- What size pistons do I need?
- Mis Firing cyL # 1.... Some HELP please
- How much whp to run a 13 sec. 1/4th?
- 98+ front end conversion?
- Throttle Body Size for GS-R
- camshaft install
- 97 DC2 Brake Ducts wanted
- Muffler fell off, but seems more peppy, what about straight exhaust?
- Engine temo. sensor and radiator question
- short shifter or no?
- question for those with fluidyne radiator
- HELP! Can a breather kit and low oil levels lead to head gasket failure?
- Rusted Spark Plug
- automatic seatbelt not working.
- Is this what honda-tech is about
- short shift installed
- dent puller...does it work well?
- How do I get this off? *PIC*
- skunkworks coilovers...any good? comments please
- REAR brake rotors fitment ?'s
- Heatshield around cat
- ebay cat for 98 gsr
- pistons
- Looking for a header for my GSR
- Time to start the MOO revolution......
- no spark
- engine managment
- how tight to make camber kit
- Cold air intake and exhaust
- what to do?
- moo
- advance timing
- Clutch disc question
- Honda MTF vs. GM Syncromesh
- Optima Red Top Battery
- Gauges in Cruise Control/Dimmer switch holes?
- ecu question
- suspension ?
- nuespeed/h&r sports or tein ss
- here plans for gsr help out!!!
- Brothers, im getting into the race of my life
- trany
- ITR rear sway w/ N1
- Newbie here! 94 Integra LS.....need ideas.
- Question - b18c5 shortblock with gsr head & ITR springs & cams OR stock itr head?
- Alarm problem
- USDM Integra headlights...
- my teg rides like S**T!!.... need advise
- (Searched and Researched) Open Diff or. OEM LSD
- vouch thread for 3rdGteg
- Integra 2gen ls vtec times
- Distributor question
- Rad/Oil Cooler question
- PLEASE HELP!!! leaking problem
- Skunk 2 coilovers
- chassis
- new clutch?
- LS shifter and GSR shifter the same?
- Acura Bose 2100 Radio
- Stolen Black GSR Sacramento, Elk Grove, Galt Area
- where to order helms manuel?
- power steering removal, stuck on pinion removal
- exhaust compatibility question
- JDM Integra Si-R DC2 - SMSP test pipe question.
- trany fluid
- Full Race Turbo
- b18b head on b20 bottom end
- Those of you using Zip's SMC ?s
- PS pump b18c1
- thread specs for oem gsr shifter??
- Cable tranny into car with hydro tranny?
- got Koni yellows used but without washers and collars
- wiring a kill switch? ....fuel cutoff?
- Valves......
- H22 DC2 with A/C?
- B16 gear ratios?? anyone know??
- BEST SETUP TO USE WITH T70 GSR TURBO, FULLY BUILT?????
- What's the tranny fluid you guys use when you start to get a grind. Sycro-something...
- How much you guys think I should try to get for these GSRs?
- Hatch Light | How to Fix?
- premium gas
- cheapest place to buy RS-R ex mag for integra LS?
- weird gas problem
- question about stolen leather seats and insurance
- SAFETY CHECK
- Rough Idling caused by TPS?
- integra parts for sale
- Broken Into But not stolen.....94 Integ Story
- oxygen sensor help
- parts for sale, i would be in classifieds but still a trial memeber sorry about this
- favorite suspension setups
- omni
- HELP! Just bought the car 2 weeks ago, already having weird problems *Read pls*
- Can I safely run a Direct Port 100 shot?
- Viper Alarm in gsr
- headlights not working.....did search
- New to Honda-Tech, just a general question and hello
- K20A swap + turbo?
- Best company to do a port and polish???
- Crappy 1/4 mile results... gimmie some pointers.
- Stock-ish looking window switch to mount on center console?
- Difference between LS GS-R Type R RS
- corner weights
- 92 integra gsr turbo..
- Turbo vs. All motor... my own personal experience
- Removing the rear spoiler?
- fuel line question
- headlight dust?
- Ping noise need help its intresting though
- wing lgiht
- 2.5 inch exhaust flange.
- quick question about the 98' b18c5 into a 94' chassis (gsr)
- What is the BEST car alarm?
- How big can i go?
- 98+ Turn signals on a 94-97?
- whats wrong with my AC
- Question about bad rings...
- ground control spring rates
- B18B operating temperature???
- Can you fit spoon style mirrors from an EF to a DA?
- Do they they sell the Spoon Horn Button Seperate online some where?
- Stolen Integra GSR Turbo-Santa Monica, California-Be on the lookout
- I need help on a choice
- Give me your opinions on this wheel
- new clutch, no free play
- any cool integra car shirts?
- compression tested my b18b with 100k? good for turbo?
- ****URGENT BEFORE SUNSET****
- Tein SS coilovers...
- Civic ex exhaust same as Integra???
- G1 Thoughts
- Transmission woes...new GSR tranny taking a shit
- Integra 2000 Leathers Needed.
- what are the two bulb sizes for the bumper lights on a 94 teg?
- Creaky Suspension on the DA
- gsr for type r??????????!!!!!!!!!!!!!
- 95 GSR didnt pass smog....WTF????
- swap h22 in 91 ls?
- VIN # Help
- Quaife LSD install (shim question)
- ctr or itr in my car?
- Right price to pay for valve spring / lma install? or somebody in bay area want to help?
- Something madd weird just happened to my car
- BUMPER WANTED!!! DOES ANYBODY HAVE A 98+ BUMPER??
- Squeaking from the distributor...
- mounting a 98 front bumper on my 97 teg
- Integra vs Accord
- C's Short Shifter
- whats the size or part # for this bolt
- kumho 711 or yoko h4 witch ones are better
- exhaust pipe
- integra window frame
- NEED HELP!!! WHAT IS NEEDED FOR THE 98+ CONVERSION??!
- do you use the plate for ingalls camber kits.
- Top 10 stolen vehicles for 2003
- bolt size on ITR header bracket
- Should my Integra have "Honda" stamped windows?
- Air horn problems!
- ECU NOT GIVING CODES
- Installing Edelbrock Victor X maniold on gsr, have questions!
- Performance Mods that drop weight
- help, 3rd brake light doesnt work
- Rear Brake Pad Removal....
- Missing: bolt sizes for DC 4-2-1 Header and Lower Starter Bolt
- Help me open my car door!! Please?!
- Plz help me!
- Tein SS suspension review
- HELP
- radiator fluid getting darker?
- somone stole my helms manual.... need some info from one
- Take out climate control and other vents
- are there mount kits to put h22's in da tegs?
- WTB 94+ integra sedan under 4000
- car shakes a lot in idle
- awd/rwd integra?
- I have some questions about the weight of my car and the whp.
- I have a problem with the power sunroof in my civic
- I want to loose more weight in My Integra
- shifter is REALLY loose
- Best shocks/struts for a DA within $250-$300 budget
- 205/50/15: which tire best suits
- How risky would a CAI be in a daily driver Gen 2?
- has anyone done a 90-93 teg right hand drive conversion.
- DA manifold question
- ls /vtec
- whats an s4 tranny from?
- Where to buy clear hose?
- obd1 / obd2 and o2 sensor question...
- My 98 ls is for sale!
- Longchamps??
- How much
- Somone smashed into me while was on the highway.
- Horn NOT Honking!! IT REALLY SUCKS
- 17 inch rims
- '87 Integra wiper switch
- integra tail light
- I need help with my a/c removale
- B16 GSR - What intake fits?
- HELP removing wheel stubs
- vote: which catback would you choose?
- DIY front endlink bushings?
- car trouble
- ?????????? about Civic GSR Hatch
- Completing the project...
- ITR SUSPENSION ON A DA......WILL IT WORK?
- 1998 CD Player
- GSR won't start after stall
- Need battery
- Best place to get OEM Quality plug wires?
- Smoking exhaust
- o2 sensor bolt size for carsound cat
- Integra Wiring need help PLEASE!!! Need some pics.
- Ls components on B20
- tappet cover seal?
- instrument light/tail light/plate light FUSE problem.... wont stop blowing fuses?
- blinker problem
- h22 integra harness
- Little steering problem!! Please Help.
