View Full Version : Acura Integra
- camber crisis!
- gsr secondaries
- messed up an install pretty bad....HELP PLEASE
- What kind of springs?
- Neuspeed Springs
- pictures of my '96 gsr with ITR catback + tannabe muffler
- lsvtec ecu
- Clutch for a 2001 GSR Turbo? Does a lighter flywheel actually make a difference in smoothness?
- Fuel Filter Install Question
- GSR lca fit on a GS?
- Bought Integra, selling civic... what parts to keep
- Do Teg brakes suck?
- Group buy: itr front lip???
- Carfax report please
- Side mirror install
- LS cam timing
- B&M FPR
- Bad Gas Milage?
- skunk 2 ecu and emissions
- 95 LS four door with intake only. should adding a 2001 ITR exhaust be my next step?
- exhaust tech
- Some questions about manual transmission???
- HELP!!...I need ECU pinout for LS...HELP!!!
- KMAC caster/camber kit bummer
- 98+ rear bumper onto a 95 teg
- KYB GR-2 shocks??
- fog lights
- I figured i should let you guys know...
- cat-back for 91 ls
- Help I think my shocks are blown
- please diagnose my tapping noise
- Anyone got a 2nf gen Integra
- Yet another SSBP Thread: Yay or Nay?
- minor problems
- b16 ecu in GSR?
- est 1/4 mile times?? any ideas
- gf's car is burning oil.. what could be the problem?
- 90 to 93 Integra with B18C5 swap?
- Which ECU?
- Adjusting Koni Yellows front and back dampening level
- ls/vtec Q's
- help! camber kit
- Swaps
- I am so pist 1/4 times
- Cross-threaded a bolt to chassis - what to do?
- Reliability & Quality: Integra vs Hyundai
- i/h/e question
- skunk2 short shifter, not short anymore?
- vidclip of b18c-R, jdm itr header, jdm itr cat, and greddy evo.
- Trust Exhaust
- Pics and instructions of above-rearview-mirror VAFC mount
- Help! Grinding noise when turning right
- broken axle?!?!?
- take a look at my new vs old oil pan
- new cams... now it boggs ???
- easy timing question
- ITR Shift Knob????
- What is the piping size on Greddy SP (TRUST)
- gas milage
- header gasket - how tights?
- cant find where to drain transmission fluid!?
- Skunk2 manifold vacuum lines
- where to smog in the south bay, ca
- Looking for teg rear skirt/valence
- CAR RUNNING LEAN
- 98-up front end converion on a 95 gsr
- cam timing
- how do you know if you have a bent valve?
- syncros or tranny?
- Anyone else do this???
- 95 gsr rotors
- Will teg TEIN HR fit an EK with ITR LCA
- All of these stolen tegs...................
- carfax report help please!
- Need help putting AC compressor back in!
- Anyone Have APEXi N1 Pro Series Dampers?
- anyone planning to upgrade their ls stock head and top end?
- Is there a VIN Number on the block?
- Ac question, what year? Help!
- Anyone with a front lower tie bar....
- 91 LS block?
- Stiff Daily Driving
- a lip question for everyone...
- OEM foglight instructions for 94-97 integra, can someone please post?
- how to remove the back seats?
- stock ls questions
- Another installing coilover sleeves question.
- quick ls cam ?
- Which tire are less noisy...
- pillar pods
- itr intake cam
- front fender removal help
- Link needed to rim offset listing of other car manufacturers?
- Coolant Problem!! Please help!
- Ferrea valves worth it?
- 96 GSR vs 98 GSR??
- slave cylinder, clutch problems..help!
- A bit of advertising for myself: Selling OEM lip 98+
- Ground Control coilovers
- Swaps in San Diego
- Tailights Leak, Gasket
- Wheel Bearings?
- replacing the molding surrounding the windows?
- 95 cluster in a 96?
- 18 degrees ignition timing... but ecu changes it...?
- Where to find NEW GSR gauge cluster with zero miles?
- threw a number 9 code...can u guys help me find this sensor?
- Educate me... (harness, ecu)... 93 motor in a 90 RS chasis
- ls running lean
- Pistons\Rods
- How to remove rear bumper support on a 1992 Integra?
- P08 Chip question
- lights dont flash when i click alarm button?
- slots/marks on the crank pulley for TDC reference
- 500 GSR's a year?
- CarFax can someone help me?
- Quick ? about 90 integra fuel pump location
- Who makes a good rear camber kit?
- How dependable is a b20 Vtec (b18c head) for Daily Driving Please!!!
- cheap but nice tires ?
- 2 step colder NGK plugs for GSR
- any one know if the apex gt header gives good power
- A couple of questions...
- Desperately Need Your Assistance!!!
- are ls and gsr injectors the same?
- Will a 95 Integra LS bra fit a 97 ITR front end?
- need pics of 2000-01 gsr exhaust man
- i need new springs...
- jdm arm rest eliminator...
- what would be the most effective filter for the comptech icebox, excluding the comptech filter itsel
- Need help....?
- Anyone heard of a JDM ITR 4-2-1 header?
- any LS owners swap trannys? I need your opinion...
- header question for 94-99 gsr guys with jdm 2.5 collector
- alright having problems!!!
- where to tap TPS wire?
- where is my ECU?
- 911 need help quick
- Compression Tester.(Houston Members)
- will d series starter fit b series
- installing my zex dry kit, got a question about a plug. and where is my ECU?
- i just installed my ZEX kit.. got some questions for anyone running nitrous
- B18C1 questions about bore, setup etc...
- Intermitant problem on Integra LS 97 with no engine mods
- VIN check please, possibly buying 99 GSR..
- installing springs!
- DC vs standard teg
- Shade Tree Clutch Job (Do it Yourself)?
- quaker state oil filter?
- I want to put a B16A in my dc2. Is it possible?
- Hey turbo/high hp guys,
- HELP! Rattling noise (not the cat. heatshield)
- CLUTCH
- SHIFT KNOB GETTING HOT
- Tire problem
- Doing my suspension, need some advice!
- SSBP: How many integras were made in this color?
- HELP! - Changing BRAKE PADS on my '94 GS-R
- LS Vs GSR Rotors
- Engine Misfiring! CEL code 71,72, and 74. What do I need to fix?
- building an exhasut and ITR header
- Teg just stolen - Sunrise, FL
- need to know timing
- Action Stage 1KS clutch
- question need help..
- how much HP/TQ??
- double wishbone??
- Apexi WS exhaust.....
- type R pullies on LS???
- specifics gsr
- Vtec activation
- Car starts and stalls immediately? wtf?
- b18c1 question
- ** WOULD 98 GSR interior FITS a 94 integra rear parts ? ?**
- will b16a header fit LS ?
- Differences between earlier gsr trannys vs later model trannys
- Big favor needed from someone with a 98+ integra only
- replacing cat
- how much would you pay.....lots of detail
- Who's teg is this? Nate?
- Wheel Offset question
- For Integra RS Owners...Question about Rear Tailgate Glass
- Clutch getting harder to step on
- Any have experience with Exedy Stage 1 Clutch?
- rhd conversions
- GSR for Ls\Vtec
- Clutchmasters Flywheel Offset
- camber kit
- Are 94-20001 Clusters interchangeable ??
- Integra LS with Skunk 2 intake manifold
- legend/nsx calipers
- People with JDM gauge clusters
- how to detect a true Type R catback
- Neuspeed struts, upper or lower?
- shift lever dimensions?
- Need help from So Cali people
- HELP i just Blew my motor into Pieces... Help
- is this where the feeler gauges go when doing valve adjustement?
- integra rear disc brakes on 88 crx
- Stock Springs and Struts
- clutch not engaging properly on teg...
- Where to tap into power
- quick question
- skunk 2 manifold on gsr
- Brake Problem
- EG to DC compatibility on parts
- squeeking noise
- How fast do you think my 96' Hatch is in the 1/4 mile with a B18C and LSD?
- What is the redline of a 97 GS-R?
- 99 white integra stolen in Henderson,NV
- Anyone have info on h22 swap on a 4 door!
- Just installed Skunk2 coilover and the back is boucyyyyy..
- climate control
- can i sawp my gsr computer for a type r
- motor mounts
- are H&R Race springs yellow or red?
- thought you guys might like this diy`
- whats a good suspension setup to slam a G3 teg?
- What do I need for bumper conv?
- Those with Vouge Silver Integras...Need color code...
- BSQ's new web site?
- Results of my 1st drag visit
- Would a ac unit from a 95 civic work on a 94+ teg?
- weird ass ticking sound when i start my car
- rear shocks
- Anyone put s2000 cluster in Dc2?
- How to get M/T ET Streets on my Integra
- will Headers from a 96GSR fit a 90LS?
- Suspension Techniques or Eibach or H&R or Tein or Progress or Skunk2 ???????
- poor man r setup times
- integra motor codes..
- recharing AC problem
- Need Advice.. Going FI on 90 teg.
- 94 gsr spark plug gap?
- will 95 interior fit 93 integra?
- how much to pay for a lsvtec
- car wont start when outside temperature is hot
- defected Koni yellow?
- Brake Problems
- anybody switch from sportlines to pro kits?? if so, what's the difference??
- cable to throtle body
- Need help on ABS trouble code for 96 gsr
- alternator mounting problems
- WHO FROM THIS FORUM DID I MEET IN KENLY NC ABOUT A MONTH AGO?
- itr intake manifold for gsr??
- Anyone have Skunk2 Race springs? how are they? Spring Rates?
- Cooling Problems
- Help can post reply.
- anybody with a SkUnK2 manifold on their GsR??
- Need help with lower ball joint.
