View Full Version : Acura Integra
- my civic/GSR swap
- oil coolers
- Which color of integra do you like?
- What should i do now?!?!?
- i need MORE HORSE POWER
- Lowering 97ls 1.5 to 2 inches.
- opinion
- Stolen Blk GSR in Wash. Heights, NYC!
- does taking out the thermostat cause the water temp cel to turn on?
- GSR Cluster in LS problem
- my A/C fan makes huge noise.
- ?'s on DAs
- jdm b18c question....
- tein suspension
- Custom Exhaust?
- Omnipower LCA
- oil pump question
- just wondering????gsr or ls???
- ERROR 41?
- so do Integra's have a Mass Air Flow sensor, or just MAP?
- Paint on front lip/bumper
- New TB=No Cruise Control
- Where do I buy gold SRR LCAs for my GSR?
- WTB: Integra 94-01 wiring stuff
- ls oil problem???
- 93 p72 head??
- what oem honda rims look best on DA's (any pics)
- OBD2 and OBD1
- air/fuel ration gauge ?
- My Swap IS COMPLETE> GSR INTO DA> Check out the pix :)
- i want to convert my 01 ls teggy to v-tec..
- One headlight is brighter than the other...how to fix?
- Clutch Pedal Problem
- v-tech or not
- skunk 2 ss question
- amber light
- wheather stripping
- All motor LS
- Need help with engine shaking..
- 95 GSR in a del sol
- Random shots of the Tegz.
- max Rim size with no lowering
- Pic of buddy club rims on dc2
- LS and GSR oil pan..same??
- spark plug wires = out of order??
- Integ pics
- Going price on 99 Integra tail lights
- apexi n1 soundclip
- Odd question, might be sold might not
- Type R Linkages and Short Shifter on GSR
- everyone look!
- skipped a tooth?
- me too
- help me diagnose why my engine runs so horribly
- Broke Tach?
- distributor??
- 4door rear bumpers
- GSr tranny
- coupling for aem cai san jose area
- tafetta white paint
- jdm itr lca's on a 94 ls
- Plugged Cat....
- Coolant catch can
- Shifting Problems on my GSR???
- spark plug wires
- electrical load detector
- Distributor?
- How do I verify if its a real GS-R?
- ATTN Optima 51R Yellow top owners!
- USDM engine store?
- wat should i run in 1/4
- Dent in Rear, Suggestions?
- 15x7 rims 205/50-15 tires What Offset?
- bottoming out with new camber kit?? why??
- wheel stud install, now screeching
- Need help with light system!!
- Best i/h/e combo for gs-r?
- RSX type s swap question
- Motor is damn hot!
- How Do You Remove The Passenger Side Air Bag?
- Should i even bother?
- Aftermarket steering wheel a little off???
- Grinding when decelerating...
- weldding?
- good junkyard or shop in OC for Integra(DC4/DC2) window trim?
- DA9 engien HELp!!
- Help.. 4th Gear Synchro
- Speed Sensor Question
- MY DA Ls/VTEC build! with pics.
- quick question about front lips
- Auto Transmission Engages Rough in the Mornings But normal later
- GSR input shaft bearing part #
- gsr header ?
- which da camber kit
- hi
- sounds like a sti!
- how do ypu put a pic on a new topic
- Installed my civic radiator into my DC4 today
- what is the pounds on the flyweeh and clutch?
- liscense plate relocator
- were can i get some good header at
- code6 ECT- why?
- Integra ls DC sport headers problem
- Please help, car runs like a POS!
- What test pipe will fit this combo? Thanks
- Mugen steering wheel install?
- better performance for a 98 LS
- which rack and pinion should I buy?
- another "idle problem" question
- need HELP ASAP!!!!!
- skunik2 stage1 cams with stock single springs and retainers (gsr)
- LS\Vtech The SETUP of the Year
- Im confused... what goes here??
- what years my motor?!
- new to forum
- starter clicks really fast! HELP!
- DA integ seats? wut to do?
- Anyone who works at a Acura Dealership?
- NEED HELP WITH LS SWAP
- Door Latch removal!?!?!?!?
- skunk 2, bbk, eldabrock intake mani ? whats better? whats the best bang for your buck
- Da springs results
- show me your turbo da's
- Stolen White 95 GSR - South Sound WA
- oil pressure drop and cant figure out why
- help with 90 integra
- what gains would i get with ls/vtech
- Replacing lower shock mounts
- ES torque mounts
- NEED HELP NOW!!!!!Clutch ?
- tranny pin
- I needa seat rail
- Key unlocks only one door...
- Longer windshield wipers...
- HELP engine
- HIDs in DA One Pieces = No high beams? WTF
- removing rear window whiper?
- Code 4 on a DA
- 92 gsr ABS removal - damn that shit is HEAVY!!
- i need help with some new shocks
- What is the housepower on 96 Integra LS???
- DC/EK suspension interchangeable?
- 16x7 with a +38 offset?
- rear lip
- Exhaust poll for integra
- ?'s to ask when buying a used jdm motor
- rattle during vtec operation
- painting valve cover
- Under Dash Fuse Box Question?!
- rattling noise
- What kind of Intake are you using?
- 94 gsr teg, oil leak??SMOKINGG-??
- Omni Power Drop Fork Conversion for DA
- California smog guys in here!! Need help with a JDM Car.
- Front shock damper fork
- axle internal help
- PIC REQUEST: 94-97 /w mugen CF lip
- Air Conditioning A/C reinstall
- Why would this happen?
- Suspension clicking
- GSR or LS (s80) transmission RPM to MPH???
- msd box ????
- rear main seal
- resistor box help asap
- ls ecu's?????
- Here we go again, more problems :(
- What to use to stick mirrors back on?
- Flushing Radiator
- LS VALVE COVER GASKETS
- HELP!!!! im working on this right now!
- what would u do??????
- Brake Pad Reviews/Advice??? I Need 99' GSR front brake pads, Daily Driver, please help?
- for sale
- Auto tranny ls/vtec ECU
- JDM integra headlights part # ?s
- Problem with idle
- problems with my gsr
- Shock question
- airbag
- removal of a/c ?
- custom exhaust
- Approximate Price On Paint Job
- Locking wheel lug nuts on OEM wheels
- if i was to make my gsr look like this.....post your personal opinion.
- Quick!! WTF to do? Buying an engine swap
- B18B IM on B18A1
- b18a oil pan the same as b16??
- Header question
- what are these rims
- Scratching 5th Gear When Shifting
- air conditioner question!!!
- Need advice. Car is having trouble starting
- Hello everyone- not tech related but very cool!
- WTB:Anyone selling a 94 n up integra gsr?
- Leaking A LOT of coolent :(
- VTEC bog?
- 96 integra gsr srs light
- EP seats in an integra?
- Innovative motor mounts (DA)
- bad tires?
- JDM B16 XSi Swap, what Spark Plugs to use?
- WHEEL QUESTION
- cracked headers???
- ITR Crank Rod bearing sizes.. Green = 2,001->2,004, what is a ITR Green/Green?
- Speedometer doesnt work engine code flashes a code 17
- CEL 72 Random Misfire. Car Jerks Hard through Lower RPMS Ideas?
- cold air intake filter fitting
- Integra Front bumper bottom bolt tweaked?
- What would you do?
- this is not tech related! but....
- My 5th Gear Scratches When I Shift Into It
- HID Retrofit Question
- Any difference between an ITR thermostat and a B16?
- B16/B17/ITR all use the same Timing belts, water pump, tensioner? Correct?
- b20 swap
- Need help changing axels
- Hi, I'm new to Honda Tech. Give me a welcome.
- [PICS] Is this normal for an Integra?
- Going back to stock ignition
- integra on Craigslist! jdm front
- ????when does the vtec really kicks in ..in a gsr
- question to anyone with stock ls motor with pvc valve on valve cover
- help i need b18c1 swap info for a 1990 integra
- k-series in da's
- How many of you are running stock internals/ LS/VTEC?
- Water and Intakes
- engine swaps
- where to buy arp headstuds
- my engine
- pic request [control arms w/ stock sway bar]
- Fuel Injector Question
- 94 gsr build with 82mm type r style pistons
- Insurance policy? Need help!
- hooking up water lines in aftermarket throttle body???
- my 99 Gs finally done
- 92-93 cams in a 90??
- Car Shuts Off for a Second...
- ALL MOTOR VS TURBO
- compression test help
- Scratchy Metal sound
- From the Type R Forum, Omni Power Clutch Master Cylinder Installed
- b18a1 in 94+ shell
- Converting from OBD1 to OBD2
- LS Crank??
- Difference
- stock DA fuel pressure
- Pressing the Hub Out
- Are distributers known to go out on our cars often?
- Cable tranny case question
- Did compression test and.....NEED SOME ANSWERS!
