View Full Version : Acura Integra
- Rotor Screws
- red usdm itr pix
- IAB's after intake manifold on obd2
- New To HT... 2000 Intergra GS... big plans to come!
- vafc
- Anyone with a 98 LS in CA help me!
- 6puck or full face on xtreme act pressure plate?
- Best exhaust setup *Including Jdm 4-1 header*
- AC Problems!
- my rebuilt poormans type R install
- should i be worried or is it ok ?
- how do these spark plugs look ? lean? ? ? pics
- b-18 LS integra parts for sale
- Vacuum hoses
- Found a good shop in O.C!
- Need Help On Rims?
- Pic request of 15's on a 94-97 DB7/8 PLZ!
- New goodies for my Integra
- Idle fluctuate on startup, have tryed everything....help
- 00 gsr problem on acceleration
- Please Need Help With Oil Question ???
- need help on castle nut...
- air in the remote line for an electric oil pressure gauge.. problem?
- help, did i get ripped?
- Hello !!!! I m new on this forum anyhoo I need help !
- Why doesn't my car go "beep" 6 times when i turn to ignition??
- Hello I am new on HT.. can someone tell me how to reply and such
- Vtec Controller
- What is the main difference between those mufflers?
- Blown headgasket question...
- 2dr front end on 4dr?
- need help locating cvs Valve
- Type R throttle cable for skunk2 IM
- GSR Axle length..?
- MAJOR issue! my car started on its own and drove onto a curb!!!
- which oil to use
- How soon should I replace my spark plug wires?
- wheel whores help me out
- 94 gsr leather front seats?....
- leather seat guys...
- i need part numbers PLEASE!!!
- type r ecu
- little help..
- Cluster wiring? missing stuff? Help!!!
- Checking CEL code and get one long pause. What is this please?
- I need to know which cams to go with in my 2000 gsr: ITR or CTR?
- CEL + Fuel Smell questions/suggestions
- oil bypass is at what pressure?
- window switches...
- s2k antenna covnersion...better signal?
- what brand????
- how to identify stolen motor....
- acl bearings - race or standard
- i this a good deal
- My Teg and Mods......
- don't answer if you don't know!
- Jdmshit.com lips
- Difference between Type-R and GSR suspension?
- JG 301 Cams
- tornado fuel saver?
- What header is needed for my B20 vtec on my Teggy?
- ( Share Time ) - My NA B18C build -
- is heatshield recomended ?
- something in the way of installing front strut bar
- how easy is it to replace the outer cv boot of an integra ?
- Question
- how do i know if driver side axle is in all the way????????
- Was Low on Oil for THREE DAYS. could this have damaged my BOOSTED MOTOR?
- flucuating idle dc2
- ATTENTION NORCAL H-T MEMBERS!!!
- LS sat for 3 years, will not start. Bad fuel?Timing?Ideas? Help!!
- Luminics head light bulbs
- gsr-type r rebuild?
- OPTIONS 4 A DA SWAP
- 2.5" or 2.25"
- Hi, im looking to purchase a 98+ GSR integra, things to look out for?
- gsr buring oil??
- BLACK?
- INJECTORS
- IM and TB Install Complete BUT Have Some Problems and Need Help
- Apexi WS2 Is Quieter Than Greddy SP2 By Far
- DA questions
- Need help installing intake manifold on integra GSR
- integra wont start.....
- Exedy Organic clutch, Low engagement point
- alt question
- DOHC VTEC badge for GSR
- are the coupe integra passenger side fender same
- will i pass smog??
- what other tie rod end will fit on the drivers side of an 94 - + integra
- Building the bottom.
- Rebuilding for LS/VTEC ????
- Another Integra F'ing stolen. Bastards.
- What Computer to use?
- S-AFC II
- baby seats
- vafc help!
- film on headlights
- Raise in fuel pressure?
- Installing JDM window visors for 4DR....???
- JACKSON HIGH FLOW CAT ????????????????? QUES?
- Proud new owner of a Black on BLack GSR!!!!!
- 1997 GSR o2 sensor question bung????
- megan headers? any good?
- Chicago
- ls-vtec
- gsr wishbone?
- my dc2
- Strange Pump sound
- milano red gsr...?
- is there an appropriate time to shift gears?
- bad problems with my integra dc-2
- what to do when changing pistons
- Stock gsr reving to 8k cause valve float?
- Were GSR sedans ever offered in Milano Red?
- ITR brake upgrade install
- stage one cams
- Vaccum Diagram
- LS/VTEC Oil Supply Question?
- tein springs
- need help buliding motor
- car runs faster at cold temp....why??
- Side markers
- b18c block , p72 head, pr4 pistons
- Just bought my 99 Infiniti G20 Touring Edition..
- APEXi N1 cat-back Question?
- teg mugen/spoon replica pix plz
- b16 ys1 tranny high on tranny side in a DA 4door integra
- What kind of motor mounts are these?
- Bad Idle, Need Solution (searched, many times)
- What's the value of this?
- pic
- Springs, Looking For stock drop or no more than an inch all around
- some pics of my car
- exhaust piping question??
- b16 tranny?
- 97 ls CEL codes
- smoking question??
- Tail lights and gauge cluster lights out!!! PLease Help!!!!!
- transmission fluid... is this true???
- a little advice please
- New Clutch Replacement
- dc2 pics
- emission's help
- new pics finally
- Heater Fuse Location
- hot wheels
- LS/VTEC, what wires need to be added to a 96 Teg RS
- Axle and Halfshaft Wont seperate.
- DA seat belt fuse location?????
- New-b PICS!
- which swap...
- intake which one?
- I need help building exhaust front to back
- LOCKED OUT!!!!! need help
- B16 in a DA
- skunk2 exhaust quality????
- can anybody help me with ABS
- amber high beams?
- 96 gsr negative output wire
- jdm itr header with a 2.36" exhaust
- need help tranny popping out of gears
- Help with header leak
- NEED HELP QUICK!!!!! should i get the LS or GSR
- requesting pic of GSR throttle cable connected to the TB
- Wiring LC1 into 92 DAs
- Wiring for horn on MOMO steering wheel....?
- clutch sinks, clutch fluid leak?, can't find out where..
- i found this somewhere once but can't find it anymore, anyone know?
- Help! Grinding noise on 3k
- Tein EG springs on a DC2?
- would u pay....
- antenna question
- Broken VSS...
- swapping my B18B to a B18C
- timing belt tensioner oem of aftermarket?
- Multiple gauge wiring help
- No oil on the dipstick
- STOLEN!!! 1994 Integra GSR
- JDM Power Folding Mirror Wiring Diagram
- NEED HELP ASAP. Electrical problems, bulbs
- should i be worried? help
- rota attacks
- Service light reset DB8
- is short shifter bad ?
- 92 Teg question
- guys running the AEBS manifold. what strut bar are you using??!?
- USDM Type R Gauge cluster in a 95 Integra PROBLEMS??????
- flowmaster for 90 gs
- 98 GSR without an OEM oil cooler?
- 4-2-1 or 4-1 header
- POST UP PICS OF YOUR IN CAR CAMERA MOUNT SET UP
- exhaust question
- ls block type r head and a turbo
- Bye Bye Side Moldings (DA)
- more hp
- Where to find a Type R wing
- Why is there a rattle noise only at 1500K rpm???
- Yellow Fogs... Help
- 96 integra ls/se code help
- ls/vtec (gsr head and p72) acting slugish.... Please help!!!!!
- rotor button screw
- Noise when shifting.
- 96 integra gsr question
- Integra Seat Belt Question
- 95 gsr problem
- Where Do you guys get your Rebuilt Axles?
- Seperating Inboard joint from Intermediate shaft Please Help!!!
- DA swap/ or not
- Forged piston
- Question about my gsr block and a ls block.
- hard choice
- type R header
- Running Hot
- New Guy needs help
- spark plug wires
- help me out question on rod bearing
- more compresion
- bumpers
- valve guide
- Bouncing off rev limiter
- BROKEN DRIVER SIDE MOTOR MOUNT
- a lil help please
- wats your drop on coilovers???
- ahh help!
- Brake question
- Which HKB HUB fits my dc2?
- DA rear fog lights?
- I need you guys opinion on this DA I wanna buy
- 2nd Trip to the track.. 94 GS-R Sedan.. Times inside, slips/video soon to be posted.
- transmission problem
- rebuilding turbo gsr
- Spring install????
- Post your nitrous non F/I times here
- Upgrading Brake master cylinder
- Dropzone springs for DC2
- Lc-1 wideband in Obd2 integra CEL p0135?
- Quick brake question
- newbie
- Tensioner noise?
- msd spark plug wires
- weird freakin problem on my gsr.....
- snow chains on lowered integ
- B16 head questions
- GSR VTEC WACKK???
- help!!! clutch master cylinder replacement!!!!
- new brembo roter brake pads?
- Auto to Standard
- installing mud flaps question
- DA h4h bulbs....
