View Full Version : Acura Integra
- KYB AGX for integra warrantee help!
- 94+ GSR BRAKE MASTER CYL same as 92-93 GSR?
- 'cutting out' problem with track car
- b20 help
- LS VTEC or DOHC VTEC?
- GSR VS ITR
- need californian opinion
- Best Suspension Setup
- Skunk2/Spoon rear strut bar, cut plastic?
- dunno if this can be asked on here..but worth a shot
- Oil Filter Threads
- throttle cables
- obd2-obd1
- jdm sh!t 4-1 headers
- Eg or an Dc2
- Diff ??
- Cylinder 1 and 2 running leaner than 3 and 4? WTF?!
- what a problem.....
- Integra GSR Bolt-Ons
- CEL please help..
- no check engine light but P0441 code
- Making an LS compete with a GSR
- difference in rs to ls?
- Quick question
- what oil is best? 97' ls w/ 124,xxx miles
- i need help with this
- hesitation at 2-3k rpms
- Price Quote Range
- Reverse lights / Shiftlock
- 99 Integra LS auto won't go in revearse
- Help me rebuild my GSR 1995 engine
- Vote: Have had distributor problems or no? common vs. uncommon
- b16 turbo
- Problem with new ecm (ecu)
- 97' ls distributor problem?
- Bad smell and smooke
- 90' GS
- Firewall map sensor to a TB map sensor?
- hytech header ground clearance pic please...
- Brakes!!!
- Da axles
- greedy turbo kit with evo8 intercooler
- B20A Camshafts In a B18b?
- B18
- b20 block!!! help!!
- Need a new clutch soon on a DA, suggestions?
- ukdm edm dc2 foglights
- HELP pasenger window not working!!
- power steering bracket question on my b16 in a da
- exhaust question
- bride zeta 3
- Need some suggestions on my 90' GS
- need help with headlights!
- do i need new tie rods?
- How could i tell if the Ignitor Unit is going out?
- How much tranny fluid?
- Skunk2 springs
- Help with short ram part
- pod filter
- Sellin a DA
- question about cupholders
- Electronic Oil Pressure Guage Install Questions
- confirm my worst fear....
- CEL codes 72 and 74..... any ideas?
- 93 gs integra
- axle shaft
- clutch topic help please
- What kind of caliper are this??????????
- code 14?
- Reverse Lights not working
- Fail Hydrocarbon
- help >>> (Dropzone) coilovers question
- Gsi vtec
- motor mounts vs inserts
- steering wheel hub (good fit)
- steering wheel question???
- Kind of a weird post...but for those who have had their tegs (or friend's) stolen, what kind of secu
- where can i buy an Si-VTEC front bumper?
- electrical problem....maybe someone knows whats wrong...
- quick questions about cat back between 96-99 gsr & 2000-01 gsr
- Will a MOMO hub from an EF work on DA??
- turbo GSR internals
- Turbo Gaskets?
- Acura Parts Down
- my sorry post for a misunderstanding..
- Who Has Msd ignition On a gsr? need help
- any difference in the 2?
- Which suspension?
- anyone know of a small front lip spoiler 98-01 other than ITR?
- HElP ME CHANGE CONNECTING ROD BEARING AND PISTON RING
- Will an LS console fit a GS-R?
- 95 GS-R Axle Problems
- wierd noise (like a ricer sound) only at 3k rpm to 3300rpm
- Want new fuel lines
- What do you guys thinks of this kit???
- suspension.
- Hate it but have to do it.....
- Comp Test/Bad Piston Rings?
- Thumping noise coming from axle
- radiator
- transmission grinds
- Car putts on low rpm if you push on the gas hard. Why?
- rod bearing question
- Damage troubles
- B18B vs B20B...
- upper table
- headlight problem help??
- ls vtec integra running lean???????
- steering wheel compatibility?
- front of car shakes real bad when i get to 40mph
- crower stage 1 cams
- Car shuts off immediately after turning it on, anyone have this problem?
- 94 ls question
- Oil Pressure Gauge Install Question
- engine bay paint/ ground question
- code 43???????????
- Wicked cool integra antenna
- what size fuel injectors should i run
- Need Part number please!
- need help installing an actuator for my "95 acura integra
- How long does it take for the radiator fan to come on after it warms up?
- Integra Sedan Taillights
- Wheel Problem
- What is a good drop range?
- F20C into a DC2 chassis?
- b16a map sensor #3 code, can't get it to go away.
- OBD2 Engine Harness question
- need help wiht stock radio for 96 integra ls
- car shuts off?
- ???? B20 Head ????
- How Can I be a Member??
- nooby needs help with headlights!
- help!! exhaust cam wont move!
- rear lower control arm went bad
- can you lower the volume of your car alarm?
- ctr pistons on ls rods??
- power door lock problem..please help
- ls rebuild, bearing question
- GSR Cluster Question
- san diego heads.. car stolen this morning
- Anyone with a DB8 that has BLOX LCA installed?
- 98 Teg Stock Stereoooo
- Good site to buy Motors off of?
- Are there any jdm front bumpers for 98+ front?
- questions about rear type r sway bar
- Best Fog lights for my integra...
- Painted acura integra dash with DUPLICOLOR VYNLE SPRAY
- need help b20?
- 92 GS-R no power?
- white smoke and little fluid leakage out of exhaust...please help
- Overheating at long stoplights and long freeway drives
- Exhaust and findin out the hard way.
- Header Question.
- Help - Installing pistons, rings, and rods
- Tranny ?
- buddy club spec 4 head package
- Problem with GS-R
- Will this work???
- Cluster problem HELP
- Relocating 94-97 ABS modulator with JDM ITR HID headlights???
- Sedan Side Mirrors - Cant take them off - please help!
- can anyone help?
- jdm front end gap
- cuttin the chassis?
- Removing DC2 headlight need help
- Fujita Intake System? Rain?
- water in engine
- coughing exhaust?
- Question on N1 exhaust vs. Skunk2
- Dim turn signal
- Can I convert my OBD1 valva cover to OBD2?
- sidemarker question
- Noise coming from Suspension/Steering system.
- da shoulder belt problem
- What kind of oil? GSR 1998
- Quick question about jdm front ends...
- Single Cam in a DB1
- Coolant disappear, Compression borderline, white fume, spark plug ground corrosion
- nitrous on a LS
- side skirts
- thinking of selling..trying to figure out price to sell my car for
- Need help with Gsr cluster!!
- DA Interior question
- Installing tacometer need help
- buying a b16 head...
- whos car????
- EG/DC stock exhaust matching up?
- Radio not powering up HELP!
- sad day....
- checking transmission fluid
- Need help with electrical problem for lighting
- ****WTB: Integra DC2 GSR 5-Speed ASAP!****
- Distributor O-Ring. Use gasket sealant or not?
- HELP! overheating problem...
- LS/Vtec which timing belt?
- Drivers without power steering, I HAVE A PROBLEM
- B20B turbo / or GSR motor ...purchase Poll
- MFR check
- Motor Mounts
- No Heat
- RHD Conversion Question
- Integra Owners w/ Kids....
- steering wheel broke? spins over and over without moving tires
- TPS B18C question
- track?
- VTEC Oil Pressure Switch Question
- gsr heater core removal
- Is it normal for Upper Heat Shield to start rattling?
- 1994 GS Opinions
- DC SQUAD
- adjust IAC?
- Whats b18A1?????????????????
- Questions on pulley system
- grinding/rattling/squeaking noises after going over dip
- a misfire problem
- few problems need help with
- starting problem with Walbro 255 fuel pump
- Strut bar - Random Question
- Question about integra 99 value.
- Weird Bogging Problem
- wire tucking?
- type r LCA
- ls turbo build
- need help 96 integra***HELP***
- integra injectors help
- WTB 2001 GS Cluster (kph)
- WTB: 2dr acura integra stock side skirts.
- Fs: Cwest Dc2 conversion bumper-Greddy (replica) BOV
- ls vtec!!!
- fuel pump cut off switch- which wires please help thanks
- cold start
- need help with questions about emissions..... already searched ..
- B18C5 Swap in DA
- RaginBull Edited Video: DC2 Boosted GSR Dyno
- Will 95 ls exhuast fit in 96 GSR?
- 98, teg ignition housing problem..
- very strange steering problem. I need help!
- fuel relay clicking in my 90 teg possible ground issue
- 92-93 Integra GS-R Productions numbers?
- Which Turbo? (not sure where to post this!!! sry)
- Fuel Pump
- Greddy sp2 axleback
- wheel hub assembly
- which motor is faster. gsr or b20
- Keyless Entry Owns me
- wiring v-tec help asap
- Which uses more Gas?
- my power steering died... broken belt while driving. no p/s = ok, but should i worry?
- Strange clutch peddle issue.
- help me find a H22/teg thread
