View Full Version : Acura Integra
- spark plugs?
- STEERING WHEEL!!! rsx dc5 into a dc2???
- $350.00 acura integra
- need to be cautious about anything? (motor swaps)
- 94' JDM b18c into 92 DA illegal ?
- how do you test GSR fuel injectors?
- Integra with H&R sport/16 inch wheels
- new to the site
- xsi?
- CEL = problem with cat
- 2000 b18b into 92 teg
- Grinding noise coming from rear off the car
- drove car 10 mins w/o coolant resoivior
- Integra Idle adjusting
- fast turn signals.
- battery for the Integra
- looking for some pics of cusom made traction bars
- turn signal problems=[
- Break Light keeps comming on! halp!
- DA/DC/DB question!
- Oil leaking from exhaust
- Should I get my rims powder coated?
- Mounting the seatbelt harness?
- vafc 2
- b18c motor swap help
- intake air presser sensor
- A/C Repair / Recharge
- Help a fellow turbo dc out.
- seized LCA bolt. Bought new LCA's, now what?
- GSR motor potenital???
- rotors and brake pads
- does anyone know the offset and lug pattern for my acura?
- What is a hydro tranny?
- Four Corners, no lights. :(
- axle is pulled out too far?
- LS manual to conversion swap
- final integra thread
- Question: Offsets for wheels on an integra
- Quick 97' hatch question
- got cel codes and how and what to fix?
- wrecked my car, now a/c won't get cold.
- ? about A/C compressor on 95 GSR
- B-series question
- searched,- looking for replacement quorter panel
- I need OEM-like exhaust for my 01 GSR and was looking at these auctions.... do you know anything abo
- Need some help guys. Anybody running a b-series and OBD2
- 93 integra gs-r tranny
- Half-core radiators, pictures and how do you guys mount half cores in a DC chassis?
- Will the Endless VN9500 Brake Pads fit Integra GSR?
- opinions on gsr
- Hose kit for type r swap?
- new bumper covers?
- hey guys!
- da is bogging, misfiring
- energy suspenion inserts
- 94-01 integra axle half shafts...
- go with fmu or safc 2??????
- what happens if i don't run a pcv valve on 91 teg
- I CANT SEE!!!!! headlights help
- lsv.. which cams is better??
- Foglight question
- Lookin for a DA (noob question)
- Rear Window Visor!?
- Where's the best place to buy OEM ITR side skirts??? searched
- obd1 n obd2 confusion
- LSVTec - Next More?? Auto - Manual??
- ITR non srs steering wheel
- help annoying brake noise (dc4)
- Question about Hondata???
- How Much Power Will It Make???
- Fuel manufacturers???
- spacers for BMW bottlecaps?
- brake master cylinder
- new header no o2 sensor housing
- obdo ls vtec help!
- Photoshop help
- Engine Light comes on when vtec kicks in in 3rd
- Turbo RS-T @ Auto-X in Deland, FL
- car shakes when letting out clutch in first gear....
- My GSR isnt Starting....
- intake air pressure sensor ???cel
- Overheating issue.
- Fuel Tank Removal
- Idle Problem...wont stay running
- help on trim removal
- apexi gt spec cat back
- GSR Non Leather seats
- would 2dr fit 4dr
- timing belt issue
- Want to buy Gsr rear leather
- does anybody want 2 trade or buy an ek
- Well, bought an LS a week ago....would like your thoughts on price
- a quick question about my integra
- SHAVED BAY DA6 RHD PICS
- fan and heater relay doesnt work
- st corsa cam question...
- Emissions
- codes
- cunningham rods for a b18a1
- B18C1 P72 GSR INTEGRA 95
- spacing out your rim?
- Help: Fellow Teg drivers I need your side view photos
- ls/vtec ecu question
- Car shaking after new clutch install???
- Oil pan what the F*CK
- Anybody have a diagram of all the grounds for 96LS?
- gsr throwin codes
- Low oil pressure???
- STOLEN BLACK 94 GS-R IN JERSEY CITY LAST NIGHT
- Question about integra I bought yesterday
- Rear Lip for DB8
- obd1 jdm gsr swap into obd2 ls teg help
- HELPPPPPPPPPPPPPPPPPPPP
- GSR in DA: Throttle cable trouble
- Photoshoot w/ a few friends cars....
- Car doesn't go into gear when ON and running..
- headlight adjustment
- help please
- Rough start up on 1990 Integra hot or cold.
- knocking in b18c1
- Lowering Springs Megan VS Tein?
- 1995 integra rs...
- how much would you pay for this integra?
- 1998 Integra LS Valve Jam Nut
- Any advice on automatic to manual??
- 96 gsr distributor? need help
- ridiculous camber/ suspension/ steering problem! HELP
- steering problem
- h22 head?
- yellow ITR stolen in San Diego
- Squeaking sound on left front
- axle diffrence
- Test pipe 96 gsr
- New Intake manifold spedo dont work?
- MR2 turbo
- need help with my control module
- Can i put install a high flow cat from a 96+ integra into my 95.
- 91 integra LS/Vtec HELP!!
- Magnaflow exhaust
- Qucik reference. A/C related
- WhenZ the NexT Integra Or HonDa Meet In CT?
- s2k push button start..
- ECU Test Harness
- tail lights stay on
- Removing fender, need help ASAP!!!
- Transmission case issue.
- When taking off the valve cover
- LS vs b20 compression?
- Steering wheels
- Hi I am new
- Turbo exhaust Oil seal
- VID of my stock LS going 14's!
- How do you wire up the horn on a JDM DC2 Honda Integra Type R Steering Wheel?
- HELP will a 92-95 civic sunroof fit for a 95 integra ls sedan?
- Suspension for 1st. gen?
- intake filter only is that bad?
- Trying to find the pictures of this DC2
- Pics of my 92 DA...
- DA Turbo
- something wrong with my suspension
- Side marker wiring with 1pc headlights?
- usdm dc2 headlamp disassembly
- 94 integra
- parking pole??
- any (94-01) Integra's have "oh Shxt" handle caps?
- DA Cable Trans Swap Question!!
- Weird steering problem and sound
- Help sucked up some water
- URGENT HELP!!
- Ls/vtec help?
- 95 dc2 overheats 2-3 times a year?
- High flow cat
- torque numbers
- Conversion? think the guys trying to con me haha
- bad gas mileage
- 95 GSR INTEGRA KNOCK SENSOR PROBLEMS!!
- b16 cams beneficial in gsr head??? (quick question)
- help 99 ls integra cranks/no start
- mounting air filter on throttle body?
- overheating sometimes?
- O2 sensor bad at 55K and 8 years old? Bad gas mileage issue
- skunk 2 coilovers pro series
- 1990 DA integra short shifter help?
- Integra Hood
- Alright I searched. removing wiper, but I have a prolem...
- 95 rear bumper on 01?
- i am throwing an iac code...HELP
- Went wingless, now going back, but a little problem...
- Hey guys, I'm new here!
- Hi, new here..buying first car:)
- where to order LCA bolts?
- modded Vtec Solenoid?!??!!?!? a lil help please
- buying a 97 integra ls help please
- Speedo help! Please
- Join now !!!!!!!!!!
- Exhaust fitment questions
- First time on NEW Noob
- What Type of Gas Should I Be Putting In My GS?
- lsv
- LS VTEC
- integra exhaust bolt sizes
- engine wire harness......
- exhoust system
- starting trouble
- picked up an ls got a fer questions.
- 90 integra runs...slows down
- HKS SMF
- H.I.D
- My horrible RedZone (NorCal) experience!
- B16 hesitant (not smooth) off the line
- supercharged questions
- LS Or GSR?
- ls integra right????
- b18b trans ?
- k20 swap
- cruise control not turning on.
- Seriously, I Just Need a Map.
- code 1508 for obd2 gsr
- obd0 ls vtec
- o2 sensor
- Car won't start.....electrial problem
- 91 integra , Coolant temp sensor wire colors?
- ls in to gsr 54 code?
- please look need help with this picture
- oil in spark plug hole?
- Fuel Feed Line 90-93...94-01
- Replacement Plastic vs. OEM Radiator
- can engine seize because of intake...read for more details
- Ignition Coil?
- size wire to use for extending harness WIRE TUCK
- Polished Blades DIY? Anyone have the link?
- just a quick question
- j1 trans... hydro solenoid attached... CUT...
- needs the helm manual for integra 1990 in PDF
- who makes OEM honda timing belts/tensioner and water pumps ?
- I NEED ANY EXHAUST!!!!!! HELP!!!
- Which motor for '89 LS
- what seems most efficient?????
- vtec
- Goin to the track
- niose in my driver side suspension
- Power Steering Pump going bad???
- 94 teg or 2000 celica gts
- code 6 issue, I'm stumped
- SeaFoam!!!
- hx wheels help
- ebay turbos
- searched but could find it
- Replacing Distributor?
- da radiator into dc.
