View Full Version : Acura Integra
- Shift boot question.....
- Why do I have oil around my spark plugs?
- 93 ecu and harness in 90 teg
- ECU HELP
- block off heat!
- My 1994 GSR, do you like it son?
- 93 integra ECU
- harness question
- Can thieves get a life
- What sideskirts are these?
- LCA's
- Tranny oil ?
- 2001 GSR timing belt change question... when did you do yours? I'm @ 111,111 miles!
- help with trans id & parts
- H22 tb on a GSR manifold
- THROTTLE CABLE PROBLEMS
- radiator leak coming from oil pan...
- few problems, need help asap.
- Wired trans issues (I think)
- CAR NOT STARTING!! please help!
- OBD2
- local mechanic
- next honda meet
- 90 teggy problem
- ls parts
- Tach Jumping at Vtec, Vtec sporadic / tried coil, fuel filter, wires plugs etc
- San Diego HELP!
- ECU HELP
- Help! My speedometer stays on 0.
- need help!!!!!! front bumper ????????
- Very quick question.
- tranny help!
- Engine cleanup
- Distributer question????
- where to get type are lip kit for 94 integra
- Heating prob.(need help/advice)
- tranny problem
- can i swap these parts from gsr to ls
- HELP!!! oil on spark plugs...
- help adjusting alternator belt
- Is LSD better or worse for drag?
- Integra gsr or Honda Si
- oil problem!!!!!!!!!
- New Member =)
- ls bogging real bad
- dc axles on a da?
- **The Official DC Lowering/Drop Picture Thread**
- oil leaking from my head??? can you guys take a look and diagonse my problem?
- On cold start, car idle dips low THEN up
- My clock does not work anymore.
- Is it possible to put an RSX tranny in a 2001 GSR?
- ITR Cams worth the $$$???
- b16a2 and b18a1 cam gears??
- how much to regloss a CF hood?
- do i need to buy a whole new tranny??
- da auto to manual swap
- THIEVES!
- my car is bogging out y????????
- LS/Vtec
- b18c swap with LS tranny.. Possible???
- question about removing dash
- Transmission problem
- Stiff oil pump
- how do i check and see if my distributor is bad?
- quick exhaust question
- how to take cap rotor outta my 96 acura integra?
- rare 90-93 integra parts
- b16 tranny?
- Da auto trans question????? need help
- Automatic Trans Questions.....yes i searched....LOL
- Integra Accident!!
- a engine/injector cleaner question (seafoam stuff)
- AEM base turbo map
- power antenna help
- automatic trans people... ideas?
- Integra Turbo ?
- Fuel converter????....searched
- crazy starting problems... plllllease help i can't get this one
- Need Advice with Engine Rebuild/Swap Options
- buddy club spec II
- more power out of gsr intake manifold
- do civic EK skunk2 pro s coilovers work on my 96 gsr?
- duralast axles
- Smog intake question
- Axles difference DA vs. DC
- 93 integra transformer or model
- Water pump question
- itr clutch
- help with high idle (2000rpm) obd0 lsvtec
- car not starting! please help
- JDM Front
- how to adjust cam timing
- help pls
- DA pics?
- 1995 gsr wit typer cams HELP
- A random question please help>>>>>>>>>>>>>>>
- Do I have the correct water pump for my car?
- B-series Tranny bolt Q's
- Short Throw Shifter info
- gsr gauge cluster
- Transmission Bounce
- JDM Sidemarkers
- would you reccomend? advice?
- speed sensor went out quick ?
- sog with cat-back
- how do you install your lips under your bumper and not on top of your bumperinstalling tye r bumper
- EBAY SCAM DO NOT BID ON THIS CAR!!!
- HP that LS tranny can handle?
- How much should i sell my DA for?
- GC install
- Questions about compression test ?
- JDM FRONT END CONVERSION QUESTION
- b18b1 turbo set up
- brake light problem
- lower arm bars or underbraces
- lamborghini doors on dc4
- cooling issue
- new to the forum, 89 integra b18A1 swap.
- Threw MIL code 90 and 91 after gsr swap.
- Have a question about speed sensors....
- wont roll
- SRS Light
- question on energy motor mount inserts
- lab junkies engine swap...
- resistor box
- Is it possible to buy 1 JDM Stanley side marker?
- Honda/Acura employees help me out! Another Radio Code thread.
- Redrill rotors
- Building a LS head
- turbo manifold
- Door actuator test, questions (reading off of a integra service manual)
- ITR DA header Install
- Why don't my turn signals fit?
- In Need Of Some Help, "Gsr needs some tlc"
- Overheating problem
- exhaust rattle fixed... :drink:
- probe h-beam rod
- exhaust ques
- Cracked Bolt in Steering Column
- b18c1 rebuild questions
- mishimoto rad?!
- ECu
- car dont start somtimes
- dashbored lights help
- Never seen this one before...
- right low beam not working, need help!!!
- could it be the differential?
- 95 integra wont start
- Integra No start problem...cylinders flooding
- question on a vtec built
- type r wing
- pix of heat shield plz
- Exhaust tickets & Insurance
- stereo wiring help!!
- vtec sputtering 2nd gear....
- cam seal plug??
- HEAD GASKET!!!
- ECU data retrieval technique
- smoke coming out of my exhaust
- new to honda-tech
- Water Leak in the Hatch
- integra wont start
- oil pan gasket and axle nuts - help!?
- Tricks how to let my car go faster
- I found a GSR, but.....
- rim
- 5zigen ProRacer GN+ Universal Exhaust
- My 3mm headgasket keep leaking?
- Which intake manifold is better?
- 93' b18c1 ?
- engine dont start
- All my Interior lights don't work!!!
- Intake manifold.....NEED HELP!!!!!!
- Intake Filter has a hole
- Tein S tech vs H tech
- Wondering how much 95 - 01 GSRs go for ?
- lowered integra on the beach
- My '88 Integra Resto
- pulled over rhd conversion and state ref'd
- ls turbo
- Koni Yellows. Mounting Perch? which is the right way?
- turbo on ls stock
- I have a brake problem!
- MAP sensor readings at idle???
- Brake Pressure even while driving?
- how much did you spend?
- Gauge Cluster Help
- Power Steering Fluid is leaking
- tire tread question
- SMOg, Need Help
- Do these swap from an Civic to an Integra?
- no start issue
- antenna not functioning
- shift linkage
- no turns/hazards... ICU???
- will a ls exaust mani fit on a c1 and wat is a evap seloniod
- ignition coil and icm problem
- Wiring HORROR... alarm system removal
- Whats my car worth???
- DA paint job
- 1994 integra Ls tranny build !!!
- 115 mph on stock ls dc4?
- ABS sensor remplacement help!
- Cruise Control Question...
- Do i have to convert to obd1?
- JDM front conversion owners help me !!!!!!
- GSR transmission swap
- Shotpeen ls rods
- K Series in DA? Searched!
- Where can I find.....
- CRX SI wheels on DC4??
- db8 front end conversion
- Which oil pan
- Help oil pan gasket tq specs
- Has anyone used sea foam on a high milage engine???
- Ls Vtec
- Velocity Stack
- Valve train question
- New GS-R owner with some ?'s
- installing ac into a dc?
- engine keep dying
- bad master clutch cylinder,slave, emm or tranny
- turning signal problem. hazards work.
- 2000 Acura Integra GSR Problems
- g3 exhaust on a g2
- what torque wrench to buy? or rent?
- Exhaust flange dimensions
- Just got hit, need some advice
- Blower motor and radio questions?
- Who sells the purge control solenoid?
- after market valve spring and retainers
- Help with state ref ticket! need advice!
- Brake Lights not lighting up??
- carpet4cars integra carpet
- ecu problems plz help
- Wrong Pinout on ECU???OBD2A
- itr headers?
- looking at buying integra gsr.
- automatic with vtec
- new spark plugs = bad idle
- 94 integra jdm headers / flex / cat
- 98 + conversion
- popping noise in 2nd gear?
- Difference between skunk2 and blox intake manifold
- Speedometer off by 10mph
- Will stock mid-pipe, muffler fit LS?
- integra foglights
- Rip Off's...
- oil leak
- Where's the water coming from?
