Is it possible to bypass IAC & Fast Idle Thermo Valve?
Old Oct 24, 2002 | 03:24 PM
teg92's Avatar
Default Is it possible to bypass IAC & Fast Idle Thermo Valve?
I am wondering if its possible to make this whole setup work. I am in the middle of fabricating a custom intake manifold and am curious of the challenge it will arise if I bypass the IAC completely along with the Fast Idle Thermo Valve. I am running with an OBD-I ECU. I understand I will obviously not get the car running high rpms on startup.
Basically both ports that feed to the throttle body via the intake manifold must be bypassed in this design. Has anyone ever done this before? If this wouldn't work, how could I appoach the situation to make it work. Could I modify the Throttle Body etc? TIA
Old Oct 24, 2002 | 03:57 PM
Rory Breaker's Avatar
Default Re: Is it possible to bypass IAC & Fast Idle Thermo Valve? (teg92)
It will work. Just bypass the IACV and run the coolant line directly from the block to the line coming out of the TB.
Old Oct 24, 2002 | 04:23 PM
94gsr's Avatar
If you dont' have an IACV, you will have a high, roaming idle, and you'll throw a code from the IACV sensor. I believe that you'd be fine without the FITV as long as the IACV was there. It will still run, but it's annoying as hell at stop lights - especially if you have a loud exhaust!
Old Oct 24, 2002 | 06:14 PM
teg92's Avatar
Default Re: Is it possible to bypass IAC & Fast Idle Thermo Valve? (94gsr)
Thanks guys! I'm sure there's gotta be a way to hook everything up so there is no roaming idle. I'd like a car that acts like a car on standalone or carburated. Turn it on, watch it idle at like 800rpm at cold....
How does the ECU make the idle roam if it can't control the amount of air the engine is getting and only fuel?
teg92
Nov 21, 2011 07:14 AM
erichackett
10
Jul 27, 2010 06:43 PM
an2ny888
Sep 28, 2005 09:23 AM
socakracer974
Jul 13, 2004 02:34 PM
GreensleeperB16
Aug 5, 2003 07:41 PM
