View Full Version : Acura Integra
- If anybody is able to run a VIN # for me, please let me know. Thanks
- NOS Questions
- Will tokico springs fit a civic? please help
- Window TSB?
- Attn: 94-96 Integra RS owners
- Making Sure Cam gears arrows in the "Up" Position
- Minty's rear cam SOCAL CANYON VID!!!! ~teaser~ more coming
- ATTN: Guys with ITR catback...
- help -redline MTF - which one do i use?
- How to get off the bottom 10 mm bolt for thermostat housing?
- What could be causing my radiator to keep breaking?
- Do i need coolant to compression check my turbo LS?
- ctr and itr cams
- I think my search for a GSR is finally over! Is this a good deal?
- Integra Tranny questions...
- Integra GS-R sway bars
- Pistons and Rods
- quick question about Skunk2 manifold
- 94 LS, where is the fuel pump relay, please need help
- 90 flywheel into 95 ls engine???
- How to remove wrist pins on B20B
- is 90-91 ecu different from 92-93 ecu?
- cracks in Tranny?!
- autometer in G3 teg, dimmer and cruise control
- 1/8 and1/4 mile times of an ls?
- b18a motor
- best place to buy a vtec controller
- ls/vtec or ls/turbo
- ? for those with ls turbo's
- taking off airbox cover for '01 dc2
- pcv assembly help!
- anyone try ITR caliper on GSR?
- Is it possible to remove the blower assembly without dash removal? (92 integra)
- painting Exhaust black, how?
- ITR tranny for LS
- after install of skunk2 manifold.. rough idle.. do i need more fuel pressure?
- What do I need and where can I find it?
- Fuel guage after cluster install...
- yoko A032 tires rubbing in rear!!??
- K&N Filter question.
- Best Block and Head combo for allmotor
- What all needs to be done to swap the b18c1 into a teg with an ls?
- anyone w/ 99+ gsr...help pleeeez (ckf sensor)!!!!!
- vibration while accelerating from 20-25 mph. ???
- header differances? ls and gsr?
- 1/4 mile times-b16 in 2nd gen teg
- Oil Change?
- Skunk2 mani. users....
- HR coilovers
- Mounting V-AFC S-AFC in cig tray.
- time for new exhaust
- Trading the car in...
- radiator?
- DFW People (FYI)
- hot tank a stock block?
- guage cluster problem
- knock sensor
- Nitrous Questions
- for those who cant decide to get an LS or GSR
- LS/VTEC Knock Sensor
- Windshield Wiper Sizes
- Best header for low end torque?
- Turbo=Fast?
- Installed Type-R rear swaybar today and ......
- quiet universal muffler
- I need a good street tire for drag racing?
- DIY ice box with short ram?
- Weird noise under dash board
- Help with Recaro brackets
- Stainless Steel Brake Line Install
- T3/T4 Turbo
- Gauge Cluster install...
- wierd sound from engine
- civic rear seat in teg?
- OEM over CF hood?
- Nighthawk Dodges Bullet!
- ecu reprograming
- Will 90-93 Axles work on 94+...?
- testpipe .com <thumbs down>
- what do you guys think..
- Removing brake rotors?
- boring out the LS block
- Hybrid integra/civic
- Screw sizes for dash/console/door panel
- Speakers replacement....
- For those of you that have Skunk coilovers
- Redrilling 92-96 prelude VTEC rotors to mach our hubs...
- Re: Type R strut bar VS. fake ITR strut bar
- Can I get a...
- Canadian Integra
- OT: Gran Turismo 3
- Jack Maintenance and Jack Oil
- A/C+StopLight=Total Brake Fade
- Removing cruise control in a g2?
- what should I expect from my dyno today
- front bumper damage.
- MSD 8.5mm spark plug wires off LS fit GSR??
- got home and there was a present for me
- eh...Power loss because of heat?
- Bleeding a hydraulic clutch.....
- I want to disconncet my radio antenna.....
- What RPM To Launch At The Drags
- Engine shops?
- anyone own skunk2 stage 1 camshafts?
- Brake nighmare
- Type R Hosted Chicagoland BBQ - All Are Welcome~!~!~!
- AEM brakes
- Check out Comptech Header Exhaust and Carsound
- Vin # on 91-95 LS motor
- How do you change your oil without making a huge mess?!
- Rage Cylnder Brace
- can someone post some pics of teg gsrs with apexi n1 exhaust?
- what type of radiator is this??
- soft clutch
- b&m fuel pressure regulator
- GSR or LS...
- just installed comptech exhaust
- AEM intake question
- will this swap work?
- G3 + N20 1/4 times
- 90 Integra Heating up!!!! Help need!!!
- smell of gas but no leak. ???
- ATS final drive
- AutoX'in Geesers
- What size torque wrench...
- My exhaust Impressions: Greddy SP vs. ITR
- 3G integra tail light suggestions/opinions
- CEL 10??
- US spec. gauge cluster
- Car Show in The Dalles, OR
- Wiring help- CEL light on 95 GSR ECM?
- Need help with ABS ring on my right axle.
- is this stock?
- Hearing strange noise after installing exhaust...
- this installation ok?
- those who went straight pipe...
- Threw code 67, fixed it but have a ?
- can i expect huge gains from.... ??
- What would you guys rather do... Motor wise
- AEM Filter
- goodbye motor.... hello coolant
- 30,000 mile Service
- 1st time at track results
- Have A Story for ya
- center console/AC lighting not working.
- crv block
- i need to know the part nuber for front sway bar endlink on 98 gsr? link inside!
- my friend just bought a turbo
- help! cant shift.
- Skunk2 Chipped ECU for Stocker
- FS: Brand new SI wheels
- Mounting a short ram intake
- sohc turbo on a b series
- ECU Reset
- ATTN: Ground Control users!
- Timing Belt question
- starting problem
- techna-fit brake lines
- Do I still have a warranty??? I'm not the original owner...
- 4th to 2nd 10k ouch
- Integra or DSM?
- brake fade/brake bleeding
- automatic 4 door fast?
- Which Radiator???
- Getting 60k tune up done. RANT!
- the years and generations..
- Need a cheap car jack
- leather seats
- JDM power folding mirrors installed(finally)
- OT: insurance rates with used parts...
- IACV on the integra. How do you know if its bad?
- s2k antenna
- R134a refrigerant shelf life
- Is term "Owned" or "Ownz", etc. derived from Fast and Furious?
- Can someone give me the paint code for Nighthawk Black Pearl
- any integra owners live in Georgia???
- Gauge Clusters and Con's to exchanging them/ Solutions to Indiglo Gauge Removal
- Cleaning out the projectors....
- wtb, caliing gsr owner, do u still have ur stock exhaust, i want it in (orange county)
- Do ACT clutches come with throwout bearings?
- any 4 door integras on here? 90-93
- how hard and long to install A/c Compressor on 94 teg?
- my right headlight is dimmer than my left. any reason?
- it's header time!
- definition of a ricer
- revmatch and double clutch
- Anyone here go from a GSR tranny to a JDM ITR one?
- valve cover gasket
- When to change your fuel filter on an integra.
- FUEL PUMP making noise way to long when starting up car
- To sell or not to sell....
- what do u think my car is worth? just curious..
- beaking in rebuilt motor/clutch
- RPM question!
- Burnt oil smell?
- GSR ins
- Installing LSD?
- Downshift problems
- will my car pass smog?
- Honed intake manifold
- need a little help guys
- car dies and comes back on
- *High Mileage Tegs - oil?*
- long block vs short block
- Goofy A/C problem....
- Best Cams for B18C1 motor?
- HELP, idle wierd, 800 to 1800 rpm then back up, etc...
- how do i get these out?
- What kind of oil???
- drop zone springs
- Check engine light
- Camber kits
- OT: Integra Insurance Rates
- cel code 43
- Will ITR Cams Fit In A 94 Integra LS
- suspension help.
- Is it true 94-95 GSR motors are better???
- visual differences between obd1 and obd2...
- car sound cats get hollowed out? (jdm 4-1 header)
- DC header with a crack in it....anyone experienced this??
- Taking out the ABS on Integra?
- Chicagoland BBQ
- GS-R or SI Tranny on a Type R motor?
- mounting 310 injectors on ITR manifold
- Check out my compression numbers!!!
- whoever got there car dynoed
- power window switch broke :(
- Car running TOO rich!
- 180 miles to the full tank !!! WHY !!>> ??
- Preparing Integra for Storage?
- anyone have a fields sfc instruction manual?
- Pulling a GSR motor from a GSR...
- weird sound when starting
- Can someone run this VIN # please??
- intalling s2k antenna on integra
- replacing air filters
- Taking off heat shield on cat
- wheel stud is stripped
- 94 Factory Security System
- Cleaning out the engine
- is the civic muffler the same size as an integra muffler?
- ECU question
- Looking for 94-01 Steering Wheel Airbag Cover (Black)
- Idle problem. Please help!
- wat gsr battery?
- stick with ngk's or try something new...
- 205/55/15s on stock gsr rims?
- Another what's my car worth thread?
- Carbotech
- What is the best I/H/E combo if i wanted to JRSC
