View Full Version : Acura Integra
- clifford alarms
- help
- Integra 94+ have denso stock radiator or Showa anyone know please help....
- somethign is ticking?
- Will projector headlights help my HIDs get brighter?
- clutch master cylinder
- vtec not working??
- Question about a swap
- *HELP*
- Just got a Teg, have a few questions
- Throttle Body
- Any insight on CEL code 73+74? (did a search, no help)
- Pressure plate(clutch) bolts
- ahhh help! i think my factory wire harness is different then it should be!
- integra coupe and sedan exhaust differences?
- sirg- bumper (foglight install)
- 91 GS + GSR seats = no seat belts, please post ideas...
- Need advise on my suspension ideas......
- LS Motor cam skipped doing timing.
- My GSR was stolen!!!!!!!!!!
- 94 ls bad gas mileage
- GSR intake manifold on LS?
- right/rear brake issue
- nut that came with skunk2 shiftknob won't fit on short shifter
- USDM or JDM?
- ls vtec turbo
- got Spark, Fuel, Compression...still no running car
- gsr head specs. and dimensions
- 90 integra vehicle speed sensor problems
- Integra Vehicle speed sensor problems
- What should i do to my integra?
- EXHAUST RATTLE???
- gsr harness, help me . wat plug is this????
- decent times?
- Keep blowing dash/driving light fuse?? HELP!!
- hydro locked or not that tis be the question
- 95 GSR motor in 97 GSR shell
- AEM PULLEYS
- sick of people trying to tell me what a racer is
- Integra got broken into...
- new ls 1/4 mile times
- Compression Tested! Tell me what you think of my Numbers
- Dynotuning in VA/MD?
- Integra Suspension
- opinions on c/f hatch 94-01 integras
- werid problem when trying to start car
- 95 LS block & 99 GSR head
- Lowering question....HELP.
- California registrationo questions
- cataylic converter
- Help me.
- ANYONE KNOW HOW TO?
- what kind of mounts?
- Will my clutch fit?
- transmission ?
- Question for all you gammers out there..
- Question about tranny...please help
- need information about individual throttle boddies
- Spring question
- hondata or vtec controller
- Any have CTR cams with stock GSR intake manifold
- ENGINE LIGHT! Code 90 EVAP Help me trouble shoot!
- walbro fuel pump
- 5th gear swap
- Is there any installation required to hookup a Hondata s200 system?
- Is This Possible???
- anyone in cali bypass IAC and FITV coolant?
- cel code 45
- omnipower sleeves/shocks???
- Has anyone tried the Bilstein...
- TB's space worth to get...?
- suspension setup
- 93 INTEGRA RS, what to do with around $2000 extra for engine??????
- if my IAB is not working, does it throw a CEL or i wont know its working?????
- Checked Compression Today
- Damn these race springs!
- this is only a test.
- what to do next
- adjusting headlamps
- question on valve spring
- chasis code question
- JDM SiR-G vs. USDM B18C1??
- Dillema Dillema
- need help w/ radiator removal
- just got my 01 gsr need a spring with 1.5 drop that wont make it look like the front is lower
- my dc2 3 steps
- LS Turbo Vs. LS with Multi bolt ons
- Short Shifter
- Headers
- Radio questions
- civic springs on integra
- Mugen Racing ECU
- Oil Problem...my teg takes 6 quarts
- "maint reqd" light is on! what to do ?!
- Does filter on V2 CIA need to be cleaned often?!
- Differences between CTR 5 lug conversion and ITR 5 lug conversion
- GSR leather interior - seats are dried and cracking - any cure?
- Integra 4-dr Suspension Noise
- Good suspension shop in Orange County?
- header/cat question
- yea, another timing question
- Warrenty on Apexi exhaust?
- Removing copper O-ring on sleeved block
- should i grease pressure plate/throw out bearing contact surface?
- question on gsr head
- where to buy mccullouch 9006 replacement bulb?
- 2000Si GC coilovers fit DA integra
- burning oil with synthetic
- Where will the 02 sensor go
- mechanical oil pressure gauge, anyone have one?
- Finally pics of the DA
- any ideas why i keep throwing a CEL
- SRP pistons Quality?
- Need passanger and drivers side front fenders for a 98 or higher Integra
- distributor cap/rotor ( oem vs. auto store)
- Need Help! and comments aprreciated
- GSR vs ITR front CV axel.. the same or diff??
- Where would someone be able to find some OEM optional equip. side skirts?????
- New here just bought a 90 4 door
- Building 94 integra for circle track racing need advice
- OBD2 has 1 o2 sensor or 2-o2 sensors?
- LS Vtec
- How to tell fuel pump bad.
- what's a good drop?
- later....
- Intrested in buying a 4-door DA teg, wondering about pics of any????
- Integra Hood problem...
- 94-97 OEM integra Stanley fog lights on a 98-01 integra front bumper!
- Another Teg Gone
- My Introduction.
- thinking about painting gsr/ls mesh wheels
- Time For a CatBack System
- Just picked up front/rear calipers, MC, and brake booster, how to test if they're bad?
- Please help...Springs from Civic fit on Integra???
- JDM conversion?!?!?!
- Aluminum or steel wheel spacers
- why is a 90-91 b18a 130hp and a 92-93 b18a 140hp
- Off the wall question?
- Quick question about ECU's
- ECU pinouts?
- Dull Headlights?
- How do you read spark plugs?
- hey guys. whats up new here and lookin for some help
- FYI, Volks te-37 on e-bay: damn cheap
- integra wont start please help
- Should I torque my DC header? What should I use to get grease stains out?
- Need help with code 45 (running rich/lean).....How should I fix this??
- lil problem
- Alternative climate controls for 94 + Integra -Custom Dash
- tires?
- free ipods actually works
- 90-93 integra axles
- check light after seafoam!!
- obd1~obd2 integra gsr: are the cat. converter the same length?
- 10w 40 oil put in by accident...ok? or not ok?
- new to integra forum
- Finally got my valves adjusted
- BC or 604 people here?
- Low beam inner lights
- turbo ls or lsvtec?
- Quick Question: Are si and gsr catalytic conveters the same?
- Belts Squeaking
- Still leaking???
- First Generation Integras
- type r fog light install
- 95 teg auto-want to install b16 manual
- Thump up for BLOX IM for b18c....
- Engine Temp drop when I hit the freeway. Help Please
- 4th gear grind with I switch gears
- question and pic of my B18B rebuild...
- Best turbo for built b18c1
- some new 1320 runs and compression numbers, for those interested.
- Bad Vibration
- I have a problem...
- 5 lug conversion?
- interested in opinions on pricing on parting out a 95 gsr
- exhaust question. 2 1/4 piping into 2 1/2 muffler inlet/outlet...help!
- fpr???
- Car sometimes will not go into gear...
- 156hp correct???
- question on b18 timing
- 95' Integra LS w/ CYP sensor problems
- HONDA VTEC SONG!!!!!
- 1st gen integra?
- Buying insurance??
- need technical help integra gsr
- Water Pump -
- PR4 ecu?
- 91 Integra (DA) converting to ITR suspension (pls read)
- Over Heating
- Headrest alternatives for 96 LS/Spec?
- PSi for es100s
- Pace Setter exhaust?
- separating intermediate shaft from axle. having some trouble.
- need a carfax please some one help
- Can I tow a trailer using Acura Integra?
- B20 POWERED TEG SHAKES AND PULLS TO THE LEFT
- Dual Din Radio Block Off Plate
- Exhaust Question?????
- the color of h&r race springs
- what do you think about my setup
- Theft Resolution for Integra Owners
- 89 integra motor.
- skunk2 coilovers
- Tein Upper Mounts or OEM Upper Mounts with Type R bushings?
- 92 DA - When should i replace the muffler
- Break upgrades for DA
- Starting to build my motor.
- ARP rod bolt question
- 95' GSR Intake Manifold Upgrade?
- 94 Gsr with b16 head does your compression drop?
- hone the block with p30 pistons?
- Fuel cut off???
- paint shop?
- OBD2 with ok with vafc2....
- VIS dealers in the BAYAREA
- 90 hatch TYPE R CONVRISOON QUESTion!?!?!?!?!?
- DA control arms.
- ***Input Needed Please*** Exedy Clutch/JDM Flywheel Kits on eBay
- header advise????
- Civic to Integra
- Gsr idle problem?
- do 93 LS' come with rear disc brakes?
- O2 Sensor and Fresh Air
- compression test how to: searched
- Immobilizer Removal ..... Make and offer for service
- tein mounts question
- best swap for DA6
- i haven't seen a g1 integra yet, well, here is one
- Man, someone pls gimme advice!
- Quick question
- Simple yes or no, 90 mount at/mt same or differnt?
- Injector problem need your help.
- What is it?
- jdm 94-97 gsr cluster and usdm 98 cluster question..y or n?
- QUESTION REGARDING MY INTEGRA
- Tranny Q's
- GSR throttle body on LS
- u dont need to run wires for a conversion v-tech swap!!!!!!!?
- GSR Tranny info
- Bought an LS, now what?
- Cooling Question.. can you figure it our?
- maint req
- is high 14's..sub 15's possible?
- Good Exhaust for a 91 LS
- It's getting so close i can taste it....
- so no help
- Honda Rap
- Thermostat location on a GSR? (searched)
- Car is shutting off while driving...help!!!
