bent valves???
What makes you htink they're bent? When mine were bent, I took them to a machine shop and had them measure them... but I obviously had them out of the car and I'm guessing you don't.
Your car would idle like crazy. Up and down, dying on you, and loss of noticeable performance.
Get a compression test done. If any of your valves are even slightly bent, the compression ratio will come out abnormal. If they come out perfectly, then it's not Bent Valves. It's probly another problem...
