View Full Version : Acura Integra
- 2000 gsr turbo 8.5k ebay, y wont this sell?
- Springs which Ones??
- Need Help getting a pic!!!!!!
- Would a blown head gasket result in losing oil?
- Jackson Racing Supercharger Questions!!
- Original RS*R exhaust guys....
- What kinda struts with skunk2 coilovers???
- Will CRV hubs fit an integra?
- jdm recaro
- which steering wheel are you guys using?
- Civic Si tranny in 94 GSR chassis.
- Need help with the Teg...
- Ignition unit needed...
- What tranny for a LS motor? Long or short gear ratio?????
- F20C in an Integra
- Wings west rs kit
- trouble with my windshield wiper
- muffler choice
- forgettin my teg
- difference between ls and gsr catback system?
- Having a hard time getting in gear.
- transmission problem - can't get into 1st
- gsr swap?????????????
- 4 Door Exhaust ?'s
- Question About Shocks
- eibach pro kit on 16in rims i need some pics
- Jet Performance ECU Upgrade
- Show your installed Benen products...
- Car won't start when car is hot...
- seats in a 90 integra
- first mod?
- near death experience........whew!
- Interesting Brake Question...
- noob question here
- Blinkers
- Is it possible to....
- Whats everyone pay in insurance and with whom, how old?????????
- Integra swap?
- Leaning out problem
- Momo steering wheel help
- 17inch rim tire size?
- master and slave cylinder.
- Stolen Integras......
- My dynochart
- How much ignition advance your guys running?
- STS Type R Sway bar question
- Side Moldings
- gsr or ITR tranny?
- 4 door 2g's
- Integra Theft in Norcal(Bay Area)
- Water Pump Bad????????????
- JG Edelbrock Inkake manifold on my GSR. Want to know what hp to expect or times in 1/4
- How much horsepower can a b18b1 handle
- Dunlop SP9000
- cant unlock driver side door
- clutch making a clunk noise
- RS*R is coming back!!
- Can anyone that has a stock or aftermarket LS header sittin around help me out? i need measurements.
- rev limiter
- condensation in lights
- jdm look
- How to make turn signals bright
- Anyone used the "Jackson Racing Cat"?
- LS - All motor to Turbo setup???
- tire size
- suspension question
- lightest rimms out there
- GSR Helms manual owners, need assistance
- porsche brake conversion..................
- What do u think of these rims?
- Aftermarket seats in your G2?
- clicking noise...???
- ROTA wheels
- Installed: "Civic Type-R" trunk brace
- Short block or Long block?
- can someone help me with cam gears?
- Crushed headlight, how much you guys think?
- Custom Turbo Project
- battery weak? new battery recommendations?
- noise help
- Looking for stock steelies and tires 14 or 15 inch I dont care!
- skunk2 im help now please!!!
- blinker not turning off
- Zex Kit into Aem Fuel Rail?
- Skunk2 or Ingalls Camber kit
- cam question
- How long do you wait til you lay down the vtec?
- Integra headlight question
- what do u guys think about these strut bars.
- Swap or Boost?
- Bottom End Help
- need help with parts for s2k antenna conversion
- trial member???
- do you think this is a good project car?
- power per dollar b18c1 or ls/vtec GOOD SITE FOR INFO ON LS/VTEC!!
- Headman Headers?
- DA integra question
- chipped p28 ecu on stock b18c1
- Damn spots on S/S header
- jdm vs. usdm p72 ecu
- anyone know where i can hear a 3" exhaust?
- Lets see your JDM-ITR 4-1's
- Rsr header
- Reseting ECU
- I just got a header, is there anything i can use to clean the carbon buildup on the inside?
- So my buds gsr gets stolen early this am
- Do you always need a camber kit?
- what kind of rims???????
- Broken steering rack, Symptoms
- 16 X 7 OZ Superleggera Offset
- Please Help w/ Exedy Clutch
- Free carfax report this weekend only
- HONDATA HELP?What should i get?What do i need?
- Honda Tuning
- Honda-Tech Help
- Help - Possible Starter Issue?
- exhaust question
- 205/40/16 vs. 205/45/16
- 2000 integra leather steering wheel in 1994 integra gsr non leather?
- Integra codes??? DC4 is 94+ LS right??
- **Theft Question**
- Rolling Fenders??
- Does anyone know if DA engine harnesses (auto vrs manual) are different??
- Dyno of GS-R
- who reprograms LS ecu's the best?
- dent king
- ls/vtec with gsr head?
- advanced the distributor..bad? good?
- engine making wierd noise..
- What are the 14" LS style wheels called?
- how do u take apart the panels behind the rear windshield wiper?
- Need some info on the 94 LS Tranny
- What should I do with my tax refund?
- Timing Belt Tips
- ls/vtec exhaust setup
- b16 intake mani on b18b1
- Cost of valve adjustment at acura stealership
- 2000 gsr o2 sensor on cat question
- for all gsr owners!!
- Finally gonna nab a GSR tmrw! Need advice
- Integra Xi Trans question
- Steam cleaning your engine??
- What does everyone use to clean headliner.?
- need 90-91 Dizzy.
- People with Skunk 2 intake manifolds....
- Models problem
- first post...motor rebuild??
- LS and GSR Fuel Pressure Regulators...
- Starter Problem... help now!
- Ecu question on gsr
- need to know how to get water out of headlight.
- How come I dont see many people w/ 1st gen tegs????
- What to do about car?
- rebuild my motor????
- 2000 integra ecu
- comparison between vtec prelude and gsr?
- high perforamnce tranny stuff
- In need of passenger side fender
- would axle back made for type r fit gsr?
- would comptech axle back work with rest being 2.5 in. tanabe pipes?
- where to take used transmission fluid?
- Stolen FBP GSR in Santa Barbara, CA
- changing belts
- What is that noise?
- will pistons from a 99 ls fit in a 92 or 93?
- is this normal? comptech exhaust install *pic*
- anyone have a comptech pro s/s exhaust or heard one?
- type R controol arms in a GSR
- What is a BSQ Kit??
- whose andrea aunie?
- 87 teg...
- building my engine
- help.....i'm blowing blue smoke
- Questions about JDM OBD1 computer
- Talked to my builder, are these precautions necessary?
- Cleaning Injectors removed from engine.
- pistons:pr3 vs p73-00
- Losing gas mileage, whats wrong?
- what wire from ECU is the O2 sensor for an A/F meter
- question about hondata
- Other Integra Websites?
- How much is this worth?
- How to remove aem CAI filter for cleaning?
- If I rebuilt to JDM Type R spec, how many hp roughly am I looking at?
- s15 conversion
- Question for you all motor LS guys
- Does fuel injection cleaner or complete fuel system cleaner really work??
- What is a good Camber kit for both front and Rear?
- Show me your teg's supension setup...
- ignition key trouble
- What are the benefits of a Hondata?Or should i just get a chipped p28?
- is a 1995 GSR OBDI or OBDII
- Need to change out motor mounts
- OT: Craftsman ratchet crapped out...Lifetime guarantee?
- need help with "Park" ASAP
- Manifold
- Rota wheels and Hubcentric rings??
- Replacing cv shaft.?
- shieTT!!!miss shift and hit over 8 1/2
- Spark Plug Cover for b18b1?
- ever paint skirtS?
- Removed AEM Bypass Valve, noticed that I was losing power all this time! *pics inside*
- pr3 pistons in 94 b18c1
- How can you tell if your clutch is going out?
- funny noise from tire when i hit a pothole
- Quick question please help...
- can i see some exhaust pics?
- 98+ fornt end conversion
- gsr cams in turbo b16?
- Interior Tar
- How do I tighten the trunk release cable?
- how to get rid of happyface
- NE1 have good dyno charts of...
- water leak plz help
- will 90-93 radiator hoses fit 94+ integras?
- Found a 94 LS for 1500$$
- help me find some wheels
- someone please help me with my problem
- Koni installation and Bumpstops.
- A/C Belt too tight
- Brakes upgrade what would you do ?
- my DIY c-pillar bar
- I Have Forseen The Future....here's my shit!
- Broken studs on a 98 gsr
- Exhaust help?
- Which Clutches Have Chatter?
- Skunk 2 cam help
- vtec not working
- how to disassemble the door panel
- Help!! What this codes mean?
- Carsound Cat. and OBD2 cars!!!! Question!
- Ls with b18c5 head?????
- already tried in appearance
- quick question about stock springs...
- can i use this 93 integ stuff on 90 integ......
- Fun washer pump question
- ITR shocks/springs
- will a itr cluster fit in a ls..
- driving gsr with no oil
- B16 Intake Manifold on a B18B1
- Are Exedy's Worth the $$$
- Did the Mechanic Screw Me?
- 96 gsr/se rims
- Engine swap exhaust questions
- Integra Ls w/ gsr intake manifold?
- JDM ITR Guage Cluster Questions
- Noise coming from under my car
- Anyone know fuel pressure and ignition timing for a 2001 GSR with a JRSC?
- Squeaking from the front tires???
- What do I do? Need help quick.
