View Full Version : Acura Integra
- I have $800 to spend on lowering my car. Need expert advise please.
- Actuator Question
- Where can I buy AEM CAI Intake Filter
- Auto trans problems. What is it?
- Turning ratio
- Suspension recomendations?
- 98+ OEM foglight wiring
- b17a
- Check out this fugly car on ebay!!!
- new to honda tech
- LSDs on Integras Pros/Cons
- 94 Integra LS - H22a swap?
- KYB shocks
- Exhaust Piping, Muffler input, output.. Backpressure, info needed
- What year is my engine ?
- camber problem
- 5 LUG CONVERSION
- ******Hey what kind of white color is 95 integra???
- got jdm b20b high compression 1999 motor but no crank sensor
- quick intake question
- Where is the thermostat located?
- hyper sun grounding kit ?s
- Dies while driving at hiway speeds
- NEED!!! 96 special edition green bumper passenger fender and hood 4 door
- Will this exhaust fit?????
- Low-priced header replacement options
- BLOX IM, what bolts/studs do I need?
- OBD Differences for Distributors
- new to honda-tech
- b18b block assembly?
- B-Series First Gen. (56k....uhhh, thats a no no)
- twin loop axle back
- What size is the collector on Edelbrock 2-piece 421 header?
- Help: Check Engine P505 Error Code - Idle System Malfunction
- hissing noise when accelerating
- WHICH ROTA'S TO BUY IN WHICH COLOR FOR MY CAR????????????????
- Corner Light install??~
- B18A1 head on D16A1 possible?
- cracked flywheel?
- car won't start anymore.. help needed
- Repairing broken tab on JDM headlight?
- HELP ME!
- whats up guys
- front ends
- type r rear sway bar
- fenders difference?
- new header,muffler and tanabe muffler. i dont feel the power
- offset fitment - 94-01 gsr
- 99 motor (OBD2) into 94 chasis (OBD1). Need Help
- clutch pedal feel sticky
- some odd noise when
- engine parts question? newbness
- Who makes the most reliable SC for the LS?
- need help
- Removal of an LS side skirt???
- lil problem. plz help.
- JDM Door Swap Wiring Help
- HELP>..
- 90 ls integra Boost
- Valve Cover
- lsd?
- jdm headlight fog cover problem....
- Radio Lightbulbs
- Drivers Side Door Lock Busted
- My Eyes and Brain are permanantly damaged!!!
- need alittle help with my motor build..........
- p75obd2 ecu auto to manual question
- ing, or key swich question
- quick compression question (GSR)
- d15 gsr
- Pulled off the head, how do my pistons look?
- heater motor does not seem like its blowing hard enough??
- Integra Failed Smog Today, someone help
- b20z finally here but one question
- throttle body question
- annoying problems
- Help with Skunk2 LCA's and Sway Bar Linkage
- where to find parts for my b17, 93 gsr
- jdm itr front end, or 98+ front end, anybody have one?
- Anyone got one MR5???
- Brake Problem
- 93 integra b18c1(blown) to b16a engine swap
- HELP! AC problem.
- help 93 acura integra problemz
- i need to do a cheap service to my car, what do i do ?
- HELP HT! simple OBD question(s)
- help with non abs conversion!!!
- back end of my teg shaking over 50 mph
- sway bar sizes
- How do you take off an axle nut without wheels on or brakes on car?
- I pulled CEL code 67 cat or 2nd 02 sensor?
- Quick question: jdm front radiator
- skunk2 manifold
- engine mods using other OEM parts
- getting no power
- Lowering question.
- Please help.. Idle issue
- where to find this integra link?
- where can i find a rear trailing arm?
- hydro locking
- SPINNING LUG
- jdm type r bumper support help
- For those w/a Skunk 2/Blox / AEBS.. a question concerning the CAI/SRI
- Lost key. Need help replacing.
- EG Springs/shocks fit DA9?
- the best
- Tire size
- Integra V6 wild thoughts
- Replacement/ performance shopping
- 98 gsr leather seats
- Integra w/porsche front end
- clutch out
- Is it possible to use 98+ abs unit in 97 below integra?
- Which engine to boost?
- aerospeed coilovers vs. eibach springs
- gsr intake manifold question
- OBD2 Timing cover for LS and GSR, are they different?
- Gas in oil?
- Pulls on Accell
- es oval w/ custom b-pipe
- Integra help
- need tranny??
- ob1 vs ob2 intake
- Authentic Buddy Club?
- brand new axle seals leaking why?
- car sputtering all over the place what could it be?
- Chattery idle
- CHECKOUT THIS 630WHP INTEGRA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
- Weird CEl problem
- best boost for your buck
- where can i send my ecu to be flashed?
- hey! your lights are on!!!
- Will 98-up front bumper fit a 96 LS?
- What would you pay for a 01" GSR 4-Door?
- slow pickup and bogs at 4-6 grand?
- power steering/performance?
- smog results....got some questions
- coolant reservior??
- High RPM on startup?
- foggy windshiel
- Carb Header Vs. Race Header???
- yooooo
- high beams yellow luminix
- anyone in the local 951 riverside area ??
- CEL flashing , Help !
- Energy suspension inserts
- va emission question
- gauge cluster question
- slc utah emissions question
- Power Steering Question
- Sunroof RELAY location? *searched*
- distributor question
- what to do with rest of freon in bottle?
- Check engine light...causes maybe because of high flow cat?
- CHECK ENGINE LIGHT ON HELP!! 95 gsr
- automatic gsr tranny
- quick???????
- Question about ls special edition seats
- integra fog lights
- Anyone know the best place to buy the mounts to put a b-series into a 87 teg?
- Do I need this pulley? Pulled A/C compressor.
- swaping an 00 gsr abs system into a 94 gsr teg HELP!!!
- Road trip from Dallas to L.A
- question about my abs removal
- What's up with my exhaust...
- Crahsed into curb, ends up seriose damges.
- Bad Iacv Question
- Thread find.. Original, Unique, Modifications???
- Squeaky front bushings?
- Whats the quietest exhaust besides stock?
- How do u tell if your cat converter is clogged?
- rod knock?
- Does the Integra F&R calipers fit the 4x114.3???
- What does this sound like...
- cleaning vtec solonoid
- What can my teg tuck?
- defroster switch, clock, and foglight switch?
- heard a rumor (taillights)
- Fuel Filter bad?
- Help please: Radiator fan not turning on automatically (causing overheat)
- cam gears?
- Can I use these WORK WHEELS??
- cel --- ecu light blinks once 1991 integra
- buddy club spec 2
- pic request
- Oil Pan Leak
- What kind of door upholstery to use?
- My Garage Queen
- DA steering wheel hub adapters
- Looking for 93 integra front suspension..mild drop...springs
- heat wrapping
- turbo kit in NJ
- TPS ? *searched*
- side markers
- crazy a/f readings
- Heat Shield Rattle
- COOLANT IN MY CARPET!?!
- jdmshit exhaust ????
- electrical problems.
- JDM Front help
- What are some good Motor Mounts?
- Installing b16.need obd0 pinout
- Distributor LS RS GS
- f/s b18c1 girdle
- axle question
- legend alternator?
- JDM DC2 headlights question
- quick question on intake/header hp gain for gsr
- should i trade my mint itr interior for mugen mr5's?
- Screeching noise when starting engine
- Opinion on wheels size selection on a DC2 Integra .... no flaming.. (really need input)
- Brown milky substance under oil cap
- Ksport lowering springs.
- Damn Bolt
- SiR-G vs. Type-R
- how to get 200whp
- 96 GSR died on my way to work and wont start
- Whats the difference between the 9005 and 9006 bulbs???
- Raders
- 1993 'Teg Auto Trans Head Cluster! ANYONE?!?
- anyone want this?
- b20b wiring
- 4th gen civic full coilovers on 3rd gen teg?
- dumb ass noob question
- headers
- obd0-obd1 injector conversion
- jdm head light
- HELP>>>PLEASE!!!
- DB8 Pics? 4Doors need love too!
- itr cams b16 head
- Eibach Pro-Kit Pics???
- ABS light on after Spring/Strut Install?
- AC removal question
- DA shock and springs?
- Need some help!
- for tha last time are there dc4's or not
- Removing stock spoiler???
- timing belt question
- CV joint emergency.
- Whats in the Starter Circuit?
- lowering springs....
- interchangeable suspension?
- for all the gsr's out there
- need help on what kind of wheels these are.
- Service Manual
- Ideas for JRSC'd GSR gauges? What guages match stock GSR gauges?
- CODE 16 (fuel Injection)?????????
- radio code
- cluster problem!
