View Full Version : Acura Integra
- LSV compression help
- Stock pistons? b18a1?
- 1991 Integra cooling fan issues
- Cyl 1 misfires under 3500 rpm (not ignition problem??)
- Need help getting stereo anti-theft code!!!
- 2000 integra overheat sorta issue
- b18a1 distributor issues
- skunk 2 coilovers help
- 90-93 Integra auto to manual reverse light wiring
- cluster bulbs
- skunk2 manifold, 68 tb what gasket?
- Forgot Knuckle Ring?
- 90-93 integra console screws
- A/C not working
- 01 integra gsr B20 swap help!!!!!!!!!!!!!!!
- causeforalarm site down?
- how many vogue silver metallics are there?
- starting problems
- Newbie
- LS/Vtec Pistons
- Newbie
- electrical gremlin with battery light
- Swapping in an OBD2 gsr motor into a OBD1 LS
- Engine knock B18c1
- 1992 gsr with 98 gsr swap
- 99 integra power window drops and sticks
- quaife lsd install into jdm gsr trans???? help...
- 92 integra problems
- 1992 1.7 acura intera
- B20z2 stats
- new radiator
- b16b piston scratch. pic
- 98+ spec titanium knob w/ oem honda locking nut on 94 RS?
- how to steal any year integra
- 2000 DC2 bloows main fuse unless battery is reversed
- B18c1 with full bolt ons only 145whp dynojet
- transmission
- Hard to shift into first gear when stopped.
- hole on the bottom corner of battery...fml
- Help with power steering pump
- 1994 Acura Integra LS Auto Misfire w/o CEL
- RPM Problems after Alternator swap
- 90 GS Upper Arm Bar Replacement question
- Synchromesh worth a shot? Waste of time?
- Integra post mounts
- JDM ITR headlights, foglights 2 different shades of yellow? WTF
- function and form
- Need Help With Replacing Clutch
- Fuel Overflowing
- New to import building. advice?
- code 15 and code 22 ignition outpu signal and vtec pressure valve
- Guage Cluster Issue
- b18 tps
- Help, idle and bad gas mileage
- Tokico whites are they rebuildable or serviceable ??
- Transmission help
- question about a turbo da that wont start
- New owner
- Main Relay Clicking Fast While Cranking
- db8 bbs rs
- Random Misfire on cylinder 1,2 & 4 Help!!!
- synchro sleeve
- 1994 GSR - Starter going crazy
- 1995 GSR Windshield wiper sticking??
- viper alarm not allowing to start with key
- help! gsr head damage could it be fixed? (pics)
- Water Leaks from Under the Glove Box....HELP!!!
- Won't go into gear, replaced CMC and no other leaks...
- Need Daily Driver advice
- My new 2001 Gsr
- Si-Vtec questions, NOT ABOUT A LIP
- obx lsd question
- 98 db8 w/ obd1 B18C-R basic tune up and ignition questions.
- Help!!! Antifreeze leaked into the tranny
- What's a good set up for Disc Breaks plus pads
- Automatic transmission will not shift to Park or other gears
- OBD2B to OBD1 conversion
- Exhaust Question
- Shaky/Vibrating Steering Wheel
- How to keep Cruise control with aftermarket wheel
- turboing my b18b1
- 95 Integra RS Cranks, No spark
- anyone using a mishimoto xline radiator with mishimoto fans and fan shroud
- no vtec
- ready 4 a rebuilt
- 1993 integra cam plug
- Function 7 subframe brace
- GSR oil pump removal problem
- help building stock gsr
- Possible Rack and Pinion leak.....90' Integra
- making 400 hp b18
- Need help getting rid of my abs light.Can you help?
- ctr nippon rebuild kit?
- 00 GSR fuel rail leak
- hard shift till i release clutch pedal
- Bbk?
- wiring fog lights as running lights.
- Oil pump
- Ls/vtec oil feed line questions
- Parts Question: LSD for K-series Transmission (Phantom Grip)
- having emissions issues
- ARP Head Studs.
- gsr and itr cams
- 98 gsr tranny noises
- car wont crank
- Harness bar vs B pillar bar
- 95 B18C1 Weak compression
- need part number for oem GSR valve cover vent hard line
- Weird idle issues among other things.
- Searched already
- Buying after market manifold which one?
- ls/vtec gsr head
- No spark issue?
- LS VTEC QUESTION???
- opinions
- performance parts
- which motor
- Bad fuel pump????
- valve adjustment
- I HATE THEIVES! LETS SEE YOUR BEFORE AND AFTER PICTURES!
- few questions about my DC2 and DB7
- suspension swap
- need help naming a part
- Help my car doesn't wanna start!!
- HELP!
- 91 integra check engine light :/
- ITR complete exhaust on 2001 GSR
- 98 ls swapped into da9, help with backfire
- 2001 dc2 rpm problem
- heater core?
- B18B1 Spun Bearing, whats my options
- 90-93 Integra DA weather strip advice
- JDM ITR conversion in s.d?? any body know a good shop or site?
- b18a1 crower 404 help
- Is Mobil1 Synth oil good for LS Tranny in a GS-R?
- My New Tegs (issues)
- Bogging and cutting in and out
- Not all Thermostats are created equal.... Informative and detailed post:
- LS/Vtec (slash) GSR question
- car just died :(
- Integra Turbo build need help
- 94 integra rough idle and wont idle when cold.
- Cooland Issue. Please Help!
- Intermittent idle issue after timing belt change
- Throttle Body Spacer
- Throttle body compatability issues/woes
- Integra leaking gas from charcol canister
- Has anyone tried STAGG SHS shocks on their integra??
- da and dc interchangeable parts help.
- SS Brake Lines, Which to buy and why?
- 98 GSR Engine help needed PLS Help
- Will i have any issues running an LS tranny in a 99 GS-R?
- Oil cooler on LS block?
- Searched. 91 DA RS, Hard or Broken Steering.
- b16a after seafoam misfires from 3k all the way to redline
- Rear o2 wiring help
- Shaved Antenae
- im try to rolling on xxr 513 15 x 8 in the back of my integra .. WHAT DO I NEED ?
- simulator
- Vibrant Adjustable Timing Belt Tensioner
- which oil do you preffer?
- Integra losing gas quick. HELP!!
- need help with starting issues!
- weird dome light issue
- Front Lower Control Arm HELP!!!
- AIR DUCT
- gsr header fitment questions
- Play in axle to half-shaft (video included)
- My 98 spec rhd Teg
- lsv vs gsr
- Avg price of a ls teggy?
- List of Parts 2 Go LS-Vtec
- rack and pinion HELP!
- b18b Valve covers interchangeable?
- 98 GSR Crank No Start
- 90-93 body parts.
- Auto tranny fluid change 94 RS
- I smell fumes from my car. HELP!!
- should i get this??
- Help finding replacement ITR bumper white Clips
- VTEC controller or HONDATA?
- ecu problem??
- DR20 or enkei92 ON dc2 HELP!!
- in need of A 90-93 ls DA9 shell
- Wrong coolant
- low idle problem
- Aftermarket Header Clear a/c and Ps in 92 Gsr?
- flywheel question
- short'd wiring 93 da
- splice or solder fuel injectors
- Continued trouble with IACV..
- DC/DB Integra SRS/Airbag deployment help
- keys sandwich inside...
- 94 Integra, Help Me!
- Idle issue!!
- Increase Torque, integra GS-R??
- SOMD_GSR_STi's Journey from Subaru to Honda
- difference between auto and manual harness
- JDM b18c ecu
- 2000 integra LS idle problems
- Help identifying a part
- 94 LS Wont Go Into Gear! Help!
- Can you use h22 plug wires on a gsr??
- e85 what injectors?
- where does this wire go (ABS fuse box)
- Integra/B18 availablility
- Am I missing something on my transmission?
- newer pics of my DA
- Oil pan gasket
- i wanna swap the head
- Talk about a recovery we'd all like to have....
- 94 LS wont Crank, just cant figure it out!
- Tranny issues..
- 97 CLUTCH AND TRANS REPLACEMENT
- B18b1 /auto swaped b18c1/manual
- New to forum.
- engine shuts off issue
- normal driving temperature acura
- Just did a valve adjustment and now i have a knock 94 RS Stock
- Driver's side mount bracket bolts(GSR)
- K20A2 for my DA how much if I got short block?
- Difference between P75 HF-2 manifold and P75 HF-3 manifold.
- Oil pump info I found
- smog
- No fuel no crank? Than 20 mins later it starts, bad Ignition Switch?
- charcoal canister removed?
- B18A1 NA Build
- Noise from front
- question please help
- 2000 Integra GSR Turbo Build
- So this is cool
- OBD2 ECM noobie question
- Dinged up adjustable cam gears
- Idle problems Please help
- Gsr build
- Topic
- OEM ITR lower tie bar position?
- Rear end squeaks
- hesitation problem
- B16 obda harness question
- LSV problems, please help
- !GSR swap w/ broken fuel injector tip!
- ls vtec and b20 vtec?
- Looking to make power on a All motor set up
- Will K series power steering hose fit B series pump?
- 94 Dc4 Project (Need Help Building)
- My first Integra build
- Bouncy idle when cold
- parting out my 2000 integra r
- 1990 b18a1 Acura Integra Won't Start
