- PLEASE HELP!! GS-R problem!!
- help rear passenger wet floor in a 2nd gen
- Idle
- Ignition Timing Steps (
- Duration and lift on gsr cams?
- IDLE SPUTTER: Everytime I turn hard. Rack and Pinion?
- does anyone know of any good brands for rear shock bushings?
- usdm type r header
- hot JDM spots in Osaka?
- OEM - Fuel Filter, Cap and Rotor Button?
- Correct Offset for Integra PIC REQUEST PLEASE
- Check engine code 43, Left Fuel Supply system????
- Cooling fan problem (searched but still have problems)
- 95 Teg has no power
- Need 96 GSR Distributor
- little help please
- need your opinions
- Help! white somking coming from the radiator
- is AEM and DC, California legal??? and would it pass smog test???
- good site to get a cheap b18c to rebuild??
- Oil Capacity
- goes down hill right at 6K rpm...
- GSR B18C1 Bottom Block Rebuild
- making a '92 teg door shut quietly
- brake light problem!
- do i need to repace the head bolts?
- check engine light comes on as soon as I start driving it!
- Will 95 cluster fit on 99?
- please help got a question about VTECH
- coilovers
- gsr engine harness
- Awsome deal on 4dr 94 gsr(bay area)
- IS JB weld ok to use on this ?????????????????????????????
- Reseting Check Engine light
- act or exedy
- exhaust piping questions...
- VAFC---GETTING NEGATIVE PRESSURE ON MY 00 GSR..NEED HELP ASAP!
- friends jdm problem
- Replaced Rear Caliper But...
- GS-R intake - compatible with anything else?
- Help for the newb to the site
- ITR replica install
- Vibration riddle for you guys.
- installed new brakes now it smells HELP
- Weird vibration coming from my DC2 GSR?????????
- 98 frontend?
- how can u make it so u feel your vtec ingage ?
- 98 GSR not hitting Vtech
- emmissions questions
- what colour dc2
- 1992 GS-R 5 speed tranny
- B-series Starter?
- WTB: auto 96' four drs. integra.
- ARE THE INTEGRA OEM HONDA FILTER SAME AS 99-00 CIVIC SI FILTER
- Help ID'ing a leaking radiator hose
- idle problem help! 93 DA
- XTR clutches on Ebay
- Will these NGK spark plug wires fit a GSR?
- WTF?? MY CAR WONT START!
- Stingy bolts.. any suggestions?
- Wiring For JDM 90-93 Integra Headlights *Searched found nothing*
- Head/Dome light issues.
- Any DB8 pictures-just DB8?
- A/C compressor removal
- Front Wheel Bearings on GSR
- Quick Q - AutoMeter vs GloShift LEDs Gauges
- **ARE THESE ITR PISTONS ANY GOOD????
- Important Spark Plug question...*All motor ITR*
- I need help with motor rebuild - b20vtec turbo setup
- Floor Heat problem
- Any one els have clutch problems?
- which exhaust for swap
- good price? 95 db8
- DA not firing
- glowing rear rotors?!...
- you got SiR-G Fog lights??
- replica seat sliders
- WAZ-UP 4 CYLINDER JUNKIES IM NEW TO HONDA TECH
- new koyo aluminum radiator - car running too cool?
- real gsr?
- speedometer not working after swap. not VSS problem!!!
- ITR knob
- b18a swap into a 96 integra
- HID stopped working :( **LOOK INSIDE***
- Turbo Question. 95 Integra LS
- how would it run?
- Yellow Haze !
- timing belt guide question
- rattle sound when the car is cold..
- Need Help Leaking from Block
- How to Wire up Bumper Lights as Foglights?
- New to the DA world!! need some help
- Rear Quarter glass removal??
- brake sensor + car wont move!! HELP!!
- NEEDED: Vac Diagram wanted... rpm fluctuates intermittently...
- need help timing and cover!!!
- 2dr teg's length/width change in 98+? or has it been the same since 94+
- car wont start when cold?
- chipping an ecu
- carnage pix of gsr tranny. any suggetions on a new final drive?
- veeery slow in low rpm, help!!!
- 98 b18c problem!!
- rearbrakes question????????????
- obx brand??
- what size arethe 3 fuel rail screws ?
- Interior Cleaning
- Power Slot vs Rotora
- 98 ls
- gsr header . .
- (PIC REQ)TANABE GF210 ON TEGS
- photo shoot with my boys civic... nothing special just having fun.
- just bought integra not to firmilar with help
- has anybody here ordered from jdmland.com (icbmotorsport.com)???
- integra enthusiests...
- car bogging out....please help
- valve seal installation
- 94-00 manual
- slicks
- Visual Wiring Diagram for JDM DA One Pc Headlights
- new to the site
- turn signal AINT working
- what size cat?
- Had Int. Manifold Powder Coated, coating is all over flanges.... what to do?
- ---APEXi V-AFCII---NEED TIPS
- 1994-1996 ignition coil spec
- Belt screeches after 6k rpm GSR w/jrsc ??
- Looking for a ls/vtec map
- problems i can't figure out
- IM GETTING CLOSER
- NEED Help on BUmper
- RHD da?
- itr swap problems
- gsr secondary activation
- Airbag question
- Which bulb is best
- a little guidence here my brathas
- Gauge Bezel removal and changing bulbs
- vtec at 4400...
- 2000 GS Front End
- ITR rear seats into 95 gsr
- obd2a obd2b years?
- Pulley set? what size to get?
- Methods to clean a contaminated clutch?
- DIY Port & Polish Intake Manifold-Dremel Rotary Tool
- Not able to hear vtec W/ new Apexi ws2 Exhaust?
- alarm questions???!!!
- yellow high beams 94^
- timing belt>?
- rotor in distributor
- tb sizes
- First Gen Integra N00b
- where to buy?
- Gsr cams in b16
- How to read Check Engine light
- Throttle positioning sensor
- bumper
- Any way to replace wheel stud??
- Never seen this before
- Exhaust system
- exhaust scrape
- dizzy rotor help
- Tranny problems?
- Clutch Question!!! Help
- Tranny problems! GSR tranny can't shift into 3rd or 4th at all.
- Burning oil????????
- Need help Asap on JRSC Gsr please
- removing SRS wheel to replace with Type R wheel
- code P1508???
- HELP WITH RADIO CODE
- water and oil pump question
- Need part number for missing piece on b18b block
- heater core problem...
- rear brakes dont work
- i need a grip of help
- o2 sensor question please help
- b20b in a da ???
- Exhaust leak at header/cat???
- air fuel help
- pistons for a b17a1 motor?
- Building B18B1 head, need some answers
- differences in side skirts between different year DC's
- DA9 fog light rewire
- h22 swap into integra???
- sun roof visor problems..
- HELP!!!
- itr/gsr brake pads
- Secondary o2 question... help
- NEED HELP WITH MY CRUISE CONTROL.
- cable or hydrolic?
- Weird noise after stopping then going...
- Cluster prob with 94 LS
- This noise is beginning to kill me.. why does nobody KNOW? what is this Noise coming from?! HELP!
- Struts and Springs
- NEED HELP WITH RUNNINGLIGHTS!
- Not Quite Ready 4 a High Flow Cat-Back BUt????........
- Throttle Lag (searched already)
- going b18c1 in my DA and have some questions.........
- Honda V6
- 92 Integra AUTO Tranny
- Why are Integras such big targets?
- ignition coil....question??
- pressure signal for the vafc 2
- Lowering Spring Fittings?
- Lost Password - Need MOD help
- GSR cable trans??????
- New To Honda -Tech 95 dc2....
- New CRX....Code 1 and 20??
- quick motor question
- installing a vafc 2
- exhaust?
- Spark plug question..for 98 LS
- ac broke and smells like something is burning 1995 Integra
- aiming headlights on a dc2?
- How log before you can respond to for sale ads?
- help manifold ???
- turbo question need an opinion
- Wooosh Sound
- Engine temperature problems....in a 94 GSR
- Brake Pad ?
- 89 integra cluster help!!!
- vtech malfunction
- GSR hitting the tricks tomorrow at fontana (1/4mile)
- OEM Fishing Pole Antenna FTL, i'd like suggestions on something else.
- alternator nut
- I NEED A ''IM'' LS
- HELP: 91 integra grinding noise window won't roll up/down
- What size nut/bolt for exhaust?
- Car bogged then oil light came on?
- tiger japanese auto
- Need help with part name or # - GSR MT cover?
- installing nrg ground wires????
- new engine?
- b18b rev limit
- ls/vtec problem
- What does a Mugen ECU Chip Do?
- HELP! Belts wont fit on ac or alternator!
- DA9 vs. RSX-S One final attempt to DO IT RIGHT!!!
- Car broke down (not enough power?)
- B18B cylinder head Questions
- ive searh.. and didint find wat ive wanted to see...
- Car starts then dies, but only when its cold outside...
- built head knocking very bad ?????????
- 91 Integra seats belts just quit working
- unbolting cams?
- 1989 trans-axel question
- Itr rear sway bar and ASR brace
- wheel advice
- Power FC or Stock JDM P73 ECU?
- wiring harnes...
- Need some advice and guidance. Building my motor from scratch. B20/B18 Turbo
