View Full Version : Acura Integra
- B18A1 help on performance
- GSR/LS vtec swap?
- engine ideas 4 90 integ
- How much money is in your integra?
- Koni/Nspeed yellow Shock Question
- hatch sometimes refuses to open
- Questions about JRSC
- Intake manifold!
- 96 Stock GSR
- i need a front lip for my DC2 w/ jdm front end!!!!
- rear brake caliper not lining up
- tire size help
- Just bought '89 Integra
- best 4dr body kit
- 2.5" collector on non JDM headers?
- WTB: Stock cat back exhaust for 93 Integra PA/NJ/MD area
- What would u guys consider for a nice little Tune-Up?
- Best header GSR (Bolt on)
- Door Light, Cabin Light, and Light NOtifier don't work
- just bought some H&R Sports
- Muffler tip
- Car broken into again....
- cleaning o2 sensor?
- help me please. something rubbing after i got my jdm wheels.
- What Jets For Nitrous on a B18 Motor?
- Do you guys need any parts?
- Rims rims and umm rims
- FS APEXi V-AFC brand new
- Does K&N airfilter give and real gains?
- Anyone her got a VIS front end conversion?
- ITR Engine swaps.
- test pipe or high flow cat?
- dc2 hood weight?
- Bolted on the N1 !
- oil leak from distributor?
- My OEM SideSkirt got messed up (underneath).. Anyone know why? w/ PICS
- Feul Pressure Question on Integra LS
- Really messed up my new GSR bad.. Help please... hit 11k RPM's
- H22A Teggy is finally done!!
- I finally bought an Integra but......
- Anyone have problems with rust on their apexi N1?
- Agh! I hate fuckin thieves!
- Lowered My Teg, ABS light now on. Ideas?
- would an N1 look right??
- where is best place to get ITR sway bar (another itr sway bar post)
- why would both fans be on Constantly?
- gsr stock front strut
- Mid section
- Thinking of painting muffler flat black...
- Installed new head unit, now my dashlights don't come on with my headlights!!
- Selling Black Leather Back Seats
- need help hooking up amp
- suspension of my DL
- maintenance due
- Installing power door locks.
- I want to know how fast an LS wit 10psi of boost would be
- Purpose of city lights?
- ITR h&r springs on a GSR
- 4DR axle back same as 2DR???
- k&n drop in filter
- My Integra Barely Gets 180miles a tank=(
- Turn Rotors?
- speedo doesn't work after puttin a jdm cluster in a g2 teg
- Anybody have pics of Neuspeed short shifter and GSR/ITR stock shifter
- need a distributor for 90 91 Ls
- my windshield wiper
- How to tell an LS header from a GSR?
- Check ECU Codes
- need help ordering from acuraautomotive.org
- What about these?
- Clutter noise when over speed bumps?
- Would an exhaust leak slow me down?
- What happend to Canuck-MX6????
- Fuel Pressure Regulator
- JDM header after install question...??????????????
- Motor mount for Integra...WTF?
- ignition coil
- Which car should I get
- Just installed Skunk2 Stage 1s... Need feedback
- Man what gives
- Sellin my Skunk2 Stage 1 cams...
- ls-vtec or straight gsr
- Will buy OEM JDM front Bumper!
- Headlight bulbs?
- help
- if your speedometer doesn't work will your cel come on?
- Can shocks be changed later w/out changing coilovers again?
- 5 lug coversion question
- Never ending problem
- Sunroof not working
- OEM itr lip clips?
- Help with a part number or description
- harness / roll bar question + handling mod question
- Dumb Question: Do GSR's have oil coolers?
- 94 and up moonroof q's?
- 0 offset rims... will they fit?
- Autometer Oil Pressure Gauge
- Supercharger and twin turbos....
- J's Racing install
- budget intake.
- Where's your 3rd brakelight?
- Question about 4Doors!
- HELP!!! partially built b20b ????
- Rsr header has no o2 bung, what do i do?
- Crashed my INTEGRA
- start up problem
- Headlight question
- Hate to do this....88-89 turn signals.
- s2000
- off topic...how do I become a "user" and not a "trial user"
- ITR OBD2 to OBD1 conversion question (Injector Problem)
- my new homemade sway bar.
- anyone in So Cal willing to help install zex?
- Video clip of my dyno run
- JDM DA 2dr frnt and rear seat Question
- Endyn's Work?
- I can not believe it!!!!
- Common reasons for water in my trunk
- Exhaust Questions
- Everybody call your dealers and check for a recall!!!!
- i need to know where to find ecu!
- A lot of questions.....new to honda/acura....buying gsr soon.
- 240??? and air!!!
- Trunk Squeaking
- which one do i have??
- Where to buy an AEM EMS 30-1000 system?
- obd sensor after straight pipe?
- B18B or B18C
- Where is the very detailed thread on JDm front end install???
- 90-93 INTEGRA. Thread pitch for rear hitch???
- Combining Skunk2 & Ingalls front camber kits
- New Part Pictures - Tein SS, ITR rear swaybar, DC lower tie bar
- removing LS tranny
- does ne one in so.cali need springs?
- moisture in your taillights? here's the fix!
- Check Engine Light
- Hid lights
- springs, coilovers what should I get? help me I have 2 months!
- Insurance
- Shift Linkage Boot Torn??????
- rear wiper removal!
- Where does the fuel return line go?
- ITR Shocks vs LS/GS/GS-R shocks
- group n rotas rims
- Easy question
- oem body kit
- "HOW TO" TUTORIAL: ITR 5 Lug conversion on Integra (detailed instructions w/ pictures)
- Just wanted to show the progress on my new teg.
- N20 on mildly built GSR
- Can someone explain the ecu thing to me!!
- why do you all go for brand name cat backs??
- 94-95 GSR Wheels... how many lbs?
- "This is a listing of businesses in the high performance automotive industry"
- mozart exhaust
- need help with jdm itr catback for ls
- Can I safely spray a 50 shot... wet or dry?
- 9005 ss conversion
- post pics of integra sir-g lip painted
- ?'s: integra going 5 lug
- ITR Springs on GS/LS/GS-R
- id like to know ur opinions about my next car...
- Does your Glove box open up when you shift hard?
- changing the horn
- Do 95 LS b18b have a knock sensor?
- need wheels!!! help
- JDM Fornt end
- MSD SCI problems???
- Trouble with hatch latch...
- Front license plate help...
- tein springs vs comptech
- My car got hit...
- turbo/swap
- 90 LS teg variety in tail lights
- need help
- H7 bulbs the same as 9006 bulbs?
- GSR max reliable power
- Engine cylinder not firing....BS???
- Funny noise when letting off the gas...
- length of Cat for 94 GSR
- KYB shocks
- Wheel Size issue...
- GSR crank vs TYPE R crank???!!!
- 94-97 front end
- Lug Locks/Nuts..Which ones are better?
- Will V-afc work on LS Ecu's??
- what's protecting your teg?
- Help with Rusty Bolt
- Anyone have 94+ rear exterior Integra parts lying around? Socal only
- getting to the strut tower in the rear or a 4dr
- OBD2 GSR P72 ecu questions
- 4dr's window getting stuck
- Someone please quick reply on stock Integra suspension!
- factory leather on canadian 95 gsr?
- Anyone know where I can find
- Race cat and heat sheild.
- alingment kits after lowering
- stupid question, with gutted interior, can you hear your gas swish around?
- I FINALLY GOT Pics of my Integ online!!!
- Teg vs civic
- Getting new car.....Gsr/eclipse GS-T.......I can't decide
- any1 know where the anti-theft code is on the stock radio.
- Re-surface cross drilled & slotted rotors?
- Stripped header bolt related to "header rattle" ?
- things to do when swapping B16A into DA's
- What do our Tegs weigh?
- Water pump removal?
- Help please! Car wont start
- got shit stolen outta my car last night...
- Question about Cams...
- suspension suggestions
- cat. converter help
- pics of my friends and my car
- Front bumper Installation
- ls vs gsr brakes
- Code 25?
- check this...
- Smog check coming up, i ran w/ a JDM ITR cluster for a while should i be worried?
- Took out my back seats
- Removing Rear Panel
- cheap JDM motors, any recommendations
- doing timing belt
- Carbon fiber hood
- 4Dr OEM kit
- 2 questions on this guys integra
- Where to find amber turning signals for DA
- Broken exhaust=any harm taking resonator off?
- Are these compression numbers accuratE???
- A good muffler shop in the bay area
- Factory spec. Head Mill for a GS-R
- Custom harness bar (need feed back)
- Plug Suggestions For Boosted Teg
- Filter Cleaner
- LS motor different from GS
- Labor prices for a JDM front end conversion????
- buzzing or vibration when shifting from 4th to 5th?
- can any1 tell me how to take out my stock stereo?
- DO all 98+ USDM headlights have this problem?
- Which pistons for B18C1!
- hydro tranny speed sensor in a cable tranny?
- Fluidyne or C&R ?? Which one do you prefer?
- How much would it sell for????!!!!
- FS: 2000 Integra GS-R with LOW LOW miles!!! (testing water)
- What intake/induction system to get ['96 gs-r]
- going to the track...
- Aftermarket full cat back exhaust interchangeable?
- How to remove A/C from integra GSR
- Xenon Depot 5000k Philips HID Kit *PICS*
- Diff Bearing Part #?
- Bumpers
