What does the charcoal canister do?
Old Oct 22, 2002 | 09:44 PM
Volcom's Avatar
Default What does the charcoal canister do?
I think that is what the battery sits above. Anyways, I spilled some battery acid on it and burned a hole in the top of it along with melting one of the hoses that connects to the top of the canister. How bad is this?
Anything I need to do?
Aaron
Old Oct 22, 2002 | 09:46 PM
Mr.Rab's Avatar
Default Re: What does the charcoal canister do? (Volcom)
I noticed that the last time you popped your hood, but didn't want to laugh or say anything. bawhahaha.
BTW no advice here sorry.
Old Oct 22, 2002 | 09:49 PM
Volcom's Avatar
Default Re: What does the charcoal canister do? (Dr. RAB01GSR)
So shut up if you don't anything nice to say
Are you ready for this weekend?
Old Oct 22, 2002 | 09:57 PM
Mr.Rab's Avatar
Good thing we got that weak *** ***** system that dumped **** snow, so it could dirty up my clean car. Glad it was now and not on Sunday. And I'm not quite ready yet. I just overnighted some Eibach custom 400f/350r springs. So I think they will be here tomorrow or the next day. And I also went to Kingmotorsports and got overnighted some front and rear strut bars. Then I went to comptech and got me that rear lower tie bar. So hopefully these will all be installed by Sunday....???
BTW just duck tape everyhting back to how it suppose to be and you'll be fine for the inspection on Sunday. Just my .02. And I think that's all it's worth.
[Modified by Dr. RAB01GSR, 11:59 PM 10/22/2002]
Old Oct 22, 2002 | 09:59 PM
Volcom's Avatar
What? You ordered more stuff for the car? You, sir are one crazy SOB. What were the rates of the stock Groundcontrols? Don't tell me that you ordered Mugen front and rear bars? If you did, can I have your old GSR bar?
Old Oct 22, 2002 | 10:00 PM
97hb's Avatar
There are vapors in the gas tank that build up, and are purged into the canister, which then are routed into the intake manifold for complete burn in the motor. Just emissions bullshti, and doesn't affect performance.
Old Oct 22, 2002 | 10:12 PM
Volcom's Avatar
Default Re: What does the charcoal canister do? (97hb)
Dumb question, but if the hose is just chillin in the engine bay not connected to the canister, will the vapors possibaly ignite?
Thanks for the reply
Old Oct 22, 2002 | 11:38 PM
97hb's Avatar
You're probably going to smell gasoline fumes if you just leave it open. If you plug it your purge solinoid cannot purge, eventually causing your tank pressure sensor to trip and throw a cel.
Old Oct 22, 2002 | 11:57 PM
Weston's Avatar
Yeah, it's just for reducing gasolene fumes. I don't know for sure about the danger of venting the fumes into the engine bay though, but I would speculate that it's pretty well ventilated. If I were you, I'd just put some duct tape over the hole and somehow try to reconnect the hose.
Man, Dr. RAB01GSR is really running up that credit card. Hope you get your stuff in time. Good luck at the autocross this weekend, I wish I could be there.
hatmanafro
Welding / Fabrication
Mar 22, 2011 07:23 PM
Bbasso
Nov 24, 2008 01:34 AM
WheaMyRyceGo
Jan 27, 2008 10:32 AM
Sonnboy18
Nov 5, 2003 03:35 AM
MVLZ
Aug 12, 2003 05:06 PM
