View Full Version : Acura Integra
- will ef suspension work on da?
- Overflowing Coolant Reservior?
- CARFAX
- where the dc squads at
- help here
- Check engine light
- Out of the three, which is best?
- Question about problem with gear transitions
- What's the problem? *Video*
- boost?
- need integra parts
- Will...
- dash bulb type
- lower spring
- Can someone tell me what lip/skirts these are?
- I need support and motivation.. or just advice...
- Are quick releases Honda universal?
- fuel pump question
- knocking noise from axle?
- 96 spec ITR complete swap into a 00 gsr???? MORE HELP NEEDED>>>>
- Clutch Problem...Please help
- GSR wheels??
- The Integra I just bought has a strange idling problem...
- **PLLZZZZ help **
- Coupe Back Seat Pull
- Honda integras Whats their pattern?
- S1 tranny the "CABLE type R?
- fuel pump needed asap do you have one
- idle rpms went up a little after valve adjustment
- Fuel supply / Map sensor code 41/3 Whats the cause?
- need help asap
- wats up
- Oil Shoting out of the exhust i don't know what it is plz help
- 1987 integra Ls?
- CHIPS
- DC2 Power folding mirror wiring questions...
- What tranny is this?
- Qaurter Panel
- need help finding rear quarter panels
- need help with my teg 91 four door
- Anyone have 98+ Rear/Front Bumpers -MarketPlace is Failing Me
- Anyone up for a 334 DA Integra meet?
- anyone from montreal?
- new to h-t
- 559 DA squad meet?
- ?????????question?????????
- Please tell me what kind of lug nuts these are and where can i get a key for them.
- 5 bolt conversion
- Ignition Wires auto and manual ?? are they the same
- b18b compatible with b18a
- installing oem springs. dont know which are what
- so ive never bought tires
- Noise from my car
- Where can i get this???
- pics of red rims (just spokes, just lip, or completely red) on red teg?
- h22 radiator hose question
- 97 4dr
- Boosting signal on Shark II antenna
- Exhaust/Piping??
- skunk 2 intake manifold?
- 90-93 rear wheel hub bearing interchangeable with 94+?
- fan trouble
- My DC4 with H22 Build 56k Go away
- Hard shifting into gears - already searched and narrowed the problem down
- did my swap dont know where they go!! please help
- Integra LS turbo
- 5zigen Fn01r-c (Pictures) on Integra
- Were to buy SiR lip for my 95 teg?
- goin rhd in dc2
- coolant resivoir... what to do?
- Radio and ciggereate lighter fuse
- WHY DOES THIS HAPPEN?
- 5 lug conversion from ctr???
- Which starter?
- Viscosity Factors of differing oil Weights
- Bumper piece above rear bumper on integra 2 door
- need help!!!overheat
- USED AUTOMATIC
- whoever has got Spoon Cam for his R plz~~
- Can someone please identify this Intake Manifold on my GSR
- does sears/craftsman , autozone or kragen carry a valve adjustment tool for a b18c ?
- Invidia test pipe for 98 gsr
- Broke Cam Holder Bolt
- new
- Opinions on Tein SS for 94 Integra
- RSX RHD DASH into a DC2 HELP!
- How to keep my JDM front teg safe from being robbed??
- i think i stripped a screw from the engine head
- yellow foglights on da?
- 94 gsr rear sway bar-What is the mm?
- jdm integra side markers
- integra da parts to integra dc
- gettin rid of abs unit 92 integra
- is this a type r tranny?
- Just replace my VSS.
- quick release steering wheel
- My Integra Transformation
- USDM B18C1 TO JDM SWAP B18C WHAT DO TOU DO WITH CKS SENSOR?
- has anybody ever herd of, Ryan Franklin" <kichwa performance
- Anyone heard of DC's tearing at subframe? or is it more common with the civics?
- who got that spring?
- Oil consumption
- Is there a website that has this?
- Max engine bay temperature
- Quaife LSD?
- HELP, Integra won't run correctly
- automatic shift?
- where to find the emblems to covert a da
- Need help with my 95 lsvtec integra
- Searched: Type R Cams as well as Cams. No answer.
- Rust on the rear quarter panel, before and after...hood before and after as well...
- motor cranks but wont turn over need help asap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Integra Carbon Fiber Hood Question. Help!!
- Strut?
- DC JDM 4-1 header/OMNI test pipe bolts???
- da9 just put motor in and it wont start
- integra bolts
- adjusting hids
- what type of alarm systems or tools do yall use???
- who has BENT a clutch release fork???
- 99 ls
- Which is better????
- help with cam choice
- My integra just died! Please help!
- Weird AC issue
- wheel and tire size limits
- saving another DA need help!
- A/C blower only working when in the 4th (high) setting HELP!
- about to do black dash swap soon..
- Cali: No Hood
- ASAP!!!!!!!!!!!!!!!!!!!!WILL HOOD FIt
- crower cams
- retofit housing
- aftermarket spoiler on a DA
- Idle @ redline
- Supercharger issues
- Question about ECU....
- tranny identification
- skunk2 coilovers
- REAR WINDOW VISOR
- little red hose by the fuel filter
- Heater/AC problem??
- What to sell regarding engine?
- cup holder for da's?
- B20 vtec
- 95 gsr
- Any body know how to take the Cluster apart?
- motor knocking
- Machining OEM pistons to fit forged rods
- DB8 Rear Lip
- B18C1: OEM main and rod bearing questions
- GS-R Exhaust Question
- b18a1
- power chip
- PARTS FOR SALE
- My motor...
- over heating problems
- Piston Rings
- HELP with 96 integra door handle
- intermittent stallying out...geeze why cant it just die??
- tranny swap jdm itr to gsr
- Suspension?
- Engine still overheating after changing thermostat.......
- Type R head?! should I or Not?
- Suspension Opinions
- Building motor question.......
- obd2a to obd1 conversion question
- Rubbing Noise From Rear Brakes
- all honda techs
- Type R Spoiler on my 95' RS
- Mechanic
- need ur answer
- 98 ACURA INTEGRA B20 VTECH 3500
- can you have a/c with in a H2B integra?
- 98-01 front bumper on 94-97...
- which oil?????
- How much for A Tune???
- trying to gain more N/A power
- Camshafts and cam gear???
- LS/vtec swap info needed
- Need Someone to Install JDM Front End, Recommendations???
- 97 integ crazy automatic tranny problem
- TOP FUEL SUSPENTION FOR A DA QUES?????
- 90 LS Smells rich Need help
- b20 swap tomorrow, tranny question please!
- 91 integra ecu code 8. help. tope dead center sensor? check engine light only on cold start
- "A tcm novel"
- Advice on B18A1 longevity
- do u need fans to run the ac w/o over heating?
- How much would it be...
- wirring aftermarket power mirrors?
- I will love you guys forever...a small bit of help on a DA plz
- Water leakinggggg
- werid headlight problem
- Price of LS motor?
- b&m short shifter
- Help for motor swap info..PLEASE
- Passing Smog with another Intake?
- --->white 4door GSR
- What tranny for a AT
- s1 axles QUESTION!!
- Motor build... need help!
- command start and alarm not working
- walboro fuel pump
- Difference in gsr and LS oil pans
- need advice about an oil leak
- 5zigen eg6 full cat back work on a dc2??
- problem after cluth fluid flush
- kind of a lame question about acura integra LS 1997 sunroof!!
- thot it was my bearing!!!
- Adjusting shift linkage
- part number for gsr rods?
- High pitching sound when revving
- HELP! What do u know about Sir-g Conversion and ITR Conversion?
- need help to get teg back on the road
- ls/vtec in 94 integra ls, will it pass smog?
- will ls cam bolts fit gsr's?
- gsr oil problem
- Power Steering Question
- B16, ECU question...
- question about struts?
- mounts
- quick and easy H.I.D. retorfit?
- Mounting Side skirts. Having trouble figure it out
- When I press in the clutch...
- Need Factual info on parts interchangability, Searched
- dumb question about my seats
- code 2 3 and 6 pw0 b16a
- JDM GSR (b18c1) q's
- Timing belt issue
- Vehicle Speed Sensor?
- infinity retro fit
- B16 cable LSD ys1 tranny
- Lip question
- BEAKS SRK INSTALL ON GSR?????
- type r cams on ebay, want to buy cams and price sounds good but...
- turn signals wont work...
- Megan or DC 4-1 header?
- stage 3 crower cams
- b17a rebuild with b16a pistons??? type r rings b16a piston?
- spring rate for a DA
- b16/b17 build question
- fuel injector
- lights bit@hes
- when can i post my vehicle for sale
- 90-93 underhood fuse box
- Need new distributor - Should I get OEM or aftermarket?
- Replaced throwout bearing, car still makes noise when clutch pressed to floor!
- gsr motor with a ls tranny?
