View Full Version : Acura Integra
- vaccum leaks.
- help needed on converting the 2000 Acura Integra's ls motor to the vtech gsr motor
- need feedback on short shifter
- 00 Teg GSR-T whining noise when starting out in first!! Help!?!?!?!?
- what you know about that???...that heat...
- Password:JDM DA '90-'93 Integra Headlamp Jumper Harness
- need some help with electrical
- ac line
- cruise control remover
- big problem..
- gauge of integra skin
- stock calipers?
- Anyone know what fuse to replace if corner lights are shorted out?
- SOHC Altenator Fit bseries?
- CEL codes?
- trade or what?
- check engine light
- DA Issues
- Hissing sound when I turn off my car obd1 95 dc4
- Weird ABS problem?
- What do ya think?
- DOES ANYONE KNOW IF DC5(RSX) SPOILER FITS ON MY DC2
- Help GSR Trans
- keep stock gsr or buy modded ls...
- Will a 9006 Bulb, fit in a 9007 spot?
- are type Rs supposed to be 30 grand?
- lsv set up...noob questions,,
- Oil on my AC belt (B18A)
- oil in coolant?
- Clutch... One picture to name that Part!!
- 98 rear bumper?
- Are integra gsr's rare?
- GS-R Value in FLorida?
- skunk 2 or tokico shock/spring kits for dc2
- 95 Integra gsr 4Door, Weird Idle! HELP PLEASE
- plug wires?
- OBD1 GSR P72 ECU - B20b = Will it start it?
- Replacing the blower motor on my DA, got a quick question.
- cruse control
- when i drive it shakes
- 90 Integra, b16 cable tranny.. keeps blowing axles
- shifting
- LS block w - Type R tranny vs. LS tranny-Quaife diff
- Hondata S200 questions
- B16A THROTTLE CABLE BRACKET SAME AS ITR!?!?
- would a block guard be reccomended?
- b18c1 rattling at low rpm
- Dealership F_cked me over !!!!
- tranny problem???
- no power steering?
- Best Aftermarket HIDs for JDM front end?
- ls vtec bogging at high rpm
- h22 in a 96 integra
- haa blown gsr gay!!! i need new crank!
- Where Can I buy: 94-96 Integra front end
- have a problem
- Problems installing 98-01 tape player
- Cam options on B18c1
- new cluster
- wat sup all i need ur guy help
- JDM B20b - won't start - what am i missing?
- Shift knob removal
- B20/VTEC. Dipping Idle and car sometimes dies. BAD MPG. HELP
- SMOG!!!
- how fast
- need a/f gauge wire up...
- The Dealership dont want to fix my car !
- where can i find headlights like these?
- ECU problem please help!!
- Car Too Cold
- storage yard ate my ECU and DIstributor!
- DA coilovers? *socal
- DA Sunroof Visor parts pics.
- crx short shifter in 92 ls?
- car wont start
- deck plate question?????
- few questions about my DA
- WILL 14s fit on a GSR
- Jdm B16A Redline
- QUESTION ABOUT DAYTIME RUNNING LIGHTS
- wiring troubles in the gauge cluster
- how do i wire this
- A question for the JDM brainiacs.
- integra motors
- How to clean integra front light
- What kind of wheels for dark green hatch?
- i have a question about coilover??
- Inspection ?
- LSD tranny?
- Half Shaft - JDM B16A1 for a type R B18
- removing back seat...
- GSR Race motor
- Code p0141 (65) or bad ecu
- DOes sparco harness bar from a EK work in a integra?
- cable or hydro???
- obd2a LS harness.. what plug is this?
- Where to get exhaust pipes?
- cruise control woes
- smog
- Supra injectors
- 95 gsr integra moonroof wiring?help.Searched.
- installing a 98+ abs system into a 94-97 integra????
- 95 integra...need new clutch..some help?
- question about rocker arms
- Question about ITR 5 lug
- for all u teg lovers watch this driver
- is the ls water pump same part number as gsr water pump
- maintenance light?
- swap opinions for my 95 teg
- Craftsman Impact Power Driver $10 11/27
- another add on to the new project..
- Megan racing strut bars and coilovers?
- auto trans shifting wierd
- Gear is blocked out when trying to downshift
- i need some help [MAINT REQ.]
- looking for gsr wheels
- battery light problem
- axleback weight
- Can A Starter....
- gsr overheating problem!!!!!!!!!!!!!
- 94-97 Headlight Help
- Just bought a 98' DC...
- gsr to ls questions.
- Another ls/vtec question
- short on power
- help with estimate/good places to go
- Turbo for B18c1 block
- 92 acura integra help (how far should it be)
- GSR throttle opening size
- distributer question
- Fitment ??s 5zigen pro racer 18x7.5 ET +43
- fuel pressure gauge?
- Integra OEM floor mats?
- GAH! nothing FITS!!! 95 gsr, with 2000 gsr header/cat bpipe.. Spipe/muffler woes
- Bolt ons for 97 GSR what are they worth?
- Code 45 Fuel System too rich I searched
- mirror problem
- ls vtec turbo...or type r turbo?
- whats up wit this HELM manual
- valve cover studs
- my da lose power in high end
- Parts diagrams?
- TDM race header and D2 Coilover feedback...
- Distributor Problem
- *********NEED HELP ON WHAT TO USE TO PUT BACK ON A EMBLEM**********
- My 95 GSR
- resistor box
- Oil on block
- 5th gear
- GSR Master Clutch cylinder into 93 cx
- 2001 integra gsr fully built turbo
- Auto/manual Swap
- anyone know where i can get custom floor mats?
- LS harness.. what the hell is this wire
- Is it safe to take off the ABS reservoir?
- My 91 LS its ugly..
- tranny issue
- h22a integra is slow
- door ajar dash light
- MY HORN AND BRAKE LIGHTS DONT WORK ?????????????????????????????????
- Rust in your enigne bays?
- rough starts
- Flex Pipe Needed for 4-1 header installation
- 93 integra and CRX suspension
- How can I check which model integra I have?
- Fuse Box Cover for 97 Integra GSR
- 94 teg project
- 1991 da lights
- Ek Shocks On a DC?
- Question on changing the heater core
- worth starting this project?
- ++Gots a few Questions on a GSR??++
- battery problem
- reset ECU or SRS?
- maintenance required light question
- Brake Question !!!!!!!!
- VSC extended warranty company from honda
- LS Motor or GSR Motor
- trouble getting into 1st
- Car wont cranck...Need HELP PLEASE!!!
- >> Sorry... another tuneup question <<
- Greddy Tuneable Exhaust? WTF?
- trans problem?
- which ecm is compatable?
- Distributor Matching 89 Integra
- another sunroof question
- exhaust bracket help plz
- ABS control Unit
- i have a question?
- Axles for 200-250 HP - 5-7 psi turbo B18B w Type R tranny
- Where can i find this part?
- Hytech Replica and Exhaust Question
- i just got a DA for 600 bucks!!!!!!
- can't remove the rotor
- car starts then dies think i fixed it but seems to easy.
- JDM DA6 Cluster
- acura car pics damage
- Need to know?
- Just swapped tranny, do i need a differnet length passanger axle?
- Wiring side markers
- wanna buy 93 DA integra , how do you know if its Real GSR or LS?
- Which fuse is my Alternator Fuse?
- smog
- does any one know if you can clean the top fuel intake filter like a KNN
- ? For my GSR good idea or bad?
- Mechanics in dealership ?
- Gsr into LS swap trouble, need help!
- 94-01 gsr seats in a da?
- where can i find factory black carpet?
- oil leak !!!!!
- how much to rebuild gsr engine
- oil in my intake please help!
- Help interpreting codes
- chnagin from 94-97 to 98-up front bumper, what do i need to change
- LSVTEC help!!!!!
- Future Mod
- Hasport transmission mount vs stock mount????? help
- fuel gauge wiring
- DID a compression test on my turbo db8 today good or bad numbers?HELP
- blox intake manifold
- winter tires
- neptune engine management question???
- 93 overheating?
- Headlight Problem
- where is your DC squad sticker post pics
- 5-SPEED SWAP IN 01 GS
- 1996 Integra headlight aiming trouble.
- Engine runs colder the more you drive?
- ok shot in the dark..i need this nut size.
- turbo integra
- EG rear seat...
- STOLEN!!!! 98-01 Silver Integra GSR Cerritos Area
- Break in period for clutch, tune anyway?
- traded my SUV for a 94 integ, need advice on what to do next
- CR/VTEC questions
- Blue or White Smoke? Opinions & Thoughts
- For those of you with race seats in your DA's......
- Vibrant flat black muffler
- hard slam noise when shifting gears
- put some pictures of your DA
- oil pressure LS.Vtec
- When to change the clutch fluid?
- oil catcher tapped to the head....
- just finish project now starting on new
- VTEC pressure valve
- Question about power steering on integras with H22
- new car no vtec!
- Megan Racing coilovers?
- h22 is it worth it???
- vtec controller
