why my teg is gay
Old Oct 22, 2002 | 08:32 PM
98integraLS's Avatar
Default why my teg is gay
two words:
1. Bodyroll
2. Stock
ive got a few things waitng to be put on to combat these problems. it just seems that i dont have the money or the time to get them on
Old Oct 22, 2002 | 08:36 PM
97hb's Avatar
Default Re: why my teg is gay (98integraLS)
Because it likes another teg of the same sex.
GSRrR's Avatar
itr sway bar and beaks kit is only around $125.
Audi A4's Avatar
you'll be alright...
Old Oct 22, 2002 | 08:39 PM
Understeer's Avatar
Default Re: why my teg is gay (DRAG lll INTEGRA)
These should help it considerbly cut down on body roll.
1. Lowering Springs (H&R Sports, Eibach Sportline)
2. 22mm ITR Rear Sway Bar + BSQ Kit
Old Oct 22, 2002 | 08:42 PM
Default Re: why my teg is gay (Understeer)
i was planning on getting some groundcontrols actually. but im still undecided on that part.
will a bigger (22mm vs 18/9) rear sway bar help keep my rear tires on the ground if i turn hard/brake at the sametime? cause my car also has that problem.
Old Oct 22, 2002 | 08:49 PM
typeR#0427's Avatar
Cool picture though. Tegs aren't gay. Don't worry.
[Modified by 95AZ-GSR, 5:50 AM 10/23/2002]
Old Oct 22, 2002 | 08:56 PM
jeebusm3's Avatar
Default Re: why my teg is gay (95AZ-GSR)
i got my gc/agx setup from ground-control.com...seemed cheap to me.
Old Oct 22, 2002 | 08:59 PM
Jsracingintegra
Guest
Posts: n/a
Default Re: why my teg is gay (gtravsr)
Save your money and get your suspension later. At least you have a nice soft ride for everyday driving.
Old Oct 22, 2002 | 09:44 PM
Mr.Rab's Avatar
Default Re: why my teg is gay (Jsracingintegra)
This is my bodyroll so don't feel bad.
Suspension setup as pictured:
-GC's
-Koni's
-16" Rota's
-Sp9000 Dunlop
I fucked up on not getting custom spring rates i.e. 400f/350r
Since picture I've add a JDM ITR rear sway bar, big difference. Best suspension upgrade to date.
Old Oct 22, 2002 | 09:54 PM
Volcom's Avatar
Default Re: why my teg is gay (Dr. RAB01GSR)
I have the same problem also. I have also done the rear ITR swaybar. It helps out a bunch
Old Oct 22, 2002 | 10:16 PM
Volcom's Avatar
Default Re: why my teg is gay (Volcom)
Here are some more pictures!
All of these pictures are with the ITR rear bar and 16 inch Slipstreams with kumho 712's. Definally made a difference racing the car!
Old Oct 22, 2002 | 10:23 PM
Mr.Rab's Avatar
You boys with the stock suspension setup doing autox, scare me. I always think we'll flip your vehicle.
i.e.
Old Oct 22, 2002 | 10:35 PM
Volcom's Avatar
Default Re: why my teg is gay (pineapple)
There's not much of a difference in the pictures, but what you can't see is that I am going faster through the turns with the bar. So, that then makes more roll. I can feel the difference when driving but the pictures don't show much.
Old Oct 22, 2002 | 11:33 PM
Jesse H's Avatar
Check out the folks running stock classes w/R compounds. THAT'S bodyroll.
Old Oct 23, 2002 | 08:29 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: why my teg is gay (Jesse H)
Yeah definitely, stickier tires w/ stock suspension means more body roll.
Old Oct 23, 2002 | 08:46 AM
Chris's Avatar
This thread has no point.
Post pics in appearance.
caiboR
Suspension & Brakes
Mar 13, 2010 01:00 PM
Jdmls
Jun 8, 2007 11:57 AM
kame1997
Suspension & Brakes
16
Mar 29, 2006 12:43 PM
Steak84SS
May 13, 2003 10:17 AM
1fastGSR
Acura TL, RL & ZDX
Mar 17, 2002 02:58 PM
