View Full Version : Acura Integra
- 3rd Gear Grinding?!?!
- (pcv) smog test question?
- B18a won't start HELP
- kakaka?
- Cluster screws
- Towe Truck Madness
- I might be screwed.......please help
- dash removal...
- GRrRrr SCREW thieves!!!!
- b16 Sir1 sparkplugs??
- What kind of kit should i get????
- Rear Perches and Compressor.
- BeheeeeeeeBUP
- exhaust
- Help quick: how to bleed clutch masetr cylinder
- Firing order 96 Integra Ls
- G3 Lips....
- Another jdm headlights question.
- HELP: My friend screwed up my spring install
- Monster nose
- b18c1 skunk2 IM install???????????????
- got a check engine light today
- Anybody know about finance and trading?
- Is the lip on the hub...
- guys help!
- I need a passenger side door (prefer black)
- exhaust question?
- CEL 14 Help!!!!!!
- valve seal/stem diameters
- Sell the GSR?
- CORBEAU seats for sale
- Fuel pressure settings???
- Review: Action Clutch with AASCO Flywheel
- torque for oil drain plug and crank pulley wrench question.
- difference between 94-97 shift knobs to 98-01, please post pics. Thanks!
- when i turn the axel has a clicking noise
- Thats It - No more Honda
- top speed ls integra???
- All orange or amber lenses for 94-97 Teg
- Opinions on KYB AGX GR2's and Neuspeed Race springs
- my belts are squeeking help.....
- GSR Intake Manifold bracket.. Do I need it?
- A few q's about the B17
- 4300k HIDs are a gimmick?
- Emissions testing (fun fun)
- Need some torque specs please :)
- head gasket
- Coolant line hookup question
- Looking for good condition headlights for 94 integra
- does anyone know where they sell OEM parts for gen 2 integras?
- I need help with noises coming from my acura integra
- i replaced TPS still code 7????
- Type R Oil Cooler on a GSR... Few probs.
- Koni Adjustables
- Sticky first gear...
- VAFC Problem..
- G3 leather in my G2??
- Header/exhaust for a 1st gen teg
- Rattling/vibrations when making right turns?? Black circles on hood?
- A4/S4 conversion thread
- Will 99 and up Integra seats fit?
- site on DIY tb cleaning...
- diff between integra clusters...help!
- Dynoed my GSR
- Is Nos really that bad for the engine?
- JDM integra type r SRS steering wheel question
- Running a test pipe on an obd2 gsr
- Grease for tranny shaft and release fork?
- TL shift knob fit g3?
- exhaust pics (please post)
- CTR cams real or fake?
- Just reset my ECU, have 1 really quick question about gas mileage.......
- Overheating, Coolant is filled no leaks..
- LS/vtec vs GSR
- Is this the right off-set?
- 740iL vs Teg LS i lost :( (Accident)
- Oil Pressure Gauge
- ***CM aluminum flywheel, new pressure plate bolts?***
- Need help/suggestions for my Integra Suspension/wheel setup!
- Trouble Starting Car.............??? Help
- ACT Clutch & Flywheel....
- Will a 215/45-16 azenis fit the teg?
- hey what's the price to align the headlights?
- Will 94 and up Integra seats fit?
- Hondata?
- what do you think of this car on ebay???
- Integra w/o armrest?
- Engine puttering at 4500 HELP!!
- Integra Service Manuals ACX - Any good???
- 95 Integra LS Sedan for $4900 ... Worth it?
- what gas to use?
- turbo internals
- stupid trim level questions
- NEED SOME SORTING DONE!!!!!!!!!!!!!!!!!!!![help please!!!!!]
- blown block?
- coilovers brands?
- can someone give advice with install of a WW kit on my gsr?
- koni yellow problem?
- sprints on koni yellows, ride quality sucks
- Valve Adjustment
- brembo rotors and rust
- Launching.
- anyone wanna trade taillights?
- 94-01 Integra Sedans
- where to get angled feeler gauges?
- Help me replace my timing belt tensioner!!
- good body shop in sac.???
- Just finished swap... Runs real rough
- Over Heating Please Help!
- Best Place to get ecu chipped???
- Question re: putting 98-01 rear seats into a 94-97 teg
- Broke a stud taking off tire. How too?
- My car finnaly died
- Obd1 Skunk2 Program
- Driverside Fender...
- Would you pay $1,375 for a brand new Five Lug Conversion?
- Transmission oil drain/filler plug washer question
- too many miles?
- Paint Codes/Sites
- sell or go Turbo???
- Moderators - Please Help
- recognizin skunk2 different stages cams
- AC power loss...
- stock ls cams
- What Year Integra Should I Get??
- body shop in san diego?
- turbo ls or type r????
- anyone with a short ram have a tornado fuel saver?
- JDM gauge cluster
- Strange LOUD Transmission sound. Help!!!
- tire question
- Would I benefit from DC4-1 jdm header?
- best way for cleaning throttle pulley
- New 5 Dollar Valve Adjustment Tool :)
- what kinda power am i lookin at here?
- Torque Spec for spring installation
- Comptech B16 header on GSR... / 1000 post anniv! =) yea me.
- Benefits of SS Brake Lines
- Will a B16A Header fit on a B18B?
- h22 in my integra?
- engine temp below normal?
- b20a bolt on?
- '90-'93 Teggy engine swaps?
- Custom turbo
- Compression
- Technical question on coolant passages behind the intake manifold.
- Dyno Results from Turbo Teg
- How do you take off the wiper blades on 94+ Integra?
- Flushing radiator instructions...no flames please
- Wich is a better setup AGX's w/ Tein S. Tech OR Tokico Illumnia Advance handeling kit?
- do I need an oil catch can?
- Breather for Valve cover? or NO ? with JRSC
- Best pads and rotors for a GSR?
- Fuse blowing!
- 97 driver's airbag fit in 94?
- just put up ITRsway.. DC lower tie bar and no name rear upper strut...
- OBD GSR Question
- 2000 b16a head on a b17a block any mods to fit
- '95 ls in my crx but wont start :-(
- JDM ITR gauge cluster in a 1998 GSR
- integra ls miles
- Those with KYB AGX
- Anyone put Airmass 4-2-1 Headers on their no v-tec teg?
- Headers
- squeaking when coming to a stop/taking off
- JDM ITR HID Kit and Wiring question
- How do you get this bolt off????
- which valves are best??
- hiding spots
- Oil coming out of valve cover air intake tube?
- slight backfires between shifts, bad????
- Correct tire pressure for Azenis?
- Is 102,000 miles too many when buying a used GSR?
- Purchase integra???
- cat-back causing problems (gas mileage is horrendous), help would be appreciated...
- Is my car worth tuning yet?
- cam gear installalation
- 99 gsr Antenna... QUICK QUESTION
- What do you guys think?
- Tein BASIC Damper.. any comments??
- Vote if you want this added to h-t.com
- Where to get Cat Heat shield bolts / exhaust hangers.
- G3 diy grounding kit help....please
- Tanabe racing medallion volume
- Service Manual
- Are NGK BKR6ES-11 ok for I/H/E?
- Windshield washer squirters
- any 98-99 gsr's have the a-pipe rattle??
- How do I get the Vin number with only the Engine's serial Numbers?
- whisteling noise
- bondo the side trim holes
- Changing brakes and rotors
- DA shirt design, comments?
- Wiring Help needed!!!!
- JDM Mugen Conversion question... Please help
- question about rpm's
- Break in Brake Pads?
- teg died on highway...
- Best Exhaust?
- Does anyone make the imatation Advanz?
- how to prevent Airbag light from coming on?
- rear main crank seal?
- cheap solid rear motor mount
- Anyone have OEM replacement headlights?
- I was just about to go and put a snail on my car....
- Engine squealing?
- help
- what's included with the skunk2 intake manifold?
- How to Fill Transmission Fluid?
- Opinion About ma Car
- Weight reduction
- 90 Integ wont Start sometimes, need some advice
- What does it mean that a car has a 907a title?
- JUST GOt My GSr DyNOeD!!!!!
- - Those with CAM GEARS
- ls crank for ls/vtec
- 5th gear grinding?
- Hops
- Reinforce Engine
- Will my computer throw a code w/ no cat?
- oem optional sides are for both 4dr and 2dr integras?
- Which would be better for my setup?
- how much more hp are stage 1 compared to itr cams?
- Code: PE-O coming from factory CD player
- Adjusting cam gears?????
- headlight adjusment
- just installed greddy evo - review/question
- Idea for Diy Cai
- Should I be happy with my 1/4 mile time?
- Trunk problems@!@!$%#
- Tire Size Question
- zex camshafts?
- Exhaust Question
- Remote oil filter kit?
- Just got some new stuff in :thumbup:
- How do I adjust Timing on an Unorthodox racing crank pulley?
- quick question on oil pan bolt
- Del Sol/Smaller Dual Core radiator?
- running a cut valve cover
- my jdm integra headlights (foglight) keeps burning out quick
- how to test 02 sensor?
- clutch different for cable & hydro tranny???
- How do I get to Instant message you guys?
- which alternator can i use
- 1st Gear VTEC not engaging???
- the person who installed hyper groun system, howd that go?
- Radio just crapped out
- KYB AGX Decision
- I hear a grinding noise.help!
