View Full Version : Acura Integra
- Question about the Skunk 2 mani.
- awww my Lug nut broke !! hEELPP
- Integra GSR - Auto-Reving =X Help me out here.
- Cam ?
- Replacing I/M gasket
- type r tranny.
- Can i use my VAFC To test my TPS?
- coolant burnin mother fucker
- new starter
- after i installed the skunk2 manifold+skunk cams.. i lost power
- where is the thermostat on a 2000 integra?
- looking to buy pistons and rods
- Question on DC tail lights
- need help asap brakes
- i need some opinions on tein
- need info on gsr intake manifold
- Modifed ECU
- fiberglass DA doors?
- Cusco 6 point roll cage *pic request*
- Will a B16 exhaust manifold fit a 97 gsr engine
- DC Sports front strut on Da. One slight problem.
- Heat Shield Necessary
- How much is the head of a stock B18C1 GSR engine worth???
- Which power ban would you prefer?
- Brakes way too soft up. I pump and have plenty of brake fluid.
- what is the advantage of this?
- Auto places master cylinder....
- WTB LS BARE BLOCK!! JERSEY AREA
- POST P1CS OF 1ST GEN 1NTEGRA'S
- help with floor mats
- B18c1 valve lash check (hot and cold)
- Quick questions
- just a little information would help, thanks.
- chamber kit for a 92
- What in ever living hell is in my oil? *500k pictures*
- I SOLD MY B20 TEGGY
- Overheat!!
- car hesitates after warmed up in cold weather
- Full-Race Turbo Kit
- pcv valve hose leaked then ripped. thanks in advance
- Quick JDM front question
- mountain rotors?
- Rear Wiper delete question.
- Brake light switch stuck on..need help
- Starting Problem...
- are the axle back for a EG the same as a DC axle back?
- 95 DC2 to 00 DC2 conversion
- Couple of questions, reinstalling my oil pump, timing gear, and ATI
- Code 54 Crank Fluctuation Sensor? Car hesitates before 3k rpm, more so when cold.
- b18c1 flywheel?
- Civic suspension on a DA Integra?
- PIC REQUEST: DC with ROTA C8's or GT3's
- Civic type R head + inlet mani on a GSR block...
- looking at buying an 2000 integra have questions?
- Wierd Problem... If you can help, I will love you long time! PLEASE!!!
- to sell or not to sell
- ls block
- motor mounts!!!
- 9000 rpm LS block?
- What suspension?
- camber kit
- Took AC hose of condensor and green stuff sprayed everywhere
- **Intake Manifold**
- Reccomendation for rear rotors?
- compressor relay location
- Ebrake locking mechanism broke
- E-bay cat/back
- maintenence req?
- fitment
- Thinking about upgrading b18b1 block components. Suggestions?
- my e brake light on the cluster
- GSR head reassembly help.
- need some help quick please
- CAR PROBLEM!!!! My car over heats! Have a 95 Integra GS-R.
- how big of nitrous shot is pushing it for a gsr....
- how much is a stock gsr exhaust worth?
- HELP ME PLEASE!!! Sputtering!!!
- need integra interior?
- A/T problem!
- just destroyed my car
- ???INTAKE MANIFOLD QUESTIONS???
- Can anyone verify this? LS/Vtec
- 1996 IT black headlights how to
- DA back seat removal
- Having an issue... Interemittent "power" cut at 8k sometimes 9k sometimes 7k Rpms...
- Alignment
- Ls Gauge Cluster
- 99 si/GSR
- when I rev the ling dime ?
- PR4 and P75 ECU's...changes in the maps?
- performance from tunable cam gears
- differences: JDM SIR-G VS. JDM ITR
- how do i take out the dash? dont need it anymore.
- help!! suspention swamp... 96teg vs civics???
- 91 Integra Gs 5spd. What is this sensor? How important is it?
- NEED help with car not starting
- 3in Twin-Loop?
- what kind of intake manifold is this
- Fog Light Part Number
- Apexi VAFC II
- transmission problem?
- spark plug gap
- Black on Silver
- New sh*t on the block...soon
- missing header bolt
- 92 integra cutting in/out...NEED HELP!
- How do you torque nut on alternator pulley?
- DH Racing ported b156a heads
- b18a to b20
- GSR with LS Tranny? Who has done it already?
- Car Alarm
- HOses
- Does this sound like fuel?????? If not what is it?
- Brand new header, is this bad?
- 95 Integra LS B18b1 swap for a 92-96 H22A?
- Mirrors.
- Fuse Block Meltdown
- switching to synthetic?....
- Hey all new to the site
- demand on 4dr gsr?
- New to the integra family! 92 GSR Turbo
- Will a VTEC spark plug cover fit on a Non-VTEC valve cover
- Holy damn my DC2 just went insane!
- Buying a car in a diff. state ?
- Elctron Blue Pearl Integra Project!
- question about dc header!
- Intake Manifold?
- oil filter relocation kit... what's a fram PH8A?
- rear wiper
- DA9 Headlight Alignment
- how much HP on stock valvetrain ??
- New DA in my hands...need ideas
- 95 LS problem
- power fluctuation from 1.5k-4.5k rpm, 92 LS
- what type of paint sould i use
- White teg problems
- ball joint dust boot seals
- springs fittment
- Just picked up my GSR... check it out!
- headlights for stock DA headlights
- Looking for full GSR swap
- maybe the throwout bearing?
- 90-93 DA
- Help identify these cams (GSR?)
- not getting enough fuel?
- diff lock vs LSD
- Radiator Fan Not Working....help!!!
- BETTER LOOKING TEG
- side mirror block off plates?
- want to buy*******
- need help with intake manifold!!!!!!!
- 90-91 turbo integra guys i have important questions for you!
- Timing on dizzy
- GSR Bolt ons
- VTEC NOT WORKING
- Time Slips ?
- 96 gsr v. 2000 gsr. is there a power difference?
- Maintenance suggestions on an older 1995 Gsr
- wiring in or around Sacramento
- 93 ls starter on a 94 ls
- part # for valve cover acorn nut in black?
- New Radiator & Fan
- oil leaking
- Throwout Bearing?
- crank case venting
- vibration at idle egb18clsd
- LS VTEC?
- sup guys, just registered my project teg today!! pic...
- Another... CAR WONT START thread. Failed Compression Test. Help!
- My OEM LSD into a GSR/ITR/B16 hydro...
- Gsr ecu???
- Royal Purple
- a/c compressor fuse?
- How hard are 4 doors to find?? 98+
- jdm front or more performance parts?
- Carbon Buildup in exhaust
- How can i get rid of all the small dents on my car????????
- Can someone help..
- axles are the devil
- integra 98 ls o2 sensor help
- NEED 5 SPEED TRANNY
- how to remove wings west air dam?
- Door Thickness of 95 Ls
- 01 LS w/ obd1 GSR swap problem
- Over heating Need help!!!
- newbie saying hello and looking....
- k20 DA
- Hawk HP+: rotor wear
- bored . took a couple pictures
- what should i sell this for
- Will a OEM GSR Head gasket fit on a b16a2
- who wants a SUPRA integra????
- spark plug gap???
- whats my next step after i swap in CTR cams, ITR valvesprings, Spoon camgears?
- Tuning my GSR with vafc...any sugg.s
- CEL 7 TPS-throttle position sensor
- Turbo Kits?
- where ALL the CALI PEOPLE AT?
- sqeeking/grinding noise in engine
- DIY: Fix that one dull headlight (non electrical), then brighten both with HIR bulbs!
- 1995 Integra GS-R ?????
- Newb integra owner swap question
- whats diff between 4dr and 2dr gsr?
- 95 acura integra LS
- What mod should i do next? any ideas?
- OBD2B ecu work on a OBD2A?
- whats the difference between ITR and TYPE R cluster?
- Camber Correction: Control Arms or Ball Joints?
- looking for a car...
- Smog Help
- Koyo Radiator HELP
- help with swap!!
- Safe to drive 6 hours missing a lug nut????
- What Year did the 1st Gen B17 GSR Motor Created
- Websites
- Running Lean and Passing Smog Question
- 5 speed tranny fluid
- What type of integra do i have?
- removing a cluster?
- 1993 Acura Integra won't start
- NEW HERE... Though I would post for first intro. New newb to the DOHC
- somebody confirm my answer
- P205/50/R15 Tire Look???
- HELP! NEED WIRING DIAGRAM
- type r cluster and b18c5 hydralic tranny.
- VTEC malfunction, HELP!
- ES Oval on DA6
- Ignition problem?
- popping noise in turns - coilovers?
- No cluster lights, No A/C Or heat etc...
- GSR b18c1 crank thrust washers...how many?
- will this fit?
- brake question
- VTEC is a perfect technology!!!
- seatbelt troubleshoot
- fu%K&ng thieves
- diffrence between type-r head and gsr
- anyone running a dc ceramic 4-1 header here?
- FLAT BLACK teg ?
- B20 block vs. B18 block weight difference???
- fuse box problems on a 90 gs
- Brake Rotors on GSr
- profab tri y or vibrant
- GSR/ITR Rebuild; Need Help
- tranny problems need assistance!!
- test pipe fitment with headers and exhuast?
- Hay whats up
- I NEED PARTS "lOOK"
- just an idea for a splitter
