dude red line in 3rd on freeway....
Old Oct 23, 2002 | 12:25 AM
J-g-D-s-M-r's Avatar
Default dude red line in 3rd on freeway....
i was running a turbo civic on the freeway... it pulled up on me while i was already goin 100... so i dropped it in 4th... when i hit about 6.5rpms i wanted to shift to 5th but slipped n hit 3rd! it hit red for like a split sec n threw it in netural... pulled over ... n chilled for a bit.... think there is any real bad harm to my moter??
Old Oct 23, 2002 | 12:32 AM
daLixz25's Avatar
Default Re: dude red line in 3rd on freeway.... (lDarkCloudl)
careful at speeds like that on a freeway. put pedestrians in danger. anyhow, why would you want to shift into 5th at 6500rpms....wouldnt you just wanna get to redline first?
Old Oct 23, 2002 | 12:38 AM
Default Re: dude red line in 3rd on freeway.... (daLixz25)
when i dropped it i passed him up about like 1/2 a car to a car ... so i wanted to throw it to 5th... think there will be any real danger to my motor.... the freeway was completely empty... i usually don't race when there are other cars on the road... the civic hit me up
Old Oct 23, 2002 | 12:43 AM
97hb's Avatar
If the motor runs good then your probably don't have to worry. Usually it will bend valves or jump a tooth on the timing belt. My step brother put a rod threw his block on a mitsubishi doing a 3rd gear redline and downshifting into 2nd.
Old Oct 23, 2002 | 12:45 AM
Default Re: dude red line in 3rd on freeway.... (97hb)
koo... the car started up fine n ran normal... i was just a lil worried i might have blown something that i didn't kno
Old Oct 23, 2002 | 12:47 AM
SIK IN DA HED's Avatar
New User
if youre not having problems with your car now.. it should be coo. avoid doin that kind of thing.. you might not be so lucky next time.
[Modified by dlplayboy, 1:47 AM 10/23/2002]
Old Oct 23, 2002 | 01:38 PM
jjh's Avatar
jjh
Default Re: dude red line in 3rd on freeway.... (dlplayboy)
hmm... sounds similar to what i did... but for me it ended up with bent valves... which was luckily fixed on warranty...i jus had a friend do a compression and leakdown test for me... after i had my mishap.... maybe you should do the same
jjh's Avatar
jjh
o ya... and if you want to do some tests... email me typer536@yahoo.com... ill be happy to help you out.. i live in san gabriel
92jdmhatch
42
Apr 20, 2004 03:50 PM
