View Full Version : Acura Integra
- want to buy a integra..... your advice
- Paint Job:Super Sonic Blue Pearl to Electron Blue Pearl
- Rear Motor Mount?
- DC Clutch / Tranny question
- 95 integra b18b1: brake issue required
- engine noise
- coupe and sedan difference in seat brackets?
- dashboard light dont work
- E-brake light comes on with brake pedal is pushed...
- noob trying to fix my car
- how to make hx rims fit on dc
- Can't Pass Smog
- Motor mount Problem! (searched)
- TB question
- Winter tires...195/65R 15???
- Vtec or NonVtec... Why
- Adjustable cam gears HELP!...
- 94 integ. what does it take?
- Yokohama S.drive opinions
- Avid Racing motor mounts info needed
- does abs light come on when key is turn over
- Looking for the foot brake lead wire
- Just boght a Integra, ECU is laying on the floor
- can someone help me on a weird noise from my vtec head!!
- weird electrical issue
- need help plz no fuel priming and main relay noice
- smoke and jolting
- Which heater hose? 92 DA with B18C
- High idle and semi sputter
- got my dream car 2000 gsr
- DA not charging
- Squicky noise coming from motor! :/
- Battery Dying... shop doesnt want to replace?
- B20Vtec'R
- b18b valve train.....?????
- 98 Gsr tempted to buy!
- IAC motor behavior.
- 99 ls, rear ended
- leaking coolant. need help hondatech
- integra glass headlight what year?
- Looking For Integra Wheels !!!!!!
- abs pump? vibrates at 40mph
- attn: Engine experts: smoking problem
- What needs to be removed to pull b18b1 auto engine
- JDM ITR Headlight harness questions
- Brake replacement and adjustment
- need help removing rotor from TD-34U distributor
- abs light goes off when seat belt is insert???
- About to install Toda header
- HELP!!! 95 Teg starting problems
- EDM Rear Fog Light
- My first car. Good deal?
- Cold Start/High RPM stutter
- Car just cranks but no start
- Help! check engine light p1337!
- 1stime start up on a new motor. wont start need help
- type-r 36mm axle question
- whats a good compression test number for ls?
- Missing screws that hold rotor
- I need a legit ITR rep lip.
- new project
- Didnt label injectors.
- Buying an integra, good deal?
- ac question/battery
- 98+ front end conversions rare?
- No Fuel At Injectors! Help!!!!!
- Trying to Identify Power Steering Part
- b18c High tension leads, what to buy?
- brackets signal lights on in dc interga different
- alignment after lowering?
- HID's
- 94-01 acura integra fenders
- volkswagen bro reporting in
- IAC Problem?
- buddy club spec 3 exhaust
- Kinda new here and I have some questions...
- Is it possible that car is smoking because it dosent have o2 sensor and cat?
- 94 Integra LS no spark! new dist.
- Turbo DD Setup
- What Springs to use Tokico blues
- Will a TPS froma 92 work on my 97??
- coolant lines with aem v2
- Storage and Oil
- Will 15x5.5 +45 fit a 1993 integra rs?
- timing belt broke what should i replace?
- GSR swapped EF cutting out
- didn't put silicone on outer front/rear main seals bad/good?
- small idle problem and sticking gas pedal?
- getting window tint off headlights
- Engine hesitation
- question about aem v2 intake
- DA b16a swap??
- Bosch, Denso, etc... products!
- Tach Issues w/New distributor
- Breather Chamber
- LS to JDM OBD1 B16 Swap
- Idle surge, checked threads, went through the diag tree, what's next?
- car jerks, clutch seems unbalanced
- front wobbles under hard accel or high rpm
- 1995 Integra Trunk Leak ! NEEED HELP
- My first car! 1992 Acura Integra
- new DA problems
- Finally got my hands on a Integra. Check it out
- Main bearing cap replacement
- is this a good set-up?
- Having a few problems
- adjusting skunk2 rear camber kit
- What is this color and where can i get?
- clutch problem
- Car wont start (no noob question)
- *Only Clean* Nothing else
- advanced tech question.
- synchromesh usage.....
- 92 gsr having problems starting up
- New to Hondas and integras
- Skunk2 IM idle high
- need a lot of help on my car :(
- Help!!! wrong light lol
- question on bassetts
- JRSC from ITR/CTR/B16A head to fit to B18C1/B18C4 - GSR P72 head HELP!!!!!!
- Help!!! Check engine light on in 1996 GSR
- Foglight installation instructions
- JDM B20B on boost
- Will a exhaust manifold from a jdm b16 obd1 fit a usdm b18c1 obd1?
- Wiring help needed...
- 97 ITR swap..few questions
- Header flange
- eg hatch exhaust direct fit?
- BWR Rear Subframe and OEM rear sway.
- How to fix tears/rips in leather seats?
- Engine running like crap, please help
- hatch window trim replacement
- Saturated injectors in 91 Teg ?
- Any interest in DA upper control arms?
- catback opinions?
- Overheating at high speeds, Help!
- Identify This Swap?
- Engine Compression Problem?
- how to wire up jdm front end with usdm wiring
- Maintenance guy at work gave me an intake manifold
- its aliiiiiiive!!! da9 just cranking
- Gsr turbo questions
- B series Skunk 2 manifold questions
- 98 front end
- This bounce means?
- gsr freshening up
- 0bd2b car with obd2a swap. RPM gauge wont work.
- 98 integra brake problem
- My 65A fuseable link continues to blow everytime I try to install it!!
- installing beat-rush x bar, confused..
- 1995 Integra Jdm B16 swap
- window wont go down..
- In need of a radio code '97 integra
- Car stalls on idle after a drive..
- Need help and/or inspiration on project B18C1
- Slight missing between 70-80mph
- 91 Integra overheating???
- My 1994 Granada Black Pearl Integra Hatchback 5MT
- **GSR rear lower control arm Bushings**
- JDM front headlight
- stock muffler with DC b-pipe
- b18a, need a plug for this thing dont know wtf it is
- almost done with the build/swap..couple questions. pics inside
- 1998 JDM ITR Transmission grinds and wont go in at high rpm. just replaced synchros.
- MY 99 Teggy. pics, ect.
- Does the wideband o2 take place of narrow band?
- main bearings?
- lower control arm and rotor contact...wtfrick...
- B20 vs Rebuilding LS
- p61 mugen valve cover
- USDM P73 Type R Ecu, How much is it worth?
- Girlfriends 91 GS, is valve adjustment THAT hard??
- Codes 1, 4, 20, 23 and limping
- 91 teggy does not start all the time
- What do i have to remove from the front to replace my Core Support
- Carbon Hood
- 94-01 Fog Light part #'s
- compression testing, what numbers should i be looking for?
- what manifold and tb for set-up?
- B18C1 , B18C question
- does springs and coilover sleves from 88/00 civic and 94/01 integra fit 90/93 DA??
- Injector Wiring 94 gsr
- 95 GSR w/ JDM B18C ..::IAT Issues!!::..
- new with questions
- B18b1 Crank Postion Sensor
- help, my gsr is hurting!!
- Has anyone used a felco fuel pump
- Post most current pics of your teg!
- Car pulls to the left after axle replacement????
- EGR valve
- Gauge Cluster 92 integra
- sucked up water
- Injector not firing.......
- Integra swap
- GSR Trany Fluid
- will itr rings work on gsr piston?
- are you suppose to tip macco people?
- LS/VTEC idles low
- I'm desperate for some good cam info...
- evaporator: how to remove need diagram or a write up
- PO 1399??
- 90 integra doesnt stall?
- 1995 Integra gsr need some pointers on turbo build
- Need help car vibrates when hitting 65mph+
- Is this a hondata?
- Quiet 2.5" exhaust?
- 1996 Integra LS Swap To 1994 Integra GS-R
- JDM B20B vs K20
- oil on lip of turbo what does this mean?
- Which Aem Dryflow filter for 96 LS stock intake
- Brake master cylinder rebuild kit?
- engine smokes from breather what is this?
- paint job
- Slight front end shake when I accelerate
- GS-R Running Rich Help!
- in need of a fix for code 9 and 17 on OBD0 Integra, please help
- integra looses water
- Can you swap 98+ lens on 94-97?
- engine swap for ls- looking for your feedback
- need a reliable mechanic for an "engine swap" in south korea
- ABS delete 98 GSR
- need help
- 98 integra ls with 96 ls ecu: will it pass smog?
- 16x8 Sportmax 513s(0 offset) fit my 95 integra?
- lowering my DA problem!!!
- Exhaust opinions
- trouble finding patch panel
- stripped header bolts help
- How to remove INNER Tie rod?
- RIP 1994 Integra GSR
- need help with gauges!
- my car almost got stolen!!!
- Braces from Block to Tranny
- 90-93 4 Door Taillights.......
- Whats the legal ride height on my 91 DA?
- overheating problems (searched)
- New winter project
- Civic exhaust fit Integra??
- DA vs DC Calipers
- 93 b20vtec turbo agp
- 94 coupe w/B16
- Buying a 93 Integra GSR
- How to check injector size?
- arp rod bolts
- 1994 ls integra 2 step question
- Timing belt broke
- Engine idles at 3000+
- Clutch or Tranny Problems??
- Rear lower tie bar Question.
- SRS light
