View Full Version : Acura Integra
- best way to tell what dizzy i have?
- retap or heli-coil
- newbie question... civic integra parts interchangable?
- Will switching to OBD-I solve my problem?
- B18B WATER PUMP PART #???
- Mugen Twin Loop Size .. Need Dimensions !
- Problem: Power Loss and Almost Stalling
- 92 GSR traction bars
- obd2 gsr swap in a hatch... vacum hoses connect to some sort of black tube like thing???
- HELP PLEASE!!!!
- Install Harness on DB8
- b18a and b18b oil pan the same ?
- FREE AUTOMATIC TRANSMISSION FROM 92 RS!!
- check engine light?
- another lsvtec ..?
- Halfcut
- Kosei K1 Racing?
- OEM parts online?
- My Check engine light...
- Supercharger?????
- maint light
- fuel pump went?
- Puttin an LS into my DA9
- GSR stolen
- bumper light harness?
- searched....wiring for electronic oil preasure gauge
- Question about boring sleeves
- Help on Research.
- Cooling fan problem...HELP!!!!
- looking for a clean da ls coup
- idle problems
- Finishing ls/vtec build.
- Kinda clueless, exhaust junkies needed
- Code 43 Flashing today ???
- What kinda clutch and spark plugs should I get for my 97 gsr?
- What kind head gasket comes stock on a b18a?
- Unknown 6 dash clips and 1 unknown metal part
- '96 Integra LS - Coolant bubbles out of top plastic pieces of radiator, Blown HG?
- TROUBLE STARTING
- I always have the most random problems/Intake
- What front and back lip is that?
- anyone have horsepower #'s for a GSR head on a b18a block
- Whats the difference between the b18c head and the b16 head??????????
- Is a JDM type R shifter shorter than a GSR?
- tenzo springs r (purple)
- 94 LS Teggie blow tranz!!! Need 5speed tranz Have Auto forsale
- HELP WITH RIM SIZES
- Tires on 16 x 7 rims
- auto tranny upgrade
- 12 Second Stock Internal B18B?
- GSR Block, ITR Pistons?
- What do you guys think of these?
- What size wrench/socket to take out 98 GSR knock sensor?
- Intake suggestions
- snapped balljoint while driving
- DA Wiper Size, Yes I'm dumb...
- ABS light just came on...
- fs: 90-93 integra momo hub (pics)
- swap wont start
- Major Sunroof Issue.. Inputs please.....
- Blox intake manifold on b18a question
- grinding tranny
- 98 GSR manual tranny problem...i think...???
- Is it necessary to change the PCV?
- Could someone please tell me what these do? **PICS**
- B-series Crank Pulley w/ AEM Alternator Pulley Belt
- Ok its time to replace my stock tires...which ones should i get??
- 88 head on 87 block
- HELP. removing wing on a 94
- Ebay earthing/grounding kits?
- My car wont stay on!!!
- ITR Muffler ?( for peeps with ITR muffer.)
- need help w/ check engine light
- Skunk 2 Intake manafold
- wheel color choice
- burning oil??
- have a question on my gsr.
- 96(obd2)b18b into a 95 LS chassis
- integra zx 1993 tuning
- Need Help
- more power with less money
- Main differences in 94-97 and 98-01 3g's???
- Fuel injector cleaners and Seafoam? How-to...
- WTF??!
- FS JDM WORK WHEELS!!!
- NEED HELP ON CLUSTER AND MIDDLE CONSOLE
- downpipe Question
- Duble Clutchin?????????????
- Need your help... what do you think my girl is worth?
- Under Dash Fush Box Question
- countination of ls cannot be a type-r thread
- 3rd Gen Integras
- Valve Tap?????
- Taking the Trunk Lock Apart?
- Quick Questions...LSD tranny
- trying to find rs-r exmag catback exhaust system for my DC coupe
- F/S 99 integra GS with mods
- Anyone running advanced timing?
- head bolt location!!!!HELP
- 00 GSR- Car Lightly Jerks at low rpms
- Rear seciton where spare tire sits.
- my fuel gauge is in-accurate....what can i do to fix/test it?
- rs-r exmag question
- ls vtec
- b16 tranny, should i get a flywheel?
- whats the harness called that connects to the blower fan?
- Offset question and your opinion
- going boost
- squeaking sound
- Can people with the JDM DC2 conversion do me a favor?
- New 2 Forum
- type r sway bar install kit-bsq vs. beaks
- what are these for? b18a1
- FAL radiator fan? Yes No?
- Another Intake question...
- need tranny
- how could i get rid of this big huge gap?
- How to clean cluster?
- TDC on crankshaft pulley
- Bogging 1st gen integra.
- Cable tranny in 94 integra?
- Exedy Stage 2: excessive chatter
- What do you think?
- 95' GSR ABS removal
- car dies when i start it...
- Power Locks
- trouble shooting code p0141 i think?
- B18b Turbo'd
- Car won't start...something with ecu?
- engine light
- ITR CAM?
- 99 dash swapped into a 97, both 2d gsrs.. Can I use the 99's harness?
- LSVTEC BLOCK help!!!!!
- ahhhhhhhhh my hood flew open!!!
- Auto Tranny problem
- LS FPR
- inspection rip off!...help
- piston questions
- When does your vtec engage with a aftermarket manifold?
- OBD1 motor in OBD2 car
- Da radiator question
- timing trouble i think need help asap
- whats aftermarket pulley good for?
- Rear Tire Wear problem..Lowered, need help please
- 1990 integra seatbelt problem. help!
- looking for tuning in my local pa/ohio area
- What to launch at?
- Setting stock deck code
- Tired to steal my gsr last night- could This part be replaced
- stuck piston rings?
- 94 white integra
- have new problem
- How often should I Balance my wheels?
- gsr motor differences
- type Rs are the only ones being taken.
- car accident again.
- Need your input please...
- what exhaust for turbo app?
- Squeeking noise when i turn on the engine!
- GSR with ls tranny :(
- now what?
- Turbo or Supercharge GSR?
- noobs and other ht members
- Type R Suspension, How much different?
- new suspension
- F/S 99 integra GS minor mods
- occasional KNOCK when leaving first gear/down shifting/dips/reversing...?!
- Got Some Quick LSVTEC Questions... Opinions, suggestions...
- which HID kit
- found 2 things taking out my interior. have any idea what they might be?
- im about to need a tune up but i wanna know yall's opinions
- what exhaust for turbo teg?
- Poll: Paint lip or not?
- What lip kit is this?
- o2 Sensor Threading
- weird idle?
- jdm integra headlight hid projector question
- engine bogs
- 1994 gsr
- Hello gays
- new exhaust setup plan
- vafc reading one rpm while my tach reads another
- Couple questions on DA's.
- Just ordered a brake system!
- s2000 Cluster Pinout
- Quick engine question...
- thoughts on greddy turbo kit
- INTEGRA TURBO FOR SALE!!
- engine harness connectors...where to buy replacement pieces?
- anyone w/6x9 speakers?
- headers
- HOW MUCH OIL!!!
- Do Corbeau seat rails come in pairs for DA's???
- brake bleeding
- Can anyone post of a diagram of b18 b16 tranny bolts?
- strange noise help
- which cam should i go with for my 2000 GSR
- What signal goes into the Vtec solenoid?
- Integra Radiator
- is my clutch going?
- nighthack balck or supersonic blue
- 90-93 guage cluster wiring diagram
- engine light turned on
- FS: Socal 1990 DA9 check it out!
- PIC request.
- What Cat/Test pipe for my header?
- need some help
- Dart block with the stroker kit?
- low idle at start upp
- Best Header
- tuning with uberdata?
- B16 tranny vs B18 tranny - engine
- starting issues
- jdm front end liscense plate problem
- Time to rebuild tranny?
- intake whistling
- what are my best options on replacing cat converter? 97 teg
- Need Help with conversion!!!!!!
- how big is my gas tank?
- need important advise on gsr
- Will RSX rear seats fit?
- Need help with part number for gas cap!!!!!!!!!
- radio and cig lighter.....
- New clutch, pedal feels kind of weird
- valve adjustment 92 LS
- Crank Question.
- removing stock headunit
- Over Heating
- Spark plug wire keeps popping off dizzy!!!!!
- How do I get impressions/indentations out of my foor panels?
- My little DB8...
- 7,000 RPM In 5th Gear?
- So. Cali Track Locations
- B18b Questions..
- 2001 ITR Fenders and Hood for sale
- DC-SP Header Help??
- Cool Auto Insurance Commparison Site!
- Integra Sunrise Wallpaper
- flywheel vs. turbo cams
- 98 Integra OBD1 or OBD2???
- How to I tell if motor has been replaced???
- 98 headlights fit a 96?
- Good Place To Get JDM ONE PIECES?
- Injector help
- horn was crazy......
- 2.5" Exhaust
- question about gas
- P73 Question
- selling my 96 ls, value?
- Help Identify these cams
