View Full Version : Acura Integra
- b16a tranny et's
- Ignition wire set part #
- Integra Rally Car??
- what is the best cam
- How bad is this leak?
- Noob here, just saying hi
- WTB:96+ Integra gs-r
- s-afc set up in my teg.
- Installing S-AFC
- Performance
- us itr header fit on LS question
- how about it
- Help Threw Code 9
- Hello!
- JDM DC-2 cluster??
- While I have the engine out??????
- Brake Caliper Bolts
- rust look alike residue on 1 intake valve??
- Size thread for Integra shift knob?
- 2nd gen ABS to Master Cylinder conversion?
- timing belt..
- Need a part number...
- Bad weekend at Hot Import Nights/Dallas
- Whats up with my BRAKES?????????????????
- brake master cylinder!! why so expensive???
- Who selling a B-16 or GSR head
- Supercharger info
- jumper wire
- ECU hookup conversion
- aem filter
- Opinions on some spoilers on an integra?
- trouble starting
- are all yall turbo setup intercooled?
- teg starting up then dying right away
- Exhaust vibration...
- how much is lsd for an integra ls
- Tint Job
- price for a good header
- Need Help With Cali Type R Conversion
- Need a Quick Question ANSWERED?????
- How to make camera mounts in a teg with racing seats?
- JDM ITR conversion OR JDM GS-R conversion?
- New mod. Need advice please --->for an LS
- All Mods Necessary to Make GSR Handle Like a Type-R (or better!)
- LS 14 inch snowflake rims
- k&n typhoon intake impression
- Where to get black lug nuts?
- jerks/shakes when let off
- unsuccessful attempt to steal my car
- Serious car prob. Help!
- Type R knock off wheels?
- A/C compressor died i think....
- ITR or Comptech
- Which O2 sensor is it (bank#1, sensor#2)? HELP!!!
- Vented Hoods????
- Valvetrian upgrade
- Whats that site for the weight of the rims?
- Got in a small reck with 97 gsr...need help quick
- does a 96 jdm gsr cluster need modification to work in a usdm 98 gsr?
- Spark Plugs?
- car shakes when accelerating.
- import builders crated engines
- Custom Turbo Setup
- 15" or 16" Wheel for G3-Integra?
- Those who have KYB AGX Shocks..
- ok waht about this set up.
- how much esitmated hp...
- does a breather even do any thing for your integra
- Welding issues with Carsound hi flow cat
- Is an LS exhaust manifold the same length as an SI one?
- Engine needed for a 1992 Integra
- Should i go 205/50/15 or stay at 195/55/15?
- aem or comptech?
- Comments on air intakes and muffler?
- how many lbs is this wheel?
- all differentials (lsd or not) interchangeable between b series trannies?
- some 90-93 integra stuff for sale
- Benen lower rear tie bar?
- aem intake ???
- whats up with my clutch????
- torque specs for header on 99gsr???
- Oil change question?
- type r sway bar swap, anyone know if these are the parts?
- Strut tower/tie bars...(did search and came up with nothing)
- check engine light is on all the time now...what do I need to check ?
- Vote people!!!!!!!!!!!11
- How to break a clutch in?
- need your help
- KVR performance brake pads????
- 95 Integra Power Antenna
- Valve Adjustment Tool for my GSR
- Properly Gapping Spark Plugs
- integra compare on hp
- JDMhondaparts august specials
- Civic Ex 98 or Integra ls 2k ?
- Running say..thunderhill with this setup w/o overheating?
- Size of the stock gs-r header collector?
- Checked Plugs Yesterday and.......
- clutch change?
- Anyone know the p/n for LS seal and gasket kit from acura??
- Has anyone ever put a Type R ecu on Gsr with Type R cams on it???
- which ecu for ls/vtec
- What offset do I need to fit a 15"x7" wheel?
- Loose Transmission Mount!?
- Quick 'need to know'. Si header on GS-R?
- Crower 403
- how hard is it to remove the TB to clean it?
- speedlimiter
- how to remove Kyukugen (sp?) lugnuts if tool is stripped
- Clock won't keep time when car is off for a day
- ParKing Brakes ProbLem
- Help on tire decision....
- Vision/spoon style mirror
- price for a 99' GSR?
- Drag Coefficient
- Carbing/Okuyama GB!!
- tire pressure for 205/55-15 for good gas mileage
- what's the Integra Fuel tank spec.??
- ac compressor
- Spoon, Skunk2, or Venon intake manifold for B18C1 motor?
- will 16" slipstreams fit under AEM ??
- Who knows turbos? If so, Is there anyway I can contact you?
- ok, what's the best tire for me?
- Old reliability ranking
- ran into trouble, axle shot? car pulls to the side and wont drive...
- how much do 94 BARE gsr b18c block and crank go for??
- whats the proper way to clean injectors?
- how to stop Wheel well rubbing on teg with SK2 coiovers?
- when does vtec kick in for a 95 gsr?
- my clock broke
- WTB...1991 2 dr. flares
- WTB...clears for 1991 2 dr. 'teg
- How to clean TB??? Did it once but not sure I did it right.
- Drop springs!
- ~ Is It really worth 10g's? ~
- south fla milano red teg owners
- any transmission experts in here??
- '95 teg question.
- Squeaky belt... I think Help please
- tire rating on the stock michillens
- Tranny problem!!!!!!!!!!!!! HELP!!
- CRV head on LS block
- energy susp mount install Q...
- any 94-96 integra's come with blue interior?
- cant find in search
- apex n1 or es oval
- Top Fuel Lip on USDM front bumper
- ITR cams with stock camgears?
- Muffler question...
- anyone use fuel treatment gas?
- exhaust melted rear bumper > options > ?
- Proper place to put jack stands.
- plugs for a gsr eng
- forced CAI?
- have a spare/busted 90-91 LS tranny? Lets chat
- Inner brake pad has no shim?
- Octane on an LS
- vafc
- stupid clutch question
- Car shakey at high speeds!?!?!?!
- Stock rim size?
- why don't the non-vtec get spark plug covers?
- 1 or 2 o2 sensors?
- Need help on cylinder head bolt removal!!!
- exedy????
- act or clutchnet or exedy
- Tools for header installation
- Camber question?
- Red suspension? anbody no anything about them?
- whats the fuel cut off on a integra ls
- **** help***
- For those with experience with the DIY intake and comptech ice box.
- Integra race car
- What do you think...
- flywheel movement?
- Who has a JDM 4-1 ITR header on their GSR??
- which wire on the o2 for installin a/f gauge for obd2
- engine "tapping" when ac is on...
- Azenis + BSQ-box intake in Monsoon review (long)
- can someone gave me a carfax report on the integra gsr??
- I'm back with a B-serious
- can you guys help me out here?
- Wide Band O2 Sensor
- will my 94 skunk2 gsr ecu work with a 91 b16a obd 0 motor??
- OT: I need your A/C and PS systems!!!
- floor jack and jack stands
- Valve Lash Controversy......Who's right????
- Mant. Req
- Need help with Axle swap on 93 LS
- ABS Problem
- anyone in the bay area, ca that can help me do timing gears?
- Wheel Bearing going...race?
- yes another post about this...
- Bilstein or Tokico Illumina?
- power steering went out...dammit!
- want to buy gsr training
- Who has the JG intake manifolds for sale actually in stock and ready to go?
- timing problem
- Next car.... ??
- WOW. Benen tie bar really works!
- check engine light came on!
- intake manifold
- OMG whats wrong??!!
- mugen exhaust
- why does it feel like my wheels are gonna fall off my teg??
- Just installed my Air/Fuel gauge.. just some questionsss
- SC with an IC?
- Transmission question.
- those with gs-r's...any of u swapped in the type r ecu?
- Clutch Master Cylinder Replacement
- Show me some knowledge
- VW like cluster.
- Tranny rebuild kit?
- Is there any difference between the trannya on a 95 gsr motor, or a newer gsr tranny??
- installation of ecu
- who has crower 63402 cams in there car
- B20 Turbo in my LS?
- gsr vtec engaugement.. and GSR vs DEL SOL
- Best overall exhaust for GS-R??????
- Height of car
- o2 sensors in 98 gsr?
- I am pissed, my car has been in the shop since Wed.!!!!!
- Just order 2 Kumho Estascy 712, 195/55/15 for $148, good price or not?
- Exhaust for 2000 GSR
- guage sensor install
- Friendly reminder before everyone forgets...
- help!!! code 67, can't fix, did everything.
- What size is the GSR muffler?
- How much have you guys paid to get your tegs repainted +bodywork question
- GC Coilovers and...
- timing may be messed up??????
- Went to the dealer and the weirdest thing happened...
- Interested on a Bay Area Dyno Meet?
- axle back exhaust question
- 1/4 mi Quiz for you guys
- does anyone have pics with Racing Hart T5 rims on their teg's??
- Am I mistaken of does the b18b1 out of a 91 teg have a knock sensor?
- syncros help please!
- Brake installation
- I hit my muffler and now its stuck to my bumper!! HELP!!..
- cam gurus!!
- My car was stolen last night!
- 5w30 or 10w30 mobil 1 on higher mileage GSR?
- Light replacement on Spoiler
- hmmm is this bad?
- Toda Cams, Cam Gears, dual Valve Springs (vtec Killer kit) Good or bad?
- Where to buy pre-molded OSRAM HID Bulbs (Bulbs only)
- 90-93 Integra One Piece front end
- Whats the diff. between hondata and a v-afc?
