View Full Version : Acura Integra
- da obdo ecu question
- problem with my 90 integra rs 4dr
- STOLEN 1996 integra gsr dc2
- Own a DC sports header?? then i have a q for U
- torque specs for everything required to change brake regions
- beeping noise when driving 95 ls
- Whats that motorized humming sound? 91 DA
- TPS Question
- trying to get my heat working.
- 01 Integra GSR help immobilizer
- Bogging issue..
- Pick My exhaust!!
- Will degreeing the cams be mandatory??
- BLOX LCA INSTALL QUESTION
- Replacing Stock Projector with E46 or TSX
- 98 DB8 w/ ITR swap... need cruise control...
- questions
- Lose A/C when going turbo? (LS)
- Steering wheel jerks violently to the right.
- Changing axles
- need lsd for ys1
- need some help with abs
- Just lost the Heat
- GSR A26 IAB Solenoid not hooked up
- Engine noise.. squealing/whistling
- how many radiator fans does a integra have?!
- What to do to my transmission?
- What should i do to my tranny?
- clutch slipping...has no resevoir cap on it!!
- DC Header 4-2-1 and 4-1
- GSR stock airbox and LS airbox
- axle boot?
- STOLEN 96 integra gsr HIGHLAND PARK CA
- GSR Dyno: ITR cams/header blox IM, tuned w/Chrome
- I think its my thermostat
- SRS Plug Location? 95 Integra
- 2001 B18B Throwing OBD Codes 170 & 172
- raddle in gauge cluster
- dc dash into da
- Serious issues
- cluster doesnt work help please
- Sounds like marble in passenger door....
- suspension?
- clutch issues
- car takes forever to warm up and operating temp is low!
- Roaring idle + Overheating in 40*F Help!
- 91 teg with 94 ls mount help?
- can someone do a testing procedure for me?
- Help with some tips and tricks
- Squeek coming from driver door?
- Cylinder 1 and 2 are not firering, HELP!!!
- integra seatbelts
- Is the 1992 integra gs engine compatible with 1990 integra gs engine harness
- ls non-vtec turbo?
- WILL A LS CRANK FIT A GSR BLOCK!!HELP!!!!
- Miss fire on cylinder 2?
- Stolen 96 integra gsr GRAY COLOR
- need ideas for new motor
- GSR Swap w/ 5K rev limit & high idle
- valve flash
- **Car Stolen **
- Exedy Clutch Racing Stage 1
- Benen Rear Lower Tie Bar fitiment ?
- looking to find this spoiler for gsr PLEASE HELP!!
- LS block questionsss. . . .PLEASE HELP .
- I'm starting to get really frustrated.
- Which quick release is this
- b20b in my 97 gsr need help
- Need Help!!
- bolting on distributor (timing)
- Can someone please tell me how long thier Integra GSR dip stick is
- 99 teg radiator leak!!!
- GSR Swap help... almost done
- idle screw?!
- license plate lights question
- transmission fluid
- will i have a problem using this ECU?
- CAR OVERHEATING!! need help
- Price of rear wheel bearing???
- Outer Tie Rod Removal Help!111!!
- Idle problem
- 95 GS-R: Tachometer Jumping Without Increased Throttle
- Exhaust for 1999 4dr GS-R versus 4dr. LS
- Missing 2 bulbs..
- My 97' GSR Build.
- Buddy Club N+ for Integra
- Hello
- buzzing sound from in dash turn sigs not working please help!
- HELP!!
- Injector wiring...
- B18B1 Head Torque Specs
- jdm headlight question
- horribly loud squeeking??
- cel p0108
- Quiet exhaust
- 2000 ls wont start
- Best set up for B18C "JDM GSR"???
- Throttle Position Sensor - 97 Integra
- Problems with hatch install! (searched)
- will it work?
- knocking noise
- HELP!! my shift column locked!!!
- insurance for a GSR teg
- integra motor help!!
- HID Install on '94 GSR
- no key in ignition (lights still come on)????
- Should i rebuild my B18A1?
- looking to buy a 95 integra.
- help
- Q? about my SRS and ABS wiring
- Don't feel like seaching, FPR any good for b18?
- SRS light question
- help on timming
- header question
- Question about integra turn signal lights
- Lumpy Idle
- A bunch of installiation questions.
- shop in dallas
- HELP!!b-series tranny issues-HELp!!
- help with distributor!!
- Stereo Install
- removing sound deadening leftovers
- 1992 Integra with Innovative cable to hydro, What kind of clutch cable ?
- Anyone know a good body shop in SoCal area?
- idle sucks!
- OEM 94-97 Foglight related question.
- Help on my 96 LS
- MY DA HAVE PROBLEMS ANY HELP
- coilovers help!
- DA problem....
- Question about radiator
- O2 Simulator
- Need Help with a Setup
- LS/VTEC
- The Hood?
- Porting your head
- ECU Limp mode question
- Replacing my valve cover seal?
- Blown up gsr motor what all do i need to swap it out for obd1 ls motor?
- Differences of the Skunk2 exhausts?
- WINDOW PROBLEM
- Problems with the teggy.
- installing front strut bar? should car be jacked up?
- speedometer jumpy, loss of power. Itr swap
- P72 obd2 auto GSR swap?
- Airbags on a 96 dc4
- cost of replacing brake lines
- GSR gave out!!!!!
- I was wondering if anyone know if this will bolt up...
- megan racing exhaust on a stock header
- 87 Integra shocks
- What give the car better performance
- 97 LS Coolant problems
- Wiring a GSR swap in my 96 RS
- braking noise
- weird clicking noise...
- Changing Steering option
- Vtec at 6 grand...
- pcv interchangeability please help
- My Ls/Vtec isn't starting. Need Help
- high flow cat question
- is it okay to mix leaded and unleaded fuel?
- 95 LS Need some Friendly Advice
- Intake sucked up coolant.
- Anyone remember the DIY CAI air box mod 4 inch???
- PIAA Halogen Lamp?
- 96 Integra LS... Where do I go from here?
- need help asap!!
- Transmission ?'s
- 90 integra issues
- Fuel pump relay??????????please help
- What is a distributor coupling??
- Subwoofer underneath the seat
- help me find my thread project resurrection!!!
- Teggy died, Please help!
- Good asking price?
- 95 ls integra advise..
- BOOST or ALL MOTOR?
- Radiator difference, Showa Vs. Denso?
- GSR tranny fit LS block?
- over cooling/heating issue! help!!
- heater not very hot.
- Simple mudflap question
- CEL codes 10 and 14 and 22
- Lower tie rod fail
- Question regarding 1 piece headlight bulbs
- transmission conditions
- Drilled & Slotted rotors
- How much is this car worth?
- HELLLP car died while driving
- how to wire power mirrors??
- question for ppl that are lowered to ~2 finger gap
- Intake Manifold
- armrest for a DA question
- fan relay
- RHD Integra-getting no spark
- What year integras interchange?
- new integra owner! needs help
- alright to do??
- car wont start
- Battery died car acting weird Help!!
- Starting problems
- Replacing the clutch in my 93' ls..
- Integra Steering Wheel Swaps
- Car wont start unless its jump started!!
- fix b18c or swap for b20?
- 94-97 foglight question
- will a ls fuel rail fit on a gsr intake manifold?
- Head lights swap?!
- 94LS reverse/rebuild!
- help with transmission swap in DA
- DC Integra Autometer Guage Cluster Bezel USERS, how's the fitment???
- need help asap 01 gsr
- need to sell 86 integra ls with jdm zc
- b18 engine parts on b20???
- HELP!! acura integra 95 ls
- Transmission Problems! Manual! Need help please asap!
- IN IAT Cel
- weird problem, lost speedo AND vtec at same time
- itr head ls-vtec, what ecu
- 90 integra wont start..got fuel,and spark ? help
- Help needed from people with 98-01 fogs
- Queston about 94 Integra ls tranny
- Whats up with my timing? << Adjustable Cam Gears >>
- quick tranny
- want to put rsx steering wheel in a DA
- 1990 integra -- AC belt popped off after sudden squeeling noise
- obd0 to obd2 distributor SOHC VTEC
- NSF's update for the non-believers.
- CTR steering wheel in integra
- one piece headlights....h4 bulb?
- rubber seal
- 95 integra LS fuel pump not turning on, main relay clicks on, cel light does't off.
- Oxygen Sensor Question
- P61 vs P73 Intake Manifold Bracket
- ABS DELETE HELP
- help with my 98 gsr
- need help...evap solenoid issue
- how reliable is an ls/vtec?
- Do I have to gap my NGK's?
- car wont start need help asap!!!!!!
- speedometer, rpm, temperation, clock is not working!
- Federal Vs California OBD2 ECU (P72 Gsr)
- 93 Integra Advice Needed
- 92 Integra - I need some advice please.
- gauge cluster help
- ABS Module buzzing...
- Antenna Broke...need help...
