View Full Version : Acura Integra
- Baby Car seat in Integra
- B16 & b18c confusion
- my check engine light comes on please look at posting!!!!
- rpm is shooting up high and going down need help
- need help ripping out oem alarm and re wireing it so wont have alarm!!!!!!!
- Installation of eBay intake installation without instructions?
- will the front mud/splash guards still fit with the optional side skirts?
- 1996-1998 Integra EVAP Vacuum Diagram Needed
- dc2 2000 LS vs. 1999 gsr exhaust midsection
- tunning my da turbo
- exhaust help!
- valves
- 96 gsr head rebuild?
- smog?
- built integra gsr
- Old school teg, motor options?
- anyone have driverside OEM foglight forsale?
- New guy here.. Couple questions... DA with B16.
- Rough Idle After Acceleration
- parts for the teg....
- 2000 Acura CL navigation into a '94 Integra?????
- injectors and fuel rail
- how does this look
- 95 teg
- CAR WONT STAR! clicks, the batt. drains??
- dumb integra thieves
- ok i finally got some video, check out my battery light!?!?!?!? WTF
- 1996 Integra RS... IM stuck
- home made 8$ resistor box, ls engine mount ?,
- Is a rear sway bar required for certification?
- Pictures of my DC2 and bro's VR4 *Lots of Pics inside!*
- help
- installing a 4-1 header
- fluctuating idle.
- QQ: Will 2001 B18B1 Automatic Tran fit on 1992 B18A1 motor??
- Part number for rear hatch latch? Need to get rid of this hatch rattle!
- How to get stiffer steering?
- b16 and gsr trans
- Rear sound help please
- power shift points!!!
- need help car won't start
- teggy gsr quetions???
- Removing 4 Dr integra seats
- Rev problems on 94 integra
- Value of this car?
- I've searched...PCV valve and oil burning?
- AUTOMATIC Integra, wants to be much more!
- Conflicting info about temp gauge
- Rear Swaybar/Lower Tie Bar Question (DB8/ITR)
- Steering Lock Assy - stuck key
- GSR HEAD/VALVE COVER QUESTION?
- Will a 4dr core support fit a 2dr are they the same?
- Newb To Tegs, Few ?'s
- IAB WIRING (JDM GSR ENGINE/ECU/ usdm wiring harness...
- dizzy problem
- Just another engine build?!? 56k not gonna happen
- Tanabe NF210 Springs
- camber kit question...
- best swap for a DA
- Over heating Problem. 1994 gsr integra
- How much for 4 Lug *Complete*
- Suffering gas mileage..what seems to be the problem?
- 30 gallon air compressor?
- swapping high mileage B18A for low mileage B18A
- What Type of OIL should i use
- Came back from the dyno!
- Stroke or no stroke; turbo build
- NEED HELP Car WONT Stop PLZ!!!
- ys1 s80 compatibility question
- High rev during idle
- need help
- vacuum issues!
- What is this sensor?
- will b18a axles fit on a b18b (5 speed)
- Attaching a K&N to stock intake pipe(pict request)?
- b18a timing belt??????
- Ls Vtec into DA gsr. What all is needed?
- temps and starting problem
- Help! Had to leave my car on the side of the road!
- WHAT IS THE FOGLIGHT BULB FOR DA ONE PIECE HEADLIGHTS CALLED?
- GSR motor Toda Vtec Killer Cam
- help after swap!
- will 98-01 halo headlights fit in a 95??
- will usdm seat rails fit jdm recaros?
- b18c into da
- JDM B18C Code 1 and 4
- Leaving cruise control gives you more mile per gallon or no?
- fuel smell in car, no pressure in fuel tank when removing gas cap
- just bought a 90 da need help
- b18c vs. b16
- B18 Rod side play!??? on turbo b18
- Question on 4x114 itr conversion
- Can you fit 4 tires inside an Integra??
- venting my block to an oil catch.
- adequate floor jack point image
- need shorter alternator belt for integra
- How Do You Adjust The Throttle Cable On A GSR?
- is my teg misfiring??
- main relay on DA
- 91 Integra bulb questions..
- no crank after motor swap
- Will these Red Honda Emblems fit on an Integra ????
- drop zone suspension??
- starting problems??
- HUB Question!!
- Upgrading to a 23mm rear sway bar
- i am having trouble starting my 93 da plz help
- red fluid leaking
- whos got a 90 or 91 DA with a b16a2 '00 si that came out of a ...
- stolen integra
- GSR greddy evo into LS
- 98-01 us itr lip
- Are old school HKS Sport exhausts for the 90-93 DA the same size as 88-91 CRX?
- What size bolt is this?
- exhaust manifold rear heat shield
- b20z2 lash question (specs inside from helms if you find this while searching.)
- Looking for Internal dimensions For new Carpeting
- New springs n a lil problem..?
- Turbo h22a DA
- new wheels
- b18b cap and rotor
- how do I take off my clear bra?
- JDM ITR 5 LUG CONVERSION
- question about head torque spec and sequence / head gasket job
- intake manifold help!!?!
- Dashboard not working - Integra 1988
- what type of gear oil?????????????
- Brake Light Stays On / AC Switch Not Working Properly
- OBD2 distributor gsr question??
- how much does it cost to ship a hood
- What is this? and what did you do about it?
- axles question.. couldn't find it on search
- Right Hand Drive Legal in California?
- gsr turbo starting problems
- Anyone know anything about this Turbo Integra?
- Would this fit my TEG
- LS VTEC FOR SELL!!!
- V6 mustang...
- Flex-a-Lite Series 130 Issue??
- HELP ME PLEASE!!!!!!!!!!!
- 93 Integra GSR Will not Start!!!
- b18b help
- IAC valve cleaning
- ls rebuild.
- Throttle cable assembly
- need some advice
- loud squeek issue
- PIC REQUEST: WHITE DA WITH DR20's
- about to buy a db8. few questions
- what can i use as a spacer for my short shifter install?
- Need help with alternator wiring diagram?
- What does the Logic Ground wires on the ecu hook up to?
- way to fill rear mount?
- thief information
- Ground short..Please help me out
- Another problem I'm trying to figure out... coolant!!
- I'm an inch from insanity... please help with battery trouble
- 91 integra need help
- Stutters when accelerating...help!
- gas on gsr
- 91 teg auto 2 5-speed swap, In progress need help!
- Integra LS-T..BOOST PROBLEM !!
- CF Spoon Style Lip
- coolant coming out of the dipstick?
- water temp gauge
- How do you know its time for new axles???
- Almost totalled car...opinions
- Tranny Drop DIY
- auto to 5 speed conversion need some help
- crusie control troubleshooting
- car idles weird can u help
- JDM Intergra Front End Conversion Question
- Missin my DA
- Is my tranny messed up for good or is there any solution?
- Earl vs. Russel
- DA vacuum lines on a GSR head
- looking for pics of a 2000-01 GSR header or stock exhaust manifold and downpipe
- tech qustion
- codes
- Anti-theft Tips and advises PLEASE!
- exhaust help
- Car breaks up around 5,000rpms
- Replacing oil seal
- DA GS-R HELP!!
- car still overheating pls help
- new rotors and pads
- usdm GSR ys1 final drive ring gear tooth count?? somebody help please
- Lookin to swap my ls tranny to gsr, what do i need?
- car shakes at 50mph, about to drive it into a wall!!!!!!
- NEED HELP WITH TEG
- h22 on a b18
- da integra help please!!!!
- Rims
- GSR Head on my LS Block
- virbration in car need help to diagnose!! car vibration dont know whats the problem!!!
- Input shaft bearing v.help identify
- Suspension????
- what oil??
- Slave/Master Clyinder? Or Clutch?
- 1991 integra car will not stay started after getting gas?
- Just Picked up a 96 Integra
- Painting my front bumper
- Where can you buy legit RHD Hondas?
- speed sensor fuse
- DA wont start
- Removing the Weather Gaskets
- sportmax/xxr 501's, What is the best size for a 93 DA integra? recomendations?
- Wire tuck question
- Burning Oil
- should i upgrade or not
- Just found out my Teg has Civic knuckles on it..need help quick!!!
- DA: Test thread
- **BEWARE** Dash removal
- philadelphia integra drivers!! performance shop locations??
- bumper light fell off..
- would you know?
- How can i boost stock HP on my 1991 acura integra??
- Car stolen. Again.
- OPINIONS WANTED ON MY SWAP SET UP
- How did you decide on an aftermarket exhaust?
- Bad O2 Sensor?
- need help car wont go past 3k
- honda-tech trial period
- does ls an gsr header compatible.?
- 4 wire o2 sensor help
- Knock sensor question
- question ppl...
- testing b18c vtec solenoid
- So my windshield wipers wont turn off...... and my climate is
- Short Throw Shifter
- replaced ICM ran for 10 seconds and quit again
- Integra 98+ hatchbacks
- vtec swap price
- possible five lug source
- 1987 Integra Engine Swap Question...?
- whats up with my tranny
- car smoking?
- Help: PCV Valve is stuck
- GSR Motor condition
- how do i change the rear coilover the easeist way possible in my
- Tranny won't go into gear
- New guy...advice?
- Old Gas?
- restoration of my teg
- Connector Pin Out
- need radio code please help.
- HELP integra wont start
- any good tuner shops in oc area??
- 96 integra, no spark after motor swap?
- where to buy rear valance???
