View Full Version : Acura Integra
- Help, trying to replace hatch supports!
- what should i get first?
- JRSC + Internals.....Recommended or not?
- I need Front Brakes!
- HEY FUZZNUTS these pics are for u!!!!
- JDM ITR & CTR Recaro Seats (Front and Back)
- JDM DC2 PARTS (FRONT END FOR SALE TOO)
- Need to vent out my anger
- Is this set up 50 state legal?
- HKS Dragger on an SE/LS Availability? Power Gain?
- can i fit prelude injectors on an integra???
- Yellow wire in Crane Ignition
- What does the GS-R redline at??
- Will a type r manifold fit on a b17? 93 gsr
- help please! my clutch pedal still squeaks with my new....
- Can anyone help me when "maint reqr" light flashing at 88k miles?
- ECU for an LS?
- zex install
- JDM ITR header & ground clearance
- how hard/easy is it to install a skunk2 intake manifold?
- Need tips on installing Comptech sway bar/tie for this weekend
- Spoon FSB
- window cracked, where to fix?
- High Flow CAT on GS-R?
- can anyone help me adjust my valves?
- Which exhaust will give most power increase
- Does this sound like a good deal? (machine shop work)
- headers
- SoCal Please Read (free exh)
- V-AFC Settings.
- 2dr GSR exhaust fit 4DR GSR?
- Autometer electrical water temp guage???
- engine light came on..
- Jackson Racing high flow cat, direct bolt on?
- Looking for the person how was selling me a DC header from Florida!!!!!!!!!!!
- NJ MEET UPDATE
- ITR clutch in a GSR tranny?
- Can someone post a pic of an LS engine area? completely STOCK!!
- Help! Engine Prob???
- E-town Nov 10
- Neuspeed Springs
- Does anyone have a picture of a stock 99 GSR taillight
- Suspenson Techniques sway bars, any good?
- which Ingalls front camber kit to buy?
- OT: Endyn pistons - the way I think it works
- In search of Mugen MF8's, and an inquiry of Skunk2 manifold or Type-R
- In search of Mugen MF8's, and an inquiry of skunk2 intake manifold
- i have a pretty good tranny question
- weight of a 15" donut?
- ecu reset>?
- Question about a gsr swap
- Changing pistons...
- If you have lost your stock radio code are you screwed?
- NGK copper conductor sparkplug for GSR
- Maybe a dumb question, but . . .
- My planned suspension setup, comments?
- !!!! CHEAP ITR LSD IN METRO AREA!!!!!
- New Magnaflow Exhaust (PICS)
- Help Installing Shocks
- Question on the ground controls.........
- Please Help! My 92 Integra wont start
- JRSC vs. Turbo kit for B18C1. discuss.......
- Damn...got displacment?
- Suspension setup
- Queation on a b18c1 in a rex?
- Interior Pics? Anyone.
- why do half the purchases I make always get funked up one way or another?
- Check engine light code 17?what to do
- Anyone have the NEW Rev / Speed Meter from Apexi??????
- New pipe section needed.
- AEM Hot air + comptech icebox will this work?
- AH! need help cant here my radio
- Spoon sports strut bars. any pics?!?!?
- Which Header to pick????
- post your b18b all motor set up and #'s if you have them
- Which wedge bulbs/signal bulbs are the brightest?
- ? GOT TURBO ?
- attempting custom leather seat cover
- Damm ppl stole my clear corners and xexon bulbs !!! :mad:
- To all the wingless gsrs....
- SCCA and AutoX
- Auto Tranny Question
- How do you find the cc's of a head?
- What are the possible tires sizes to run on a 17" rim.. Thinking of changing and wanted opinions and
- Knife Edging Crank?
- HIDs ?s
- Wheel balancing on aftermarket rims
- Where to start modding on a 97 GSR
- Hard to get in 1st gear...
- Looking for stock airbox
- Instrument Panel Removal
- ls/vtec where??
- is belt tensioner really necessary?
- Squeaking transmission?
- head light adjustment
- Distributor problems...
- DAC cold air.
- GSR vs. 328i
- How the hell do I convert 9005 bulbs to 9006??!
- 3rd gear syncro?????
- how do you change lights in the climate control module?
- OEM sideskirt removal?
- high to mid 12's daily driver going N/A?
- pistons?
- where can i get jg/edelbrock products?
- does anyone know about the g1 integras?
- Pulley Install Help
- anyones rearwiper pop up at 120mph
- wide band o2 sensor?
- toda spec B or C?
- Is this a good deal for Mugen RNR's?
- Help-Trying to find Half shafts/intermedietes f/s-
- I've got a few sets of 11.75" 4 piston kits left...
- Great place to buy Eagle rods...
- Distributor making screeching noises.
- Comments please for my "buildup"
- People with White Integra's!!
- Good Valve Springs!!
- Prelude injectors
- Anyone in the OC area wanna help me do a valve adjusment?
- Timing belt
- The rebuild
- What do they have?
- Help please, i think i got ripped
- ------ Spoon 4-2-1 Header GB and Monthly Specials -----
- Suspension and alignment work in Orange County?
- Anyone use Yokohama Avid T4 in the snow?
- B&M fuel riser and gauge kit, is it worth it? is it enough for my set-up?
- Looking for more power but where?
- JE B20/B16 pistons in a straight B20
- new intake manifold?
- Could I have bent a valve?
- Anyone racing at MIR this Sunday ?
- Possible big bad problem...
- skunk2 cam gears???
- New Drag Times... Received TONS of thumbs up at the track!!!
- Opinions of B18B Engine Buildup
- hollowed out cat
- stupid questions: Bearing kit nesessary for a clutch install?
- I need a remote/ignition wire in the engine bay of a 3G teg
- do they make black te-37?
- PLEASE BUY MY Speedvision/NASA US Touring Car '93 Integra-Road racecar!
- when to shift...
- Well I did a compression check...
- Comtech Sport Springs and Koni Yellows
- Help, lost my ignition rotor screw ?
- S2000 Cluster in a Teg?
- Raising compression, please answer??????
- Loudest cat back system poll.
- Max milling b18a1/b head?
- Tanabe and Eibach for suspensions...
- Skunk2 IM vs. Match porting
- head bolt broke, how to replace?
- need some help.......
- Got an oil catch can for my all motor GSR.....should i put it in?
- Any front bumper lips for a 90-93 Teg?
- Update on Valve Adjustment and Whistling sound...
- any of you guys know where i can get an actualy TYPE R badge from?? any of you selling one???
- Where did YOU buy your Carsound cat from?
- Will Quaife LSD or Type-R LSD fit an LS?
- Exhaust question
- Truth About LIMP MODE !!!
- KPH gauges
- CLUTCH..
- LS/Vtec Turbo
- Everyone with CARSOUND CATS !!!
- b17/91 crx - code 4...burnt valve too?
- B18A for $325 shipped - buy it?
- GSR Manifold on B18B/B20?
- B20 head on a B18C block?
- How low should I go and how should I do it?
- bored TB and inake manifold???
- ATTN: All Motor Tegs
- Falkens ziex ze-502 m+s
- Valve Adjustment
- Picture of ram air duct for DIY "Icebox" CAI
- OT: Car Fuel Cutoff Switch?
- White or Yellow 2000 ITR???????
- what do i do?
- removing plastic rocker panel (door sill)
- what size speakers come stock in 99 integra 4dr?
- Need alot of help
- Honda-Tech IRC Server
- What can be the cause of this? Steering wheel shaking...
- help... getting euro indiglo guages tommorrow,,
- Heatshields for JDM 4-1 header
- NIRA Sold Out!!!
- b16a cable tranny on LS
- My quest for 30 more hp...gotta beat those gsr :)
- F*ck! B20 sucked up water!!!
- Anyone know where to get the Mugen body decals?
- How do you remove the climate control module on a 95 Teggy?
- main difference between usdm 4.875 and jdm 4.785 final drive setup
- what's the best clutch for the streets?
- 98+ front end?
- Anyone know anywhere to get good deals on Comptech items?
- b20 b or b20 z?
- crvtec?
- whistling sound coming from engine...
- Best spring/shock combination for autocross/roadrace?
- Depress Clutch @ 4k rpm and it grinds
- 3 or 2.25?
- gTECH
- Kosei k1
- Will this size tranny cooler fit in a LS teg?
- anyone ever experience check engine code 54?
- Anyone ever install JUN cam gears?
- ATTN: Turbo Teggie owners.
- Can't get my car to ping (Advance timing w/o a gun)
- Autometer Dual Gauge Cluster Bezel
- Any websites for auto junkyards that are in So Cal?
- Advan RG's or Volk TE37
- what winshield wipers to get?
- ATTN: All those with cams
- ---Moroso Oil Pan and Pick Up part numbers... thanks
- Check Engine Light
- B16's What do you think
- Iceman intake owners
- B-series head on B20 bottom end
- best brakes for gsr
- A little question for you turbo Gs-r Owners out there
- my main ecu fuse keeps blowing when i drive, how can i fix this ?!?!?!
- Where to go next on a limited budget
- Will 14" CRX wheel's clear the brakes of a GS-R???
- CTR cams and with....
- Who has lowjack?
- Is JDM always a better upgrade than USDM?
- 95 GSR Ecu Upgrade
- is this a good quarter mile time...
- Racing Hart CP-FG
- AEM Style Intake?
- compression test results
- Pls help w/ my Spoon front strut bar!
- anyone have the spoon ventuli plate intake gasket
- Speed gains on new setup
- Help why does my engine go rev crackhead at 6300RPM?
- Anyone know why this happens?
- vtec head
- is t worth getting an ITR tranny?
- Rota Subzero weight ... confirmed!
- My car creaks!!
- mugen b20 header on b18b?
- Re-post from earlier: Integra LS
- anyone know of any good 4 door integra sites out there???? list them for me!??!?
- New LS Owner with some questions
- how to tell if in TDC
- SWEET DEALS on BODYKITS, WHEELS etc.
- You sunk my battleship!
- GSR RADIATOR IN LS
- Engine Oil??
