View Full Version : Acura Integra
- NEED HELP ON DA LCA'S
- RHD Carpet
- HELP HELP!!! my guages r messin up!
- Is this compression test any good?
- ls/vtec oil leak
- Is this a blown headgasket?
- k20a swap questions
- Radio wont accept code
- My b18b1 . . . in processinq . . .
- (DA) CV Joints went out, mechanic said i need to replace FLCA's
- any one know what side skirts will fit the DA
- Is My Rear End Improved From This Setup?
- 94 teggy wont start
- 91 integra dash question
- Will springs from a 95 civic fit a 91 integra?
- My 92 Integra Gs-R
- Rear wiper delete
- turbo a poorman type r
- JDM FOG LIGHT HELP!!!
- B16A G2 into 97 GSR
- 60K service from dealership or garage?
- Please help....oil and vent problem
- bought a teg. where should i start before i get it running?
- No power to fuse box?
- HEAD GASKET
- I wanna change the fuel guage in my DC cluster NEED HELP!!
- Sluggish and using a ton of gas...
- NEED HELP FOR DA LCA's
- MY GUAGES R [freak]IN UP!!! HELP!!!
- loud knocking noise in my motor
- Qusetion about Key Blank Integra - Civic / Accord PLS
- Help me out here: B18B1 engine cuts out after acceleration
- valve covers? interchangable? paint?
- Swap / It's ok to plug in power?
- SO-CAL dyno shoot out! show what u got!
- camber kit question
- Integra sunroof Dimensions??? is it bigger than the 92-95 civic?
- Check engine light came on and idle jumped up to 1500-1800rpms randomly
- b series oil pan
- machining b16
- my dc4 complete champion chip repaint process in my garage look inside
- DA kit question
- Headgasket Size
- h22a smog legal in a da
- Where can I purchase a 30A relay for my headlights?
- YS1 Rebuild Kit?
- fitment of front strut bar
- Problems with ls/vtec.
- Fitting location on block
- Play in shifter
- removing ac lines and pws lines
- CEL on 96 GSR
- Spark plug gap - GSR motor, ITR pistons
- Starting problem *95 Acura Integra LS*
- 96 integra rear seat removal?
- 1990 Integra needs new engine
- rs machine pistons
- Need Help to remove Wristpin from connecting rod
- cruise control with aftermarket steering wheel???
- Swapping my 94 GSR into my 99 LS auto. What do I need?
- '91 Integra rough idle
- problems with Ls
- motor mount question
- guide pin on drivers side window
- sleeve question
- Stuttering idle when cold and slight gas smell, bent valve?
- gsr body swap with ls engine problem
- Oil comin out of my Throttle body..
- Need help deciding clutch, NOT just any dumb post.
- Instructions installing 94-97 integra OEM Fogs?
- 06-08 civic si seats in dc?
- Need HELP plzz... Anybody know how to get LBJ out??
- Car starts up, but immediatly shuts off????
- new pads dont work a s good as old ones any help?
- Quick Spark PLug Question
- Does a 96 JDM ITR Brake Master Cylinder and Booster fit on a 95 GSR?
- Power steering delete kit for 94 teg gsr
- car jerking please help
- Integra rims
- Starter for b series.. Need help!!!
- Motor options for a 92 Integra Gs-r
- Tranny Problems?
- k20 swap info
- engine restorer????
- Help... Not sure what to do about LBJ
- jdm p72 basemap
- What would cause my speedometer to melt like this?
- Passing Smog- San Diego, CA for B20b swap
- Windshield Replacement
- 94 TEGGY> LOWER BALL JOINTS
- Have you ever heard this? PLEASE HELP ME TROUBLESHOOT!
- open header or muffler?
- Skunk 2 Muffler?
- B18B1 intake mani on my B18A1
- Question about 2000 GSR Paint Color
- Poormans R advice
- B18C Build-up??
- GSR BLOCK WITH LS CRANK AND RODS
- Idle problem
- Over Heating Problem
- Idle problems
- How do I remove the small quarter glass on a 1997 acura integra
- Really easy noob question....dizzy related
- my gsr teg vs a mini-me
- how do i test my water pump?
- need advice on buying a db8 jdm front.....
- oil leaking on my block
- wont start
- Forged pistons?
- CKF sensor
- need help
- GSR/INTEGRA KNOB
- knocking noise at idle
- tps sensor
- Fuel Control
- oil coming out of my header.
- trouble codes
- distributor ls
- Help swapping in a obd0 b16 into a 93 gsr
- 96 gsr into 98 ls need help
- Help. Water Leaking Through Car.
- Help: Door water leak in a 93
- I'm stumped!?
- can any one tell me what this is?
- type R pistons in GSR block
- GSR shell for sale
- ---Engine Re-build help & Suggestions---
- How do I jump an OBD1 PR4 ECU to pull a code in a 93 RS?
- Autometer guage in a stock cluster
- GSR Exhaust Question??
- MOtor problems
- Changed head gasket now Having problems Need Help
- no spark thru dizzy
- CEL code P1259
- need pedals
- Car Wont Turn Over
- trans and break lights problem
- Help with motor??
- A weird electrical problem?
- why the hell isnt my alarm working. wtf
- How-to: installing ITR 22mm sway to a DA
- Integra front O2 sensor replacement
- which sensor?
- aluminum flywheel vs stock
- '99 Integra, obd reading failed? emissions
- 94-01 seats
- How difficult is it to swap an engine?
- Hawk HPS Brake Pad Life??
- oil in my first spark plug
- help rack and pinion
- best solution for broken a/c condensor?
- turbo lsvtec Crome chip injector help
- Just picked up a 1995 Integra LS, the modding begins...
- alarm/jumping idle
- Need help identifying B18c
- 1997 gsr to 1994 ls
- Transmission Spec Questions: Searched...not a WTb thread...
- Vehicle Speed Sensor ?
- 01 gsr vs 08 GTI 2.0t
- sk2 IM mani install, what fuel line? :searched:
- anyone ever had their crank pulley come loose?
- 91 integra quto to manual wiring.
- Replacing JDM 5 Lug ITR Front Hub?
- fuel pump relay?
- is a LS i-vtec possible and how much HP will i gain
- Amber Turn Lights
- 95 LS question searched
- could use someone elses opinion on this
- LS trans question- easy and quick I hope!
- Black Gunk build up on bumper
- f22 injectors in an integra?
- Integra GSR AC vs LS Ac
- Car wont start!
- how to lower/raise my car
- have ebay? want 10 bucks!?
- gsr vs b16 tranny
- Broken Fuel Gauge
- Cruise Control and Horn
- can i put type r cams in a 95 gsr
- friend not sure how much to sale car?
- PICK ONE......gsr head on b18c5 block or on a b20b block
- J's racing exhaust for DC
- Dash Swap From an 07 Civic SI to a 95 Integra
- can i bolt on a Vtec head to a B18b1 non vtec
- tail light and instrument lights went out fuse popped and i cant replace it
- OEM OPTIONAL KITS AND OEM ITR FRONT LIP
- Turbo filter??
- Thin Head Gasket
- anyone have a part number for valve cover plug??
- HOW MUCH ARE B18 TRANNYS WORTH?
- Someones DA got stolen in san diego? Cops here are dicks
- Alignment results. Do I need a camber kit ?
- DA...need help....please look
- Trans, clutch, shift linkage?!!?
- clunking noise
- GSR Repairs HELP!
- upper control arm nuts
- DA and DC Integra axles interchangeable?
- finding part #
- over heating
- IS a MINT condition 90 RS teg with 400,000k!! worth $1600???
- 88 integra ls - parting out
- OBD1 Integra GSR VTEC, Map, and Knock Sensor Wires Colors and locations (on engine harness)
- skunk2 cams??
- 91 integra fuel problem
- need help with vacum line on my turbo ls!!!!!!!
- Automatic Integra, when did your tranny drop?
- 91 integra gs gauge cluster removal
- db7 weight
- HELP: 96 integra with 5spd "dead battery"
- rebuild kits?
- maximum camber ajustment
- Bleeding Brakes. Do you also have to bleed abs?
- Started my build today...Coolant/Oil Mix...Pix Inside
- anyone seen a gen3 with volk gr-ns?
- fixing stripped block bolts??
- ?'s on ABS deletion-Stainless Clutch line Kits-Fuel line Kits On Dc2
- 3rd brake light question
- PLEASE HELP!! Power window and mirror problem......
- Trying to get more power out of a turbo GSR
- Idols too high
- 90 integra
- rust, any ideas on this lil project or horror?
- HIGH IDLE ON TURBO GSR.
- ?? Does stock GSR cluster's climate control bezel's etc.LIGHT UP AMBER?
- 98 GSR SSBP vs 94 RS MR
- Power drop?!? HELP!?
- Skunk 2 pro series C coil overs
- fuel filter HELP!!!
- Questions after comp stage 2 clutch install
- making your replica sides fit better. possible solution?
- Car won't stay running
- I have a 93 GSR RARE Just a coulpe of questions PlEASE READ
- 98 ls horse power
- E-brake problem
- 98 ls maybe with gsr tranny
- 2001 GS Ron uberdata ECU - safe to switch back to OEM for emissions?
- will 90 integra clutch kit fit on a 88-91 b16a1 tranny?
- HELP: Power Lock not working.
- Fresh Rebuilt B18B - Sleeved - Cooling Issues? Need Some Help!
- my GSR build
- anyone use the JSR 4-1 header?
- Brake problem
- How do I identify which B18C I have ???
- Valve Springs and Retainers
- help plz need info on gsr cams and crank
- no acceleration
- b20 possibilities
- New rear caliper sticking
