View Full Version : Acura Integra
- car in day time
- 1991 Acura Integra help!!
- ecu codes again, not fixed
- Integra excorcism? Door ajar emulation?
- ***BOLO*** STOLEN S2000 05 SILVER
- brake question
- Boiling Coolant? Need some help. (DA)
- Small weird problem
- Coolant smell but NO visible leaks, no idea where its coming from?
- throwout bearing: searched but no answer
- Help Please
- New (to me) Car.
- broken fog lights
- I just got my GSR but it has a few issues
- Would you trade a 92 gsr for a 93 h22 prelude?
- Sparks shooting from starter?! + where does the fast idle vaccum go?
- b18b to b18c1 swap
- 100,000 and the problems start
- I'm Going Turbo after I get back from Basic Training.
- baking sidemarkers
- Help on how to unhook the latch for the key
- New to H-T
- how fast are you DA with stock b18c running ?
- Passenger side Recaro on driver side - will there be problem?
- Catalytic Converter Problems.. again! please help
- replacing piston rings, major question
- ls motor build coming soon!
- Moving to California... LSV?
- Grinding into 5th gear
- brain crower valvetrain
- (((( STARTER RELAY ???? ))))
- car keeps shutting off dont know why... please help...
- Another Integra stolen off the streets of Los Angeles
- ***How To Install New Radiator?***(help)
- motor just blew
- New exhaust = Pics !
- n/a non vtec ls build question
- Jdm dc2
- need help
- what is Y1 tranny?
- Car wont accelerate at 0-50% throttle when warm only goes at 50%+ HELP!!! TPS??
- cams for my LS V stup
- p1457 code
- Is a $500 turbo setup possible?
- import shops in midwest
- exedy stage 1 capable of holding turbo b18c ?
- 4.7 FD in a ls tranny
- cv axles
- JDM SiR -G Hids?
- ITR Cam Gear question
- 93 Integra GS - Type R Swap
- JDM ITR HEADERS>>>>>
- Timing belt question
- Can I use another Honda/Acura fuel filter in my DA?
- 5 lug conversion
- lowering spring help
- meet up
- Flywheel question
- rpm high
- Integra SE has VTEC engine?
- 1991 engine swap
- CAR PAINTING EARL SHEIB HELP
- Drivers side soor wont lock all the way!!! help!
- HELP!!!Nardi deep corn 330 mm
- ((WHAT GAS?)))
- new to the tech..just a few pics
- side marker Harness?
- failed CA smog test. HELP!!
- 1997 integra lights dont work
- who has used omni power full coil-overs
- Headers Split Pipe
- exhaust w/bent tail pipe
- 91 integra swap, problems
- Water pump/timing belt FAQ?
- underdash harness question!!!help please
- I did 125mph on a residential
- Dipstick
- Will Acura TSX Emblems Fit on the Integra? Anyone know the Sizes
- 96 GSR snapped timing belt
- Anyones door locks ever freeze? (power locks DC4)
- Jdm 1pc headlights for DA
- lowering srpings
- check it out
- im looking for products for my 90' integra.
- Need help finding certain tail lights for my 93 integra
- vac hoses
- Question about dc2 side markers (searched)
- How many gallon is left when the gas light goes on?
- why does my maintenance require light...
- Burned oil smell - '99 Integra
- engine tuck kit?
- Radaito/hoses steam
- Remove paint fro my block??
- How do i pull the tranny?
- fuel filter
- anyone know another site like acuraparts247.com?
- LS rod bolt installation ?
- BCIII or BC Pro-Spec
- where to buy fuel filter for cheap?
- Quick release steering wheel.....
- Recipe for ls V-tec
- GSR w/cams + light mods.....Tuning needed?
- im new
- what do u think?
- I need at dumbass's How To on cleaning your IACV! *Searched*
- what is the actual weight of a typical 94 up integra flywheel?
- Need a cat
- Could I have gotten Bad Gas???
- Back Fire in between shifts! Please Help!
- HID options....
- integra shocks on em1
- '97 Integra LS turbo, S300
- Q
- swapping in an engine
- v-tec oil pressure switch
- air/fuel gauge malfunction
- integra short shifter (height)
- rsx muffler on g3
- Honda_Fanatic's Project H22a4 Integra 94 LS
- Complete Swap?
- Turbocharging Help
- Is your thermostat housing like this one?
- 15 x 7.5 Offset 38mm - OK on a 94 LS?
- DA integra spindles on DC integra
- Cheap ODB 2 CAT that is CA Approved?
- My GSR type r wannabe...what ya all think?
- a wake to make more power?
- Anybody around Portland want to do a wire tuck for me...Will pay
- Reversed Battery Cables
- i have a ?
- interior question
- cd player
- GSR build question!
- HUGE SPIKING PROBLEM
- race fuel????
- where is my air intake temp. sensor.
- Oval muffler - Quiet?
- Gears wont go in......
- I need microfiche website for my integra
- oil in IM
- Anyone else think Skunk 2 Coils are a joke...
- Poor 1/4 times
- b18c1 head gasket
- difference btween ls/rs exhaust system and gsr
- brake pedal not sitting right
- name of this color??
- Need help for wiring my dc2 doors, im doing a RHD conversion
- Wheel bearing question... HELP
- New to the Integra
- Calling out for feature cars... Bradenton/Sarasota FLA this weekend
- ***** 94 GSR turbo****
- Where to buy a locking cylinder for driver side door handle?
- QUICK QUESTION, PLEASE READ!
- FS: 92 DA GSR - $3400 OBO
- clutch going out?
- weird noise during 3.5krpm
- Problem Areas on 97 GSR
- valve cover gromits. lost one
- B20? I didnt know there was such thing.. Also whats the difference...
- can anybody run motor/tranny vin #
- whats the difference between the 94-97 integra from the 98-01 ?
- weight difference????
- dizzy replaced. car so slow???
- abs light
- Installing New ABS pump / bleeding system?
- need to go lower with Omnipower
- .20 over Type R pistons, where to get head gasket??
- switched tranny and feels weaker...HELP!
- Fitting a TiAL Wastegate with Inline Pro log Manifold?
- Does anybody know the codes for the radio in an integra?
- i need professional opinions
- ****** 94 GSR custum turbo Vs. Port n polish.****
- $$$$94 GSR Custum turbo?$?$?
- i want to see all b18 non-vect all motor work
- 89 teg hesitation in low rpm
- high milage.. any suggestions?
- How do u flare you hood!
- b16a1 in 95 integra
- Wiring LS/vtec
- tranny
- odometer not working
- strange rattling sound coming from the engine
- ? on buying a whip
- 91 integra with 89-91 dohc zc
- part??
- check off list PLEASEEEEEE HELP
- problem installing lip
- Clutch Cable Help !
- Problems: Fast idle / surging idle / weird temp reading
- 2 Way Pager Alarm
- Vtec not firing!!!
- Coilovers!!!!!
- need windshield wiper help
- HELP.... Integra clutch problem..
- Removing the black can!
- JRSC teg broke 2 belts in 3 days
- problem starting
- VW Guy, Buying a 1994 GSR
- side markers need help
- TRANNY HELP...
- DA electrical problems! Heeeeelp me.
- has anyone cared enough to share this with you
- $$$$ Best bang for buck with least problems for 94 GSR! Plese HELP!!!$$$$
- HELP! need info on DC2 rhd power door wiring
- Replacing Timing Belt and Water Pump, what about tensioner and spring?
- bumper reinforcement???
- need help, something wrong w/v-tec
- Jumpy idle when car is warm
- USDM 97 Front End
- GSR exhaust on an LS? Whats the difference?
- Where does this nipple connect to??
- 92 gsr rhd
- **Post Pics Of Your Integra with Circuit 8 or MF-8**
- FOR SALE!! Spark Plugs
- help with ITR rear sway bar
- Wiring Gauge
- 95 ls Overheating.
- Help: P1337 & p1300 misfire
- quick queston, search does not work: dc and eg lca's (factory) interchangeable?
- lowering teg
- tranny help
- help car shaking/shuddering
- rate these struts/springs
- ordered springs, received wrong color are they still the right springs
- Usdm ITR cluster
- Need help finding a good clutch
- Power Stearing and AC removal...?
- DC2 T1R full exhaust on DC4
- what is an s80 transmission
- acuraoemparts.com??????
- chipping ECU
- security for gsr
- new to honda-tech!!
- what intake manifolds will fit a b17a1
- torque specs
- CHECK your steering racks!!!! thank god for sway bars and LSD
- Main Girdle Kit
- 98+ Front Bumper for 94-97 LS
- Cant find Foglight Connection. Please Help
- My DA
- Burning some oil while "getting on it"??
- VW Guy here, need some help.
- Swaping a b16 into a '91 Integra (pics!)
- where can i find fogs for my dc2
- WTF Idle messed up after intake mani install
- Radiator Fluid Flush ***help***
- VTEC Question
- will eg coilovers fit dc chassis
- new emblems
- 91 teg WTF is this and where do these go?
