Problems With My Integra How Much to Fix??????
Ok I toke my car into the honda doctor and they said that i need a new distrubtor,plug wires, spark plugs, and some rotor turned. I know the plugs wires and plugs will only be like 70 but how much does it cost for a new distrubotor and the rotor turned I have no clue what rotor the meant. Also my car has 67ish k miles on it did any one else have to replace these. Thanks in advance
I have a 94 acura integra when you guys got your 60k tune up what did u have to get done. Also he said i need a whole new distrubutor is that just b/s or do I really need to. Also what rotor is he talkign about when it needs to be turned. Thanks
ls integra
around 60k did any one have to replace there I have been researching it and people said all they did was the dist. cap and rotor does any one no where i can get these or how much it will run me
btw this is integraautox but im on my gf's computer:
i have no clue, but if i did would that mean i have to buy a whole new distributor?
and also the mechanic said he had to rotate the rotor or something along those lines
[Modified by XxIntegraGurliexX, 8:01 PM 10/21/2002]
Sounds like a normal tune-up... Spark plugs, wires, distributor cap & rotor. If they're turning a rotor, then it's likely your brake rotors. Are they warped? Parts from my Acura dealer runs about $60. The ignition stuff is not difficult to do yourself, but you may have some trouble with the distributor rotor screw (it strips very easily).
I just got it all done this afternoon along with an oil change, and for free (used my free tune up included in the emissions warranty extension for most '96 and '97 Acuras).
how much did it cost for your distributor cap and rotor thing? How hard is it to install and what steps are involved? because my car started dying on me so is ther any way that there is more of a problem than this?
Guest
Posts: n/a
id also like to know to becuase i just changed my sparks, cap and rotor. it felt good for about 2 days but it started feeling weak again. timing belt maybe? 84,000 mi. on 96 LS.
If you want stock ignition parts one place to try is http://www.ahmotor.com/.
How hard or how easy depends on your mechanical skill, background ect...
Just look here http://www.acuraautomotiveparts.net/ , they have diagrams and everything, i prefer them over a&h any day. No bs over the phone crap
A distributor shouldnt be more than 125 or so... you can make any 94-01 b series vtec distributors work. just need to modify the wiring harness if its a non obd I. I got a 99 for 90$ and put it on my ls.
TTatro
Aug 13, 2018 07:42 AM
577HondaPrelude
Feb 20, 2004 09:52 AM
82, 94, acura, cap, code, cost, distributer, distributor, distrubtor, fix, honda, integra, price, replace, tune
