View Full Version : Acura Integra
- Honda Accord vs Acura Integra?
- 4dr DA window motors the same?
- HELP!! 93 DA Randomly won't start
- Clean Rubber Cement off Cluster?
- which intake manifold ??
- ? here 98 teg
- Received Bad Mount from Hondaautomotiveparts.com? Take a Look
- Problem after new clutch cylinder!!!
- intercooler no turbo?
- HELP!!!! Automatic transmission problem. (Throtle cable hookup)
- GSR FUEL FILTER
- car shakes when IN NETURAL
- B16 tranny
- Radiator fan only turns on with AC. Have replaced t-stat + fan switch + rad. cap.
- thermostat
- high flow/oem catalytic converters on an engine that burns oil through the tailpipe?
- integra rear seat gap?
- using stock box....
- B16 Ls Vtec Q's. need help
- cooling fan
- WHiich size exhaust to get?
- TYPE-R FRONT LIP FOR DA9 --NEED HELP PLEASE!!--
- RHD DA with a TURBO!
- My future build and questions (pictures)
- mod?
- replaceing gsr swaybar
- help wiring, radiator/condenser fan wont turn off
- HONDA-TECH.COM STICKERS
- Another no start problem
- is a carbon fiber hood shipped as frieght?
- Top Stolen Cars in 2004
- Purchasing an Integra. Some Questions (Which OBD?)
- Harness question
- !!!! whats the difference between gsr and ls cranks ??? !!!!
- header question
- tire recommendation for 15' rota
- I'm in need of a water pump. Any recommendations?
- Putting Intake back on need help with hose location!
- NEED HELLP CODE PO 420
- Swap questions for an LS
- leak down test- integra smoking..
- Better flowing catbacks than the jdm ITR catback????
- B18b1 and B18c1 Bare Block Difference
- where to get a radiator hose??
- Difference between B16 LSD tranny and 96 Spec Type R tranny for GSR ?
- DA is over heating
- Idiot friend broke back seat
- How much do backseats weigh in a DC2/4????????
- b20 or ls vtec
- Poll: New Engine....positive or negative effect on selling car?
- Hard gas pedal.throttle cable?
- Need some pointers on changing my alternator on my 91 DA
- JDMcarboyDOTcom
- B18B1 cylinder head swap 2 a GSR B18C1
- center caps
- vacuum line
- 98 LS 4dr AT shifting above 3. ((Help))
- 96 acura integra Integra Clutch Problem
- 90 DA with a B20 swap... trouble code advice...
- when car is hot wont start up help
- EGR???
- turbo integra running weird
- Integra Won't Start After Headgasket Install ....
- Painting integra headlight housing
- unturbo an integra
- Christmas came early this year
- integra wont start. no reason why
- SMOG PLUG?
- HELP!!!! Bent radiator support
- type r climate control in LS
- need to smog.
- obd1/obd2?
- will a stuck thermostat make ur cooling fan not turn on?
- NEED HELP CAR WON"T START!!
- Crank No Start After Accidental Ignition when Fuel Pump was Dissconected
- need help
- B16 Swap into 90' Integra GS 4 Door
- I think my wheel bearing is going out, any help?
- 97 Integra OEM Alarm
- A/C Trouble Please help
- Car sat for 6 months.. Caliper frozen
- White ROTA Circuit 10s on DA xD or White MUGEN MF10L
- problem after master cylinder install
- -type r lower control arms-
- Anyone know where i can buy a 2.5inch converter to fit my jdm 2.5 collector header?
- Integra back bumper (aftremarket functional)
- rsr exmag gsr and ls same?
- TURBO KITS!!!!
- WTB: complete integra AC 94-01
- Integra is overheating...in a weird way.
- *need timing opinions*
- OK, so im new to H-T! heres my DB1
- WHAT 16 INCH TIRE SIZE??????
- heat/ac smells horrible
- i have a 1987 integra i wanna put a b18 gsr motor in it
- Brake pad replacement problems
- Civic Si exhaust on Teggy
- Koni question specifically for Tegs
- 91 Teg Front Lip Help
- Water pump differences?
- to the guy i meet at the car wash in havelock NC
- integra gsr 280k!! should i buy?
- 1995 Fuse Diagram
- intake help sound of vtec?
- fog
- b16a odb1
- valve covers
- blue sway bars
- 90 teg in-car camera
- I need help with smog
- stock exhaust question
- car dies when rev... NEED HELP ASAP!!!...
- info for b series
- b18a1 vacuum line routing obd-0 and obd-1
- code 21
- '95 B18B w/ 155kmi. Switch to synthetic = ok?
- B16 Rear Engine Bracket
- So my A/C doesn't work.
- something to laugh at!!!!!!
- DA Squad?
- Distributor wiring
- Best Dealership parts department?
- Smoke coming out of exhaust when i rev match/downshift? whats causing this???
- help? seriously...
- I have a question: 90 DA with Hydro, how does the VSS work?
- Is it possible to put AC into a 94 LS with a H22A4?????
- HELP With DA Suspension Setup
- AXLE PROBLEMS
- What to do...
- Jdm headlights???
- What harness plug for USDM DC foglight switch?
- throttle cable
- Tranny Rattle?
- help da jdm seat belt conversion?
- WHATS THE BEST ENGINE SWAP
- P2p computer
- shifting problem...
- quick battery relocation question
- high pitched squeel in reverse and low gears
- what is a good exhaust b4 conversion
- removing my cruise control ???????'s
- STOLEN TURBO GSR NOVA TYSONS CORNER
- brake rotor size
- Stock resonator + Hammer = Free cai
- omni power adjustable dampening any good?
- i need to know what axel i need asap for my 92 integra with b20 swap
- boosted b18c or k20 swap
- 5,000 rpm's
- Spark plug wire problem
- h20 pump/timing belt change
- why is this thing leaking and how do i fix it??
- No gauges working in cluster
- OBD2 dizzy on OBD1 engine?
- oil spits out of exhaust
- Gen 3 Integra spoiler removal question?
- Not the same old spark gap question
- A bit confused about overbore
- over heating problem plz help
- Front Driver Side Wiggles?
- Need a/c help
- in need for new clutch. and other questions
- Selling My 99 Integra
- Spark Plug wire order on cap, b18a1
- front seal ????
- 95 ls brackets on 01 civic seats..?
- 1998 gsr stereo code????????
- idle surging when cold, but fine when engine is warm.
- godspeed radiator
- Temperature gauge acts crazy at Idle AFTER driving for some time
- question about GSR
- Integra doesnt start...brand new starter and battery
- List of ABS Removal
- E-brake squeaks and slips!
- 99 gs 2dr car wont start
- 92 integra passive restraint seatbelt issues
- Alternator Showing only 65 Amps
- catalytic converter buzzing
- gas cap not tight
- installing new rotors help
- PU ITR lip from ebay?
- No spark please help
- coilovers question
- Fried ECU..... Fixable or No !!!!!!!!!
- Can't Buy This Honda Part? and a few questions...
- stock block how high would you rev it
- helpppp electrical problemmm
- skunk2 pro s coilovers on DA???
- need a bit of help
- 4dr integra in need of lip
- compression
- OBD 1 to OBD 2 years.....
- PICKED UP A ITR SHELL TODAY FROM AUCTION -- SEEING IF IT BELONGED TO ANYONE ON THIS SITE
- What engine type is more reccomended for a turbo integra?
- B18a WOnt Rev pass 4K RPM
- Weird Car Wont Start Issue
- HELP ME WITH BRAKE PROBLEM........
- ctr piston
- how compatible is my turbo kit?
- Installing new passenger side door for integra...need help
- A/C on & off
- Gsr transmission pops out of reverse
- Leaking Fluid
- Well this was weird...
- my integra shell
- 94 gsr died and wont start no codes????
- 98 integra door actuator
- h22a crank angle sensor
- CALLING INTEGRA OWNERS WITH ENDYN catcahcan setup where's your located
- 91 Integra Fogs
- ebay airbags??
- Breaking Engine in question
- skunk 2 stage 2 pro series cams for sale
- dizzy problems....
- JDM Headlights, little purple bulb?
- trouble shoot
- Can't drive over 100 mph please help!!!!!!
- obd1 intake manifold on obd0 motor
- Transmission problem?
- 93-teg gsr or 95-teg gsr
- ls/vtec engine, good deal?
- 94-97 Trunk Actuator Conversion on 98+ Problems
- ebrake light
- help
- redlight runners beware...
- Need help on my timing
- Stock block max RPM?
- DA brake issues
- clutch
- hondata with 1600cc injectors
- Tein S tech springs on stock shocks personal review DC integra
- need susp help!? koni yell/gc setup
- i have a S1 or YS1 manual transmission ? NEED HELP
- JDM integra hood latch vs 92-95 civic
- Axle shopping
- b16a ac compressor on a 94 LS bracket
- 3 puck clutch is it good for everyday car
- lowering spring question
- Anyone in Valencia area with obd2 p72?
- 93 Integra Low idle at start..
- Tranni makin weird metal rattling noise, drives fine.
- JDM ITR CF LIP pic request!
- HELP! i think i killed my car with engine cleaner. help please
- anyone used phearable.net? good or bad?
- Keep her alive?
- Confused about GSR motor/tranny
- Radio and dash clock have no power
- Hood Rattle...
- one piece headlight
- stage 1 racing clutch/9.75 lb flywheel
- weird noise
