View Full Version : Acura Integra
- Buying Comptech Header for LS, have ??
- Integra rear sway bar options
- Tranny fluid filler plug...Need Helf FAST!!
- Anybody sellin 98 front+rear bumper?
- Really Really bad news
- 00 GSR ecu pinouts
- 60k tune up
- install on a itr steering wheel
- Running rich, please help..
- gas question
- Apexi WS sound clips?
- Who has the BSQ DIY Intake?
- 94 ls gift ideas
- Power Antenna Install...
- silverstar 9005 conversion???
- Stock Spider Rims Trade??
- jdm itr cat back install
- PLEASE READ: Cam install gone bad.... well kinda
- sway bars
- Damn caliiper bolts!!!!
- Shaved door locks Q
- 240sx-SILVIA-
- where's your vin number??
- High Compression, Colder Plugs?
- finally got pics of my car(pretty big, wallpaper size)
- got a new integra
- GSR Butterfly removal....
- Shift Knobs..
- ball joint removal
- HELP!!! It won't go down...
- S2000 Antenna*PICS*
- 98 + door handle swap off 4 door
- sellin my gsr and maybe gettin the WRX
- just got black corners, dno what bulbs i should put in it..
- Just installed DIY trunk bar and Benen rear lower tie bar last night...
- Bolt Pattern?
- anybody have a G2 GSR gauge cluster
- for those of you with low gas mileage
- B17 Crankshaft???????
- Wheel Websites?
- i traded cars with my friend today
- Type-R Rear Sway - Another Testimonial
- CTR Camshaft Specs?
- What's the deal here? (97 vs 98 GSR comparison)
- have to touch the ABS?
- need help on 92 gsr engine
- My GS-R almost got stolen last night!!!
- just wanna say WHATS UP HT! im new ;)
- is this muffler worth the install????
- LS Block question... need help!
- emergency lights!?
- I need camshafts!!!!!!!!
- ???how do you turn your climate control amber???
- S2000 cluster in 1995 Integra
- GSR Dyno Shootout
- I donot know if i can do this but.......FS post.
- cams on gsr motor idle moving up and down?
- oil filters
- need car to rotate
- fs tenzo shu rims, 17" white..
- Fixing frame rust?
- integra splash guard
- Launching
- B18A and B18B, interchangeable?
- Adjusting the headlights............
- HELP with locating used engine in CA
- homemade sway bar? hmmmm
- Any how to's on removing the carpeting or dash?
- S-AFC Wiring Diagram
- obd2-obd1 conversion question
- s80 tranny?
- Trunk side panel trim -- how to remove???
- Is it possible to pass emission without catalytic converter?
- compatible filters??
- Front brake caliper seized/seizing
- Tein S. Tech springs ?
- Comptech Sport spings or usdm stock Type R springs??
- Big Problem
- how to change tranny oil??
- Interesting How-To's
- clutch blew out on GSR, repair questions, flywheel
- help
- Installation on s2000 antenna on g3 teg?
- safe turbo gsr?
- civic springs to a DA?
- Are there any places around VA/MD/PA that do good port and polish work?
- Do i need to retard my timing back to stock when using a chiped ECU?
- Quickest stock GSR time I've seen so far (correct me if I'm wrong)
- Integra radiator problems
- .Shift knob fitment
- Who has the highest hp?
- New 11" 4 piston kit for Integra-works with stock 15 wheels
- always running rich
- Headers for 98 GSR
- Quick Question!!
- What muffler fits under an integra?
- POLL: How many miles per full tank?
- VTEC light...
- Should I go 5 lug?
- light housing
- Duel Exhaust Valve Springs
- looking for someone
- B17 cams
- how many miles per full tank of gas?
- Help please! Spoon STB on 2000 GS-R?
- Teg Help..
- Need help with clear corners
- lewylou?
- 94+ Teg seats. Are there two different rail designs?
- Advantages of Adjustable sway bar i.e. comptech 22mm bar
- Looking to buy a stock type r exhaust
- Carbon Deposits on Bumper
- headers without exhaust....?
- Apexi worldsport catback exhaust
- Teg idleing below 1000 rpm's Any insight
- Electrical issues..........2 part problem
- was changing my cluster....
- head: for sale- 90 stock gs head 150 k miles. CLEAN! w/ manifold
- fully built b18+b20 = weird knockin noises? Normal?
- Lubbing the camber kit
- Turbo Teg!!!!
- Gsr Head
- Need Help/ Radio Intermittently Powers On When I start The Car
- Pics of my car
- AEM V2 Intake Free
- stainless steel braided fuel line
- idle when declecerating.
- Int swapp?
- 94+ LS cams in a B18A
- Yet another idle question
- any one want to trade there teg for my hatchback?
- The horror of salt...(need high speed)
- Speedo question.
- importautodismantling.com
- Spoon DA
- Type R Retainers, Springs and Clips........
- How much for 94-97 conversion?
- venom
- gsr owners with type r cams please read
- Ebay headers?
- Bad Sound??? Any suggestions?
- Guage installs in pass side dash (pictures)
- Need help with turbo vacum lines!!!
- what time should I get if I have a turbo?
- Which Pistons For Ls-Vtech
- any1 know where i can get a clear red distributo car?
- OBd2-OBd1 conversion harness group buy......
- skunk2 intake manifold on b18a
- www.testpipe.com?
- OEM or Bosch O2 sensor???
- idle problems help
- need some serious help with my gen 2 teg
- Tein SS worth it?
- No problem
- JDM GSR engine
- genuine honda ignitor
- Lost my wheel lock key, anyway to get them off without paying 50 bucks for a new one?
- need tips on clutch install
- 200k CLUB....
- Yes I did a search, but still need suggestion on camber kit
- cool little tip for you guys
- RSR 4-2-1 Header Review for GSR
- What's the right offset for 17inch rims on a gen3 integra??
- Skunk2 rear sway bar vs. oem itr
- lost brakes in 88 ls PLEASE HELP ME....
- ITR or GSR Exhaust manifold?
- saved money for my teg, Suggestions for my 98 gsr?
- Snow cables on Integra?
- What can I sell for???
- look at these pic's of my teg
- Can anyone recomend someone for overboring my b18c TB?
- what do stock GSR floormats look like?
- cold morning start=bad noises...wtf?
- Greddy Oil Catch Can question
- fine tune my t-bo teg?
- too low for carwash?
- pay for it or do it?
- Hella HID kits from www.misterjung.com ????
- Prestone antifreze?
- hmmm.. what are the chances that this will work? (ex lip on teg)
- so cal timing belt help?
- 91 Integra
- Dual or Triple Gauge pod DIN
- F/S: Brand new Eagle rods for B18A/B B20B/Z
- Pulley Timing........
- will a P06 ecu run a LS?
- obd2 chipping?
- Clock doesn't work because of no deck??
- Funny sound from rear driver side area
- What does a 94 LS in SoCal go for?
- anyone running a P28 in their GSR?
- Help...! Car Dies... Ignition Switch = Bad? Please Read.
- foggy headlight
- coolant leak
- Problem With Installing New Clutch On Integra?????????
- all red 4 dr integra taillights
- H&R Cup Kits
- LS owner's with any of the Crower cams?
- Difficult cold starts
- MOMO Steering Wheel
- Make sure I'm right...
- Need an answer...
- Zeal S6
- valve specs?
- Gram Lights 57 PRO wheels?
- where to get aem v2 cheap?
- ODB1 and ODB2
- Anyone have a flat center cap that fits 16" Rota Slipstreams?
- help!!!! Car wont start!!
- anyone want to sell me their usdm itr lip??
- Clutch Noise
- Anyone on the forum running CTR pistons?
- ITR pistons on an otherwise internally stock motor. okay??
- Just wondering what it takes...
- Forum Moderator Please PM me
- CSK Aluminum Radiator install review
- I ITR Cams and Nitrous, Good idea?
- Attn: Washington 2nd gen teg owners
- help
- pixs of my car
- power potential on older b18 90 integ
- Wing wemoval woes.
- Specials, Clearance, and Used Items. You won't be disapointed !!!
- quick, What engine did this come in. . . .??
- Wheel offset ? - 16" Rota Slips on GSR w/ ITR springs shocks (here we go again)
- Any last minute tips before my cam/cam gear installs
- do all 3g integras come with power windows and door locks?
- WTB: 94-95 p72 5 speed ecu... sorry for OT
- rflange to remove bottle neck
- Not so bright question about LUBE OIL AND FILTER?
- can seat belts work with racing seats?
- What to do first?
- itr exhaust
- Need pages from Helms for cam install
- pic request: intake system installed
- guys why the hell do keep breaking axels...
- 90-93 Exhaust Designing
- Ground wires install instructions ??
- how to see check engine codes in a 2nd gen integra
- Swapping Tranny In my LS w/ b16a or itr tranny.
- autocarparts.com
- Calling for dc2's with Super Sonic Pearl Blue (wheels decision)
- What is the Honda part # for 94+Gsr headgasket?
- kinda new kinda not
- Help! How do you fix a sticky door?
- OT: Locating OEM Bumper Lights
- Fuel filter line inner diameter???
- Some JDM parts for sale in the Classified forum, check'em out
- Stock Shocks : 95 GsR
- Do rear lower tie bars actually work??
